commit 00df214b1faae520880cc5c57e206f21239ef741 upstream.
Realtek bluetooth may not work after reboot:
[ 12.446130] Bluetooth: hci0: RTL: rtl: unknown IC info, lmp subver a99e, hci rev 826c, hci ver 0008
This is a regression introduced by commit 26503ad25de8 ("Bluetooth:
btrtl: split the device initialization into smaller parts"). The new
logic errors out early when no matching IC info can be found, in this
case it means the firmware is already loaded.
So let's assume the firmware is already loaded when we can't find
matching IC info, like the old logic did.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=201921
Fixes: 26503ad25de8 ("Bluetooth: btrtl: split the device initialization into smaller parts")
Cc: stable@vger.kernel.org # 4.19+
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
[ Upstream commit 28ac03b9ac3f784c2f048a910c8d0a7a87483b66 ]
On some systems that actually have the bluetooth controller wired up
with an extra clock signal, it's possible the bluetooth controller
probes before the clock provider. clk_get would return a defer probe
error, which was not handled by this driver.
Handle this properly, so that these systems can work reliably.
Tested-by: Ondrej Jirman <megous@megous.com>
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
[ Upstream commit 2da711bcebe81209a9f2f90e145600eb1bae2b71 ]
Include the new USB product ID for Intel Bluetooth device 22260
family(CcPeak)
The /sys/kernel/debug/usb/devices portion for this device is:
T: Bus=01 Lev=01 Prnt=01 Port=02 Cnt=02 Dev#= 2 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=8087 ProdID=0029 Rev= 0.01
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=81(I) Atr=03(Int.) MxPS= 64 Ivl=1ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms
I: If#= 1 Alt= 6 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 63 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 63 Ivl=1ms
Signed-off-by: Raghuram Hegde <raghuram.hegde@intel.com>
Signed-off-by: Chethan T N <chethan.tumkur.narayan@intel.com>
Pull tty ioctl updates from Al Viro:
"This is the compat_ioctl work related to tty ioctls.
Quite a bit of dead code taken out, all tty-related stuff gone from
fs/compat_ioctl.c. A bunch of compat bugs fixed - some still remain,
but all more or less generic tty-related ioctls should be covered
(remaining issues are in things like driver-private ioctls in a pcmcia
serial card driver not getting properly handled in 32bit processes on
64bit host, etc)"
* 'work.tty-ioctl' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (53 commits)
kill TIOCSERGSTRUCT
change semantics of ldisc ->compat_ioctl()
kill TIOCSER[SG]WILD
synclink_gt(): fix compat_ioctl()
pty: fix compat ioctls
compat_ioctl - kill keyboard ioctl handling
gigaset: add ->compat_ioctl()
vt_compat_ioctl(): clean up, use compat_ptr() properly
gigaset: don't try to printk userland buffer contents
dgnc: don't bother with (empty) stub for TCXONC
dgnc: leave TIOC[GS]SOFTCAR to ldisc
remove fallback to drivers for TIOCGICOUNT
dgnc: break-related ioctls won't reach ->ioctl()
kill the rest of tty COMPAT_IOCTL() entries
dgnc: TIOCM... won't reach ->ioctl()
isdn_tty: TCSBRK{,P} won't reach ->ioctl()
kill capinc_tty_ioctl()
take compat TIOC[SG]SERIAL treatment into tty_compat_ioctl()
synclink: reduce pointless checks in ->ioctl()
complete ->[sg]et_serial() switchover
This patch will prevent error messages splashing on console.
[ 78.426697] Bluetooth: hci_core.c:hci_acldata_packet() hci0: ACL packet for unknown connection handle 3804
[ 78.436682] Bluetooth: hci_core.c:hci_acldata_packet() hci0: ACL packet for unknown connection handle 3804
[ 78.446639] Bluetooth: hci_core.c:hci_acldata_packet() hci0: ACL packet for unknown connection handle 3804
[ 78.456596] Bluetooth: hci_core.c:hci_acldata_packet() hci0: ACL packet for unknown connection handle 3804
QCA wcn3990 will send the debug logs in the form of ACL packets.
While decoding packet in qca_recv(), marking the received debug log
packet as diagnostic packet.
Signed-off-by: Harish Bandi <c-hbandi@codeaurora.org>
Signed-off-by: Balakrishna Godavarthi <bgodavar@codeaurora.org>
T: Bus=01 Lev=01 Prnt=01 Port=03 Cnt=02 Dev#= 3 Spd=12 MxCh= 0
D: Ver= 2.01 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0cf3 ProdID=535b Rev= 0.01
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
Signed-off-by: Owen Lin <olin@rivetnetworks.com>
BCM43430 devices soldered onto the PCB (non-removable)
use an UART connection for bluetooth.
But also advertise btsdio support on their 3th sdio function.
Signed-off-by: Cho, Yu-Chen <acho@suse.com>
First of all, make it return int. Returning long when native method
had never allowed that is ridiculous and inconvenient.
More importantly, change the caller; if ldisc ->compat_ioctl() is NULL
or returns -ENOIOCTLCMD, tty_compat_ioctl() will try to feed cmd and
compat_ptr(arg) to ldisc's native ->ioctl().
That simplifies ->compat_ioctl() instances quite a bit - they only
need to deal with ioctls that are neither generic tty ones (those
would get shunted off to tty_ioctl()) nor simple compat pointer ones.
Note that something like TCFLSH won't reach ->compat_ioctl(),
even if ldisc ->ioctl() does handle it - it will be recognized
earlier and passed to tty_ioctl() (and ultimately - ldisc ->ioctl()).
For many ldiscs it means that NULL ->compat_ioctl() does the
right thing. Those where it won't serve (see e.g. n_r3964.c) are
also easily dealt with - we need to handle the numeric-argument
ioctls (calling the native instance) and, if such would exist,
the ioctls that need layout conversion, etc.
All in-tree ldiscs dealt with.
Conflicts were easy to resolve using immediate context mostly,
except the cls_u32.c one where I simply too the entire HEAD
chunk.
https://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Kees writes:
"Fix open-coded multiplication arguments to allocators
- Fixes several new open-coded multiplications added in the 4.19
merge window."
* tag 'alloc-args-v4.19-rc8' of https://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
treewide: Replace more open-coded allocation size multiplications
As done treewide earlier, this catches several more open-coded
allocation size calculations that were added to the kernel during the
merge window. This performs the following mechanical transformations
using Coccinelle:
kvmalloc(a * b, ...) -> kvmalloc_array(a, b, ...)
kvzalloc(a * b, ...) -> kvcalloc(a, b, ...)
devm_kzalloc(..., a * b, ...) -> devm_kcalloc(..., a, b, ...)
When there is an error in either ath3k_load_firmware() or
ath3k_load_fwfile(), the inlined function ath3k_log_failed_loading() is
called receiving the error returned and both the block size requested to
load and the size actually loaded. These values are printed in an error
message using the macro BT_ERR.
This patch changes that function in order to print the variable "count"
as well, to show more information when a failing firmware loading
operation happens. The calls to the older function were changed to the
new one.
This event is being monitored in a laptop with an adapter which
identifies itself as 0cf3:0036, where sometimes there are errors in the
firmware loading process.
Signed-off-by: Luiz Carlos Ramos <lramos.prof@yahoo.com.br>
simple_strtol and simple_strtoul are obsolete, both place
use kstrtouint instead.
V2: fix error tmp += tn
V3: fix compile error
Signed-off-by: Ding Xiang <dingxiang@cmss.chinamobile.com>
observed sometimes data is coming with unaligned address from kernel
BT stack. If unaligned address is passed, some data in payload is
stripped when packet is loading to firmware and this results, BT
connection timeout is happening.
sh# hciconfig hci0 up
Can't init device hci0: hci0 command 0x0c03 tx timeout
Fixed this by moving the data to aligned address.
Signed-off-by: Sanjay Kumar Konduri <sanjay.konduri@redpinesignals.com>
Signed-off-by: Siva Rebbagondla <siva.rebbagondla@redpinesignals.com>
This patch adds the device ID for the AMPAK AP6335 combo module used
in the 1st generation WeTek Hub Android/LibreELEC HTPC box. The WiFI
chip identifies itself as BCM4339, while Bluetooth identifies itself
as BCM4335 (rev C0):
[ 4.864248] Bluetooth: hci0: BCM: chip id 86
[ 4.866388] Bluetooth: hci0: BCM: features 0x2f
[ 4.889317] Bluetooth: hci0: BCM4335C0
[ 4.889332] Bluetooth: hci0: BCM4335C0 (003.001.009) build 0000
[ 9.778383] Bluetooth: hci0: BCM4335C0 (003.001.009) build 0268
Output from hciconfig:
hci0: Type: Primary Bus: UART
BD Address: 43:39:00:00:1F:AC ACL MTU: 1021:8 SCO MTU: 64:1
UP RUNNING
RX bytes:7567 acl:234 sco:0 events:386 errors:0
TX bytes:53844 acl:77 sco:0 commands:304 errors:0
Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy: RSWITCH SNIFF
Link mode: SLAVE ACCEPT
Class: 0x0c0000
Service Classes: Rendering, Capturing
Device Class: Miscellaneous,
HCI Version: 4.0 (0x6) Revision: 0x10c
LMP Version: 4.0 (0x6) Subversion: 0x6109
Manufacturer: Broadcom Corporation (15)
Signed-off-by: Christian Hewitt <christianshewitt@gmail.com>
This device is included in the RTL8822CU combination wifi and BT part,
as well as the BT part of the RTL8822CE.
The necessary firmware has been submitted to the linux-firmware
project.
Signed-off-by: Alex Lu <alex_lu@realsil.com.cn>
Fixed error in space required before paranthesis
in drivers/bluetooth/hci_serdev.c
Signed-off-by: Jagdish Tirumala <t.jag587@gmail.com>
This patch enables power off support for hci down and power on support
for hci up. As wcn3990 power sources are ignited by regulators, we will
turn off them during hci down, i.e. an complete power off of wcn3990.
So while hci up, will call vendor setup which will turn on the regulators,
requests BT chip version and download the firmware.
Intel "new" controllers can do both LE scan and BR/EDR inquiry at once.
Signed-off-by: Justin TerAvest <teravest@google.com>
Don't populate the array extension_sig on the stack but instead make it
static. Makes the object code smaller by 75 bytes:
Before:
14325 4920 0 19245 4b2d drivers/bluetooth/btrtl.o
After:
14186 4984 0 19170 4ae2 drivers/bluetooth/btrtl.o
(gcc version 8.2.0 x86_64)
This will help to check the status of protocol while dequeuing an
skb packet. In some instaces we will end up kernel crash,
where proto close is called and we trying to dequeue an packet.
[ 500.142902] [<ffffff80080f9ce4>] do_raw_spin_lock+0x1c/0xe0
[ 500.148643] [<ffffff80088f1c7c>] _raw_spin_lock_irqsave+0x38/0x48
[ 500.154917] [<ffffff8008780ce8>] skb_dequeue+0x28/0x84
[ 500.160209] [<ffffff8000ad6f48>] 0xffffff8000ad6f48
[ 500.165230] [<ffffff8000ad6610>] 0xffffff8000ad6610
[ 500.170257] [<ffffff80080c7ce8>] process_one_work+0x238/0x3e4
[ 500.176174] [<ffffff80080c8330>] worker_thread+0x2bc/0x3d4
[ 500.181821] [<ffffff80080cdabc>] kthread+0x138/0x140
[ 500.186945] [<ffffff80080844e0>] ret_from_fork+0x10/0x18
Clearing HCI_UART_PROTO_READY will avoid usage of proto function pointers
before running the proto close function pointer. There is chance of kernel
crash, due to usage of non proto close function pointers after proto close.
When flag KASAN is set, we are seeing an following crash while removing
hci_uart module.
[ 50.589909] Unable to handle kernel paging request at virtual address 6b6b6b6b6b6b73
[ 50.597902] Mem abort info:
[ 50.600846] Exception class = DABT (current EL), IL = 32 bits
[ 50.606959] SET = 0, FnV = 0
[ 50.610142] EA = 0, S1PTW = 0
[ 50.613396] Data abort info:
[ 50.616401] ISV = 0, ISS = 0x00000004
[ 50.620373] CM = 0, WnR = 0
[ 50.623466] [006b6b6b6b6b6b73] address between user and kernel address ranges
[ 50.630818] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[ 50.671670] PC is at qca_power_shutdown+0x28/0x100 [hci_uart]
[ 50.677593] LR is at qca_close+0x74/0xb0 [hci_uart]
[ 50.775689] Process rmmod (pid: 2144, stack limit = 0xffffff801ba90000)
[ 50.782493] Call trace:
[ 50.872150] [<ffffff8000c3c81c>] qca_power_shutdown+0x28/0x100 [hci_uart]
[ 50.879138] [<ffffff8000c3c968>] qca_close+0x74/0xb0 [hci_uart]
[ 50.885238] [<ffffff8000c3a71c>] hci_uart_unregister_device+0x44/0x50 [hci_uart]
[ 50.892846] [<ffffff8000c3c9f4>] qca_serdev_remove+0x50/0x5c [hci_uart]
[ 50.899654] [<ffffff800844f630>] serdev_drv_remove+0x28/0x38
[ 50.905489] [<ffffff800850fc44>] device_release_driver_internal+0x140/0x1e4
[ 50.912653] [<ffffff800850fd94>] driver_detach+0x78/0x84
[ 50.918121] [<ffffff800850edac>] bus_remove_driver+0x80/0xa8
[ 50.923942] [<ffffff80085107dc>] driver_unregister+0x4c/0x58
[ 50.929768] [<ffffff8000c3ca8c>] qca_deinit+0x24/0x598 [hci_uart]
[ 50.936045] [<ffffff8000c3ca10>] hci_uart_exit+0x10/0x48 [hci_uart]
[ 50.942495] [<ffffff8008136630>] SyS_delete_module+0x17c/0x224
This crash is due to dereference of hdev, after freeing it.
Removed serdev_device_open/close functions from qca_open/close as
they are called in hci_uart_register_device() and
hci_uart_unregister_device() functions.
The percpu_rw_semaphore is not currently freed, and this leads to
a crash when the stale rcu callback is invoked. DEBUG_OBJECTS
detects this.
ODEBUG: free active (active state 1) object type: rcu_head hint: (null)
WARNING: CPU: 1 PID: 2024 at debug_print_object+0xac/0xc8
PC is at debug_print_object+0xac/0xc8
LR is at debug_print_object+0xac/0xc8
Call trace:
[<ffffff80082e2c2c>] debug_print_object+0xac/0xc8
[<ffffff80082e40b0>] debug_check_no_obj_freed+0x1e8/0x228
[<ffffff8008191254>] kfree+0x1cc/0x250
[<ffffff80083cc03c>] hci_uart_tty_close+0x54/0x108
[<ffffff800832e118>] tty_ldisc_close.isra.1+0x40/0x58
[<ffffff800832e14c>] tty_ldisc_kill+0x1c/0x40
[<ffffff800832e3dc>] tty_ldisc_release+0x94/0x170
[<ffffff8008325554>] tty_release_struct+0x1c/0x58
[<ffffff8008326400>] tty_release+0x3b0/0x490
[<ffffff80081a3fe8>] __fput+0x88/0x1d0
[<ffffff80081a418c>] ____fput+0xc/0x18
[<ffffff80080c0624>] task_work_run+0x9c/0xc0
[<ffffff80080a9e24>] do_exit+0x24c/0x8a0
[<ffffff80080aa4e0>] do_group_exit+0x38/0xa0
[<ffffff80080aa558>] __wake_up_parent+0x0/0x28
[<ffffff8008082c00>] el0_svc_naked+0x34/0x38
---[ end trace bfe08cbd89098cdf ]---
Signed-off-by: Hermes Zhang <chenhuiz@axis.com>
In case memory resources for *fw* were allocated, release them before
return.
Addresses-Coverity-ID: 1472611 ("Resource leak")
Fixes: 7237c4c9ec92 ("Bluetooth: mediatek: Add protocol support for MediaTek serial devices")
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Acked-by: Sean Wang <sean.wang@mediatek.com>
At the moment we only support ACPI enumeration for serial port attached
RTL bluetooth controllers.
This commit adds a dependency on ACPI to the BT_HCIUART_RTL configuration
option, fixing the following warning when ACPI is not enabled:
drivers/bluetooth/hci_h5.c:920:22: warning: 'rtl_vnd' defined but not used
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
We're supposed to pass the number of elements in the mtk_recv_pkts, not
the number of bytes.
Like all the other UART protocols, introduce a configuration option for
Realtek based serial devices.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
This adds a driver based on serdev driver for the MediaTek serial protocol
based on running H:4, which can enable the built-in Bluetooth device inside
MT7622 SoC.
Signed-off-by: Sean Wang <sean.wang@mediatek.com>
Using HCI_VENDOR_PKT for vendor specific events does work since it has
also the value 0xff, but it is actually the packet type indicator
constant and not the event constant. So introduce HCI_EV_VENDOR and
use it.
This driver was recently updated to use serdev, so add the appropriate
dependency. Without this one can get compiler warnings like this if
CONFIG_SERIAL_DEV_BUS is not enabled:
CC [M] drivers/bluetooth/hci_h5.o
drivers/bluetooth/hci_h5.c:934:36: warning: ‘h5_serdev_driver’ defined but not used [-Wunused-variable]
static struct serdev_device_driver h5_serdev_driver = {
Add support to set voltage/current of various regulators
to power up/down Bluetooth chip wcn3990.
Reviewed-by: Matthias Kaehlcke <mka@chromium.org>
This patch enables the RAM and NV patch download for wcn3990.
Enable Qualcomm chips to operate at 3.2Mbps.
In function qca_setup, we set initial and operating speeds for Qualcomm
Bluetooth SoC's. This block of code is common across different
Qualcomm Bluetooth SoC's. Instead of duplicating the code, created
a wrapper function to set the speeds. So that future coming SoC's
can use these wrapper functions to set speeds.
Redefinition of qca_uart_setup will help future Qualcomm Bluetooth
SoC, to use the same function instead of duplicating the function.
Added new arguments soc_type and soc_ver to the functions.
These arguments will help to decide type of firmware files
to be loaded into Bluetooth chip.
soc_type holds the Bluetooth chip connected to APPS processor.
soc_ver holds the Bluetooth chip version.
Some of the QCA BTSoC ROME functions, are used for different versions
or different make of BTSoC's. Instead of duplicating the same functions
for new chip, update names of the functions that are used for both
chips to keep this generic and would help in future when we would have
new BT SoC. To have generic text in logs updated from ROME to QCA where
ever possible. This avoids confusion to user, when using the future
Qualcomm Bluetooth SoC's. Updated BT_DBG, BT_ERR and BT_INFO with
bt_dev_dbg, bt_dev_err and bt_dev_info where ever applicable.
Add support for the enable and device-wake GPIOs used on ACPI enumerated
RTL8723BS devices.
Implement support for the RTL8723BS chip.
Signed-off-by: Jeremy Cline <jeremy@jcline.org>
[hdegoede@redhat.com: Port from bt3wire.c to hci_h5.c, drop broken GPIO code]
Allow vendor-specific setup, open, and close functions to be defined.
[hdegoede@redhat.com: Port from bt3wire.c to hci_h5.c, drop dt support]
Add basic support for serdev enumerated devices, note sine this does
not (yet) declare any of / ACPI ids to bind to atm this is a nop.
The contents of the rtl_bt/rtlXXXX_config.bin file may be board specific
allow the caller of btrtl_initialize to specify a postfix identifying
the board, which if specified will make btrtl_initialize look for
rtl_bt/rtlXXXX_config-<postfix>.bin instead.
The Realtek RTL8723BS and RTL8723DS chipsets are SDIO wifi chips. They
also contain a Bluetooth module which is connected via UART to the host.
Realtek's userspace initialization tool (rtk_hciattach) differentiates
these two via the HCI version and revision returned by the
HCI_OP_READ_LOCAL_VERSION command.
Additionally we apply these checks only the for UART devices. Everything
else is assumed to be a "RTL8723B" which was originally supported by the
driver (communicating via USB).
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
The UART settings are embedded in the config blob. This has to be parsed
to successfully initialize the Bluetooth part of the RTL8723BS (which is
an SDIO chip, but the Bluetooth part is connected via UART).
The Realtek "rtl8723bs_bt" and "rtl8723ds_bt" userspace Bluetooth UART
initialization tools (rtk_hciattach) use the following sequence:
- send H5 sync pattern (already supported by hci_h5)
- get LMP version (already supported by btrtl)
- get ROM version (already supported by btrtl)
- load the firmware and config for the current chipset (already
supported by btrtl)
- read UART settings from the config blob (part of this patch)
- send UART settings via a vendor command to the device (which changes
the baudrate of the device and enables or disables flow control
depending on the config)
- change the baudrate and flow control settings on the host
- send the firmware and config blob to the device (already supported by
btrtl)
Sending the last firmware and config blob download command
(rtl_download_cmd) fails if the UART settings are not updated
beforehand. This is presumably because the device applies the config
right after the firmware and config blob download - which means that at
this point the host is using different UART settings than the device
(which will obviously result in non-working communication).
Consistently use rtl_dev_err and rtl_dev_info everywhere for messages.
This prepares the btrtl code so it can be used to initialize Bluetooth
modules connected via UART (these are found for example on the RTL8723BS
and RTL8723DS SDIO chips, which come with an embedded UART Bluetooth
module).
1) send H5 sync pattern (already supported by hci_h5)
2) get LMP version (already supported by btrtl)
3) get ROM version (already supported by btrtl)
4) load the firmware and config for the current chipset (already
supported by btrtl)
5) read UART settings from the config blob (currently not supported)
6) send UART settings via a vendor command to the device (which changes
7) change the baudrate and flow control settings on the host
8) send the firmware and config blob to the device (already supported by
btrtl)
The main reason why the initialization has to be split is step #7. This
requires changes to the underlying "bus", which should be kept outside
of the "generic" btrtl driver.
The idea for this split is borrowed from the btbcm driver but adjusted
where needed (the btrtl driver for example needs two blobs: firmware and
config, while the btbcm only needs one).
This also prepares the code for step #5 (parsing the config blob) by
centralizing the code which loads the firmware and config blobs and
storing the result in the new struct btrtl_device_info.
This makes the firmware names show up in modinfo.
Replace the BT_ERR functions with bt_dev_err to get a consistent error
printout that always prefixes the HCI device identifier.
Issue description: Intel 7265 shares the same RF with Wifi and BT.
In the shutdown scenario turn off BT, followed by turn WiFi off
and on causing error in RF calibration in WiFi Module
Solution: before shutdown BT ensure any RF activity to clear by
HCI reset command.
Reference Logs:
ERR kernel: [ 386.193284] iwlwifi 0000:01:00.0: Failed to run INIT calibrations: -5
ERR kernel: [ 386.193298] iwlwifi 0000:01:00.0: Failed to run INIT ucode: -5
ERR kernel: [ 386.193309] iwlwifi 0000:01:00.0: Failed to start RT ucode: -5
Signed-off-by: Amit K Bag <amit.k.bag@intel.com>
Singed-off-by: Chethan T N <chethan.tumkur.narayan@intel.com>
