path: root/drivers/bus
2018-01-10sunxi-rsb: Include OF based modalias in device ueventStefan Brüns
commit e2bf801ecd4e62222a46d1ba9e57e710171d29c1 upstream. Include the OF-based modalias in the uevent sent when registering devices on the sunxi RSB bus, so that user space has a chance to autoload the kernel module for the device. Fixes a regression caused by commit 3f241bfa60bd ("arm64: allwinner: a64: pine64: Use dcdc1 regulator for mmc0"). When the axp20x-rsb module for the AXP803 PMIC is built as a module, it is not loaded and the system ends up with an disfunctional MMC controller. Fixes: d787dcdb9c8f ("bus: sunxi-rsb: Add driver for Allwinner Reduced Serial Bus") Acked-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20arm-ccn: perf: Prevent module unload while PMU is in useSuzuki K Poulose
[ Upstream commit c7f5828bf77dcbd61d51f4736c1d5aa35663fbb4 ] When the PMU driver is built as a module, the perf expects the pmu->module to be valid, so that the driver is prevented from being unloaded while it is in use. Fix the CCN pmu driver to fill in this field. Fixes: a33b0daab73a0 ("bus: ARM CCN PMU driver") Cc: Pawel Moll <pawel.moll@arm.com> Cc: Will Deacon <will.deacon@arm.com> Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27bus: mbus: fix window size calculation for 4GB windowsJan Luebbe
commit 2bbbd96357ce76cc45ec722c00f654aa7b189112 upstream. At least the Armada XP SoC supports 4GB on a single DRAM window. Because the size register values contain the actual size - 1, the MSB is set in that case. For example, the SDRAM window's control register's value is 0xffffffe1 for 4GB (bits 31 to 24 contain the size). The MBUS driver reads back each window's size from registers and calculates the actual size as (control_reg | ~DDR_SIZE_MASK) + 1, which overflows for 32 bit values, resulting in other miscalculations further on (a bad RAM window for the CESA crypto engine calculated by mvebu_mbus_setup_cpu_target_nooverlap() in my case). This patch changes the type in 'struct mbus_dram_window' from u32 to u64, which allows us to keep using the same register calculation code in most MBUS-using drivers (which calculate ->size - 1 again). Fixes: fddddb52a6c4 ("bus: introduce an Marvell EBU MBus driver") Signed-off-by: Jan Luebbe <jlu@pengutronix.de> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19bus: vexpress-config: fix device reference leakJohan Hovold
commit c090959b9dd8c87703e275079aa4b4a824ba3f8e upstream. Make sure to drop the reference to the parent device taken by class_find_device() after populating the bus. Fixes: 3b9334ac835b ("mfd: vexpress: Convert custom func API to regmap") Acked-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24bus: arm-ccn: Fix XP watchpoint settings bitmaskPawel Moll
commit b928466b2169e061822daad48ecf55b005445547 upstream. The code setting XP watchpoint comparator and mask registers should, in order to be fully compliant with specification, zero one or more most significant bits of each field. In both L cases it means zeroing bit 63. The bitmask doing this was wrong, though, zeroing bit 60 instead. Fortunately, due to a lucky coincidence, this turned out to be fairly innocent with the existing hardware. Fixed now. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24bus: arm-ccn: Do not attempt to configure XPs for cycle counterPawel Moll
commit b7c1beb278e8e3dc664ed3df3fc786db126120a9 upstream. Fuzzing the CCN perf driver revealed a small but definitely dangerous mistake in the event setup code. When a cycle counter is requested, the driver should not reconfigure the events bus at all, otherwise it will corrupt (in most but the simplest cases) its configuration and may end up accessing XP array out of its bounds and corrupting control registers. Reported-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Mark Rutland <mark.rutland@arm.com> Tested-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24bus: arm-ccn: Fix PMU handling of MNPawel Moll
commit 4e486cba285ff06a1f28f0fc2991dde1482d1dcf upstream. The "Miscellaneous Node" fell through cracks of node initialisation, as its ID is shared with HN-I. This patch treats MN as a special case (which it is), adding separate validation check for it and pre-defining the node ID in relevant events descriptions. That way one can simply run: # perf stat -a -e ccn/mn_ecbarrier/ <workload> Additionally, direction in the MN pseudo-events XP watchpoint definitions is corrected to be "TX" (1) as they are defined from the crosspoint point of view (thus barriers are transmitted from XP to MN). Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04bus: imx-weim: Take the 'status' property value into accountFabio Estevam
commit 33b96d2c9579213cf3f36d7b29841b1e464750c4 upstream. Currently we have an incorrect behaviour when multiple devices are present under the weim node. For example: &weim { ... status = "okay"; sram@0,0 { ... status = "okay"; }; mram@0,0 { ... status = "disabled"; }; }; In this case only the 'sram' device should be probed and not 'mram'. However what happens currently is that the status variable is ignored, causing the 'sram' device to be disabled and 'mram' to be enabled. Change the weim_parse_dt() function to use for_each_available_child_of_node()so that the devices marked with 'status = disabled' are not probed. Suggested-by: Wolfgang Netbal <wolfgang.netbal@sigmatek.at> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-12-22bus: sunxi-rsb: Fix peripheral IC mapping runtime addressChen-Yu Tsai
0x4e is the runtime address normally associated with perihperal ICs. 0x45 is not a valid runtime address. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-12-22bus: sunxi-rsb: Fix primary PMIC mapping hardware addressChen-Yu Tsai
The primary PMICs use 0x3a3 as their hardware address, not 0x3e3. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-12-14Merge tag 'sunxi-fixes-for-4.4' of ↵Kevin Hilman
https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux into fixes Merge "Allwinner fixes for 4.4" from Maxime Ripard: Allwinner fixes for 4.4 Two patches, one to fix the touchscreen axis on one Allwinner board, and the other one fixing a mutex unlocking issue on one error path in the RSB driver. * tag 'sunxi-fixes-for-4.4' of https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux: bus: sunxi-rsb: unlock on error in sunxi_rsb_read() ARM: dts: sunxi: sun6i-a31s-primo81.dts: add touchscreen axis swapping property
2015-11-17bus: sunxi-rsb: unlock on error in sunxi_rsb_read()Dan Carpenter
Don't forget to unlock before returning an error code. Fixes: d787dcdb9c8f ('bus: sunxi-rsb: Add driver for Allwinner Reduced Serial Bus') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-11-12Merge branch 'x15-audio-fixes' into omap-for-v4.4/fixesTony Lindgren
2015-11-10Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Olof Johansson: "As we've enabled multiplatform kernels on ARM, and greatly done away with the contents under arch/arm/mach-*, there's still need for SoC-related drivers to go somewhere. Many of them go in through other driver trees, but we still have drivers/soc to hold some of the "doesn't fit anywhere" lowlevel code that might be shared between ARM and ARM64 (or just in general makes sense to not have under the architecture directory). This branch contains mostly such code: - Drivers for qualcomm SoCs for SMEM, SMD and SMD-RPM, used to communicate with power management blocks on these SoCs for use by clock, regulator and bus frequency drivers. - Allwinner Reduced Serial Bus driver, again used to communicate with PMICs. - Drivers for ARM's SCPI (System Control Processor). Not to be confused with PSCI (Power State Coordination Interface). SCPI is used to communicate with the assistant embedded cores doing power management, and we have yet to see how many of them will implement this for their hardware vs abstracting in other ways (or not at all like in the past). - To make confusion between SCPI and PSCI more likely, this release also includes an update of PSCI to interface version 1.0. - Rockchip support for power domains. - A driver to talk to the firmware on Raspberry Pi" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (57 commits) soc: qcom: smd-rpm: Correct size of outgoing message bus: sunxi-rsb: Add driver for Allwinner Reduced Serial Bus bus: sunxi-rsb: Add Allwinner Reduced Serial Bus (RSB) controller bindings ARM: bcm2835: add mutual inclusion protection drivers: psci: make PSCI 1.0 functions initialization version dependent dt-bindings: Correct paths in Rockchip power domains binding document soc: rockchip: power-domain: don't try to print the clock name in error case soc: qcom/smem: add HWSPINLOCK dependency clk: berlin: add cpuclk ARM: berlin: dts: add CLKID_CPU for BG2Q ARM: bcm2835: Add the Raspberry Pi firmware driver soc: qcom: smem: Move RPM message ram out of smem DT node soc: qcom: smd-rpm: Correct the active vs sleep state flagging soc: qcom: smd: delete unneeded of_node_put firmware: qcom-scm: build for correct architecture level soc: qcom: smd: Correct SMEM items for upper channels qcom-scm: add missing prototype for qcom_scm_is_available() qcom-scm: fix endianess issue in __qcom_scm_is_call_available soc: qcom: smd: Reject send of too big packets soc: qcom: smd: Handle big endian CPUs ...
2015-10-26bus: sunxi-rsb: Add driver for Allwinner Reduced Serial BusChen-Yu Tsai
Reduced Serial Bus (RSB) is an Allwinner proprietery interface used to communicate with PMICs and other peripheral ICs. RSB is a two-wire push-pull serial bus that supports 1 master device and up to 15 active slave devices. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Mark Brown <broonie@kernel.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-10-15bus: arm-ccn: Fix irq affinity setting on CPU migrationPawel Moll
When PMU context is migrating between CPUs, interrupt affinity is set as well. Only this should not happen when the CCN interrupt is not being used at all (the driver is using a hrtimer tick instead). Fixed now. Cc: <stable@vger.kernel.org> # 4.2+ Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-10-15bus: arm-ccn: Handle correctly no-more-cpus casePawel Moll
When migrating events the driver picks another cpu using cpumask_any_but() function, which returns value >= nr_cpu_ids when there is none available, not a negative value as the code assumed. Fixed now. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-10-12bus: omap-ocp2scp: Fix module aliasAxel Lin
Remove extra space between platform prefix and driver name in MODULE_ALIAS. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-09-28arm-cci500: Don't enable PMU driver by defaultSuzuki K. Poulose
Disable building CCI-500 PMU driver by default. Reported-by: Russell King <linux@arm.linux.org.uk> Cc: Punit Agrawal <punit.agrawal@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: arm@kernel.org Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-09-08Merge tag 'regmap-v4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap Pull regmap updates from Mark Brown: "This has been a busy release for regmap. By far the biggest set of changes here are those from Markus Pargmann which implement support for block transfers in smbus devices. This required quite a bit of refactoring but leaves us better able to handle odd restrictions that controllers may have and with better performance on smbus. Other new features include: - Fix interactions with lockdep for nested regmaps (eg, when a device using regmap is connected to a bus where the bus controller has a separate regmap). Lockdep's default class identification is too crude to work without help. - Support for must write bitfield operations, useful for operations which require writing a bit to trigger them from Kuniori Morimoto. - Support for delaying during register patch application from Nariman Poushin. - Support for overriding cache state via the debugfs implementation from Richard Fitzgerald" * tag 'regmap-v4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap: (25 commits) regmap: fix a NULL pointer dereference in __regmap_init regmap: Support bulk reads for devices without raw formatting regmap-i2c: Add smbus i2c block support regmap: Add raw_write/read checks for max_raw_write/read sizes regmap: regmap max_raw_read/write getter functions regmap: Introduce max_raw_read/write for regmap_bulk_read/write regmap: Add missing comments about struct regmap_bus regmap: No multi_write support if bus->write does not exist regmap: Split use_single_rw internally into use_single_read/write regmap: Fix regmap_bulk_write for bus writes regmap: regmap_raw_read return error on !bus->read regulator: core: Print at debug level on debugfs creation failure regmap: Fix regmap_can_raw_write check regmap: fix typos in regmap.c regmap: Fix integertypes for register address and value regmap: Move documentation to regmap.h regmap: Use different lockdep class for each regmap init call thermal: sti: Add parentheses around bridge->ops->regmap_init call mfd: vexpress: Add parentheses around bridge->ops->regmap_init call regmap: debugfs: Fix misuse of IS_ENABLED ...
2015-09-03MIPS: Remove "weak" from mips_cdmm_phys_base() declarationBjorn Helgaas
Weak header file declarations are error-prone because they make every definition weak, and the linker chooses one based on link order (see 10629d711ed7 ("PCI: Remove __weak annotation from pcibios_get_phb_of_node decl")). mips_cdmm_phys_base() is defined only in arch/mips/mti-malta/malta-memory.c so there's no problem with multiple definitions. But it works better to have a weak default implementation and allow a strong function to override it. Then we don't have to test whether a definition is present, and if there are ever multiple strong definitions, we get a link error instead of calling a random definition. Add a weak mips_cdmm_phys_base() definition and remove the weak annotation from the declaration in arch/mips/include/asm/cdmm.h. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: Andrew Bresticker <abrestic@chromium.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/10688/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-08-07mfd: vexpress: Add parentheses around bridge->ops->regmap_init callNicolas Boichat
regmap_init(...) is a macro since commit "regmap: Use different lockdep class for each regmap init call". That same name is used as a function pointer: prevent its expansion by adding parentheses around the function pointer. Signed-off-by: Nicolas Boichat <drinkcat@chromium.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-06-26Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Kevin Hilman: "Some of these are for drivers/soc, where we're now putting SoC-specific drivers these days. Some are for other driver subsystems where we have received acks from the appropriate maintainers. Some highlights: - simple-mfd: document DT bindings and misc updates - migrate mach-berlin to simple-mfd for clock, pinctrl and reset - memory: support for Tegra132 SoC - memory: introduce tegra EMC driver for scaling memory frequency - misc. updates for ARM CCI and CCN busses" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) drivers: soc: sunxi: Introduce SoC driver to map SRAMs arm-cci: Add aliases for PMU events arm-cci: Add CCI-500 PMU support arm-cci: Sanitise CCI400 PMU driver specific code arm-cci: Abstract handling for CCI events arm-cci: Abstract out the PMU counter details arm-cci: Cleanup PMU driver code arm-cci: Do not enable CCI-400 PMU by default firmware: qcom: scm: Add HDCP Support ARM: berlin: add an ADC node for the BG2Q ARM: berlin: remove useless chip and system ctrl compatibles clk: berlin: drop direct of_iomap of nodes reg property ARM: berlin: move BG2Q clock node ARM: berlin: move BG2CD clock node ARM: berlin: move BG2 clock node clk: berlin: prepare simple-mfd conversion pinctrl: berlin: drop SoC stub provided regmap ARM: berlin: move pinctrl to simple-mfd nodes pinctrl: berlin: prepare to use regmap provided by syscon reset: berlin: drop arch_initcall initialization ...
2015-06-26Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform support updates from Kevin Hilman: "Our SoC branch usually contains expanded support for new SoCs and other core platform code. Some highlights from this round: - sunxi: SMP support for A23 SoC - socpga: big-endian support - pxa: conversion to common clock framework - bcm: SMP support for BCM63138 - imx: support new I.MX7D SoC - zte: basic support for ZX296702 SoC" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (134 commits) ARM: zx: Add basic defconfig support for ZX296702 ARM: dts: zx: add an initial zx296702 dts and doc clk: zx: add clock support to zx296702 dt-bindings: Add #defines for ZTE ZX296702 clocks ARM: socfpga: fix build error due to secondary_startup MAINTAINERS: ARM64: EXYNOS: Extend entry for ARM64 DTS ARM: ep93xx: simone: support for SPI-based MMC/SD cards MAINTAINERS: update Shawn's email to use kernel.org one ARM: socfpga: support suspend to ram ARM: socfpga: add CPU_METHOD_OF_DECLARE for Arria 10 ARM: socfpga: use CPU_METHOD_OF_DECLARE for socfpga_cyclone5 ARM: EXYNOS: register power domain driver from core_initcall ARM: EXYNOS: use PS_HOLD based poweroff for all supported SoCs ARM: SAMSUNG: Constify platform_device_id ARM: EXYNOS: Constify irq_domain_ops ARM: EXYNOS: add coupled cpuidle support for Exynos3250 ARM: EXYNOS: add exynos_get_boot_addr() helper ARM: EXYNOS: add exynos_set_boot_addr() helper ARM: EXYNOS: make exynos_core_restart() less verbose ARM: EXYNOS: fix exynos_boot_secondary() return value on timeout ...
2015-06-23Merge tag 'pm+acpi-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI updates from Rafael Wysocki: "The rework of backlight interface selection API from Hans de Goede stands out from the number of commits and the number of affected places perspective. The cpufreq core fixes from Viresh Kumar are quite significant too as far as the number of commits goes and because they should reduce CPU online/offline overhead quite a bit in the majority of cases. From the new featues point of view, the ACPICA update (to upstream revision 20150515) adding support for new ACPI 6 material to ACPICA is the one that matters the most as some new significant features will be based on it going forward. Also included is an update of the ACPI device power management core to follow ACPI 6 (which in turn reflects the Windows' device PM implementation), a PM core extension to support wakeup interrupts in a more generic way and support for the ACPI _CCA device configuration object. The rest is mostly fixes and cleanups all over and some documentation updates, including new DT bindings for Operating Performance Points. There is one fix for a regression introduced in the 4.1 cycle, but it adds quite a number of lines of code, it wasn't really ready before Thursday and you were on vacation, so I refrained from pushing it on the last minute for 4.1. Specifics: - ACPICA update to upstream revision 20150515 including basic support for ACPI 6 features: new ACPI tables introduced by ACPI 6 (STAO, XENV, WPBT, NFIT, IORT), changes related to the other tables (DTRM, FADT, LPIT, MADT), new predefined names (_BTH, _CR3, _DSD, _LPI, _MTL, _PRR, _RDI, _RST, _TFP, _TSN), fixes and cleanups (Bob Moore, Lv Zheng). - ACPI device power management core code update to follow ACPI 6 which reflects the ACPI device power management implementation in Windows (Rafael J Wysocki). - rework of the backlight interface selection logic to reduce the number of kernel command line options and improve the handling of DMI quirks that may be involved in that and to make the code generally more straightforward (Hans de Goede). - fixes for the ACPI Embedded Controller (EC) driver related to the handling of EC transactions (Lv Zheng). - fix for a regression related to the ACPI resources management and resulting from a recent change of ACPI initialization code ordering (Rafael J Wysocki). - fix for a system initialization regression related to ACPI introduced during the 3.14 cycle and caused by running the code that switches the platform over to the ACPI mode too early in the initialization sequence (Rafael J Wysocki). - support for the ACPI _CCA device configuration object related to DMA cache coherence (Suravee Suthikulpanit). - ACPI/APEI fixes and cleanups (Jiri Kosina, Borislav Petkov). - ACPI battery driver cleanups (Luis Henriques, Mathias Krause). - ACPI processor driver cleanups (Hanjun Guo). - cleanups and documentation update related to the ACPI device properties interface based on _DSD (Rafael J Wysocki). - ACPI device power management fixes (Rafael J Wysocki). - assorted cleanups related to ACPI (Dominik Brodowski, Fabian Frederick, Lorenzo Pieralisi, Mathias Krause, Rafael J Wysocki). - fix for a long-standing issue causing General Protection Faults to be generated occasionally on return to user space after resume from ACPI-based suspend-to-RAM on 32-bit x86 (Ingo Molnar). - fix to make the suspend core code return -EBUSY consistently in all cases when system suspend is aborted due to wakeup detection (Ruchi Kandoi). - support for automated device wakeup IRQ handling allowing drivers to make their PM support more starightforward (Tony Lindgren). - new tracepoints for suspend-to-idle tracing and rework of the prepare/complete callbacks tracing in the PM core (Todd E Brandt, Rafael J Wysocki). - wakeup sources framework enhancements (Jin Qian). - new macro for noirq system PM callbacks (Grygorii Strashko). - assorted cleanups related to system suspend (Rafael J Wysocki). - cpuidle core cleanups to make the code more efficient (Rafael J Wysocki). - powernv/pseries cpuidle driver update (Shilpasri G Bhat). - cpufreq core fixes related to CPU online/offline that should reduce the overhead of these operations quite a bit, unless the CPU in question is physically going away (Viresh Kumar, Saravana Kannan). - serialization of cpufreq governor callbacks to avoid race conditions in some cases (Viresh Kumar). - intel_pstate driver fixes and cleanups (Doug Smythies, Prarit Bhargava, Joe Konno). - cpufreq driver (arm_big_little, cpufreq-dt, qoriq) updates (Sudeep Holla, Felipe Balbi, Tang Yuantian). - assorted cleanups in cpufreq drivers and core (Shailendra Verma, Fabian Frederick, Wang Long). - new Device Tree bindings for representing Operating Performance Points (Viresh Kumar). - updates for the common clock operations support code in the PM core (Rajendra Nayak, Geert Uytterhoeven). - PM domains core code update (Geert Uytterhoeven). - Intel Knights Landing support for the RAPL (Running Average Power Limit) power capping driver (Dasaratharaman Chandramouli). - fixes related to the floor frequency setting on Atom SoCs in the RAPL power capping driver (Ajay Thomas). - runtime PM framework documentation update (Ben Dooks). - cpupower tool fix (Herton R Krzesinski)" * tag 'pm+acpi-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (194 commits) cpuidle: powernv/pseries: Auto-promotion of snooze to deeper idle state x86: Load __USER_DS into DS/ES after resume PM / OPP: Add binding for 'opp-suspend' PM / OPP: Allow multiple OPP tables to be passed via DT PM / OPP: Add new bindings to address shortcomings of existing bindings ACPI: Constify ACPI device IDs in documentation ACPI / enumeration: Document the rules regarding the PRP0001 device ID ACPI / video: Make acpi_video_unregister_backlight() private acpi-video-detect: Remove old API toshiba-acpi: Port to new backlight interface selection API thinkpad-acpi: Port to new backlight interface selection API sony-laptop: Port to new backlight interface selection API samsung-laptop: Port to new backlight interface selection API msi-wmi: Port to new backlight interface selection API msi-laptop: Port to new backlight interface selection API intel-oaktrail: Port to new backlight interface selection API ideapad-laptop: Port to new backlight interface selection API fujitsu-laptop: Port to new backlight interface selection API eeepc-laptop: Port to new backlight interface selection API dell-wmi: Port to new backlight interface selection API ...
2015-06-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: "Here is the crypto update for 4.2: API: - Convert RNG interface to new style. - New AEAD interface with one SG list for AD and plain/cipher text. All external AEAD users have been converted. - New asymmetric key interface (akcipher). Algorithms: - Chacha20, Poly1305 and RFC7539 support. - New RSA implementation. - Jitter RNG. - DRBG is now seeded with both /dev/random and Jitter RNG. If kernel pool isn't ready then DRBG will be reseeded when it is. - DRBG is now the default crypto API RNG, replacing krng. - 842 compression (previously part of powerpc nx driver). Drivers: - Accelerated SHA-512 for arm64. - New Marvell CESA driver that supports DMA and more algorithms. - Updated powerpc nx 842 support. - Added support for SEC1 hardware to talitos" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (292 commits) crypto: marvell/cesa - remove COMPILE_TEST dependency crypto: algif_aead - Temporarily disable all AEAD algorithms crypto: af_alg - Forbid the use internal algorithms crypto: echainiv - Only hold RNG during initialisation crypto: seqiv - Add compatibility support without RNG crypto: eseqiv - Offer normal cipher functionality without RNG crypto: chainiv - Offer normal cipher functionality without RNG crypto: user - Add CRYPTO_MSG_DELRNG crypto: user - Move cryptouser.h to uapi crypto: rng - Do not free default RNG when it becomes unused crypto: skcipher - Allow givencrypt to be NULL crypto: sahara - propagate the error on clk_disable_unprepare() failure crypto: rsa - fix invalid select for AKCIPHER crypto: picoxcell - Update to the current clk API crypto: nx - Check for bogus firmware properties crypto: marvell/cesa - add DT bindings documentation crypto: marvell/cesa - add support for Kirkwood and Dove SoCs crypto: marvell/cesa - add support for Orion SoCs crypto: marvell/cesa - add allhwsupport module parameter crypto: marvell/cesa - add support for all armada SoCs ...
2015-06-19Merge branches 'pm-sleep' and 'pm-runtime'Rafael J. Wysocki
* pm-sleep: PM / sleep: trace_device_pm_callback coverage in dpm_prepare/complete PM / wakeup: add a dummy wakeup_source to record statistics PM / sleep: Make suspend-to-idle-specific code depend on CONFIG_SUSPEND PM / sleep: Return -EBUSY from suspend_enter() on wakeup detection PM / tick: Add tracepoints for suspend-to-idle diagnostics PM / sleep: Fix symbol name in a comment in kernel/power/main.c leds / PM: fix hibernation on arm when gpio-led used with CPU led trigger ARM: omap-device: use SET_NOIRQ_SYSTEM_SLEEP_PM_OPS bus: omap_l3_noc: add missed callbacks for suspend-to-disk PM / sleep: Add macro to define common noirq system PM callbacks PM / sleep: Refine diagnostic messages in enter_state() PM / wakeup: validate wakeup source before activating it. * pm-runtime: PM / Runtime: Update last_busy in rpm_resume PM / runtime: add note about re-calling in during device probe()
2015-06-01Merge tag 'arm-soc/for-4.2/soc-part2' of http://github.com/broadcom/stblinux ↵Arnd Bergmann
into next/soc Merge "changes for Broadcom SoCs": - Dan fixes an error path in the BCM63xx SMP code - Ray adds the relevant Kconfig selects to enable the Broadcom NAND driver on Cygnus - Kevin provides a change to the Broadcom GISB arbiter driver to make it work with MIPS-based big-endian STB SoCs (this was a long-standing change that had dependencies on code in drivers/of/*) - Gregory enables the use of GPIOLIB for brcmstb SoCs and bumps the number of GPIOs for these platforms * tag 'arm-soc/for-4.2/soc-part2' of http://github.com/broadcom/stblinux: ARM: brcmstb: Add default gpio number ARM: brcmstb: Select ARCH_WANT_OPTIONAL_GPIOLIB bus: brcmstb_gisb: Honor the "big-endian" and "native-endian" DT properties ARM: BCM: Enable NAND support for iProc SoCs ARM: BCM63xx: fix an error path in bcm63xx_pmb_power_on_cpu()
2015-06-01Merge tag 'mvebu-drivers-4.2' of git://git.infradead.org/linux-mvebu into ↵Arnd Bergmann
next/drivers Merge "mvebu drivers change for 4.2" from Gregory CLEMENT: mvebu-mbus: add mv_mbus_dram_info_nooverlap() needed for the new Marvell crypto driver * tag 'mvebu-drivers-4.2' of git://git.infradead.org/linux-mvebu: bus: mvebu-mbus: add mv_mbus_dram_info_nooverlap() Based on the earlier bug fixes branch, which contains six other patches already merged into 4.1.
2015-06-01Merge tag 'mvebu-fixes-4.1-3' of git://git.infradead.org/linux-mvebu into fixesArnd Bergmann
Merge "mvebu fixes for 4.1 (part 3)" from Gregory CLEMENT: Disable unused internal RTC for Mamba from linksys (Armada XP) And 2 commits fixing regressions on mvebu-mbus: - the first one for Kirkwood or Orion SoC - the second one for DMA when the platform have more than 4GB (only possible on Armada XP as far as I know) * tag 'mvebu-fixes-4.1-3' of git://git.infradead.org/linux-mvebu: Revert "bus: mvebu-mbus: make sure SDRAM CS for DMA don't overlap the MBus bridge window" bus: mvebu-mbus: do not set WIN_CTRL_SYNCBARRIER on non io-coherent platforms. ARM: mvebu: armada-xp-linksys-mamba: Disable internal RTC
2015-05-29arm-cci: Add aliases for PMU eventsSuzuki K. Poulose
Each CCI model have different event/source codes and formats. This patch exports this information via the sysfs, which includes the aliases for the events. The aliases are listed by 'perf list', helping the users to specify the name of the event instead of the binary config values. Each event alias must accompany the 'source' code except for the following cases : 1) CCI-400 - cycles event, doesn't relate to an interface. 2) CCI-500 - Global events to the CCI. (Fixed source code = 0xf) Each CCI model provides two sets of attributes(format and event), which are dynamically populated before registering the PMU, to allow for the appropriate information. Cc: Punit Agrawal <punit.agrawal@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com> Acked-by: Punit Agrawal <punit.agrawal@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-29arm-cci: Add CCI-500 PMU supportSuzuki K. Poulose
CCI-500 provides 8 event counters which can count any of the supported events independently. The PMU event id is a 9-bit value made of two parts. bits [8:5] - Source port 0x0-0x6 Slave Ports 0x8-0xD Master Ports 0xf Global Events to CCI 0x7,0xe Reserved bits [0:4] - Event code (specific to each type of port) The generic CCI-500 controlling interface remains the same with CCI-400. However there are some differences in the PMU event counters. - No cycle counter - Upto 8 counters(4 in CCI-400) - Each counter area is 64K(4K in CCI400) - The counter0 starts at offset 0x10000 from the base of CCI Cc: Punit Agrawal <punit.agrawal@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: devicetree@vger.kernel.org Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com> Acked-by: Punit Agrawal <punit.agrawal@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-29arm-cci: Sanitise CCI400 PMU driver specific codeSuzuki K. Poulose
Rename CCI400 specific defintions from CCI_xxx to CCI400_xxx. Introduce generic ARM_CCI_PMU to cover common code for handling the CCI PMU. Cc: Mark Rutland <mark.rutland@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Punit Agrawal <punit.agrawal@arm.com> Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com> Acked-by: Punit Agrawal <punit.agrawal@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-29arm-cci: Abstract handling for CCI eventsSuzuki K. Poulose
Given that each CCI has different set of interfaces and its associated events, it is good to abstract the validation of the event codes to make it easier to add support for a new CCI model. This patch also abstracts the mapping of a given event to a counter, as there are some special counters for certain specific events. We assume that the fixed hardware counters are always at the beginning, so that we can use cci_model->fixed_hw_events as an upper bound to given idx to check if we need to program the counter for an event. Cc: Punit Agrawal <punit.agrawal@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com> Acked-by: Punit Agrawal <punit.agrawal@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-29arm-cci: Abstract out the PMU counter detailsSuzuki K. Poulose
Adds the PMU model specific counters to the PMU model abstraction to make it easier to add a new PMU. The patch cleans up the naming convention used all over the code. e.g, CCI_PMU_MAX_HW_EVENTS => maximum number of events that can be counted at any time, which is in fact the maximum number of counters available. Change all such namings to use 'counters' instead of events. This patch also abstracts the following: 1) Size of a PMU event counter area. 2) Maximum number of programmable counters supported by the PMU model 3) Number of counters which counts fixed events (e.g, cycle counter on CCI-400). Also changes some of the static allocation of the data structures to dynamic, to accommodate the number of events supported by a PMU. Gets rid ofthe CCI_PMU_* defines for the model. All such data should be accessed via the model abstraction. Limits the number of counters to the maximum supported by the 'model'. Cc: Punit Agrawal <punit.agrawal@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com> Acked-by: Punit Agrawal <punit.agrawal@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-29arm-cci: Cleanup PMU driver codeSuzuki K. Poulose
This patch gets rid of the global struct cci_pmu variable and makes the code use the cci_pmu explicitly. Makes code a bit more robust and reader friendly. Cc: Punit Agrawal <punit.agrawal@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com> Acked-by: Punit Agrawal <punit.agrawal@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-29arm-cci: Do not enable CCI-400 PMU by defaultSuzuki K. Poulose
Do not enable CCI-400 PMU by default and fix the dependency on PERF_EVENTS than HW_PERF_EVENTS. Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Will Deacon <will.deacon@arm.com> Cc: arm@kernel.org Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-28bus: brcmstb_gisb: Honor the "big-endian" and "native-endian" DT propertiesKevin Cernekee
On chips strapped for BE, we'll need to use ioread32be/iowrite32be instead of ioread32/iowrite32. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-05-28bus: mvebu-mbus: add mv_mbus_dram_info_nooverlap()Thomas Petazzoni
This commit introduces a variant of the mv_mbus_dram_info() function called mv_mbus_dram_info_nooverlap(). Both functions are used by Marvell drivers supporting devices doing DMA, and provide them a description the DRAM ranges that they need to configure their DRAM windows. The ranges provided by the mv_mbus_dram_info() function may overlap with the I/O windows if there is a lot (>= 4 GB) of RAM installed. This is not a problem for most of the DMA masters, except for the upcoming new CESA crypto driver because it does DMA to the SRAM, which is mapped through an I/O window. For this unit, we need to have DRAM ranges that do not overlap with the I/O windows. A first implementation done in commit 1737cac69369 ("bus: mvebu-mbus: make sure SDRAM CS for DMA don't overlap the MBus bridge window"), changed the information returned by mv_mbus_dram_info() to match this requirement. However, it broke the requirement of the other DMA masters than the DRAM ranges should have power of two sizes. To solve this situation, this commit introduces a new mv_mbus_dram_info_nooverlap() function, which returns the same information as mv_mbus_dram_info(), but guaranteed to not overlap with the I/O windows. In the end, it gives us two variants of the mv_mbus_dram_info*() functions: - The normal one, mv_mbus_dram_info(), which has been around for many years. This function returns the raw DRAM ranges, which are guaranteed to use power of two sizes, but will overlap with I/O windows. This function will therefore be used by all DMA masters (SATA, XOR, Ethernet, etc.) except the CESA crypto driver. - The new 'nooverlap' variant, mv_mbus_dram_info_nooverlap(). This function returns DRAM ranges after they have been "tweaked" to make sure they don't overlap with I/O windows. By doing this tweaking, we remove the power of two size guarantee. This variant will be used by the new CESA crypto driver. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2015-05-28Revert "bus: mvebu-mbus: make sure SDRAM CS for DMA don't overlap the MBus ↵Thomas Petazzoni
bridge window" This reverts commit 1737cac69369 ("bus: mvebu-mbus: make sure SDRAM CS for DMA don't overlap the MBus bridge window"), because it breaks DMA on platforms having more than 2 GB of RAM. This commit changed the information reported to DMA masters device drivers through the mv_mbus_dram_info() function so that the returned DRAM ranges do not overlap with I/O windows. This was necessary as a preparation to support the new CESA Crypto Engine driver, which will use DMA for cryptographic operations. But since it does DMA with the SRAM which is mapped as an I/O window, having DRAM ranges overlapping with I/O windows was problematic. To solve this, the above mentioned commit changed the mvebu-mbus to adjust the DRAM ranges so that they don't overlap with the I/O windows. However, by doing this, we re-adjust the DRAM ranges in a way that makes them have a size that is no longer a power of two. While this is perfectly fine for the Crypto Engine, which supports DRAM ranges with a granularity of 64 KB, it breaks basically all other DMA masters, which expect power of two sizes for the DRAM ranges. Due to this, if the installed system memory is 4 GB, in two chip-selects of 2 GB, the second DRAM range will be reduced from 2 GB to a little bit less than 2 GB to not overlap with the I/O windows, in a way that results in a DRAM range that doesn't have a power of two size. This means that whenever you do a DMA transfer with an address located in the [ 2 GB ; 4 GB ] area, it will freeze the system. Any serious DMA activity like simply running: for i in $(seq 1 64) ; do dd if=/dev/urandom of=file$i bs=1M count=16 ; done in an ext3 partition mounted over a SATA drive will freeze the system. Since the new CESA crypto driver that uses DMA has not been merged yet, the easiest fix is to simply revert this commit. A follow-up commit will introduce a different solution for the CESA crypto driver. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Fixes: 1737cac69369 ("bus: mvebu-mbus: make sure SDRAM CS for DMA don't overlap the MBus bridge window") Cc: <stable@vger.kernel.org> # v4.0+ Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2015-05-28bus: mvebu-mbus: do not set WIN_CTRL_SYNCBARRIER on non io-coherent platforms.Nicolas Schichan
Commit a0b5cd4ac2d6 ("bus: mvebu-mbus: use automatic I/O synchronization barriers") enabled the usage of automatic I/O synchronization barriers by enabling bit WIN_CTRL_SYNCBARRIER in the control registers of MBus windows, but on non io-coherent platforms (orion5x, kirkwood and dove) the WIN_CTRL_SYNCBARRIER bit in the window control register is either reserved (all windows except 6 and 7) or enables read-only protection (windows 6 and 7). Signed-off-by: Nicolas Schichan <nschichan@freebox.fr> Reviewed-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: <stable@vger.kernel.org> # v4.0+ Fixes: a0b5cd4ac2d6 ("bus: mvebu-mbus: use automatic I/O synchronization barriers") Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2015-05-26MIPS: Fix CDMM to use native endian MMIO readsJames Hogan
The MIPS Common Device Memory Map (CDMM) is internal to the core and has native endianness. There is therefore no need to byte swap the accesses on big endian targets, so convert the CDMM bus driver to use __raw_readl() rather than readl(). Fixes: 8286ae03308c ("MIPS: Add CDMM bus support") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/9904/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-05-13bus: arm-ccn: Use hrtimer_start() againPawel Moll
hrtimer_start() will no longer defer already expired timers to the softirq in 4.2, and the __hrtimer_start_range_ns() function is getting removed, causing build errors when both the tip tree and the arm-ccn changes are merged. This changes the code back to using hrtimer_start, which will do the right thing after this branch gets merged with the timers update from tip. As pointed out after a discussion on the mailing list, the result will not be worse than the what was there before you pulled my updates, as the code was using normal hrtimer_start(). It's just when I realised that it should be pinned I looked at what x86 uncore pmu is doing and shamelessly (and probably a bit mindlessly) copied the "do not wakeup" version from there. [arnd: update commit message] Reported-by: Mark Brown <mark.brown@arm.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-12bus: omap_l3_noc: add missed callbacks for suspend-to-diskGrygorii Strashko
Add missed callbacks needed for proper supporting of suspend-to-disk by using recently introduced macro SET_NOIRQ_SYSTEM_SLEEP_PM_OPS. Signed-off-by: Grygorii Strashko <Grygorii.Strashko@linaro.org> Acked-by: Nishanth Menon <nm@ti.com> Acked-by: Santosh Shilimkar <ssantosh@kernel.org> Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Pavel Machek <pavel@ucw.cz> Reviewed-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-05-12Merge tag 'ccn/updates-for-4.2' of ↵Arnd Bergmann
git://git.linaro.org/people/pawel.moll/linux into next/drivers Pull "Set of ARM CCN PMU driver updates" from Pawel Moll: - fixed a nasty bitfield mangling bug - added new hints to the perf userspace tool - pinned events processing to a single PMU - modified events initialisation so they can be rotated now * tag 'ccn/updates-for-4.2' of git://git.linaro.org/people/pawel.moll/linux: bus: arm-ccn: Allocate event when it is being added, not initialised bus: arm-ccn: Do not group CCN events with other PMUs bus: arm-ccn: Provide required event arguments bus: arm-ccn: cpumask attribute bus: arm-ccn: Fix node->XP config conversion
2015-05-07drivers: CCI: fix used_mask init in validate_group()Mark Salter
Currently in validate_group(), there is a static initializer for fake_pmu.used_mask which is based on CPU_BITS_NONE but the used_mask array size is based on CCI_PMU_MAX_HW_EVENTS. CCI_PMU_MAX_HW_EVENTS is not based on NR_CPUS, so CPU_BITS_NONE is not correct and will cause a build failure if NR_CPUS is set high enough to make CPU_BITS_NONE larger than used_mask. Reviewed-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-05-04bus: omap_l3_noc: Fix master id address decoding for OMAP5Suman Anna
The L3 Error handling on OMAP5 for the most part is very similar to that of OMAP4, and had leveraged common data structures and register layout definitions so far. Upon closer inspection, there are a few minor differences causing an incorrect decoding and reporting of the master NIU upon an error: 1. The L3_TARG_STDERRLOG_MSTADDR.STDERRLOG_MSTADDR occupies 11 bits on OMAP5 as against 8 bits on OMAP4, with the master NIU connID encoded in the 6 MSBs of the STDERRLOG_MSTADDR field. 2. The CLK3 FlagMux component has 1 input source on OMAP4 and 3 input sources on OMAP5. The common DEBUGSS source is at a different input on each SoC. Fix the above issues by using a OMAP5-specific compatible property and using SoC-specific data where there are differences. Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-05-04bus: omap_l3_noc: Fix offset for DRA7 CLK1_HOST_CLK1_2 instanceIllia Smyrnov
The base address for DRA7 CLK1_HOST_CLK1_2 host instance is 0x44800000, so correct offset is 0x800000. DRA7 TRM rev X(fewb 2015) has updates for this information. With wrong offset these errors are not correctly cleared by the L3 IRQ handler and cause an continuous interrupt scenario and system lockup. Signed-off-by: Illia Smyrnov <illia.smyrnov@globallogic.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-05-01bus: arm-ccn: Allocate event when it is being added, not initialisedPawel Moll
To make events rotation possible, they should be allocated when event is being ->added(), not during initialisation. This patch moves the respective code. Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2015-05-01bus: arm-ccn: Do not group CCN events with other PMUsPawel Moll
Groups must not mix events from different PMUs (software events are allowed). Unfortunately the core does not ensures that, so it is necessary to validate the group at the PMU driver level. Signed-off-by: Pawel Moll <pawel.moll@arm.com>
