path: root/drivers/bus
2017-01-19bus: vexpress-config: fix device reference leakJohan Hovold
commit c090959b9dd8c87703e275079aa4b4a824ba3f8e upstream. Make sure to drop the reference to the parent device taken by class_find_device() after populating the bus. Fixes: 3b9334ac835b ("mfd: vexpress: Convert custom func API to regmap") Acked-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-15bus: arm-ccn: Prevent hotplug callback leakThomas Gleixner
commit 26242b330093fd14c2e94fb6cbdf0f482ab26576 upstream. In case the driver registration fails, the hotplug callback is leaked. Not fatal, because it's never invoked as there are no instances registered, but wrong nevertheless. Fixes: fdc15a36d84e ("bus/arm-ccn: Convert to hotplug statemachine") Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Suzuki K Poulose <suzuki.poulose@arm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-17bus: qcom-ebi2: depend on ARCH_QCOM or COMPILE_TESTLinus Walleij
This hides the option for people who do not want their Kconfig vision cluttered (i.e. x86) and enables compile testing apart from the supported main arch. Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2016-10-07Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Arnd Bergmann: "Driver updates for ARM SoCs, including a couple of newly added drivers: - The Qualcomm external bus interface 2 (EBI2), used in some of their mobile phone chips for connecting flash memory, LCD displays or other peripherals - Secure monitor firmware for Amlogic SoCs, and an NVMEM driver for the EFUSE based on that firmware interface. - Perf support for the AppliedMicro X-Gene performance monitor unit - Reset driver for STMicroelectronics STM32 - Reset driver for SocioNext UniPhier SoCs Aside from these, there are minor updates to SoC-specific bus, clocksource, firmware, pinctrl, reset, rtc and pmic drivers" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits) bus: qcom-ebi2: depend on HAS_IOMEM pinctrl: mvebu: orion5x: Generalise mv88f5181l support for 88f5181 clk: mvebu: Add clk support for the orion5x SoC mv88f5181 dt-bindings: EXYNOS: Add Exynos5433 PMU compatible clocksource: exynos_mct: Add the support for ARM64 perf: xgene: Add APM X-Gene SoC Performance Monitoring Unit driver Documentation: Add documentation for APM X-Gene SoC PMU DTS binding MAINTAINERS: Add entry for APM X-Gene SoC PMU driver bus: qcom: add EBI2 driver bus: qcom: add EBI2 device tree bindings rtc: rtc-pm8xxx: Add support for pm8018 rtc nvmem: amlogic: Add Amlogic Meson EFUSE driver firmware: Amlogic: Add secure monitor driver soc: qcom: smd: Reset rx tail rather than tx memory: atmel-sdramc: fix a possible NULL dereference reset: hi6220: allow to compile test driver on other architectures reset: zynq: add driver Kconfig option reset: sunxi: add driver Kconfig option reset: stm32: add driver Kconfig option reset: socfpga: add driver Kconfig option ...
2016-10-03Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull CPU hotplug updates from Thomas Gleixner: "Yet another batch of cpu hotplug core updates and conversions: - Provide core infrastructure for multi instance drivers so the drivers do not have to keep custom lists. - Convert custom lists to the new infrastructure. The block-mq custom list conversion comes through the block tree and makes the diffstat tip over to more lines removed than added. - Handle unbalanced hotplug enable/disable calls more gracefully. - Remove the obsolete CPU_STARTING/DYING notifier support. - Convert another batch of notifier users. The relayfs changes which conflicted with the conversion have been shipped to me by Andrew. The remaining lot is targeted for 4.10 so that we finally can remove the rest of the notifiers" * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits) cpufreq: Fix up conversion to hotplug state machine blk/mq: Reserve hotplug states for block multiqueue x86/apic/uv: Convert to hotplug state machine s390/mm/pfault: Convert to hotplug state machine mips/loongson/smp: Convert to hotplug state machine mips/octeon/smp: Convert to hotplug state machine fault-injection/cpu: Convert to hotplug state machine padata: Convert to hotplug state machine cpufreq: Convert to hotplug state machine ACPI/processor: Convert to hotplug state machine virtio scsi: Convert to hotplug state machine oprofile/timer: Convert to hotplug state machine block/softirq: Convert to hotplug state machine lib/irq_poll: Convert to hotplug state machine x86/microcode: Convert to hotplug state machine sh/SH-X3 SMP: Convert to hotplug state machine ia64/mca: Convert to hotplug state machine ARM/OMAP/wakeupgen: Convert to hotplug state machine ARM/shmobile: Convert to hotplug state machine arm64/FP/SIMD: Convert to hotplug state machine ...
2016-10-02bus: qcom-ebi2: depend on HAS_IOMEMLinus Walleij
After being asked to not depend on ARCH_QCOM* or similar, unsurprisingly compilation fails on UM as it has no I/O memory: drivers/built-in.o: In function `qcom_ebi2_probe': >> drivers/bus/qcom-ebi2.c:333: undefined reference to `devm_ioremap_resource' Fix this by letting the Kconfig atleast depend on HAS_IOMEM. Reported-by: kbuild test robot <fengguang.wu@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Andy Gross <andy.gross@linaro.org> Cc: linux-arm-msm@vger.kernel.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2016-09-21Merge tag 'qcom-ebi2-arm-soc' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator into next/drivers Pull "Qualcomm EBI2 bindings and bus driver" from Linus Walleij * tag 'qcom-ebi2-arm-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator: bus: qcom: add EBI2 driver bus: qcom: add EBI2 device tree bindings Acked-by: Andy Gross <andy.gross@linaro.org>
2016-09-08bus: qcom: add EBI2 driverLinus Walleij
This adds a driver for the Qualcomm External Bus Interface EBI2 found in the MSM8660 and APQ8060 SoCs (at least). This was tested with the SMSC9112 ethernet on the APQ8060 Dragonboard sitting on top of the SLOW CS2. Some of my understanding if very vague and based on guesses and extrapolations: the documentation in APQ8060 Qualcomm Application Processor User Guide 80-N7150-14 Rev. A describes select features but does not document the register bit fields. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-09-07arm-cci: pmu: Fix typo in event nameSuzuki K Poulose
For one of the CCI events exposed under sysfs, "snoop" was typo'd as "snopp". Correct this such that users see the expected event name when enumerating events via sysfs. Cc: arm@kernel.org Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2016-09-06MIPS/BUS/CDMM: Convert to hotplug state machineSebastian Andrzej Siewior
Install the callbacks via the state machine and let the core invoke the callbacks on the already online CPUs. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: James Hogan <james.hogan@imgtec.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160818125731.27256-14-bigeasy@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-09-02bus/arm-ccn: Use cpu-hp's multi instance support instead custom listSebastian Andrzej Siewior
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Suzuki K Poulose <suzuki.poulose@arm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/1471024183-12666-6-git-send-email-bigeasy@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-09-02bus/arm-cci: Use cpu-hp's multi instance support instead custom listSebastian Andrzej Siewior
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Suzuki K Poulose <suzuki.poulose@arm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Cc: rt@linutronix.de Cc: Olof Johansson <olof@lixom.net> Link: http://lkml.kernel.org/r/1471024183-12666-5-git-send-email-bigeasy@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-09-02Merge tag 'ccn/fixes-for-4.8-v2' of ↵Arnd Bergmann
git://git.linaro.org/people/pawel.moll/linux into fixes Merge "bus: ARM CCN PMU driver updates" from Paweł Moll: - Fixes and improvements for XP watchpoint and events handling - Added missing condition checks for KVM-related exclusions - Improved interrupt affinity handling - Fix for hrtimer use in polling mode - Event grouping implementation improvement * tag 'ccn/fixes-for-4.8-v2' of git://git.linaro.org/people/pawel.moll/linux: bus: arm-ccn: make event groups reliable bus: arm-ccn: fix hrtimer registration bus: arm-ccn: fix PMU interrupt flags bus: arm-ccn: Add missing event attribute exclusions for host/guest bus: arm-ccn: Correct required arguments for XP PMU events bus: arm-ccn: Fix XP watchpoint settings bitmask bus: arm-ccn: Do not attempt to configure XPs for cycle counter bus: arm-ccn: Fix PMU handling of MN
2016-08-26bus: arm-ccn: make event groups reliableMark Rutland
The CCN PMU driver leaves the counting logic always enabled, and thus events are enabled while groups are manipulated. As each event is stopped and read individually, this leads to arbitrary skew across event groups, which can be seen if counting several identical events. To avoid this, implement pmu_{enable,disable} callbacks to stop and start all counters atomically around event manipulation. As the counters are now stopped, we cannot poll the cycle counter to wait for events to drain from the bus. However, as the counters are stopped and the events will not be read regardless, we can simply allow the bus to drain naturally. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2016-08-26bus: arm-ccn: fix hrtimer registrationMark Rutland
The CCN PMU driver has a single hrtimer, used to simulate a periodic interrupt on systems where the overflow interrupt is not possible to use. The hrtimer is started when any event is started, and cancelled when any event is stopped. Thus, stopping a single event is sufficient to disable to hrtimer, and overflows (of other events) may be lost. To avoid this, this patch reworks the hrtimer start/cancel to only occur when the first event is added to a PMU, and the last event removed, making use of the existing bitmap counting active events. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2016-08-26bus: arm-ccn: fix PMU interrupt flagsMark Rutland
Currently the IRQ core is permitted to make the CCN PMU IRQ handler threaded, and will allow userspace to change the CPU affinity of the interrupt behind our back. Both of these could violate our synchronisation requirements with the core perf code, which relies upon strict CPU affinity and disabling of interrupts to guarantee mutual exclusion in some cases. As with the CPU PMU drivers, we should request the interrupt with IRQF_NOBALANCING and IRQF_NO_THREAD, to avoid these issues. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Pawel Moll <pawel.moll@arm.com> Reviewed-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2016-08-17bus: arm-ccn: Add missing event attribute exclusions for host/guestPawel Moll
CCN PMUs have no knowledge into VM-related origins of the memory traffic, therefore can't handle requests for host-only or guest-only events. Added appropriate exclusions (they should have been there from the beginning). This required changing the error code returned, as the userspace tool only re-negotiates the options (exclude_guest is true by default) only for EINVAL. Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2016-08-17bus: arm-ccn: Correct required arguments for XP PMU eventsPawel Moll
XP can provide events from two sources: watchpoints, observing traffic on device ports and PMU looking at internal buses. Unfortunately the sysfs definition of the PMU events was requiring port number (instead of bus number) and direction (the buses are unidirectional), as these fields were shared with the watchpoint event. Although it does not introduce a major problem (port can be used as bus alias and direction is simply ignored for XP PMU events), it's better to fix it now, before external tools start depending on this behaviour. Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2016-08-17bus: arm-ccn: Fix XP watchpoint settings bitmaskPawel Moll
The code setting XP watchpoint comparator and mask registers should, in order to be fully compliant with specification, zero one or more most significant bits of each field. In both L cases it means zeroing bit 63. The bitmask doing this was wrong, though, zeroing bit 60 instead. Fortunately, due to a lucky coincidence, this turned out to be fairly innocent with the existing hardware. Fixed now. Cc: stable@vger.kernel.org # 3.17+ Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2016-08-17bus: arm-ccn: Do not attempt to configure XPs for cycle counterPawel Moll
Fuzzing the CCN perf driver revealed a small but definitely dangerous mistake in the event setup code. When a cycle counter is requested, the driver should not reconfigure the events bus at all, otherwise it will corrupt (in most but the simplest cases) its configuration and may end up accessing XP array out of its bounds and corrupting control registers. Reported-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Mark Rutland <mark.rutland@arm.com> Tested-by: Mark Rutland <mark.rutland@arm.com> Cc: stable@vger.kernel.org # 3.17+ Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2016-08-17bus: arm-ccn: Fix PMU handling of MNPawel Moll
The "Miscellaneous Node" fell through cracks of node initialisation, as its ID is shared with HN-I. This patch treats MN as a special case (which it is), adding separate validation check for it and pre-defining the node ID in relevant events descriptions. That way one can simply run: # perf stat -a -e ccn/mn_ecbarrier/ <workload> Additionally, direction in the MN pseudo-events XP watchpoint definitions is corrected to be "TX" (1) as they are defined from the crosspoint point of view (thus barriers are transmitted from XP to MN). Cc: stable@vger.kernel.org # 3.17+ Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2016-08-16bus: tegra-aconnect: Use of_pm_clk_add_clk()Jon Hunter
Commit 498b5fdd40dd ("PM / clk: Add support for adding a specific clock from device-tree") add a new helper function for adding a clock from device-tree to a device. Update the Tegra ACONNECT driver to use this new function to simplify the driver. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2016-08-16bus: tegra-aconnect: Make symbol tristateThierry Reding
The driver uses symbols that weren't being exported in earlier versions of the Linux kernel and hence it had to be made bool. The exports have been merged into v4.8-rc1, so the driver can now be built as a module again. Signed-off-by: Thierry Reding <treding@nvidia.com>
2016-08-08bus: vexpress-config: add missing of_node_put after calling of_parse_phandlePeter Chen
of_node_put needs to be called when the device node which is got from of_parse_phandle has finished using. Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Acked-by: Liviu Dudau <liviu.dudau@arm.com> Signed-off-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
2016-08-01Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Olof Johansson: "Driver updates for ARM SoCs. A slew of changes this release cycle. The reset driver tree, that we merge through arm-soc for historical reasons, is also sizable this time around. Among the changes: - clps711x: Treewide changes to compatible strings, merged here for simplicity. - Qualcomm: SCM firmware driver cleanups, move to platform driver - ux500: Major cleanups, removal of old mach-specific infrastructure. - Atmel external bus memory driver - Move of brcmstb platform to the rest of bcm - PMC driver updates for tegra, various fixes and improvements - Samsung platform driver updates to support 64-bit Exynos platforms - Reset controller cleanups moving to devm_reset_controller_register() APIs - Reset controller driver for Amlogic Meson - Reset controller driver for Hisilicon hi6220 - ARM SCPI power domain support" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (100 commits) ARM: ux500: consolidate base platform files ARM: ux500: move soc_id driver to drivers/soc ARM: ux500: call ux500_setup_id later ARM: ux500: consolidate soc_device code in id.c ARM: ux500: remove cpu_is_u* helpers ARM: ux500: use CLK_OF_DECLARE() ARM: ux500: move l2x0 init to .init_irq mfd: db8500 stop passing around platform data ASoC: ab8500-codec: remove platform data based probe ARM: ux500: move ab8500_regulator_plat_data into driver ARM: ux500: remove unused regulator data soc: raspberrypi-power: add CONFIG_OF dependency firmware: scpi: add CONFIG_OF dependency video: clps711x-fb: Changing the compatibility string to match with the smallest supported chip input: clps711x-keypad: Changing the compatibility string to match with the smallest supported chip pwm: clps711x: Changing the compatibility string to match with the smallest supported chip serial: clps711x: Changing the compatibility string to match with the smallest supported chip irqchip: clps711x: Changing the compatibility string to match with the smallest supported chip clocksource: clps711x: Changing the compatibility string to match with the smallest supported chip clk: clps711x: Changing the compatibility string to match with the smallest supported chip ...
2016-08-01Merge tag 'armsoc-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "The cleanup branch keeps going down in size as we've completed a lot of the major legacy platform removals and conversions. A handful of changes this time around, some of the themes or larger sets are: - A bunch of i.MX cleanups around platform detection, init call cleanups - Misc fixes of missing/implicit includes - Removal of ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB" * tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits) ARM: mps2: fix typo ARM: s3c64xx: avoid warning about 'struct device_node' bus: mvebu-mbus: make mvebu_mbus_syscore_ops static bus: mvebu-mbus: fix __iomem on register pointers ARM: tegra: Remove board_init_funcs array ARM: iop: Fix indentation ARM: imx: remove cpu_is_mx*() ARM: imx: remove last call to cpu_is_mx5* ARM: imx: rework mx27_pm_init() call ARM: imx: deconstruct mx3_idle ARM: imx: deconstruct mxc_rnga initialization ARM: imx: remove cpu_is_mx1 check ARM: i.MX: Do not explicitly call l2x0_of_init() ARM: i.MX: system.c: Tweak prefetch settings for performance ARM: i.MX: system.c: Replace magic numbers ARM: i.MX: system.c: Remove redundant errata 752271 code ARM: i.MX: system.c: Convert goto to if statement ARM: Kirkwood: fix kirkwood_pm_init() declaration/type ARM: Kirkwood: make kirkwood_disable_mbus_error_propagation() static ARM: orion5x: make orion5x_legacy_handle_irq static ...
2016-07-30Merge tag 'devicetree-for-4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree updates from Rob Herring: - remove most of_platform_populate() calls in arch code. Now the DT core code calls it in the default case and platforms only need to call it if they have special needs - use pr_fmt on all the DT core print statements - CoreSight binding doc improvements to block name descriptions - add dt_to_config script which can parse dts files and list corresponding kernel config options - fix memory leak hit with a PowerMac DT - correct a bunch of STMicro compatible strings to use the correct vendor prefix - fix DA9052 PMIC binding doc to match what is actually used in dts files * tag 'devicetree-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (35 commits) documentation: da9052: Update regulator bindings names to match DA9052/53 DTS expectations xtensa: Partially Revert "xtensa: Remove unnecessary of_platform_populate with default match table" xtensa: Fix build error due to missing include file MIPS: ath79: Add missing include file Fix spelling errors in Documentation/devicetree ARM: dts: fix STMicroelectronics compatible strings powerpc/dts: fix STMicroelectronics compatible strings Documentation: dt: i2c: use correct STMicroelectronics vendor prefix scripts/dtc: dt_to_config - kernel config options for a devicetree of: fdt: mark unflattened tree as detached of: overlay: add resolver error prints coresight: document binding acronyms Documentation/devicetree: document cavium-pip rx-delay/tx-delay properties of: use pr_fmt prefix for all console printing of/irq: Mark initialised interrupt controllers as populated of: fix memory leak related to safe_name() Revert "of/platform: export of_default_bus_match_table" of: unittest: use of_platform_default_populate() to populate default bus memory: omap-gpmc: use of_platform_default_populate() to populate default bus bus: uniphier-system-bus: use of_platform_default_populate() to populate default bus ...
2016-07-14bus/arm-ccn: Convert to hotplug statemachineSebastian Andrzej Siewior
Install the callbacks via the state machine and let the core invoke the callbacks on the already online CPUs. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Suzuki K Poulose <suzuki.poulose@arm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160713153334.768498577@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-07-14bus/arm-cci: Convert to hotplug statemachineSebastian Andrzej Siewior
Install the callbacks via the state machine and let the core invoke the callbacks on the already online CPUs. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de> Cc: Andrzej Hajda <a.hajda@samsung.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Olof Johansson <olof@lixom.net> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Punit Agrawal <punit.agrawal@arm.com> Cc: Suzuki K Poulose <suzuki.poulose@arm.com> Cc: Suzuki K. Poulose <suzuki.poulose@arm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160713153334.679142601@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-07-11bus: mvebu-mbus: make mvebu_mbus_syscore_ops staticBen Dooks
Make mvebu_mbus_syscore_ops static as it does not get used or declared outside mvebu-mbus.c to fix the following sparse warning: linux/drivers/bus/mvebu-mbus.c:1092:20: warning: symbol 'mvebu_mbus_syscore_ops' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-07-11bus: mvebu-mbus: fix __iomem on register pointersBen Dooks
The save_cpu_target functions should take "u32 __iomem *", not a plain "u32 *" as it is passed to register access functions. Fix the following warnings by adding the annotation: drivers/bus/mvebu-mbus.c:739:17: warning: incorrect type in argument 2 (different address spaces) drivers/bus/mvebu-mbus.c:739:17: expected void volatile [noderef] <asn:2>*addr drivers/bus/mvebu-mbus.c:739:17: got unsigned int [usertype] * drivers/bus/mvebu-mbus.c:741:17: warning: incorrect type in argument 2 (different address spaces) drivers/bus/mvebu-mbus.c:741:17: expected void volatile [noderef] <asn:2>*addr drivers/bus/mvebu-mbus.c:741:17: got unsigned int [usertype] * drivers/bus/mvebu-mbus.c:742:17: warning: incorrect type in argument 2 (different address spaces) drivers/bus/mvebu-mbus.c:742:17: expected void volatile [noderef] <asn:2>*addr drivers/bus/mvebu-mbus.c:742:17: got unsigned int [usertype] * drivers/bus/mvebu-mbus.c:744:17: warning: incorrect type in argument 2 (different address spaces) drivers/bus/mvebu-mbus.c:744:17: expected void volatile [noderef] <asn:2>*addr drivers/bus/mvebu-mbus.c:744:17: got unsigned int [usertype] * drivers/bus/mvebu-mbus.c:790:17: warning: incorrect type in argument 2 (different address spaces) drivers/bus/mvebu-mbus.c:790:17: expected void volatile [noderef] <asn:2>*addr drivers/bus/mvebu-mbus.c:790:17: got unsigned int [usertype] * drivers/bus/mvebu-mbus.c:792:17: warning: incorrect type in argument 2 (different address spaces) drivers/bus/mvebu-mbus.c:792:17: expected void volatile [noderef] <asn:2>*addr drivers/bus/mvebu-mbus.c:792:17: got unsigned int [usertype] * Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-07-01bus: Add support for Tegra ACONNECTJon Hunter
Add a bus driver for the Tegra ACONNECT which is used to interface to various devices within the Audio Processing Engine (APE). The purpose of the bus driver is to register child devices that are accessed via the ACONNECT bus and through the device parent child relationship, ensure that the appropriate power domain and clocks are enabled for the ACONNECT when any of the child devices are active. Hence, the ACONNECT driver simply enables runtime-pm for the ACONNECT device so that when a child device is resumed, it will enable the power-domain and clocks associated with the ACONNECT. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2016-06-23bus: uniphier-system-bus: use of_platform_default_populate() to populate ↵Kefeng Wang
default bus Use helper of_platform_default_populate() in linux/of_platform when possible, instead of calling of_platform_populate() with the default match table. Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-06-23bus: imx-weim: use of_platform_default_populate() to populate default busKefeng Wang
Use helper of_platform_default_populate() in linux/of_platform when possible, instead of calling of_platform_populate() with the default match table. Acked-by: Shawn Guo <shawn.guo@linaro.org> Cc: Signed-off-by: Huang Shijie <b32955@freescale.com> Cc: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-05-19Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is the main pull request for MIPS for 4.7. Here's the summary of the changes: - ATH79: Support for DTB passuing using the UHI boot protocol - ATH79: Remove support for builtin DTB. - ATH79: Add zboot debug serial support. - ATH79: Add initial support for Dragino MS14 (Dragine 2), Onion Omega and DPT-Module. - ATH79: Update devicetree clock support for AR9132 and AR9331. - ATH79: Cleanup the DT code. - ATH79: Support newer SOCs in ath79_ddr_ctrl_init. - ATH79: Fix regression in PCI window initialization. - BCM47xx: Move SPROM driver to drivers/firmware/ - BCM63xx: Enable partition parser in defconfig. - BMIPS: BMIPS5000 has I cache filing from D cache - BMIPS: BMIPS: Add cpu-feature-overrides.h - BMIPS: Add Whirlwind support - BMIPS: Adjust mips-hpt-frequency for BCM7435 - BMIPS: Remove maxcpus from BCM97435SVMB DTS - BMIPS: Add missing 7038 L1 register cells to BCM7435 - BMIPS: Various tweaks to initialization code. - BMIPS: Enable partition parser in defconfig. - BMIPS: Cache tweaks. - BMIPS: Add UART, I2C and SATA devices to DT. - BMIPS: Add BCM6358 and BCM63268support - BMIPS: Add device tree example for BCM6358. - BMIPS: Improve Improve BCM6328 and BCM6368 device trees - Lantiq: Add support for device tree file from boot loader - Lantiq: Allow build with no built-in DT. - Loongson 3: Reserve 32MB for RS780E integrated GPU. - Loongson 3: Fix build error after ld-version.sh modification - Loongson 3: Move chipset ACPI code from drivers to arch. - Loongson 3: Speedup irq processing. - Loongson 3: Add basic Loongson 3A support. - Loongson 3: Set cache flush handlers to nop. - Loongson 3: Invalidate special TLBs when needed. - Loongson 3: Fast TLB refill handler. - MT7620: Fallback strategy for invalid syscfg0. - Netlogic: Fix CP0_EBASE redefinition warnings - Octeon: Initialization fixes - Octeon: Add DTS files for the D-Link DSR-1000N and EdgeRouter Lite - Octeon: Enable add Octeon-drivers in cavium_octeon_defconfig - Octeon: Correctly handle endian-swapped initramfs images. - Octeon: Support CN73xx, CN75xx and CN78xx. - Octeon: Remove dead code from cvmx-sysinfo. - Octeon: Extend number of supported CPUs past 32. - Octeon: Remove some code limiting NR_IRQS to 255. - Octeon: Simplify octeon_irq_ciu_gpio_set_type. - Octeon: Mark some functions __init in smp.c - Octeon: Octeon: Add Octeon III CN7xxx interface detection - PIC32: Add serial driver and bindings for it. - PIC32: Add PIC32 deadman timer driver and bindings. - PIC32: Add PIC32 clock timer driver and bindings. - Pistachio: Determine SoC revision during boot - Sibyte: Fix Kconfig dependencies of SIBYTE_BUS_WATCHER. - Sibyte: Strip redundant comments from bcm1480_regs.h. - Panic immediately if panic_on_oops is set. - module: fix incorrect IS_ERR_VALUE macro usage. - module: Make consistent use of pr_* - Remove no longer needed work_on_cpu() call. - Remove CONFIG_IPV6_PRIVACY from defconfigs. - Fix registers of non-crashing CPUs in dumps. - Handle MIPSisms in new vmcore_elf32_check_arch. - Select CONFIG_HANDLE_DOMAIN_IRQ and make it work. - Allow RIXI to be used on non-R2 or R6 cores. - Reserve nosave data for hibernation - Fix siginfo.h to use strict POSIX types. - Don't unwind user mode with EVA. - Fix watchpoint restoration - Ptrace watchpoints for R6. - Sync icache when it fills from dcache - I6400 I-cache fills from dcache. - Various MSA fixes. - Cleanup MIPS_CPU_* definitions. - Signal: Move generic copy_siginfo to signal.h - Signal: Fix uapi include in exported asm/siginfo.h - Timer fixes for sake of KVM. - XPA TLB refill fixes. - Treat perf counter feature - Update John Crispin's email address - Add PIC32 watchdog and bindings. - Handle R10000 LL/SC bug in set_pte() - cpufreq: Various fixes for Longson1. - R6: Fix R2 emulation. - mathemu: Cosmetic fix to ADDIUPC emulation, plenty of other small fixes - ELF: ABI and FP fixes. - Allow for relocatable kernel and use that to support KASLR. - Fix CPC_BASE_ADDR mask - Plenty fo smp-cps, CM, R6 and M6250 fixes. - Make reset_control_ops const. - Fix kernel command line handling of leading whitespace. - Cleanups to cache handling. - Add brcm, bcm6345-l1-intc device tree bindings. - Use generic clkdev.h header - Remove CLK_IS_ROOT usage. - Misc small cleanups. - CM: Fix compilation error when !MIPS_CM - oprofile: Fix a preemption issue - Detect DSP ASE v3 support:1" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (275 commits) MIPS: pic32mzda: fix getting timer clock rate. MIPS: ath79: fix regression in PCI window initialization MIPS: ath79: make ath79_ddr_ctrl_init() compatible for newer SoCs MIPS: Fix VZ probe gas errors with binutils <2.24 MIPS: perf: Fix I6400 event numbers MIPS: DEC: Export `ioasic_ssr_lock' to modules MIPS: MSA: Fix a link error on `_init_msa_upper' with older GCC MIPS: CM: Fix compilation error when !MIPS_CM MIPS: Fix genvdso error on rebuild USB: ohci-jz4740: Remove obsolete driver MIPS: JZ4740: Probe OHCI platform device via DT MIPS: JZ4740: Qi LB60: Remove support for AVT2 variant MIPS: pistachio: Determine SoC revision during boot MIPS: BMIPS: Adjust mips-hpt-frequency for BCM7435 mips: mt7620: fallback to SDRAM when syscfg0 does not have a valid value for the memory type MIPS: Prevent "restoration" of MSA context in non-MSA kernels MIPS: cevt-r4k: Dynamically calculate min_delta_ns MIPS: malta-time: Take seconds into account MIPS: malta-time: Start GIC count before syncing to RTC MIPS: Force CPUs to lose FP context during mode switches ...
2016-05-18Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Arnd Bergmann: "Driver updates for ARM SoCs, these contain various things that touch the drivers/ directory but got merged through arm-soc for practical reasons. For the most part, this is now related to power management controllers, which have not yet been abstracted into a separate subsystem, and typically require some code in drivers/soc or arch/arm to control the power domains. Another large chunk here is a rework of the NVIDIA Tegra USB3.0 support, which was surprisingly tricky and took a long time to get done. Finally, reset controller handling as always gets merged through here as well" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (97 commits) arm-ccn: Enable building as module soc/tegra: pmc: Add generic PM domain support usb: xhci: tegra: Add Tegra210 support usb: xhci: Add NVIDIA Tegra XUSB controller driver dt-bindings: usb: xhci-tegra: Add Tegra210 XUSB controller support dt-bindings: usb: Add NVIDIA Tegra XUSB controller binding PCI: tegra: Support per-lane PHYs dt-bindings: pci: tegra: Update for per-lane PHYs phy: tegra: Add Tegra210 support phy: Add Tegra XUSB pad controller support dt-bindings: phy: tegra-xusb-padctl: Add Tegra210 support dt-bindings: phy: Add NVIDIA Tegra XUSB pad controller binding phy: core: Allow children node to be overridden clk: tegra: Add interface to enable hardware control of SATA/XUSB PLLs drivers: firmware: psci: make two helper functions inline soc: renesas: rcar-sysc: Add support for R-Car H3 power areas soc: renesas: rcar-sysc: Add support for R-Car E2 power areas soc: renesas: rcar-sysc: Add support for R-Car M2-N power areas soc: renesas: rcar-sysc: Add support for R-Car M2-W power areas soc: renesas: rcar-sysc: Add support for R-Car H2 power areas ...
2016-05-13MIPS: Remove no longer needed work_on_cpu() callAnna-Maria Gleixner
Since commit 3b9d6da67e11 ("cpu/hotplug: Fix rollback during error-out in __cpu_disable()") it is ensured that callbacks of CPU_ONLINE and CPU_DOWN_PREPARE are processed on the hotplugged CPU. Due to this work_on_cpu() calls are no longer required. Replace work_on_cpu() with a direct call of mips_cdmm_bus_up() or mips_cdmm_bus_down(). Description of those functions are adapted. Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: rt@linutronix.de Patchwork: https://patchwork.linux-mips.org/patch/13197/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-05-13BUS: brcmstb_gisb: Hook to MIPS board_be_handlerFlorian Fainelli
MIPS kernels allow platforms to invoke a custom Bus Error handler, add the necessary code to do this for Broadcom SoCs where the GISB bus error handler can be used. We may get a bus error from an address decoded outside of the GISB bus space, so we need to check the validity of such a capture before printing anything. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Cc: cernekee@gmail.com Cc: arnd@arndb.de Cc: jaedon.shin@gmail.com Cc: pgynther@google.com Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/12284/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-05-09arm-ccn: Enable building as moduleSuzuki K Poulose
arm-ccn driver uses irq_set_affinity, which is not exported and hence cannot be built as a module, eventhough we have all the bits ready. This patch makes use of the exported helper irq_set_affinity_hint() instead. Also, the __free_irq expects the affinity_hint to be NULL when we free the irq. So set the affinity_hint to NULL at clean up. Now that we can build it as a module, update the Kconfig to reflect the change. Cc: Will Deacon <will.deacon@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-04-25Merge tag 'arm-soc/for-4.7/drivers' of http://github.com/Broadcom/stblinux ↵Arnd Bergmann
into next/drivers Merge "Broadcom ARM-based SoCs drivers changes" from Florian Fainelli: - Justin adds a soc_dev driver to properly report to user-space the Broadcom STB SoC family, product and revision - Florian reworks how the brcmstb_gisb driver dependency is done to enable it on Broadcom STB MIPS-based SoCs and remove a select in arch/arm/mach-bcm/Kconfig * tag 'arm-soc/for-4.7/drivers' of http://github.com/Broadcom/stblinux: bus: brcmstb_gisb: Rework dependencies soc: brcmstb: add SoC driver to brcmstb
2016-04-18bus: brcmstb_gisb: Rework dependenciesFlorian Fainelli
Do not have the machine Kconfig entry point need to select BRCMSTB_GISB_ARB, instead, just let it be default ARCH_BRCMSTB which is a better way to deal with this. While at it, also make it default BMIPS_GENERIC so the legacy MIPS-based STB platforms can benefit from the same thing. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-04-12Merge tag 'mvebu-fixes-4.6-1' of git://git.infradead.org/linux-mvebu into fixesOlof Johansson
mvebu fixes for 4.6 (part 1) - fix USB adress register for Linksys Armada 388 based boards - fix build warning in mvebu-mbus * tag 'mvebu-fixes-4.6-1' of git://git.infradead.org/linux-mvebu: ARM: mvebu: Correct unit address for linksys bus: mvebu-mbus: use %pa to print phys_addr_t Signed-off-by: Olof Johansson <olof@lixom.net>
2016-04-12bus: uniphier-system-bus: fix condition of overlap checkKunihiko Hayashi
This patch fixes condition whether the specified address ranges overlap each other. Fixes: 4b7f48d395a7 ("bus: uniphier-system-bus: add UniPhier System Bus driver") Signed-off-by: Kunihiko Hayashi <hayashi.kunihiko@socionext.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2016-03-30bus: mvebu-mbus: use %pa to print phys_addr_tArnd Bergmann
A recent change to the mbus driver added a warning printk that prints a phys_addr_t using the %x format string, which fails in case we build with 64-bit phys_addr_t: drivers/bus/mvebu-mbus.c: In function 'mvebu_mbus_get_dram_win_info': drivers/bus/mvebu-mbus.c:975:9: error: format '%x' expects argument of type 'unsigned int', but argument 2 has type 'phys_addr_t {aka long long unsigned int}' [-Werror=format=] This uses the special %pa format string instead, so we always print the correct type. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: f2900acea801 ("bus: mvebu-mbus: provide api for obtaining IO and DRAM window information") Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-03-28bus: simple-pm-bus: Use ARCH_RENESASSimon Horman
Make use of ARCH_RENESAS in place of ARCH_SHMOBILE. This is part of an ongoing process to migrate from ARCH_SHMOBILE to ARCH_RENESAS the motivation for which being that RENESAS seems to be a more appropriate name than SHMOBILE for the majority of Renesas ARM based SoCs. Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-03-21Merge tag 'arm64-perf' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm[64] perf updates from Will Deacon: "I have another mixed bag of ARM-related perf patches here. It's about 25% CPU and 75% interconnect, but with drivers/bus/ languishing without an obvious maintainer or tree, Olof and I agreed to keep all of these PMU patches together. I suspect a whole load of code from drivers/bus/arm-* can be moved under drivers/perf/, so that's on the radar for the future. Summary: - Initial support for ARMv8.1 CPU PMUs - Support for the CPU PMU in Cavium ThunderX - CPU PMU support for systems running 32-bit Linux in secure mode - Support for the system PMU in ARM CCI-550 (Cache Coherent Interconnect)" * tag 'arm64-perf' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (26 commits) drivers/perf: arm_pmu: avoid NULL dereference when not using devicetree arm64: perf: Extend ARMV8_EVTYPE_MASK to include PMCR.LC arm-cci: remove unused variable arm-cci: don't return value from void function arm-cci: make private functions static arm-cci: CoreLink CCI-550 PMU driver arm-cci500: Rearrange PMU driver for code sharing with CCI-550 PMU arm-cci: CCI-500: Work around PMU counter writes arm-cci: Provide hook for writing to PMU counters arm-cci: Add helper to enable PMU without synchornising counters arm-cci: Add routines to save/restore all counters arm-cci: Get the status of a counter arm-cci: write_counter: Remove redundant check arm-cci: Delay PMU counter writes to pmu::pmu_enable arm-cci: Refactor CCI PMU enable/disable methods arm-cci: Group writes to counter arm-cci: fix handling cpumask_any_but return value arm-cci: simplify sysfs attr handling drivers/perf: arm_pmu: implement CPU_PM notifier arm64: dts: Add Cavium ThunderX specific PMU ...
2016-03-20Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Arnd Bergmann: "Driver updates for ARM SoCs, these contain various things that touch the drivers/ directory but got merged through arm-soc for practical reasons: - Rockchip rk3368 gains power domain support - Small updates for the ARM spmi driver - The Atmel PMC driver saw a larger rework, touching both arch/arm/mach-at91 and drivers/clk/at91 - All reset controller driver changes alway get merged through arm-soc, though this time the largest change is the addition of a MIPS pistachio reset driver - One bugfix for the NXP (formerly Freescale) i.MX weim bus driver" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (43 commits) bus: imx-weim: Take the 'status' property value into account clk: at91: remove useless includes clk: at91: pmc: remove useless capacities handling clk: at91: pmc: drop at91_pmc_base usb: gadget: atmel: access the PMC using regmap ARM: at91: remove useless includes and function prototypes ARM: at91: pm: move idle functions to pm.c ARM: at91: pm: find and remap the pmc ARM: at91: pm: simply call at91_pm_init clk: at91: pmc: move pmc structures to C file clk: at91: pmc: merge at91_pmc_init in atmel_pmc_probe clk: at91: remove IRQ handling and use polling clk: at91: make use of syscon/regmap internally clk: at91: make use of syscon to share PMC registers in several drivers hwmon: (scpi) add energy meter support firmware: arm_scpi: add support for 64-bit sensor values firmware: arm_scpi: decrease Tx timeout to 20ms firmware: arm_scpi: fix send_message and sensor_get_value for big-endian reset: sti: Make reset_control_ops const reset: zynq: Make reset_control_ops const ...
2016-03-14bus: mvebu-mbus: provide api for obtaining IO and DRAM window informationMarcin Wojtas
This commit enables finding appropriate mbus window and obtaining its target id and attribute for given physical address in two separate routines, both for IO and DRAM windows. This functionality is needed for Armada XP/38x Network Controller's Buffer Manager and PnC configuration. [gregory.clement@free-electrons.com: Fix size test for mvebu_mbus_get_dram_win_info] Signed-off-by: Marcin Wojtas <mw@semihalf.com> [DRAM window information reference in LKv3.10] Signed-off-by: Evan Wang <xswang@marvell.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-03-12bus: imx-weim: Take the 'status' property value into accountFabio Estevam
Currently we have an incorrect behaviour when multiple devices are present under the weim node. For example: &weim { ... status = "okay"; sram@0,0 { ... status = "okay"; }; mram@0,0 { ... status = "disabled"; }; }; In this case only the 'sram' device should be probed and not 'mram'. However what happens currently is that the status variable is ignored, causing the 'sram' device to be disabled and 'mram' to be enabled. Change the weim_parse_dt() function to use for_each_available_child_of_node()so that the devices marked with 'status = disabled' are not probed. Cc: <stable@vger.kernel.org> Suggested-by: Wolfgang Netbal <wolfgang.netbal@sigmatek.at> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2016-03-01Merge tag 'sunxi-drivers-for-4.6' of ↵Arnd Bergmann
https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux into next/drivers Merge "Allwinner drivers changes for 4.6" from Maxime Ripard: Some minor fixes for the RSB and SRAM controller drivers * tag 'sunxi-drivers-for-4.6' of https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux: drivers: soc: sunxi: Fix mask generation for SRAM mapping drivers: sunxi-rsb: fix error output type
