commit b36a1552d7319bbfd5cf7f08726c23c5c66d4f73 upstream.
Certain ttys operations (pty_unix98_ops) lack tiocmget() and tiocmset()
functions which are called by the certain HCI UART protocols (hci_ath,
hci_bcm, hci_intel, hci_mrvl, hci_qca) via hci_uart_set_flow_control()
or directly. This leads to an execution at NULL and can be triggered by
an unprivileged user. Fix this by adding a helper function and a check
for the missing tty operations in the protocols code.
This fixes CVE-2019-10207. The Fixes: lines list commits where calls to
tiocm[gs]et() or hci_uart_set_flow_control() were added to the HCI UART
protocols.
Link: https://syzkaller.appspot.com/bug?id=1b42faa2848963564a5b1b7f8c837ea7b55ffa50
Reported-by: syzbot+79337b501d6aa974d0f6@syzkaller.appspotmail.com
Cc: stable@vger.kernel.org # v2.6.36+
Fixes: b3190df62861 ("Bluetooth: Support for Atheros AR300x serial chip")
Fixes: 118612fb9165 ("Bluetooth: hci_bcm: Add suspend/resume PM functions")
Fixes: ff2895592f0f ("Bluetooth: hci_intel: Add Intel baudrate configuration support")
Fixes: 162f812f23ba ("Bluetooth: hci_uart: Add Marvell support")
Fixes: fa9ad876b8e0 ("Bluetooth: hci_qca: Add support for Qualcomm Bluetooth chip wcn3990")
Signed-off-by: Vladis Dronov <vdronov@redhat.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Reviewed-by: Yu-Chen, Cho <acho@suse.com>
Tested-by: Yu-Chen, Cho <acho@suse.com>
commit 95065a61e9bf25fb85295127fba893200c2bbbd8 upstream.
Make sure to check the tty-device pointer before looking up the sibling
platform device to avoid dereferencing a NULL-pointer when the tty is
one end of a Unix98 pty.
Fixes: 0395ffc1ee05 ("Bluetooth: hci_bcm: Add PM for BCM devices")
Cc: Frederic Danis <frederic.danis@linux.intel.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
ACPI table for BCM2E55 of Lenovo ThinkPad 8 is not correct.
Set correctly IRQ polarity for this device, fixing the issue of bluetooth
never resuming after autosuspend PM.
Signed-off-by: Jérôme de Bretagne <jerome.debretagne@gmail.com>
Use full name instead of abbreviation.
Signed-off-by: Loic Poulain <loic.poulain@intel.com>
This ID is used at least by Asus T100-CHI.
Lenovo ThinkPad Tablet 8 with BCM43241 rev B5 chipset uses the BCM2E55
ACPI ID for Bluetooth. Add it to the list of supported devices.
Recent macbooks (early 2015) with BCM43241 use this ACPI ID. Add it to the
Reported-by: Leif Liddy <leif.liddy@gmail.com>
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
This ACPI ID is used at least by HP for their Omni 10 5600eg tablet.
Signed-off-by: J.J. Meijer <jjmeijer88@gmail.com>
These are used at least by Acer with BCM43241.
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
The IDs should all be for Broadcom BCM43241 module, and
hci_bcm is now the proper driver for them. This removes one
of two different ways of handling PM with the module.
Cc: Johannes Berg <johannes@sipsolutions.net>
Add BCM2E65 device in acpi_device_id table used on Asus T100TAF.
Signed-off-by: Luka Karinja <luka.karinja@gmail.com>
The new hci_skb_pkt_* wrappers are mainly intented for drivers to
require less knowledge about bt_cb(sbk) handling. So after converting
the core packet handling, convert all drivers.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
bt_skb_alloc() returns NULL on error, it never returns an ERR_PTR.
Provide an early indication about the manufacturer information so that
it can be forwarded into monitor channel.
The set_diag driver callback allows enabling and disabling the vendor
specific diagnostic information. Since Broadcom chips have support for
a dedicated LM_DIAG channel, hook it up accordingly.
The Broadcom UART based controllers can send LM_DIAG messages with the
identifier 0x07 inside the HCI stream. These messages are 63 octets in
size and have no variable payload or length indicator.
This patch adds correct parsing information for the h4_recv_buf handler
and in case these packets are received, they are forwarded to the
Bluetooth core via hci_recv_diag interface.
This device has always ACPI companion because driver supports only ACPI
enumeration. Therefore there is no need to test it in bcm_acpi_probe() and
we can pass it directly to acpi_dev_get_resources() (which will return
-EINVAL in case of NULL argument is passed).
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Tree wide grep for "hci_bcm" doesn't reveal there is any code registering
this platform device and "struct acpi_device_id" use for passing the
platform data looks a debug/test code leftover to me.
I'm assuming this driver effectively supports only ACPI enumeration and
thus test for ACPI_HANDLE() and platform data can be removed.
There is no need to call acpi_match_device() in driver's probe path and
verify does it find a match to given ACPI _HIDs in .acpi_match_table as
driver/platform/acpi core code has found the match prior calling the probe.
Driver doesn't handle possible error from acpi_dev_get_resources(). Test it
and return the error code in case of error.
Caller of acpi_dev_get_resources() should free the constructed resource
list by calling the acpi_dev_free_resource_list() in order to avoid memory
leak.
Adds autosuspend runtime functionality to BCM UART driver.
Autosuspend is enabled at end of bcm_setup.
bcm_device_lock is used for system sleep functions as they can be
called at any time.
bcm_device_lock is not held for runtime suspend functions as this
is only enabled as long as platform device is opened.
Signed-off-by: Frederic Danis <frederic.danis@linux.intel.com>
Change some CONFIG_PM_SLEEP to CONFIG_PM as hu and is_suspended parameters
will be used during PM runtime callbacks.
Add bcm_suspend_device() and bcm_resume_device() which performs link
management for PM callbacks.
These functions will be used for runtime management.
ACPI table for BCM2E39 of T100TA is not correct.
Set correct irq_polarity for this device.
Retrieve the Interruption used by BCM device, which can be declared
as Interruption or GpioInt in the ACPI table.
Retrieve IRQ polarity from the ACPI table to use it for host_wake_active
parameter of Setup Sleep vendor specific command.
Configure BCM device to wake-up the host.
Enable IRQ wake while suspended.
Replace BT_ logging calls by the new bt_dev ones.
Replace spinlock by mutex to be able to use bcm_device_lock in
sleepable context like devm_request_threaded_irq or upcomming PM support.
If bcm_suspend is called whithout device opened there is a crash as
it tries to use bdev->hu which is NULL.
Rename bcm_device_list_lock to bcm_device_lock as it does not only apply
to bcm_device_list.
We should not sleep while holding a spinlock.
bcm_gpio_set_power is called while holding the bcm_device_list lock.
The kbuild test robot reported implicit declaration of function
'acpi_dev_get_resources'.
Surround ACPI function by CONFIG_ACPI test.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
devm_gpiod_get currently has an optional parameter to set initial
direction and value for the requested gpio. Make use of this to simplify
the driver and make it not fail to build when this parameter is made
mandatory (which is scheduled for 4.3-rc1).
Moreover use the _optional variant of devm_gpiod_get to simplify error
handling (which also gets more strict for free).
Add reference to hci_uart structure to bcm_device.
This allows suspend/resume callbacks to manage UART flow control.
Parse platform_device's ACPI to retrieve UART init speed.
When BCM device is open, check if its TTY has same parent as one of the
platform devices saved. If yes, use platform_device's init speed.
Retrieve "shutdown" and "device_wakeup" GPIOs from ACPI.
Set device off during platform device enumeration.
Set device on only when attached.
As driver can be unbound we need to check if the bcm_device still exists
before calling GPIO's functions, this is protected using device_list_lock.
hu->proto->*speed will always be used for all device where it is set.
But hu->*speed should be used if exist, so the test should be swapped.
The equivalent change is needed in bcm_setup() of hci_bcm.c.
If h4_recv_buf() return ERR_PTR instead sk_buff pointer, it should be
cleared once PTR_ERR is completed for the further dereference such as
h4_recv(), or h4_close().
Signed-off-by: Chan-yeol Park <chanyeol.park@samsung.com>
Add vendor specific command to change controller device speed.
Use btbcm helpers to perform controller setup.
Perform host UART reset to init speed between btbcm_patchram() and
btbcm_finalize(). This may be need because firmware loading may have
reseted controller UART to init speed.
Move request/release_firmware() out of btbcm_patchram().
This allows a better error management, if request_firmware() returns an
error then the controller will be used without firmware loading and 0 is
returned.
This will imply to change btbcm_patchram() to accept a firmware instead
of firmware name.
Future H:4 based UART drivers require custom packet types and custom
receive functions. To support this, extended the h4_recv_buf function
with a packet definition table.
For the default H:4 packets types of ACL data, SCO data and events,
provide helpers to reduce the amount of code duplication.
This adds the protocol support for Broadcom based UART devices to
enable firmware and patchram download procedure. It is a pretty
straight forward H:4 driver with the exception of actually having
its own setup and address configuration callbacks.
The new Broadcom Bluetooth support module provides generic functionality
for changing and checking the Bluetooth device address. Use these new
features instead of keeping a duplicate in the driver.
When using vendor detection, this adds support for the Broadcom
specific address configuration command.
