path: root/drivers/cdrom/viocd.c
2008-04-29drivers: use non-racy method for proc entries creation (2)Denis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Neil Brown <neilb@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-21cdrom: make unregister_cdrom() return voidAkinobu Mita
Now unregister_cdrom() always returns 0. Make it return void and update all callers that check the return value. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk> Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-06[POWERPC] iSeries: Fix section mismatch in viocdStephen Rothwell
WARNING: drivers/cdrom/viocd.o(.text+0x504): Section mismatch in reference from the function .viocd_probe() to the function .init.text:.find_capability() Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-28blk_end_request: changing viocd (take 4)Kiyoshi Ueda
This patch converts viocd to use blk_end_request interfaces. Related 'uptodate' arguments are converted to 'error'. As a result, the interface of internal function, viocd_end_request(), is changed. Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-24SG: audit of drivers that use blk_rq_map_sg()Jens Axboe
They need to properly init the sg table, or blk_rq_map_sg() will complain if CONFIG_DEBUG_SG is set. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-11[POWERPC] iSeries: Move detection of virtual cdromsStephen Rothwell
Now we will only have entries in the device tree for the actual existing devices (including their OS/400 properties). This way viocd.c gets all the information about the devices from the device tree. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-11[POWERPC] Remove iSeries_vio_devStephen Rothwell
It was only being used to carry around dma_iommu_ops and vio_iommu_table which we can use directly instead. This also means that vio_bus_device doesn't need to refer to them either. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-11[POWERPC] iSeries: Simplify viocd initialisationStephen Rothwell
We don't need to keep a lump of dma coherent memory around for the life of the module. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-03-05[PATCH] Fix soft lockup with iSeries viocd driverTony Breeds
Fix soft lockup with iSeries viocd driver, caused by eventually calling end_that_request_first() with nr_bytes 0. Some versions of hald do an SG_IO ioctl on the viocd device which becomes a request with hard_nr_sectors and hard_cur_sectors set to zero. Passing zero as the number of sectors to end_request() (which calls end_that_request_first()) causes an infinite loop when the bio is being freed. This patch makes sure that the zero is never passed. It only requires some number larger the the request size the terminate the loop. The lockup is triggered by hald, interrogating the device. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 3Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-20[POWERPC] iSeries: fix viocd initStephen Rothwell
Only initialise viocd on legacy iSeries. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-26[PATCH] devfs: Last little devfs cleanups throughout the kernel tree.Greg Kroah-Hartman
Just removes a few unused #defines and fixes some comments due to devfs now being gone. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove the gendisk devfs_name field as it's no longer neededGreg Kroah-Hartman
And remove the now unneeded number field. Also fixes all drivers that set these fields. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-19[PATCH] powerpc: update iSeries viocd and viotape device-treeStephen Rothwell
Make their device_type entries more generic and their compatible entries more specific. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-23[PATCH] kill cdrom ->dev_ioctl methodChristoph Hellwig
Since early 2.4.x all cdrom drivers implement the block_device methods themselves, so they can handle additional ioctls directly instead of going through the cdrom layer. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] remove bogus asm/bug.h includes.Al Viro
A bunch of asm/bug.h includes are both not needed (since it will get pulled anyway) and bogus (since they are done too early). Removed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-01-12[PATCH] powerpc: remove bitfields from HvLpEventStephen Rothwell
2005-11-02merge filename and modify references to iseries/vio.hKelly Daly
Signed-off-by: Kelly Daly <kelly@au.ibm.com>
2005-11-02merge filename and modify references to iseries/hv_types.hKelly Daly
2005-11-02merge filename and modify references to iseries/hv_lp_event.hKelly Daly
2005-10-24powerpc: set the driver.owner field for all vio driversStephen Rothwell
2005-10-24powerpc: don't duplicate name between vio_driver and device_driverStephen Rothwell
Just set the name field directly in the device_driver structure contained in the vio_driver struct. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2005-08-30[PATCH] Make MODULE_DEVICE_TABLE work for vio devicesStephen Rothwell
Make MODULE_DEVICE_TABLE work for vio devices. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-05-28[PATCH] ppc64 iSeries: make virtual DVD-RAMs writable againStephen Rothwell
It appears that another test has been added in the Uniform CDROM layer that must be passed before a DVD-RAM is considered writeable. This patch implements an emulation of the needed packet command for the viocd driver. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
