commit 3d44a6fd0775e6215e836423e27f8eedf8c871ea upstream.
If setup() fails a reference for runtime PM has already
been taken. Proper use of the error handling in btusb_open()is needed.
You cannot just return.
Fixes: ace31982585a3 ("Bluetooth: btusb: Add setup callback for chip init on USB")
Signed-off-by: Oliver Neukum <oneukum@suse.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit cf94da6f502d8caecabd56b194541c873c8a7a3c upstream.
Syzbot reported an invalid-free that I introduced fixing a memleak.
bcsp_recv() also frees bcsp->rx_skb but never nullifies its value.
Nullify bcsp->rx_skb every time it is freed.
Signed-off-by: Tomas Bortoli <tomasbortoli@gmail.com>
Reported-by: syzbot+a0d209a4676664613e76@syzkaller.appspotmail.com
Cc: Alexander Potapenko <glider@google.com>
hci_uart_set_proto()
commit 56897b217a1d0a91c9920cb418d6b3fe922f590a upstream.
task A: task B:
hci_uart_set_proto flush_to_ldisc
- p->open(hu) -> h5_open //alloc h5 - receive_buf
- set_bit HCI_UART_PROTO_READY - tty_port_default_receive_buf
- hci_uart_register_dev - tty_ldisc_receive_buf
- hci_uart_tty_receive
- test_bit HCI_UART_PROTO_READY
- h5_recv
- clear_bit HCI_UART_PROTO_READY while() {
- p->open(hu) -> h5_close //free h5
- h5_rx_3wire_hdr
- h5_reset() //use-after-free
It could use ioctl to set hci uart proto, but there is
a use-after-free issue when hci_uart_register_dev() fail in
hci_uart_set_proto(), see stack above, fix this by setting
HCI_UART_PROTO_READY bit only when hci_uart_register_dev()
return success.
Reported-by: syzbot+899a33dc0fa0dbaf06a6@syzkaller.appspotmail.com
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Reviewed-by: Jeremy Cline <jcline@redhat.com>
[ Upstream commit 6d0762b19c5963ff9e178e8af3626532ee04d93d ]
The ASUS X412FA laptop contains a Realtek RTL8822CE device with an
associated BT chip using a USB ID of 04ca:4005. This ID is added to the
driver.
The /sys/kernel/debug/usb/devices portion for this device is:
T: Bus=01 Lev=01 Prnt=01 Port=09 Cnt=04 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 1.00 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=04ca ProdID=4005 Rev= 0.00
S: Manufacturer=Realtek
S: Product=Bluetooth Radio
S: SerialNumber=00e04c000001
C:* #Ifs= 2 Cfg#= 1 Atr=a0 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms
Buglink: https://bugzilla.kernel.org/show_bug.cgi?id=204707
Signed-off-by: Jian-Hong Pan <jian-hong@endlessm.com>
[ Upstream commit 8059ba0bd0e4694e51c2ee6438a77b325f06c0d5 ]
On WCN3990 downloading the NVM sometimes fails with a "TLV response
size mismatch" error:
[ 174.949955] Bluetooth: btqca.c:qca_download_firmware() hci0: QCA Downloading qca/crnv21.bin
[ 174.958718] Bluetooth: btqca.c:qca_tlv_send_segment() hci0: QCA TLV response size mismatch
It seems the controller needs a short time after downloading the
firmware before it is ready for the NVM. A delay as short as 1 ms
seems sufficient, make it 10 ms just in case. No event is received
during the delay, hence we don't just silently drop an extra event.
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
commit b36a1552d7319bbfd5cf7f08726c23c5c66d4f73 upstream.
Certain ttys operations (pty_unix98_ops) lack tiocmget() and tiocmset()
functions which are called by the certain HCI UART protocols (hci_ath,
hci_bcm, hci_intel, hci_mrvl, hci_qca) via hci_uart_set_flow_control()
or directly. This leads to an execution at NULL and can be triggered by
an unprivileged user. Fix this by adding a helper function and a check
for the missing tty operations in the protocols code.
This fixes CVE-2019-10207. The Fixes: lines list commits where calls to
tiocm[gs]et() or hci_uart_set_flow_control() were added to the HCI UART
protocols.
Link: https://syzkaller.appspot.com/bug?id=1b42faa2848963564a5b1b7f8c837ea7b55ffa50
Reported-by: syzbot+79337b501d6aa974d0f6@syzkaller.appspotmail.com
Cc: stable@vger.kernel.org # v2.6.36+
Fixes: b3190df62861 ("Bluetooth: Support for Atheros AR300x serial chip")
Fixes: 118612fb9165 ("Bluetooth: hci_bcm: Add suspend/resume PM functions")
Fixes: ff2895592f0f ("Bluetooth: hci_intel: Add Intel baudrate configuration support")
Fixes: 162f812f23ba ("Bluetooth: hci_uart: Add Marvell support")
Fixes: fa9ad876b8e0 ("Bluetooth: hci_qca: Add support for Qualcomm Bluetooth chip wcn3990")
Signed-off-by: Vladis Dronov <vdronov@redhat.com>
Reviewed-by: Yu-Chen, Cho <acho@suse.com>
Tested-by: Yu-Chen, Cho <acho@suse.com>
[ Upstream commit 4ce9146e0370fcd573f0372d9b4e5a211112567c ]
Syzkaller found that it is possible to provoke a memory leak by
never freeing rx_skb in struct bcsp_struct.
Fix by freeing in bcsp_close()
Reported-by: syzbot+98162c885993b72f19c4@syzkaller.appspotmail.com
This reverts commit b5c98d8ca8f93a4f73e9cbb53c7e6b8c78ed3f80 which is
commit 6c3711ec64fd23a9abc8aaf59a9429569a6282df upstream.
You Ling writes that this config option isn't even in 4.9.y yet, so it
causes a regression. Revert the patch because of this.
Reported-by: youling 257 <youling257@gmail.com>
Cc: Johan Hedberg <johan.hedberg@intel.com>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Sasha Levin <alexander.levin@microsoft.com>
[ Upstream commit a357ea098c9605f60d92a66a9073f56ce25726da ]
This patch adds the device ID for the AMPAK AP6335 combo module used
in the 1st generation WeTek Hub Android/LibreELEC HTPC box. The WiFI
chip identifies itself as BCM4339, while Bluetooth identifies itself
as BCM4335 (rev C0):
[ 4.864248] Bluetooth: hci0: BCM: chip id 86
[ 4.866388] Bluetooth: hci0: BCM: features 0x2f
[ 4.889317] Bluetooth: hci0: BCM4335C0
[ 4.889332] Bluetooth: hci0: BCM4335C0 (003.001.009) build 0000
[ 9.778383] Bluetooth: hci0: BCM4335C0 (003.001.009) build 0268
Output from hciconfig:
hci0: Type: Primary Bus: UART
BD Address: 43:39:00:00:1F:AC ACL MTU: 1021:8 SCO MTU: 64:1
UP RUNNING
RX bytes:7567 acl:234 sco:0 events:386 errors:0
TX bytes:53844 acl:77 sco:0 commands:304 errors:0
Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy: RSWITCH SNIFF
Link mode: SLAVE ACCEPT
Class: 0x0c0000
Service Classes: Rendering, Capturing
Device Class: Miscellaneous,
HCI Version: 4.0 (0x6) Revision: 0x10c
LMP Version: 4.0 (0x6) Subversion: 0x6109
Manufacturer: Broadcom Corporation (15)
Signed-off-by: Christian Hewitt <christianshewitt@gmail.com>
[ Upstream commit 45ae68b8cfc25bdbffc11248001c47ab1b76ff6e ]
Without this patch we cannot turn on the Bluethooth adapter on HP
14-bs007la.
T: Bus=01 Lev=02 Prnt=03 Port=00 Cnt=01 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0bda ProdID=b009 Rev= 2.00
S: Product=802.11n WLAN Adapter
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=500mA
[ Upstream commit 6c3711ec64fd23a9abc8aaf59a9429569a6282df ]
This driver was recently updated to use serdev, so add the appropriate
dependency. Without this one can get compiler warnings like this if
CONFIG_SERIAL_DEV_BUS is not enabled:
CC [M] drivers/bluetooth/hci_h5.o
drivers/bluetooth/hci_h5.c:934:36: warning: ‘h5_serdev_driver’ defined but not used [-Wunused-variable]
static struct serdev_device_driver h5_serdev_driver = {
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
[ Upstream commit 66d9975c5a7c40aa7e4bb0ec0b0c37ba1f190923 ]
Without this patch we cannot turn on the Bluethooth adapter on ASUS
E406MA.
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=12 MxCh= 0
P: Vendor=2ff8 ProdID=b011 Rev= 2.00
[ Upstream commit 9960521c44a5d828f29636ceac0600603ecbddbf ]
This patch fixes the following warning during boot:
do not call blocking ops when !TASK_RUNNING; state=1 set at
[<(ptrval)>] qca_setup+0x194/0x750 [hci_uart]
WARNING: CPU: 2 PID: 1878 at kernel/sched/core.c:6135
__might_sleep+0x7c/0x88
In qca_set_baudrate(), the current task state is set to
TASK_UNINTERRUPTIBLE before going to sleep for 300ms. It was then
restored to TASK_INTERRUPTIBLE. This patch sets the current task state
back to TASK_RUNNING instead.
Signed-off-by: Thierry Escande <thierry.escande@linaro.org>
commit 7dc5fe0814c35ec4e7d2e8fa30abab72e0e6a172 upstream.
AOSP use userspace firmware loader to load firmwares, which will
return -EAGAIN in case qca/rampatch_00440302.bin is not found.
Since there is no rampatch for dragonboard820c QCA controller
revision, just make it work as is.
CC: Loic Poulain <loic.poulain@linaro.org>
CC: Nicolas Dechesne <nicolas.dechesne@linaro.org>
CC: Marcel Holtmann <marcel@holtmann.org>
CC: Johan Hedberg <johan.hedberg@gmail.com>
CC: Stable <stable@vger.kernel.org>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
[ Upstream commit fed03fe7e55b7dc16077f672bd9d7bbe92b3a691 ]
The Asus Z370-I contains a Realtek RTL8822BE device with an associated
BT chip using a USB ID of 0b05:185c. This device is added to the driver.
Signed-off-by: Hon Weng Chong <honwchong@gmail.com>
[ Upstream commit a41e0796396eeceff673af4a38feaee149c6ff86 ]
This WiFi/Bluetooth USB dongle uses a Realtek chipset, so, use btrtl for it.
Product information:
https://wikidevi.com/wiki/Edimax_EW-7611ULB
>From /sys/kernel/debug/usb/devices
T: Bus=02 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.10 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=7392 ProdID=a611 Rev= 2.00
S: Product=Edimax Wi-Fi N150 Bluetooth4.0 USB Adapter
C:* #Ifs= 3 Cfg#= 1 Atr=e0 MxPwr=500mA
A: FirstIf#= 0 IfCount= 2 Cls=e0(wlcon) Sub=01 Prot=01
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 6 Cls=ff(vend.) Sub=ff Prot=ff Driver=rtl8723bu
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=87(I) Atr=03(Int.) MxPS= 64 Ivl=500us
E: Ad=08(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=09(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
Tested-by: Vicente Bergas <vicencb@gmail.com>
Signed-off-by: Vicente Bergas <vicencb@gmail.com>
commit 544a591668813583021474fa5c7ff4942244d654 upstream.
Commit f44cb4b19ed4 ("Bluetooth: btusb: Fix quirk for Atheros
1525/QCA6174") is causing bluetooth to no longer work for several
people, see: https://bugzilla.redhat.com/show_bug.cgi?id=1568911
So lets revert it for now and try to find another solution for
devices which need the modified quirk.
Cc: Takashi Iwai <tiwai@suse.de>
commit f44cb4b19ed40b655c2d422c9021ab2c2625adb6 upstream.
The Atheros 1525/QCA6174 BT doesn't seem working properly on the
recent kernels, as it tries to load a wrong firmware
ar3k/AthrBT_0x00000200.dfu and it fails.
This seems to have been a problem for some time, and the known
workaround is to apply BTUSB_QCA_ROM quirk instead of BTUSB_ATH3012.
The device in question is:
T: Bus=01 Lev=01 Prnt=01 Port=09 Cnt=03 Dev#= 4 Spd=12 MxCh= 0
P: Vendor=0cf3 ProdID=3004 Rev= 0.01
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
Bugzilla: http://bugzilla.opensuse.org/show_bug.cgi?id=1082504
Reported-by: Ivan Levshin <ivan.levshin@microfocus.com>
Tested-by: Ivan Levshin <ivan.levshin@microfocus.com>
Cc: <stable@vger.kernel.org>
[ Upstream commit 67b8fbead4685b36d290a0ef91c6ddffc4920ec9 ]
In case of hci send frame failure, skb is still owned
by the caller (hci_core) and then should not be freed.
This fixes crash on dragonboard-410c when sending SCO
packet. skb is freed by both btqcomsmd and hci_core.
Fixes: 1511cc750c3d ("Bluetooth: Introduce Qualcomm WCNSS SMD based HCI driver")
Signed-off-by: Loic Poulain <loic.poulain@linaro.org>
[ Upstream commit ba8f3597900291a93604643017fff66a14546015 ]
Assuming that the original code idea was to enable in-band sleeping
only if the setup_rome method returns succes and run in 'standard'
mode otherwise, we should not return setup_rome return value which
makes qca_setup fail if no rampatch/nvm file found.
This fixes BT issue on the dragonboard-820C p4 which includes the
following QCA controller:
hci0: Product:0x00000008
hci0: Patch :0x00000111
hci0: ROM :0x00000302
hci0: SOC :0x00000044
Since there is no rampatch for this controller revision, just make
it work as is.
[ Upstream commit 2d6f1da168e1d62c47f7d50135ac4cbd8411dcb1 ]
Before attempting to schedule a work-item onto hu->write_work in
hci_uart_tx_wakeup(), check that the Data Link protocol layer is
still bound to the HCI UART driver.
Failure to perform this protocol check causes a race condition between
the work queue hu->write_work running hci_uart_write_work() and the
Data Link protocol layer being unbound (closed) in hci_uart_tty_close().
Note hci_uart_tty_close() does have a "cancel_work_sync(&hu->write_work)"
but it is ineffective because it cannot prevent work-items being added
to hu->write_work after cancel_work_sync() has run.
Therefore, add a check for HCI_UART_PROTO_READY into hci_uart_tx_wakeup()
which prevents scheduling of the work queue when HCI_UART_PROTO_READY
is in the clear state. However, note a small race condition remains
because the hci_uart_tx_wakeup() thread can run in parallel with the
hci_uart_tty_close() thread so it is possible that a schedule of
hu->write_work can occur when HCI_UART_PROTO_READY is cleared. A complete
solution needs locking of the threads which is implemented in a future
commit.
Signed-off-by: Dean Jenkins <Dean_Jenkins@mentor.com>
[ Upstream commit 048e1bd3a27fbeb84ccdff52e165370c1339a193 ]
Before attempting to dequeue a Data Link protocol encapsulated message,
check that the Data Link protocol is still bound to the HCI UART driver.
This makes the code consistent with the usage of the other proto
function pointers.
Therefore, add a check for HCI_UART_PROTO_READY into hci_uart_dequeue()
and return NULL if the Data Link protocol is not bound.
This is needed for robustness as there is a scheduling race condition.
hci_uart_write_work() is scheduled to run via work queue hu->write_work
from hci_uart_tx_wakeup(). Therefore, there is a delay between
scheduling hci_uart_write_work() to run and hci_uart_dequeue() running
whereby the Data Link protocol layer could become unbound during the
scheduling delay. In this case, without the check, the call to the
unbound Data Link protocol layer dequeue function can crash.
It is noted that hci_uart_tty_close() has a
"cancel_work_sync(&hu->write_work)" statement but this only reduces
the window of the race condition because it is possible for a new
work-item to be added to work queue hu->write_work after the call to
cancel_work_sync(). For example, Data Link layer retransmissions can
be added to the work queue after the cancel_work_sync() has finished.
commit 61f5acea8737d9b717fcc22bb6679924f3c82b98 upstream.
Commit 7d06d5895c15 ("Revert "Bluetooth: btusb: fix QCA...suspend/resume"")
removed the setting of the BTUSB_RESET_RESUME quirk for QCA Rome devices,
instead favoring adding USB_QUIRK_RESET_RESUME quirks in usb/core/quirks.c.
This was done because the DIY BTUSB_RESET_RESUME reset-resume handling
has several issues (see the original commit message). An added advantage
of moving over to the USB-core reset-resume handling is that it also
disables autosuspend for these devices, which is similarly broken on these.
But there are 2 issues with this approach:
1) It leaves the broken DIY BTUSB_RESET_RESUME code in place for Realtek
devices.
2) Sofar only 2 of the 10 QCA devices known to the btusb code have been
added to usb/core/quirks.c and if we fix the Realtek case the same way
we need to add an additional 14 entries. So in essence we need to
duplicate a large part of the usb_device_id table in btusb.c in
usb/core/quirks.c and manually keep them in sync.
This commit instead restores setting a reset-resume quirk for QCA devices
in the btusb.c code, avoiding the duplicate usb_device_id table problem.
This commit avoids the problems with the original DIY BTUSB_RESET_RESUME
code by simply setting the USB_QUIRK_RESET_RESUME quirk directly on the
usb_device.
This commit also moves the BTUSB_REALTEK case over to directly setting the
USB_QUIRK_RESET_RESUME on the usb_device and removes the now unused
BTUSB_RESET_RESUME code.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1514836
Fixes: 7d06d5895c15 ("Revert "Bluetooth: btusb: fix QCA...suspend/resume"")
Cc: Leif Liddy <leif.linux@gmail.com>
Cc: Matthias Kaehlcke <mka@chromium.org>
Cc: Brian Norris <briannorris@chromium.org>
Cc: Daniel Drake <drake@endlessm.com>
Cc: Kai-Heng Feng <kai.heng.feng@canonical.com>
commit 7d06d5895c159f64c46560dc258e553ad8670fe0 upstream.
This reverts commit fd865802c66bc451dc515ed89360f84376ce1a56.
This commit causes a regression on some QCA ROME chips. The USB device
reset happens in btusb_open(), hence firmware loading gets interrupted.
Furthermore, this commit stops working after commit
("a0085f2510e8976614ad8f766b209448b385492f Bluetooth: btusb: driver to
enable the usb-wakeup feature"). Reset-resume quirk only gets enabled in
btusb_suspend() when it's not a wakeup source.
If we really want to reset the USB device, we need to do it before
btusb_open(). Let's handle it in drivers/usb/core/quirks.c.
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Reviewed-by: Brian Norris <briannorris@chromium.org>
Tested-by: Brian Norris <briannorris@chromium.org>
commit b4cdaba274247c9c841c6a682c08fa91fb3aa549 upstream.
BCM43341 devices soldered onto the PCB (non-removable) always (AFAICT)
use an UART connection for bluetooth. But they also advertise btsdio
support on their 3th sdio function, this causes 2 problems:
1) A non functioning BT HCI getting registered
2) Since the btsdio driver does not have suspend/resume callbacks,
mmc_sdio_pre_suspend will return -ENOSYS, causing mmc_pm_notify()
to react as if the SDIO-card is removed and since the slot is
marked as non-removable it will never get detected as inserted again.
Which results in wifi no longer working after a suspend/resume.
This commit fixes both by making btsdio ignore BCM43341 devices
when connected to a slot which is marked non-removable.
This reverts commit 7336f5481f6cf913a2d29d98c6e11f4bbe19d3b2 which is
commit a0085f2510e8976614ad8f766b209448b385492f upstream.
It causes problems with working systems, as noted by a number of the
ChromeOS developers.
Cc: Sukumar Ghorai <sukumar.ghorai@intel.com>
Cc: Amit K Bag <amit.k.bag@intel.com>
Cc: Oliver Neukum <oneukum@suse.com>
Reported-by: Guenter Roeck <linux@roeck-us.net>
Reported-by: Brian Norris <briannorris@chromium.org>
Acked-by: Brian Norris <briannorris@chromium.org>
BT-Controller connected as platform non-root-hub device and
usb-driver initialize such device with wakeup disabled,
Ref. usb_new_device().
At present wakeup-capability get enabled by hid-input device from usb
function driver(e.g. BT HID device) at runtime. Again some functional
driver does not set usb-wakeup capability(e.g LE HID device implement
as HID-over-GATT), and can't wakeup the host on USB.
Most of the device operation (such as mass storage) initiated from host
(except HID) and USB wakeup aligned with host resume procedure. For BT
device, usb-wakeup capability need to enable form btusc driver as a
generic solution for multiple profile use case and required for USB remote
wakeup (in-bus wakeup) while host is suspended. Also usb-wakeup feature
need to enable/disable with HCI interface up and down.
Signed-off-by: Sukumar Ghorai <sukumar.ghorai@intel.com>
Signed-off-by: Amit K Bag <amit.k.bag@intel.com>
Acked-by: Oliver Neukum <oneukum@suse.com>
commit fd865802c66bc451dc515ed89360f84376ce1a56 upstream.
There's been numerous reported instances where BTUSB_QCA_ROME
bluetooth controllers stop functioning upon resume from suspend. These
devices seem to be losing power during suspend. Patch will detect a status
change on resume and perform a reset.
Signed-off-by: Leif Liddy <leif.linux@gmail.com>
Cc: Kai Heng Feng <kai.heng.feng@canonical.com>
[ Upstream commit 9af02d86e11dc409e5c3de46e81c0a492ba58905 ]
It's much the same as what we did for mwifiex in:
b9da4d2 mwifiex: avoid double-disable_irq() race
"We have a race where the wakeup IRQ might be in flight while we're
calling mwifiex_disable_wake() from resume(). This can leave us
disabling the IRQ twice.
Let's disable the IRQ and enable it in case if we have double-disabled
it."
Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com>
commit a81d72d2002d6a932bd83022cbf8c442b1b97512 upstream.
T: Bus=02 Lev=01 Prnt=01 Port=03 Cnt=03 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 2.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=13d3 ProdID=3494 Rev= 2.00
Signed-off-by: Dmitry Tunin <hanipouspilot@gmail.com>
commit dcb9cfaa5ea9aa0ec08aeb92582ccfe3e4c719a9 upstream.
Make sure to check the tty-device pointer before looking up the sibling
platform device to avoid dereferencing a NULL-pointer when the tty is
one end of a Unix98 pty.
Fixes: 74cdad37cd24 ("Bluetooth: hci_intel: Add runtime PM support")
Fixes: 1ab1f239bf17 ("Bluetooth: hci_intel: Add support for platform driver")
Cc: Loic Poulain <loic.poulain@intel.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 95065a61e9bf25fb85295127fba893200c2bbbd8 upstream.
Fixes: 0395ffc1ee05 ("Bluetooth: hci_bcm: Add PM for BCM devices")
Cc: Frederic Danis <frederic.danis@linux.intel.com>
commit 441ad62d6c3f131f1dbd7dcdd9cbe3f74dbd8501 upstream.
T: Bus=01 Lev=01 Prnt=01 Port=07 Cnt=04 Dev#= 5 Spd=12 MxCh= 0
P: Vendor=04ca ProdID=3018 Rev=00.01
C: #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
Probe functions should return 0 on success. This driver's probe
returns the value returned by hci_register_dev(), which is the hci
index. This works for systems with only one hci device (id = 0) but
for systems where the btwilink device ends up with an id larger than
0, things will start to fall apart.
Make the probe function return 0 on success.
Signed-off-by: Jacob Siverskog <jacob@teenage.engineering>
ACPI table for BCM2E55 of Lenovo ThinkPad 8 is not correct.
Set correctly IRQ polarity for this device, fixing the issue of bluetooth
never resuming after autosuspend PM.
Signed-off-by: Jérôme de Bretagne <jerome.debretagne@gmail.com>
Move usb_autopm_get_interface() ahead of setup_on_usb() to prevent
device from sending usb control message in usb suspend mode.
The error message is as below:
[ 83.944103] btusb 1-2:1.1: usb_suspend_interface: status 0
[ 83.944107] btusb 1-2:1.0: usb_suspend_interface: status 0
[ 83.960132] usb 1-2: usb auto-suspend, wakeup 0
[ 83.976156] usb 1-2: usb_suspend_device: status 0
[ 83.976162] usb 1-2: usb_suspend_both: status 0
[ 298.689106] Bluetooth: hci0
[ 298.689399] Bluetooth: hci0: Failed to access otp area (-113)
Signed-off-by: Ethan Hsieh <ethan.hsieh@canonical.com>
btusb_set_bdaddr_marvell() configures BD address for Marvell chipsets.
This patch adds new chipset 8997 in the list so that BD address feature
would be available for it.
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Pull networking updates from David Miller:
1) BBR TCP congestion control, from Neal Cardwell, Yuchung Cheng and
co. at Google. https://lwn.net/Articles/701165/
2) Do TCP Small Queues for retransmits, from Eric Dumazet.
3) Support collect_md mode for all IPV4 and IPV6 tunnels, from Alexei
Starovoitov.
4) Allow cls_flower to classify packets in ip tunnels, from Amir Vadai.
5) Support DSA tagging in older mv88e6xxx switches, from Andrew Lunn.
6) Support GMAC protocol in iwlwifi mwm, from Ayala Beker.
7) Support ndo_poll_controller in mlx5, from Calvin Owens.
8) Move VRF processing to an output hook and allow l3mdev to be
loopback, from David Ahern.
9) Support SOCK_DESTROY for UDP sockets. Also from David Ahern.
10) Congestion control in RXRPC, from David Howells.
11) Support geneve RX offload in ixgbe, from Emil Tantilov.
12) When hitting pressure for new incoming TCP data SKBs, perform a
partial rathern than a full purge of the OFO queue (which could be
huge). From Eric Dumazet.
13) Convert XFRM state and policy lookups to RCU, from Florian Westphal.
14) Support RX network flow classification to igb, from Gangfeng Huang.
15) Hardware offloading of eBPF in nfp driver, from Jakub Kicinski.
16) New skbmod packet action, from Jamal Hadi Salim.
17) Remove some inefficiencies in snmp proc output, from Jia He.
18) Add FIB notifications to properly propagate route changes to
hardware which is doing forwarding offloading. From Jiri Pirko.
19) New dsa driver for qca8xxx chips, from John Crispin.
20) Implement RFC7559 ipv6 router solicitation backoff, from Maciej
Żenczykowski.
21) Add L3 mode to ipvlan, from Mahesh Bandewar.
22) Support 802.1ad in mlx4, from Moshe Shemesh.
23) Support hardware LRO in mediatek driver, from Nelson Chang.
24) Add TC offloading to mlx5, from Or Gerlitz.
25) Convert various drivers to ethtool ksettings interfaces, from
Philippe Reynes.
26) TX max rate limiting for cxgb4, from Rahul Lakkireddy.
27) NAPI support for ath10k, from Rajkumar Manoharan.
28) Support XDP in mlx5, from Rana Shahout and Saeed Mahameed.
29) UDP replicast support in TIPC, from Richard Alpe.
30) Per-queue statistics for qed driver, from Sudarsana Reddy Kalluru.
31) Support BQL in thunderx driver, from Sunil Goutham.
32) TSO support in alx driver, from Tobias Regnery.
33) Add stream parser engine and use it in kcm.
34) Support async DHCP replies in ipconfig module, from Uwe
Kleine-König.
35) DSA port fast aging for mv88e6xxx driver, from Vivien Didelot.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1715 commits)
mlxsw: switchx2: Fix misuse of hard_header_len
mlxsw: spectrum: Fix misuse of hard_header_len
net/faraday: Stop NCSI device on shutdown
net/ncsi: Introduce ncsi_stop_dev()
net/ncsi: Rework the channel monitoring
net/ncsi: Allow to extend NCSI request properties
net/ncsi: Rework request index allocation
net/ncsi: Don't probe on the reserved channel ID (0x1f)
net/ncsi: Introduce NCSI_RESERVED_CHANNEL
net/ncsi: Avoid unused-value build warning from ia64-linux-gcc
net: Add netdev all_adj_list refcnt propagation to fix panic
net: phy: Add Edge-rate driver for Microsemi PHYs.
vmxnet3: Wake queue from reset work
i40e: avoid NULL pointer dereference and recursive errors on early PCI error
qed: Add RoCE ll2 & GSI support
qed: Add support for memory registeration verbs
qed: Add support for QP verbs
qed: PD,PKEY and CQ verb support
qed: Add support for RoCE hw init
qede: Add qedr framework
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull usb/phy/extcon updates from Greg KH:
"Here is the big USB, and PHY, and extcon, patchsets for 4.9-rc1.
Full details are in the shortlog, but generally a lot of new hardware
support, usb gadget updates, and Wolfram's great cleanup of USB error
message handling, making the kernel image a tad bit smaller.
All of this has been in linux-next with no reported issues"
* tag 'usb-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (343 commits)
Revert "usbtmc: convert to devm_kzalloc"
USB: serial: cp210x: Add ID for a Juniper console
usb: Kconfig: using select for USB_COMMON dependency
bluetooth: bcm203x: don't print error when allocating urb fails
mmc: host: vub300: don't print error when allocating urb fails
usb: hub: change CLEAR_FEATURE to SET_FEATURE
usb: core: Introduce a USB port LED trigger
USB: bcma: drop Northstar PHY 2.0 initialization code
usb: core: hcd: add missing header dependencies
usb: musb: da8xx: fix error handling message in probe
usb: musb: Fix session based PM for first invalid VBUS
usb: musb: Fix PM runtime for disconnect after unconfigure
musb: Export musb_root_disconnect for use in modules
usb: misc: legousbtower: Fix NULL pointer deference
cdc-acm: hardening against malicious devices
Revert "usb: gadget: NCM: Protect dev->port_usb using dev->lock"
include: extcon: Fix compilation error caused because of incomplete merge
MAINTAINERS: add tree entry for USB Serial
phy-twl4030-usb: initialize charging-related stuff via pm_runtime
phy-twl4030-usb: better handle musb_mailbox() failure
kmalloc will print enough information in case of failure.
Signed-off-by: Wolfram Sang <wsa-dev@sang-engineering.com>
Remove multiple return statements in hci_uart_tty_ioctl() call and
added a single return statement.
This code re-organisation allows subsequent locking to be easily
added.
Signed-off-by: Vignesh Raman <Vignesh_Raman@mentor.com>
Signed-off-by: Rajeev Kumar <rajeev_kumar@mentor.com>
Send an ACK frame with the current txack value in response to
every received reliable frame unless a TX reliable frame is being
sent. This modification allows re-transmitted frames from the remote
peer to be acknowledged rather than ignored. It means that the remote
peer knows which frame number to start re-transmitting from.
Without this modification, the recovery time to a missing frame
from the remote peer was unnecessarily being extended because the
headers of the out of order reliable frames were being discarded rather
than being processed. The frame headers of received frames will
indicate whether the local peer's transmissions have been
acknowledged by the remote peer. Therefore, the local peer may
unnecessarily re-transmit despite the remote peer already indicating
that the frame had been acknowledged in out of order reliable frame.
Signed-off-by: Jiada Wang <jiada_wang@mentor.com>
drivers/bluetooth/hci_bcsp.c contains some style issues as
highlighted by
./scripts/checkpatch.pl --strict -f drivers/bluetooth/hci_bcsp.c
a) comments - maintainer prefers network style comments
b) positioning of lines in multi-line statements
c) spaces after casts
d) missing blank lines after declarations
Therefore, tidy-up the above to make it easier to apply
future code changes that have conforming style.
Running with KASAN produces some messages:
BUG: KASAN: use-after-free in ti_st_send_frame+0x9c/0x16c at addr
ffffffc064868fe8
Read of size 1 by task kworker/u17:1/1266
<KASAN output trimmed>
Hardware name: HiKey Development Board (DT)
Workqueue: hci0 hci_cmd_work
Call trace:
[<ffffffc00008c00c>] dump_backtrace+0x0/0x178
[<ffffffc00008c1a4>] show_stack+0x20/0x28
[<ffffffc00067da38>] dump_stack+0xa8/0xe0
[<ffffffc000288430>] print_trailer+0x110/0x174
[<ffffffc00028aedc>] object_err+0x4c/0x5c
[<ffffffc00028f714>] kasan_report_error+0x254/0x54c
[<ffffffc00028fa70>] kasan_report+0x64/0x70
[<ffffffc00028eb8c>] __asan_load1+0x4c/0x54
[<ffffffc000b59b24>] ti_st_send_frame+0x9c/0x16c
[<ffffffc000ee8dcc>] hci_send_frame+0xb4/0x118
[<ffffffc000ee8efc>] hci_cmd_work+0xcc/0x154
[<ffffffc0000f6c48>] process_one_work+0x26c/0x7a4
[<ffffffc0000f721c>] worker_thread+0x9c/0x73c
[<ffffffc000100250>] kthread+0x138/0x154
[<ffffffc000085c50>] ret_from_fork+0x10/0x40
The packet is being accessed for statistics after it has been freed.
Save the packet type before sending for statistics afterwards.
Signed-off-by: Laura Abbott <labbott@redhat.com>
BugLink: https://bugs.launchpad.net/bugs/1535802
T: Bus=01 Lev=02 Prnt=02 Port=04 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
P: Vendor=04ca ProdID=3011 Rev=00.01
This patch introduces support for Marvell Bluetooth controller over
UART (8897 for now). In order to send the final firmware at full speed,
a helper firmware is firstly sent. Firmware download is driven by the
controller which sends request firmware packets (including expected
size).
This driver is a global rework of the one proposed by
Amitkumar Karwar <akarwar@marvell.com>.
Signed-off-by: Loic Poulain <loic.poulain@intel.com>
Will be used by hci_nokia extra protocol.
Use full name instead of abbreviation.
The RTL8822BE is a new Realtek wifi and BT device. Support for the BT
part is hereby added.
As this device is similar to most of the other Realtek BT devices, the
changes are minimal. The main difference is that the 8822BE needs a
configuration file for enabling and disabling features. Thus code is
added to select and load this configuration file. Although not needed
at the moment, hooks are added for the other devices that might need
such configuration files.
One additional change is to the routine that tests that the project
ID contained in the firmware matches the hardware. As the project IDs
are not sequential, continuing to use the position in the array as the
expected value of the ID would require adding extra unused entries in
the table, and any subsequant rearrangment of the array would break the
code. To fix these problems, the array elements now contain both the
hardware ID and the expected value for the project ID.
Signed-off-by: 陆朱伟 <alex_lu@realsil.com.cn>
edl->data is an array of __u8 so the null check is unneccessary,
so remove it.
