path: root/drivers/bluetooth/hci_uart.h
2010-07-21Bluetooth: Support for Atheros AR300x serial chipSuraj Sumangala
Implements Atheros AR300x serial HCI protocol. This protocol extends H4 serial protocol to implement enhanced power management features supported by Atheros AR300x serial Bluetooth chipsets. Signed-off-by: Suraj Sumangala <suraj@atheros.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-07-21Bluetooth: Add HCIUARTSETFLAGS and HCIUARTGETFLAGS ioctlsJohan Hedberg
This patch introduces two new ioctls: HCIUARTSETFLAGS and HCIUARTGETFLAGS. The only flag available for now is HCI_UART_RAW_DEVICE which allows to initialize a UART device into RAW mode from userspace. This is particularly useful for experimenting with Bluetooth controllers that don't yet have proper support in BlueZ. Signed-off-by: Johan Hedberg <johan.hedberg@nokia.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-10-22[Bluetooth] Add UART driver for Texas Instruments' BRF63xx chipsOhad Ben-Cohen
Add support for Texas Instruments' HCI Low Level (HCILL) Bluetooth protocol, which is a power management extension to H4. The HCILL is widely used by TI's BRF63xx Bluetooth chips. Signed-off-by: Ohad Ben-Cohen <ohad@bencohen.org> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-10[Bluetooth] Add HCIUARTGETDEVICE support for HCI line disciplineMarcel Holtmann
Adding HCIUARTGETDEVICE makes it possible to get the HCI device number that is attached to a given serial device. This is required during the initialization process of some Bluetooth chips. Signed-off-by: Ohad Ben-Cohen <ohad@bencohen.org> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2005-10-28[Bluetooth] Cleanup of the HCI UART driverMarcel Holtmann
This patch contains the big cleanup of the HCI UART driver. The uneeded header files are removed and their structure declarations are moved into the protocol implementations. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
