[ Upstream commit 7f09d5a6c33be66a5ca19bf9dd1c2d90c5dfcf0d ]
This patch enables enough time to ROME controller to bootup
after we bring the enable pin out of reset.
Fixes: 05ba533c5c11 ("Bluetooth: hci_qca: Add serdev support").
Signed-off-by: Balakrishna Godavarthi <bgodavar@codeaurora.org>
Reviewed-by: Rocky Liao <rjliao@codeaurora.org>
Tested-by: Rocky Liao <rjliao@codeaurora.org>
Tested-by: Claire Chang <tientzu@chromium.org>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 77f328dbc6cf42f22c691a164958a5452142a542 upstream.
Restore bdev->tx_state with clearing bit BTMTKUART_TX_WAIT_VND_EVT
when there is an error on waiting for the corresponding event.
Fixes: 7237c4c9ec92 ("Bluetooth: mediatek: Add protocol support for MediaTek serial devices")
Signed-off-by: Sean Wang <sean.wang@mediatek.com>
commit 771acc7e4a6e5dba779cb1a7fd851a164bc81033 upstream.
Badly-designed systems might have (for example) active-high wake pins
that default to high (e.g., because of external pull ups) until they
have an active firmware which starts driving it low. This can cause an
interrupt storm in the time between request_irq() and disable_irq().
We don't support shared interrupts here, so let's just pre-configure the
interrupt to avoid auto-enabling it.
Fixes: fd913ef7ce61 ("Bluetooth: btusb: Add out-of-band wakeup support")
Fixes: 5364a0b4f4be ("arm64: dts: rockchip: move QCA6174A wakeup pin into its USB node")
Signed-off-by: Brian Norris <briannorris@chromium.org>
Reviewed-by: Matthias Kaehlcke <mka@chromium.org>
hci_uart_set_proto()
commit 56897b217a1d0a91c9920cb418d6b3fe922f590a upstream.
task A: task B:
hci_uart_set_proto flush_to_ldisc
- p->open(hu) -> h5_open //alloc h5 - receive_buf
- set_bit HCI_UART_PROTO_READY - tty_port_default_receive_buf
- hci_uart_register_dev - tty_ldisc_receive_buf
- hci_uart_tty_receive
- test_bit HCI_UART_PROTO_READY
- h5_recv
- clear_bit HCI_UART_PROTO_READY while() {
- p->open(hu) -> h5_close //free h5
- h5_rx_3wire_hdr
- h5_reset() //use-after-free
It could use ioctl to set hci uart proto, but there is
a use-after-free issue when hci_uart_register_dev() fail in
hci_uart_set_proto(), see stack above, fix this by setting
HCI_UART_PROTO_READY bit only when hci_uart_register_dev()
return success.
Reported-by: syzbot+899a33dc0fa0dbaf06a6@syzkaller.appspotmail.com
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Reviewed-by: Jeremy Cline <jcline@redhat.com>
commit 32a7b4cbe93b0a0ef7e63d31ca69ce54736c4412 upstream.
The hci_dev struct hdev is referenced in work queues and timers started
by open() in some protocols. This creates a race between the
initialization function and the work or timer which can result hdev
being dereferenced while it is still null.
The syzbot report contains a reliable reproducer which causes a null
pointer dereference of hdev in hci_uart_write_work() by making the
memory allocation for hdev fail.
To fix this, ensure hdev is valid from before calling a protocol's
open() until after calling a protocol's close().
Reported-by: syzbot+257790c15bcdef6fe00c@syzkaller.appspotmail.com
Signed-off-by: Jeremy Cline <jcline@redhat.com>
commit 1dc2d785156cbdc80806c32e8d2c7c735d0b4721 upstream.
h4_recv_buf() callers store the return value to socket buffer and
recursively pass the buffer to h4_recv_buf() without protection. So,
ERR_PTR returned from h4_recv_buf() can be dereferenced, if called again
before setting the socket buffer to NULL from previous error. Check if
skb is ERR_PTR in h4_recv_buf().
Reported-by: syzbot+017a32f149406df32703@syzkaller.appspotmail.com
Signed-off-by: Myungho Jung <mhjungk@gmail.com>
commit 00df214b1faae520880cc5c57e206f21239ef741 upstream.
Realtek bluetooth may not work after reboot:
[ 12.446130] Bluetooth: hci0: RTL: rtl: unknown IC info, lmp subver a99e, hci rev 826c, hci ver 0008
This is a regression introduced by commit 26503ad25de8 ("Bluetooth:
btrtl: split the device initialization into smaller parts"). The new
logic errors out early when no matching IC info can be found, in this
case it means the firmware is already loaded.
So let's assume the firmware is already loaded when we can't find
matching IC info, like the old logic did.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=201921
Fixes: 26503ad25de8 ("Bluetooth: btrtl: split the device initialization into smaller parts")
Cc: stable@vger.kernel.org # 4.19+
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
[ Upstream commit 28ac03b9ac3f784c2f048a910c8d0a7a87483b66 ]
On some systems that actually have the bluetooth controller wired up
with an extra clock signal, it's possible the bluetooth controller
probes before the clock provider. clk_get would return a defer probe
error, which was not handled by this driver.
Handle this properly, so that these systems can work reliably.
Tested-by: Ondrej Jirman <megous@megous.com>
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
[ Upstream commit 2da711bcebe81209a9f2f90e145600eb1bae2b71 ]
Include the new USB product ID for Intel Bluetooth device 22260
family(CcPeak)
The /sys/kernel/debug/usb/devices portion for this device is:
T: Bus=01 Lev=01 Prnt=01 Port=02 Cnt=02 Dev#= 2 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=8087 ProdID=0029 Rev= 0.01
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=81(I) Atr=03(Int.) MxPS= 64 Ivl=1ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms
I: If#= 1 Alt= 6 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 63 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 63 Ivl=1ms
Signed-off-by: Raghuram Hegde <raghuram.hegde@intel.com>
Signed-off-by: Chethan T N <chethan.tumkur.narayan@intel.com>
[ Upstream commit c2d7827338618a9e73a3f892ca63d9082bb7a94d ]
When flag KASAN is set, we are seeing an following crash while removing
hci_uart module.
[ 50.589909] Unable to handle kernel paging request at virtual address 6b6b6b6b6b6b73
[ 50.597902] Mem abort info:
[ 50.600846] Exception class = DABT (current EL), IL = 32 bits
[ 50.606959] SET = 0, FnV = 0
[ 50.610142] EA = 0, S1PTW = 0
[ 50.613396] Data abort info:
[ 50.616401] ISV = 0, ISS = 0x00000004
[ 50.620373] CM = 0, WnR = 0
[ 50.623466] [006b6b6b6b6b6b73] address between user and kernel address ranges
[ 50.630818] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[ 50.671670] PC is at qca_power_shutdown+0x28/0x100 [hci_uart]
[ 50.677593] LR is at qca_close+0x74/0xb0 [hci_uart]
[ 50.775689] Process rmmod (pid: 2144, stack limit = 0xffffff801ba90000)
[ 50.782493] Call trace:
[ 50.872150] [<ffffff8000c3c81c>] qca_power_shutdown+0x28/0x100 [hci_uart]
[ 50.879138] [<ffffff8000c3c968>] qca_close+0x74/0xb0 [hci_uart]
[ 50.885238] [<ffffff8000c3a71c>] hci_uart_unregister_device+0x44/0x50 [hci_uart]
[ 50.892846] [<ffffff8000c3c9f4>] qca_serdev_remove+0x50/0x5c [hci_uart]
[ 50.899654] [<ffffff800844f630>] serdev_drv_remove+0x28/0x38
[ 50.905489] [<ffffff800850fc44>] device_release_driver_internal+0x140/0x1e4
[ 50.912653] [<ffffff800850fd94>] driver_detach+0x78/0x84
[ 50.918121] [<ffffff800850edac>] bus_remove_driver+0x80/0xa8
[ 50.923942] [<ffffff80085107dc>] driver_unregister+0x4c/0x58
[ 50.929768] [<ffffff8000c3ca8c>] qca_deinit+0x24/0x598 [hci_uart]
[ 50.936045] [<ffffff8000c3ca10>] hci_uart_exit+0x10/0x48 [hci_uart]
[ 50.942495] [<ffffff8008136630>] SyS_delete_module+0x17c/0x224
This crash is due to dereference of hdev, after freeing it.
[ Upstream commit a357ea098c9605f60d92a66a9073f56ce25726da ]
This patch adds the device ID for the AMPAK AP6335 combo module used
in the 1st generation WeTek Hub Android/LibreELEC HTPC box. The WiFI
chip identifies itself as BCM4339, while Bluetooth identifies itself
as BCM4335 (rev C0):
[ 4.864248] Bluetooth: hci0: BCM: chip id 86
[ 4.866388] Bluetooth: hci0: BCM: features 0x2f
[ 4.889317] Bluetooth: hci0: BCM4335C0
[ 4.889332] Bluetooth: hci0: BCM4335C0 (003.001.009) build 0000
[ 9.778383] Bluetooth: hci0: BCM4335C0 (003.001.009) build 0268
Output from hciconfig:
hci0: Type: Primary Bus: UART
BD Address: 43:39:00:00:1F:AC ACL MTU: 1021:8 SCO MTU: 64:1
UP RUNNING
RX bytes:7567 acl:234 sco:0 events:386 errors:0
TX bytes:53844 acl:77 sco:0 commands:304 errors:0
Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy: RSWITCH SNIFF
Link mode: SLAVE ACCEPT
Class: 0x0c0000
Service Classes: Rendering, Capturing
Device Class: Miscellaneous,
HCI Version: 4.0 (0x6) Revision: 0x10c
LMP Version: 4.0 (0x6) Subversion: 0x6109
Manufacturer: Broadcom Corporation (15)
Signed-off-by: Christian Hewitt <christianshewitt@gmail.com>
https://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Kees writes:
"Fix open-coded multiplication arguments to allocators
- Fixes several new open-coded multiplications added in the 4.19
merge window."
* tag 'alloc-args-v4.19-rc8' of https://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
treewide: Replace more open-coded allocation size multiplications
As done treewide earlier, this catches several more open-coded
allocation size calculations that were added to the kernel during the
merge window. This performs the following mechanical transformations
using Coccinelle:
kvmalloc(a * b, ...) -> kvmalloc_array(a, b, ...)
kvzalloc(a * b, ...) -> kvcalloc(a, b, ...)
devm_kzalloc(..., a * b, ...) -> devm_kcalloc(..., a, b, ...)
The percpu_rw_semaphore is not currently freed, and this leads to
a crash when the stale rcu callback is invoked. DEBUG_OBJECTS
detects this.
ODEBUG: free active (active state 1) object type: rcu_head hint: (null)
WARNING: CPU: 1 PID: 2024 at debug_print_object+0xac/0xc8
PC is at debug_print_object+0xac/0xc8
LR is at debug_print_object+0xac/0xc8
Call trace:
[<ffffff80082e2c2c>] debug_print_object+0xac/0xc8
[<ffffff80082e40b0>] debug_check_no_obj_freed+0x1e8/0x228
[<ffffff8008191254>] kfree+0x1cc/0x250
[<ffffff80083cc03c>] hci_uart_tty_close+0x54/0x108
[<ffffff800832e118>] tty_ldisc_close.isra.1+0x40/0x58
[<ffffff800832e14c>] tty_ldisc_kill+0x1c/0x40
[<ffffff800832e3dc>] tty_ldisc_release+0x94/0x170
[<ffffff8008325554>] tty_release_struct+0x1c/0x58
[<ffffff8008326400>] tty_release+0x3b0/0x490
[<ffffff80081a3fe8>] __fput+0x88/0x1d0
[<ffffff80081a418c>] ____fput+0xc/0x18
[<ffffff80080c0624>] task_work_run+0x9c/0xc0
[<ffffff80080a9e24>] do_exit+0x24c/0x8a0
[<ffffff80080aa4e0>] do_group_exit+0x38/0xa0
[<ffffff80080aa558>] __wake_up_parent+0x0/0x28
[<ffffff8008082c00>] el0_svc_naked+0x34/0x38
---[ end trace bfe08cbd89098cdf ]---
Signed-off-by: Hermes Zhang <chenhuiz@axis.com>
In case memory resources for *fw* were allocated, release them before
return.
Addresses-Coverity-ID: 1472611 ("Resource leak")
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Acked-by: Sean Wang <sean.wang@mediatek.com>
At the moment we only support ACPI enumeration for serial port attached
RTL bluetooth controllers.
This commit adds a dependency on ACPI to the BT_HCIUART_RTL configuration
option, fixing the following warning when ACPI is not enabled:
drivers/bluetooth/hci_h5.c:920:22: warning: 'rtl_vnd' defined but not used
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
We're supposed to pass the number of elements in the mtk_recv_pkts, not
the number of bytes.
Like all the other UART protocols, introduce a configuration option for
Realtek based serial devices.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
This adds a driver based on serdev driver for the MediaTek serial protocol
based on running H:4, which can enable the built-in Bluetooth device inside
MT7622 SoC.
Using HCI_VENDOR_PKT for vendor specific events does work since it has
also the value 0xff, but it is actually the packet type indicator
constant and not the event constant. So introduce HCI_EV_VENDOR and
use it.
This driver was recently updated to use serdev, so add the appropriate
dependency. Without this one can get compiler warnings like this if
CONFIG_SERIAL_DEV_BUS is not enabled:
CC [M] drivers/bluetooth/hci_h5.o
drivers/bluetooth/hci_h5.c:934:36: warning: ‘h5_serdev_driver’ defined but not used [-Wunused-variable]
static struct serdev_device_driver h5_serdev_driver = {
Add support to set voltage/current of various regulators
to power up/down Bluetooth chip wcn3990.
This patch enables the RAM and NV patch download for wcn3990.
Enable Qualcomm chips to operate at 3.2Mbps.
In function qca_setup, we set initial and operating speeds for Qualcomm
Bluetooth SoC's. This block of code is common across different
Qualcomm Bluetooth SoC's. Instead of duplicating the code, created
a wrapper function to set the speeds. So that future coming SoC's
can use these wrapper functions to set speeds.
Redefinition of qca_uart_setup will help future Qualcomm Bluetooth
SoC, to use the same function instead of duplicating the function.
Added new arguments soc_type and soc_ver to the functions.
These arguments will help to decide type of firmware files
to be loaded into Bluetooth chip.
soc_type holds the Bluetooth chip connected to APPS processor.
soc_ver holds the Bluetooth chip version.
Some of the QCA BTSoC ROME functions, are used for different versions
or different make of BTSoC's. Instead of duplicating the same functions
for new chip, update names of the functions that are used for both
chips to keep this generic and would help in future when we would have
new BT SoC. To have generic text in logs updated from ROME to QCA where
ever possible. This avoids confusion to user, when using the future
Qualcomm Bluetooth SoC's. Updated BT_DBG, BT_ERR and BT_INFO with
bt_dev_dbg, bt_dev_err and bt_dev_info where ever applicable.
Add support for the enable and device-wake GPIOs used on ACPI enumerated
RTL8723BS devices.
Implement support for the RTL8723BS chip.
Signed-off-by: Jeremy Cline <jeremy@jcline.org>
[hdegoede@redhat.com: Port from bt3wire.c to hci_h5.c, drop broken GPIO code]
Allow vendor-specific setup, open, and close functions to be defined.
[hdegoede@redhat.com: Port from bt3wire.c to hci_h5.c, drop dt support]
Add basic support for serdev enumerated devices, note sine this does
not (yet) declare any of / ACPI ids to bind to atm this is a nop.
The contents of the rtl_bt/rtlXXXX_config.bin file may be board specific
allow the caller of btrtl_initialize to specify a postfix identifying
the board, which if specified will make btrtl_initialize look for
rtl_bt/rtlXXXX_config-<postfix>.bin instead.
The Realtek RTL8723BS and RTL8723DS chipsets are SDIO wifi chips. They
also contain a Bluetooth module which is connected via UART to the host.
Realtek's userspace initialization tool (rtk_hciattach) differentiates
these two via the HCI version and revision returned by the
HCI_OP_READ_LOCAL_VERSION command.
Additionally we apply these checks only the for UART devices. Everything
else is assumed to be a "RTL8723B" which was originally supported by the
driver (communicating via USB).
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
The UART settings are embedded in the config blob. This has to be parsed
to successfully initialize the Bluetooth part of the RTL8723BS (which is
an SDIO chip, but the Bluetooth part is connected via UART).
The Realtek "rtl8723bs_bt" and "rtl8723ds_bt" userspace Bluetooth UART
initialization tools (rtk_hciattach) use the following sequence:
- send H5 sync pattern (already supported by hci_h5)
- get LMP version (already supported by btrtl)
- get ROM version (already supported by btrtl)
- load the firmware and config for the current chipset (already
supported by btrtl)
- read UART settings from the config blob (part of this patch)
- send UART settings via a vendor command to the device (which changes
the baudrate of the device and enables or disables flow control
depending on the config)
- change the baudrate and flow control settings on the host
- send the firmware and config blob to the device (already supported by
btrtl)
Sending the last firmware and config blob download command
(rtl_download_cmd) fails if the UART settings are not updated
beforehand. This is presumably because the device applies the config
right after the firmware and config blob download - which means that at
this point the host is using different UART settings than the device
(which will obviously result in non-working communication).
Consistently use rtl_dev_err and rtl_dev_info everywhere for messages.
This prepares the btrtl code so it can be used to initialize Bluetooth
modules connected via UART (these are found for example on the RTL8723BS
and RTL8723DS SDIO chips, which come with an embedded UART Bluetooth
module).
1) send H5 sync pattern (already supported by hci_h5)
2) get LMP version (already supported by btrtl)
3) get ROM version (already supported by btrtl)
4) load the firmware and config for the current chipset (already
supported by btrtl)
5) read UART settings from the config blob (currently not supported)
6) send UART settings via a vendor command to the device (which changes
7) change the baudrate and flow control settings on the host
8) send the firmware and config blob to the device (already supported by
btrtl)
The main reason why the initialization has to be split is step #7. This
requires changes to the underlying "bus", which should be kept outside
of the "generic" btrtl driver.
The idea for this split is borrowed from the btbcm driver but adjusted
where needed (the btrtl driver for example needs two blobs: firmware and
config, while the btbcm only needs one).
This also prepares the code for step #5 (parsing the config blob) by
centralizing the code which loads the firmware and config blobs and
storing the result in the new struct btrtl_device_info.
This makes the firmware names show up in modinfo.
Replace the BT_ERR functions with bt_dev_err to get a consistent error
printout that always prefixes the HCI device identifier.
Issue description: Intel 7265 shares the same RF with Wifi and BT.
In the shutdown scenario turn off BT, followed by turn WiFi off
and on causing error in RF calibration in WiFi Module
Solution: before shutdown BT ensure any RF activity to clear by
HCI reset command.
Reference Logs:
ERR kernel: [ 386.193284] iwlwifi 0000:01:00.0: Failed to run INIT calibrations: -5
ERR kernel: [ 386.193298] iwlwifi 0000:01:00.0: Failed to run INIT ucode: -5
ERR kernel: [ 386.193309] iwlwifi 0000:01:00.0: Failed to start RT ucode: -5
Signed-off-by: Amit K Bag <amit.k.bag@intel.com>
Singed-off-by: Chethan T N <chethan.tumkur.narayan@intel.com>
qca_open() and qca_set_baudrate() are never called in atomic context.
They call kzalloc() and bt_skb_alloc() with GFP_ATOMIC,
which is not necessary.
GFP_ATOMIC can be replaced with GFP_KERNEL.
This is found by a static analysis tool named DCNS written by myself.
I also manually check the kernel code before reporting it.
Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com>
inject_cmd_complete()
inject_cmd_complete() is only called by intel_dequeue(),
which is never called in atomic context.
inject_cmd_complete() calls bt_skb_alloc() with GFP_ATOMIC,
inject_cmd_complete() is only called by btusb_send_frame_intel(),
which is set to hdev->send, and hdev->send() is never
btmrvl_sdio_card_to_host()
btmrvl_sdio_card_to_host() is never called in atomic context.
It calls bt_skb_alloc() with GFP_ATOMIC, which is not necessary.
bpa10x_send_frame() is only set to hdev->send, and hdev->send() is never
bpa10x_send_frame() calls usb_alloc_urb(), kmalloc() and usb_submit_urb()
bluecard_hci_set_baud_rate()
bluecard_hci_set_baud_rate() is never called in atomic context.
bluecard_hci_set_baud_rate() is only by bluecard_hci_open(), which is
set to hdev->open, and hdev->open() is never called in atomic context.
bluecard_hci_set_baud_rate() calls bt_skb_alloc() with GFP_ATOMIC,
which is not necessary. GFP_ATOMIC can be replaced with GFP_KERNEL.
bfusb_send_frame() is only set to hdev->send, and hdev->send() is never
bfusb_send_frame() calls bt_skb_alloc() with GFP_ATOMIC, which is not
The USB completion callback does not disable interrupts while acquiring
the ->lock. We want to remove the local_irq_disable() invocation from
__usb_hcd_giveback_urb() and therefore it is required for the callback
handler to disable the interrupts while acquiring the lock.
The callback may be invoked either in IRQ or BH context depending on the
USB host controller.
Use the _irqsave variant of the locking primitives.
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Cc: linux-bluetooth@vger.kernel.org
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Without this patch we cannot turn on the Bluethooth adapter on HP
14-bs007la.
T: Bus=01 Lev=02 Prnt=03 Port=00 Cnt=01 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0bda ProdID=b009 Rev= 2.00
S: Manufacturer=Realtek
S: Product=802.11n WLAN Adapter
S: SerialNumber=00e04c000001
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=500mA
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
Signed-off-by: Jian-Hong Pan <jian-hong@endlessm.com>
This breaks the build as this header is not meant to be used in this
way.
./include/linux/unaligned/access_ok.h:8:28: error: redefinition of ‘get_unaligned_le16’
static __always_inline u16 get_unaligned_le16(const void *p)
In file included from drivers/bluetooth/hci_nokia.c:32:
./include/linux/unaligned/le_struct.h:7:19: note: previous definition of ‘get_unaligned_le16’ was here
static inline u16 get_unaligned_le16(const void *p)
Use asm/unaligned.h instead.
The Asus ROG GL702ZC laptop contains a Realtek RTL8822BE device with
an associated BT chip using a USB ID of 13d3:3526. This ID is added
to the driver.
T: Bus=01 Lev=01 Prnt=01 Port=09 Cnt=04 Dev#= 5 Spd=12 MxCh= 0
P: Vendor=13d3 ProdID=3526 Rev= 1.10
S: Product=Bluetooth Radio
Signed-off-by: Artiom Vaskov <velemas@gmail.com>
