path: root/drivers/bluetooth
2007-09-09[Bluetooth] Add missing stat.byte_rx counter modificationMarcel Holtmann
With the support for hci_recv_fragment() the call to increase the stat.byte_rx counter got accidentally removed. This patch fixes it. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-07-11[Bluetooth] Remove the redundant non-seekable llseek methodRobert P. J. Day
Remove the llseek method given that the open method already calls nonseekable_open(). Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-07-11[Bluetooth] Use hci_recv_fragment() within HCI USB driverMarcel Holtmann
This patch modifies the HCI USB driver to use the new helper function for reassembling HCI data packets and events. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-24[Bluetooth] Always send HCI_Reset for Broadcom devicesMarcel Holtmann
In case of Broadcom based Bluetooth devices, it is safe to always send HCI_Reset as first command. This gives the advantage that all HID Proxy versions will automatically work and don't need any additional quirks anymore. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-10[Bluetooth] Fix unintentional fall-through in HCI line disciplineMarcel Holtmann
A trivial fix to (what looks like) an unintentional fall-through in the HCI line discipline. Signed-off-by: Ohad Ben-Cohen <ohad@bencohen.org> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-10[Bluetooth] Fix NULL pointer dereference in HCI line disciplineMarcel Holtmann
Normally a serial Bluetooth device is opened, TIOSETD'ed to N_HCI line discipline, HCIUARTSETPROTO'ed and finally closed. In case the device fails to HCIUARTSETPROTO, closing it produces a NULL pointer dereference. Signed-off-by: Ohad Ben-Cohen <ohad@bencohen.org> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-10[Bluetooth] Add HCIUARTGETDEVICE support for HCI line disciplineMarcel Holtmann
Adding HCIUARTGETDEVICE makes it possible to get the HCI device number that is attached to a given serial device. This is required during the initialization process of some Bluetooth chips. Signed-off-by: Ohad Ben-Cohen <ohad@bencohen.org> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-05[Bluetooth] Correct SCO buffer for another Broadcom based dongleMarcel Holtmann
The SCO buffer size values for Bluetooth chips from Broadcom are wrong and the USB Bluetooth driver has to set a quirk to correct these SCO buffer size values. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-05[Bluetooth] Add support for Targus ACB10US USB dongleMarcel Holtmann
This patch adds the vendor and product id of the Targus ACB10US dongle and sets a flag to send HCI_Reset as the first command. Signed-off-by: Marcel Holtmann <marcel@holtmann.org
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[BLUETOOTH]: Introduce skb->data accessor methods for hci_{acl,event,sco}_hdrArnaldo Carvalho de Melo
For consistency with other skb data accessors, reducing the number of direct accesses to skb->data. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-02-26[Bluetooth] Make use of MODULE_FIRMWAREMarcel Holtmann
Some Bluetooth drivers need one or more binary firmware images. Export these image names via the MODULE_FIRMWARE tag. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-02-12[PATCH] mark struct file_operations const 3Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-09[Bluetooth] Correct SCO buffer for Broadcom based Dell laptopsMarcel Holtmann
The SCO buffer size values on Dell laptops with a Bluetooth chip from Broadcom are wrong. The USB Bluetooth driver has to set a quirk to correct the SCO buffer size values. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-01-09[Bluetooth] Correct SCO buffer for Broadcom based HP laptopsMarcel Holtmann
The SCO buffer size values on HP laptops with a Bluetooth chip from Broadcom are wrong. The USB Bluetooth driver has to set a quirk to correct the SCO buffer size values. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-01-09[Bluetooth] Correct SCO buffer size for another ThinkPad laptopMarcel Holtmann
The ThinkPad R60E uses a Broadcom based Bluetooth chip and even this version needs the quirk to correct the SCO buffer size values. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-12-20[PATCH] bluetooth: add support for another Kensington dongleOlivier Galibert
Add the stupid sco fixup quirk to yet another Broadcom/Kensington device. Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-07[PATCH] lockdep: annotate bcsp driverPeter Zijlstra
============================================= [ INFO: possible recursive locking detected ] 2.6.18-1.2699.fc6 #1 --------------------------------------------- swapper/0 is trying to acquire lock: (&list->lock#3){+...}, at: [<c05ad307>] skb_dequeue+0x12/0x43 but task is already holding lock: (&list->lock#3){+...}, at: [<df98cd79>] bcsp_dequeue+0x6a/0x11e [hci_uart] Two different list locks nest, annotate so. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Marcel Holtmann <marcel@holtmann.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-06Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/pcmcia/ds.c Fix up merge failures with Linus's head and fix new compile failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-04[PATCH] pcmcia: conf.ConfigBase and conf.Present consolidationDominik Brodowski
struct pcmcia_device *p_dev->conf.ConfigBase and .Present are set in almost all PCMICA driver right at the beginning, using the same calls but slightly different implementations. Unfiy this in the PCMCIA core. Includes a small bugfix ("drivers/net/pcmcia/xirc2ps_cs.c: remove unused label") from and Signed-off-by Adrian Bunk <bunk@stusta.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-30[PATCH] lockdep: annotate DECLARE_WAIT_QUEUE_HEADPeter Zijlstra
kernel: INFO: trying to register non-static key. kernel: the code is fine but needs lockdep annotation. kernel: turning off the locking correctness validator. kernel: [<c04051ed>] show_trace_log_lvl+0x58/0x16a kernel: [<c04057fa>] show_trace+0xd/0x10 kernel: [<c0405913>] dump_stack+0x19/0x1b kernel: [<c043b1e2>] __lock_acquire+0xf0/0x90d kernel: [<c043bf70>] lock_acquire+0x4b/0x6b kernel: [<c061472f>] _spin_lock_irqsave+0x22/0x32 kernel: [<c04363d3>] prepare_to_wait+0x17/0x4b kernel: [<f89a24b6>] lpfc_do_work+0xdd/0xcc2 [lpfc] kernel: [<c04361b9>] kthread+0xc3/0xf2 kernel: [<c0402005>] kernel_thread_helper+0x5/0xb Another case of non-static lockdep keys; duplicate the paradigm set by DECLARE_COMPLETION_ONSTACK and introduce DECLARE_WAIT_QUEUE_HEAD_ONSTACK. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Greg KH <gregkh@suse.de> Cc: Markus Lidel <markus.lidel@shadowconnect.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@infradead.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[Bluetooth] Add missing entry for Nokia DTL-4 PCMCIA cardMarcel Holtmann
The device id for the Nokia DTL-4 PCMCIA card was missing. This patch adds it back to the list of supported devices. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-10-20[Bluetooth] Add support for newer ANYCOM USB donglesMarcel Holtmann
This patch adds the vendor and product id of the ANYCOM Bluetooth USB-200 and USB-250 dongles and sets a flag to send HCI_Reset as the first command. Signed-off-by: Marcel Holtmann <marcel@holtmann.org
2006-10-15[Bluetooth] Use work queue to trigger URB submissionMarcel Holtmann
The bcm203x firmware loading driver uses a timer to trigger the URB submission. It is better to use a work queue instead. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-28[Bluetooth] Code cleanup for the HCI UART driverMarcel Holtmann
This patch cleans up the Bluetooth HCI UART driver a bit. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-09-28[Bluetooth] Add support for Canyon CN-BTU1 dongleMarcel Holtmann
This patch adds the vendor and product id of the Canycon CN-BTU1 dongle and sets a flag to send HCI_Reset as the first command. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-09-28[Bluetooth] Add HCI device identifier for SDIO cardsMarcel Holtmann
This patch assigns the next free HCI device identifier to Bluetooth devices based on the SDIO interface. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-09-28[Bluetooth] Code cleanup of the drivers source codeMarcel Holtmann
This patch is an attempt to cleanup the drivers source code to make all Bluetooth drivers look more unique. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-24[Bluetooth] Enable SCO support for Broadcom HID proxy dongleMarcel Holtmann
The Broadcom dongles with HID proxy support actually support SCO over HCI if the SCO buffer size values are corrected. So instead of disabling the SCO support, mark this dongle with the quirk for the Bluetooth core to correct the wrong buffer size values. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-24[Bluetooth] Add quirk for another broken RTX Telecom based dongleMarcel Holtmann
This patch disables the ISOC transfers for another broken RTX Telecom based USB dongle. Starting the USB ISOC transfers only ends in a burst of error messages for invalid SCO packets on connection handle 0. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-24[Bluetooth] Correct SCO buffer size for Belkin devicesMarcel Holtmann
The Belkin F8T012 and F8T013 devices are both based on a Bluetooth chip from Broadcom and their SCO buffer size values are wrong. The Bluetooth core should correct these values. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-24[Bluetooth] Correct SCO buffer size for another Broadcom chipMarcel Holtmann
The SCO buffer size values on IBM/Lenovo ThinkPad laptops with a Bluetooth chip from Broadcom are wrong. The USB Bluetooth driver has to set a quirk to correct the SCO buffer size values. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-12[Bluetooth] Avoid NULL pointer dereference with tty->driverMarcel Holtmann
This patch checks for tty->driver before trying to call flush_buffer(). Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-10[PATCH] release_firmware() fixesMagnus Damm
Use release_firmware() to free requested resources. According to Documentation/firmware_class/README the request_firmware() call should be followed by a release_firmware(). Some drivers do not however free the firmware previously allocated with request_firmware(). This patch tries to fix this by making sure that release_firmware() is used as expected. Signed-off-by: Magnus Damm <magnus@valinux.co.jp> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[Bluetooth] Add platform device for virtual and serial devicesMarcel Holtmann
This patch adds a generic Bluetooth platform device that can be used as parent device by virtual and serial devices. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-03[Bluetooth] Correct SCO buffer size on requestMarcel Holtmann
This patch introduces a quirk that allows the drivers to tell the host to correct the SCO buffer size values. Signed-off-by: Olivier Galibert <galibert@pobox.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-03[Bluetooth] Add suspend/resume support to the HCI USB driverMarcel Holtmann
This patch implements the suspend/resume methods for the HCI USB driver by killing all outstanding URBs on suspend, and re-issuing them on resume. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-03[Bluetooth] Use raw mode for the Frontline sniffer deviceMarcel Holtmann
The Frontline sniffer device looks like a normal H:2 Bluetooth device, but it is not and so mark it as raw mode device. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-06-26[PATCH] Bluetooth: fix potential NULL ptr deref in ↵Jesper Juhl
dtl1_cs.c::dtl1_hci_send_frame() There's a problem in drivers/bluetooth/dtl1_cs.c::dtl1_hci_send_frame() If bt_skb_alloc() returns NULL, then skb_reserve(s, NSHL); will cause a NULL pointer deref - ouch. If we can't allocate the resources we require we need to tell the caller by returning -ENOMEM. Found by the coverity checker as bug #409 Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] pcmcia: use bitfield instead of p_state and stateDominik Brodowski
Instead of the two status values struct pcmcia_device->p_state and state, use descriptive bitfields. Most value-checking in drivers was invalid, as the core now only calls the ->remove() (a.k.a. detach) function in case the attachement _and_ configuration was successful. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add return value to _config() functionsDominik Brodowski
Most of the driver initialization isn't done in the .probe function, but in the internal _config() functions. Make them return a value, so that .probe can properly report whether the probing of the device succeeded or not. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove dev_link_t and client_handle_t indirectionDominik Brodowski
dev_link_t * and client_handle_t both mean struct pcmcai_device * by now. Therefore, remove all such indirections. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: embed dev_link_t into struct pcmcia_deviceDominik Brodowski
Embed dev_link_t into struct pcmcia_device(), as they basically address the same entity. The actual contents of dev_link_t will be cleaned up step by step. This patch includes a bugfix from and signed-off-by Andrew Morton. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove unneeded Vcc pseudo settingDominik Brodowski
As we do not allow setting Vcc in the pcmcia core, and Vpp1 and Vpp2 can only be set to the same value, a lot of code can be streamlined. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: default suspend and resume handlingDominik Brodowski
In all but one case, the suspend and resume functions of PCMCIA drivers contain mostly of calls to pcmcia_release_configuration() and pcmcia_request_configuration(). Therefore, move this code out of the drivers and into the core. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add pcmcia_disable_deviceDominik Brodowski
pcmcia_disable_device(struct pcmcia_device *p_dev) performs the necessary cleanups upon device or driver removal: it calls the appropriate pcmcia_release_* functions, and can replace (most) of the current drivers' _release() functions. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
