commit c19483cc5e56ac5e22dd19cf25ba210ab1537773 upstream.
Fortunately this is only exploitable on very unusual hardware.
[Reported a while ago but nothing happened so just fixing it]
Signed-off-by: Alan Cox <alan@linux.intel.com>
commit 0a79f67445de50ca0a8dc1d34f3cc406d89c28b2 upstream.
Device class is ff(vend.) instead of e0(wlcon).
Output from command `usb-devices`:
T: Bus=01 Lev=03 Prnt=03 Port=00 Cnt=01 Dev#= 6 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=ff(vend.) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=05ac ProdID=8215 Rev=01.82
S: Manufacturer=Apple Inc.
S: Product=Bluetooth USB Host Controller
S: SerialNumber=7C6D62936607
C: #Ifs= 4 Cfg#= 1 Atr=e0 MxPwr=0mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 3 Alt= 0 #EPs= 0 Cls=fe(app. ) Sub=01 Prot=00 Driver=(none)
Signed-off-by: Cyril Lacoux <clacoux@ifeelgood.org>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 652fd781a52ad6e24b908cd8b83d12699754f253 upstream.
The device must be marked busy as it receives data.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
Tested-by: Matthew Garrett <mjg@redhat.com>
If the waker is killed before it can replay outstanding URBs, these URBs
won't be freed or will be replayed at the next open. This patch closes
the window by explicitely discarding outstanding URBs.
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Rafael debugged a resume-time hang (with oopses in workqueue handling)
on his laptop that was due to the 'waker' workqueue entry being
disconnected and then released without the workqueue entry having been
synchronized.
Several people were involved, with Oleg Nesterov doing a debugging patch
showing what workqueue entry was corrupt etc.
This was a regression introduced by commit 7bee549e19 ("Bluetooth: Add
USB autosuspend support to btusb driver") as Rafael points out (not
actually bisected, but it became clear once the bug was found).
Tested-and-reported-by: Rafael J. Wysocki <rjw@sisk.pl>
Acked-by: Oliver Neukum <oliver@neukum.org>
Cc: Tejun Heo <tj@kernel.org>
Cc: Marcel Holtmann <marcel@holtmann.org>
pcmcia_loop_config returns 0 on success.
[wsa: added '< 0' for better readability]
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
This patch adds support of USB autosuspend to the btusb driver.
If the device doesn't support remote wakeup, simple support based on
up/down is provided. If the device supports remote wakeup, additional
support for autosuspend while the interface is up is provided. This is
done by queueing URBs in an anchor structure and waking the device up
from a work queue on sending. Reception triggers remote wakeup.
The last busy facility of the USB autosuspend code is used. To close
a race between autosuspend and transmission, a counter of ongoing
transmissions is maintained.
Add #ifdefs for CONFIG_PM as necessary.
Tested-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
The error message "Removed only %u out of %u pkts" is printed when multiple
to be acked packets are queued.
if (i++ >= pkts_to_be_removed)
break;
This will break out of the loop and increase the counter i when
i==pkts_to_be_removed and the loop ends up with i=pkts_to_be_removed+1.
The following line
if (i != pkts_to_be_removed) {
BT_ERR("Removed only %u out of %u pkts", i, pkts_to_be_removed);
will then display the false message.
The counter i must not increase on the same statement.
Signed-off-by: Wending Weng <wweng@rheinmetall.ca>
Check that the result of kmalloc is not NULL before dereferencing it.
The patch also replaces kmalloc + memset by kzalloc.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression *x;
identifier f;
constant char *C;
x = \(kmalloc\|kcalloc\|kzalloc\)(...);
... when != x == NULL
when != x != NULL
when != (x || ...)
kfree(x)
f(...,C,...,x,...)
*f(...,x,...)
*x->f
// </smpl>
The driver uses "u32" for alignment check and calculation which
works only on 32-bit system. It will crash the 64-bit system.
Replace "u32" with "unsigned long" to fix this issue.
Signed-off-by: Bing Zhao <bzhao@marvell.com>
The Marvell Bluetooth driver is full of Enter/Leave debug statements and
all of them are really pointless and only clutter the code. Seems to be
some left-overs when they ported the driver from Windows. For the Linux
driver lets remove these.
After fixing the driver to use skb_put properly for their HCI commands
only a few compiler warnings are left. Add proper casting for them.
The Marvell driver has some weird quirks on how to construct proper SKBs
with Bluetooth HCI commands. Fix it to use skb_put properly and also
use hci_opcode_pack instead of self-crafted macro.
For some reason the btmrvl_device struct has a name field that the SDIO
fills in, but then never ever uses again. That is totally pointless and
so just remove it.
Make the module description entries for the core and also the Marvell
SDIO driver match common practive inside the Bluetooth subsystem.
The Marvell Bluetooth SDIO driver has a really complicated concept on how
firmware names are assigned to specific device ids. Fix that by doing a
proper structure and assign it to the module device table.
And while at it fix various coding style weirdness that is still present
in this driver.
Signed-off-by: Marcel Holtman <marcel@holtmann.org>
The Marvell core Bluetooth driver has various weird casting and unneeded
braces in its code that makes it hard to read. Remove all of these to
make the code a little bit simpler.
The Marvell Bluetooth driver has debugfs support and they are casting
like there is no tomorrow. Remove all of them and magically the code
becomes more readable.
Both header files of the Marvell Bluetooth driver are private anyway and
if the driver happens to include them twice or they create a circular
dependency then the driver needs fixing. So just remove both pointless
ifdefs.
The Makefile entry for the Marvell driver is broken when it comes to
handling the optional DEBUG_FS correctly. That must have been the reason
why they were using select in Kconfig in the first place. Fix this and
make it really optional.
The Marvell driver selects DEBUG_FS and FW_LOADER for its core driver
and that is pointless. Don't select DEBUG_FS since it is either enabled
or not and it is not for the driver to enable it. Also FW_LOADER is
only used within the SDIO driver and so just have that one select the
FW_LOADER option.
/debug/btmrvl/config/
/debug/btmrvl/status/
See Documentation/btmrvl.txt for details.
This patch incorporates a lot of comments given by
Nicolas Pitre <nico@marvell.com>. Many thanks to Nicolas Pitre.
Signed-off-by: Rahul Tank <rahult@marvell.com>
This driver supports Marvell Bluetooth enabled devices with SDIO
interface. Currently only SD8688 chip is supported.
The helper/firmware images of SD8688 can be downloaded from this tree:
git://git.infradead.org/users/dwmw2/linux-firmware.git
This driver provides basic definitions and library functions to
support Marvell Bluetooth enabled devices, such as 88W8688 WLAN/BT
combo chip.
This patch increases the receive buffer size to HCI_MAX_FRAME_SIZE
which improves the RX throughput considerably.
Tested against BRM/Atheros/CSR USB Dongles with PAN profile using
iperf and chariot. This gave significant (around 40%) increase
in performance (increased from 0.8 to 1.5 Mb/s in Sheld room)
Signed-off-by: Vikram Kandukuri <vikram.kandukuri@atheros.com>
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Documentation/feature-removal-schedule.txt
drivers/scsi/fcoe/fcoe.c
net/core/drop_monitor.c
net/core/net-traces.c
The current build shows a warning with the DTL-1 driver:
CC [M] drivers/bluetooth/dtl1_cs.o
drivers/bluetooth/dtl1_cs.c: In function ‘dtl1_hci_send_frame’:
drivers/bluetooth/dtl1_cs.c:396: warning: ‘nsh.type’ may be used uninitialized in this function
Fix this by adding a proper error for unknown packet types.
Bluetooth shouldn't be doing this as most drivers don't support the flag,
furthermore it shouldn't be needed with newer buffering. This becomes rather
more visible as the locking fixes make the abuse of low_latency visible as
spew on the users console/dmesg.
There are several pretty much unfixable races in the old ldisc code, especially
with respect to pty behaviour and also to hangup. It's easier to rewrite the
code than simply try and patch it up.
This patch
- splits the ldisc from the tty (so we will be able to refcount it more cleanly
later)
- introduces a mutex lock for ldisc changing on an active device
- fixes the complete mess that hangup caused
- implements hopefully correct setldisc/close/hangup locking
There are still some problems around pty pairs that have always been there but
at least it is now possible to understand the code and fix further problems.
This fixes the following known bugs
- hang up can leak ldisc references
- hang up may not call open/close on ldisc in a matched way
- pty/tty pairs can deadlock during an ldisc change
- reading the ldisc proc files can cause every ldisc to be loaded
and probably a few other of the mysterious ldisc race reports.
I'm sure it also adds the odd new one.
The virtual driver implements fasync and ioctl support, but it is not used
and unneeded due to its constraints via the Bluetooth core layer. So too
just make the driver simpler, remove support for both of them.
The BKL push down added some BKL into the open callback of the virtual
driver. The driver is really simple and need no such locking and so just
remove it.
The virtual driver still uses a home grown way of waiting for events and
so just replace it with wait_event_interruptible. And while at it remove
the useless access_ok() checks.
Allowing to specify a specific misc minor number for the virtual driver
is pretty much useless and nobody is using this feature. So just remove
it and use MISC_DYNAMIC_MINOR all the time.
Remove some pointless conditionals before kfree_skb().
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Submitting the bulk URBs for ACL data transfers only on demand has no
real benefit compared to just submit them when a Bluetooth device gets
opened. So when submitting the interrupt URBs for HCI events, just
submit the bulk URBs, too.
This solves a problem with some Bluetooth USB dongles that has been
reported over the last few month. These devices require that the bulk
URBs are actually present. These devices are really broken, but there
is nothing we can do about it.
This eliminates a sparse warning that symbol 'stat' shadows an earlier one.
Signed-off-by: Andre Haupt <andre@bitwigglers.org>
With the introduction of CONFIG_DYNAMIC_PRINTK_DEBUG it is possible to
allow debugging without having to recompile the kernel. This patch turns
all BT_DBG() calls into pr_debug() to support dynamic debug messages.
As a side effect all CONFIG_BT_*_DEBUG statements are now removed and
some broken debug entries have been fixed.
This patch allows the Asus WL-BTD202 dongle to be used with a mono
headset without having to specify "options btusb force_scofix=1".
Based on a patch from Guillaume Bedot <littletux@zarb.org>
The Bluetooth subsystem was not using the HCI Reset command when doing
device initialization. The Bluetooth 1.0b specification was ambiguous
on how the device firmware was suppose to handle it. Almost every device
was triggering a transport reset at the same time. In case of USB this
ended up in disconnects from the bus.
All modern Bluetooth dongles handle this perfectly fine and a lot of
them actually require that HCI Reset is sent. If not then they are
either stuck in their HID Proxy mode or their internal structures for
inquiry and paging are not correctly setup.
To handle old and new devices smoothly the Bluetooth subsystem contains
a quirk to force the HCI Reset on initialization. However maintaining
such a quirk becomes more and more complicated. This patch turns the
logic around and lets the old devices disable the HCI Reset command.
The only device where the HCI_QUIRK_NO_RESET is still needed are the
original Digianswer devices and dongles with an early CSR firmware.
CSR reported that they fixed this for version 12 firmware. The last
official release of version 11 firmware is build ID 115. The first
version 12 candidate was build ID 117.
The old hci_usb driver has been fully replaced with the new btusb driver
and all major distributions switched to the new driver now. This removes
it since it should not be used at all anymore.
Following the pattern from hci_*.c, turn off BT_DBG messages unless
they have been requested via HCI_UART_DEBUG
Signed-off-by: Nick Pelly <npelly@google.com>
Acked-by: Brian Swetland <swetland@google.com>
Since size, addr, fcs, and tmp are unsigned, it would seem better to use
simple_strtoul that simple_strtol.
A simplified version of the semantic patch that makes this change is as
follows: (http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r2@
long e;
position p;
e = simple_strtol@p(...)
position p != r2.p;
type T;
T e;
e =
- simple_strtol@p
+ simple_strtoul
// </smpl>
This patch fixes accumulating of the header in case packet was requeued
in the error path.
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
During suspend it is important that all URBs are cancelled and then on
resume re-submitted. This gives initial suspend/resume support.
Based on initial work from Oliver Neukum <oneukum@suse.de>
With the addition of usb_unlink_anchored_urbs() it is possible to fully
control the bulk URBs from the notify callback. There is no need to
schedule work and so only do this for the ISOC URBs.
The URB submission routines need more fine grained control for the
mem_flags used by kmalloc(), usb_alloc_urb() and usb_submit_urb() to
better support different caller situations. Add a mem_flags parameter
and give the caller full control.
Inspired by Sergio Luis' similar patches, I finally found
a case which is trivial enough that spatch won't choke
on it.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
fdomain_cs: Sort out modules with duplicate description
pcmcia: Whine harder about use of EXCLUSIVE
pcmcia: IRQ_TYPE_EXCLUSIVE is long obsoleted
free sk_buff with kfree_skb, instead of kree
Signed-off-by: Sergio Luis <sergio@larces.uece.br>
