path: root/drivers/cdrom
2008-10-09block: introduce struct rq_map_data to use reserved pagesFUJITA Tomonori
This patch introduces struct rq_map_data to enable bio_copy_use_iov() use reserved pages. Currently, bio_copy_user_iov allocates bounce pages but drivers/scsi/sg.c wants to allocate pages by itself and use them. struct rq_map_data can be used to pass allocated pages to bio_copy_user_iov. The current users of bio_copy_user_iov simply passes NULL (they don't want to use pre-allocated pages). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Douglas Gilbert <dougg@torque.net> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: add gfp_mask argument to blk_rq_map_user and blk_rq_map_user_iovFUJITA Tomonori
Currently, blk_rq_map_user and blk_rq_map_user_iov always do GFP_KERNEL allocation. This adds gfp_mask argument to blk_rq_map_user and blk_rq_map_user_iov so sg can use it (sg always does GFP_ATOMIC allocation). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Douglas Gilbert <dougg@torque.net> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-18cdrom: handle TOCAlexander Inyukhin
This patch should fix TOC handling for cdroms that can not play audio. It extends commit af744e3294d09d706c4eae26cffaaa68a8d40337 ("cdrom: don't check CDC_PLAY_AUDIO in cdrom_count_tracks()") with a safety check and non-audio ioctls support. Since CDC_PLAY_AUDIO flag was used not only to check ability to play audio but also to ensure that audio_ioctl was not NULL, all TOC-related operations had to use it. As far as I understand, now audio_ioctl is never NULL, so a sanity check during device registration should be sufficient. It was tested on Optiarc AD7203A device, that has no ability to play audio. Cc: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [bart: remove now unneeded ->audio_ioctl check (noticed by Borislav)] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-18gdrom: add dummy audio_ioctl handlerBorislav Petkov
Make sure audio_ioctl is always defined even if being a dummy function since the cdrom_ioctl interface assumes its existence and we don't want to BUG on null ptr on some ioctls like, e.g. CDROMREADTOCENTRY, CDROMREADTOCHDR etc. when we fix CDC_PLAY_AUDIO checking in cdrom.c. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-18viocd: add dummy audio ioctl handlerBorislav Petkov
Make sure audio_ioctl is always defined even if being a dummy function since the cdrom_ioctl interface assumes its existence and we don't want to BUG on null ptr on some ioctls like, e.g. CDROMREADTOCENTRY, CDROMREADTOCHDR etc. when we fix CDC_PLAY_AUDIO checking in cdrom.c. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-05cdrom: don't check CDC_PLAY_AUDIO in cdrom_count_tracks()Tejun Heo
According to MMC-3 (or any later versions) READ TOCs are mandatory commands and have nothing to do with CDC_PLAY_AUDIO. I have no idea why the check was put there in the first place but it now only breaks automatic actions on certain drives. Note that this test was only effective when ide-cdrom was being used as sr didn't mask CDC_PLAY_AUDIO according to the capabilities. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-29sh: More header path fixups for mach dir refactoring.Paul Mundt
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-04cdrom: revert commit 22a9189 (cdrom: use kmalloced buffers instead of ↵FUJITA Tomonori
buffers on stack) The commit 22a9189fd073db3d03a4cf8b8c098aa207602de1 (cdrom: use kmalloced buffers instead of buffers on stack) is introduced to use kmalloced buffers for packet commands to avoid stack corruption on non coherent platforms. SCSI cdrom uses blk_rq_map_kern, which properly avoids DMA on the stack by using the bounce buffers. IDE cdrom also has the mechnism to avoids DMA on the stack. So we don't need this extra complexitiy in cdrom.c, such as allocating just 8 bytes. The lower layers can handle it. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-23[POWERPC] iSeries: Remove unused mail addressStephen Rothwell
I don't use my IBM email address normally and people can find me in CREDITS. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-29Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: Skip I/O merges when disabled block: add large command support block: replace sizeof(rq->cmd) with BLK_MAX_CDB ide: use blk_rq_init() to initialize the request block: use blk_rq_init() to initialize the request block: rename and export rq_init() block: no need to initialize rq->cmd with blk_get_request block: no need to initialize rq->cmd in prepare_flush_fn hook block/blk-barrier.c:blk_ordered_cur_seq() mustn't be inline block/elevator.c:elv_rq_merge_ok() mustn't be inline block: make queue flags non-atomic block: add dma alignment and padding support to blk_rq_map_kern unexport blk_max_pfn ps3disk: Remove superfluous cast block: make rq_init() do a full memset() relay: fix splice problem
2008-04-29drivers: use non-racy method for proc entries creation (2)Denis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Neil Brown <neilb@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29block: no need to initialize rq->cmd with blk_get_requestFUJITA Tomonori
blk_get_request initializes rq->cmd (rq_init does) so the users don't need to do that. The purpose of this patch is to remove sizeof(rq->cmd) and &rq->cmd, as a preparation for large command support, which changes rq->cmd from the static array to a pointer. sizeof(rq->cmd) will not make sense and &rq->cmd won't work. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Alasdair G Kergon <agk@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-21cdrom: use kmalloced buffers instead of buffers on stackThomas Bogendoerfer
If cdrom commands are issued to a scsi drive in most cases the buffer will be filled via dma. This leads to bad stack corruption on non coherent platforms, because the buffers are neither cache line aligned nor is the size a multiple of the cache line size. Using kmalloced buffers avoids this. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-21cdrom: make unregister_cdrom() return voidAkinobu Mita
Now unregister_cdrom() always returns 0. Make it return void and update all callers that check the return value. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk> Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-21cdrom: use list_head for cdrom_device_info listAkinobu Mita
Use list_head for cdrom_device_info list instead of opencoded singly list handling. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-21cdrom: protect cdrom_device_info list by mutexAkinobu Mita
This patch protects the list of cdrom_device_info by cdrom_mutex when the file in /proc/sys/dev/cdrom/ is written. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-21cdrom: cleanup hardcoded error-codeAkinobu Mita
This patch eliminates hardcoded return value of register_cdrom(). It also changes the return value to -EINVAL. It is more appropriate than -2 (-ENOENT) because it is only happen invalid usage of register_cdrom() by broken cdrom driver. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-21cdrom: remove ifdef CONFIG_SYSCTLAkinobu Mita
This patch removes #ifdef for CONFIG_SYSCTL by defining empty cdrom_sysctl_register and cdrom_sysctl_unregister when CONFIG_SYSCTL is not defined. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04make cdrom.c:check_for_audio_disc() staticAdrian Bunk
This patch makes the needlessly global check_for_audio_disc() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-07Merge branch 'for-2.6.25' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'for-2.6.25' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (69 commits) [POWERPC] Add SPE registers to core dumps [POWERPC] Use regset code for compat PTRACE_*REGS* calls [POWERPC] Use generic compat_sys_ptrace [POWERPC] Use generic compat_ptrace_request [POWERPC] Use generic ptrace peekdata/pokedata [POWERPC] Use regset code for PTRACE_*REGS* requests [POWERPC] Switch to generic compat_binfmt_elf code [POWERPC] Switch to using user_regset-based core dumps [POWERPC] Add user_regset compat support [POWERPC] Add user_regset_view definitions [POWERPC] Use user_regset accessors for GPRs [POWERPC] ptrace accessors for special regs MSR and TRAP [POWERPC] Use user_regset accessors for SPE regs [POWERPC] Use user_regset accessors for altivec regs [POWERPC] Use user_regset accessors for FP regs [POWERPC] mpc52xx: fix compile error introduce when rebasing patch [POWERPC] 4xx: PCIe indirect DCR spinlock fix. [POWERPC] Add missing native dcr dcr_ind_lock spinlock [POWERPC] 4xx: Fix offset value on Warp board [POWERPC] 4xx: Add 440EPx Sequoia ehci dts entry ...
2008-02-06drivers/cdrom/cdrom.c: simplify logic in cdrom_release()Borislav Petkov
Simplify logic in cdrom_release() without semantic change. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06[POWERPC] iSeries: Fix section mismatch in viocdStephen Rothwell
WARNING: drivers/cdrom/viocd.o(.text+0x504): Section mismatch in reference from the function .viocd_probe() to the function .init.text:.find_capability() Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-01ide-cd: move lba_to_msf() and msf_to_lba() to <linux/cdrom.h>Bartlomiej Zolnierkiewicz
* Move lba_to_msf() and msf_to_lba() to <linux/cdrom.h> (use 'u8' type instead of 'byte' while at it). * Remove msf_to_lba() copy from drivers/cdrom/cdrom.c. Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (197 commits) sh: add spi header and r2d platform data V3 sh: update r7780rp interrupt code sh: remove consistent alloc stuff from the machine vector sh: use declared coherent memory for dreamcast pci ethernet adapter sh: declared coherent memory support V2 sh: Add support for SDK7780 board. sh: constify function pointer tables sh: Kill off -traditional for linker script. cdrom: Add support for Sega Dreamcast GD-ROM. sh: Kill off hs7751rvoip reference from arch/sh/Kconfig. sh: Drop r7780rp_defconfig, use r7780mp_defconfig as kbuild default. sh: Kill off dead HS771RVoIP board support. sh: r7785rp: Fix up DECLARE_INTC_DESC() arg mismatch. sh: r7785rp: Hook up the rest of the HL7785 FPGA IRQ vectors. sh: r2d - enable sm501 usb host function sh: remove voyagergx sh: r2d - add lcd planel timings to sm501 platform data sh: Add OHCI and UDC platform devices for SH7720. sh: intc - remove default interrupt priority tables sh: Correct pte size mismatch for X2 TLB. ...
2008-01-28blk_end_request: changing viocd (take 4)Kiyoshi Ueda
This patch converts viocd to use blk_end_request interfaces. Related 'uptodate' arguments are converted to 'error'. As a result, the interface of internal function, viocd_end_request(), is changed. Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28cdrom: Add support for Sega Dreamcast GD-ROM.Adrian McMenamin
This patch adds support for the GD-Rom drive, SEGA's proprietary implementation of an IDE CD Rom for the SEGA Dreamcast. This driver implements Sega's Packet Interface (SPI) - at least partially. It will also read disks in SEGA's propreitary GD format. Unlike previous drivers (which were never in mainline) this uses DMA and not PIO to read disks. It is a new driver, not a refactoring of old drivers. Signed-off by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-10-24SG: audit of drivers that use blk_rq_map_sg()Jens Axboe
They need to properly init the sg table, or blk_rq_map_sg() will complain if CONFIG_DEBUG_SG is set. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-19Use helpers to obtain task pid in printksPavel Emelyanov
The task_struct->pid member is going to be deprecated, so start using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in the kernel. The first thing to start with is the pid, printed to dmesg - in this case we may safely use task_pid_nr(). Besides, printks produce more (much more) than a half of all the explicit pid usage. [akpm@linux-foundation.org: git-drm went and changed lots of stuff] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sysctl: remove broken cdrom binary sysctlsEric W. Biederman
The binary interface for the cdrom sysctls can't possilby work. So remove the binary sysctls and update the test for finding out which sysctl table entry we are dealy with to use the procname and not the ctl_name (which I am removing). Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Alexey Dobriyan <adobriyan@sw.ru> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11[POWERPC] iSeries: Move detection of virtual cdromsStephen Rothwell
Now we will only have entries in the device tree for the actual existing devices (including their OS/400 properties). This way viocd.c gets all the information about the devices from the device tree. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-11[POWERPC] Remove iSeries_vio_devStephen Rothwell
It was only being used to carry around dma_iommu_ops and vio_iommu_table which we can use directly instead. This also means that vio_bus_device doesn't need to refer to them either. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-11[POWERPC] iSeries: Simplify viocd initialisationStephen Rothwell
We don't need to keep a lump of dma coherent memory around for the life of the module. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-09-26cdrom_open() forgets to unlock on -EROFS failure exitsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-16bsg: add a request_queue argument to scsi_cmd_ioctl()FUJITA Tomonori
bsg uses scsi_cmd_ioctl() for some SCSI/sg ioctl commands. scsi_cmd_ioctl() gets a request queue from a gendisk arguement. This prevents bsg being bound to SCSI devices that don't have a gendisk (like OSD). This adds a request_queue argument to scsi_cmd_ioctl(). The SCSI/sg ioctl commands doesn't use a gendisk so it's safe for any SCSI devices to use scsi_cmd_ioctl(). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10Remove legacy CDROM driversJens Axboe
They are all broken beyond repair. Given that nobody has complained about them (most haven't worked in 2.6 AT ALL), remove them from the tree. A new mitsumi driver that actually works is in progress, it'll get added when completed. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10[PATCH] fix request->cmd == INT casesBoaz Harrosh
- I have unearthed very old bugs in stale drivers that still used request->cmd as a READ|WRITE int - This patch is maybe a proof that these drivers have not been used for a long time. Should they be removed completely? Drivers that currently do not work for sure: drivers/acorn/block/fd1772.c | 2 +- drivers/acorn/block/mfmhd.c | 8 ++++---- drivers/cdrom/aztcd.c | 2 +- drivers/cdrom/cm206.c | 2 +- drivers/cdrom/gscd.c | 2 +- drivers/cdrom/mcdx.c | 2 +- drivers/cdrom/optcd.c | 2 +- drivers/cdrom/sjcd.c | 2 +- Drivers with cosmetic fixes only: b/drivers/block/amiflop.c b/drivers/block/nbd.c b/drivers/ide/legacy/hd.c Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10[PATCH] cdrom_sysctl_info fixDave Young
Fix the cdrom_sysctl_info possible buffer overwrite bug. Also fix the locking of accessing topCdromPtr pointer. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-06-08potential parse error in ifdef part 3Yoann Padioleau
Fix various bits of obviously-busted code which we're not happening to compile, due to ifdefs. Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Andi Kleen <ak@suse.de> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: remove destroy_dirty_buffers from invalidate_bdev()Peter Zijlstra
Remove the destroy_dirty_buffers argument from invalidate_bdev(), it hasn't been used in 6 years (so akpm says). find * -name \*.[ch] | xargs grep -l invalidate_bdev | while read file; do quilt add $file; sed -ie 's/invalidate_bdev(\([^,]*\),[^)]*)/invalidate_bdev(\1)/g' $file; done Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] Fix soft lockup with iSeries viocd driverTony Breeds
Fix soft lockup with iSeries viocd driver, caused by eventually calling end_that_request_first() with nr_bytes 0. Some versions of hald do an SG_IO ioctl on the viocd device which becomes a request with hard_nr_sectors and hard_cur_sectors set to zero. Passing zero as the number of sectors to end_request() (which calls end_that_request_first()) causes an infinite loop when the bio is being freed. This patch makes sure that the zero is never passed. It only requires some number larger the the request size the terminate the loop. The lockup is triggered by hald, interrogating the device. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: cdrom: don't set de->ownerEric W. Biederman
There is no need for open files in /proc/sys/XXX to hold a reference count on the module that provides the file to prevent module unload races. While there is code active in the module p->used in the sysctl_table_header is incremented, preventing the sysctl from being unregisted. Once the sysctl is unregistered it cannot be found. Open files are also not a problem as they revalidate the sysctl information and bump p->used before accessing module code. So setting de->owner is unnecessary, makes for a bad example and gets in my way of removing ctl_table->de. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: cdrom: remove unnecessary insert_at_head flagEric W. Biederman
With unique binary sysctl numbers setting insert_at_head to override other sysctl entries is pointless. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 3Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-03[PATCH] cdrom: set default timeout to 7 secondsJens Axboe
It's a known fact that Windows times out commands after 7 seconds, so drives generally try and respond if they can before that happens. We default to 5 seconds, which sometimes is a bit too short. Jeremy Higdon reported here: http://lkml.org/lkml/2007/1/1/145 that his drive takes longer than 5 seconds for a "read track information" command, later confirming that it is about 6.7 seconds. So just do the sane thing and change the default command timeout to 7 seconds to avoid other surprises. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-21Merge branch 'for-linus' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://brick.kernel.dk/data/git/linux-2.6-block: [PATCH] block: document io scheduler allow_merge_fn hook [PATCH] cfq-iosched: don't allow sync merges across queues [PATCH] Fixup blk_rq_unmap_user() API [PATCH] __blk_rq_unmap_user() fails to return error [PATCH] __blk_rq_map_user() doesn't need to grab the queue_lock [PATCH] Remove queue merging hooks [PATCH] ->nr_sectors and ->hard_nr_sectors are not used for BLOCK_PC requests [PATCH] cciss: fix XFER_READ/XFER_WRITE in do_cciss_request [PATCH] cciss: set default raid level when reading geometry fails
2006-12-20[POWERPC] iSeries: fix viocd initStephen Rothwell
Only initialise viocd on legacy iSeries. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-19[PATCH] Fixup blk_rq_unmap_user() APIJens Axboe
The blk_rq_unmap_user() API is not very nice. It expects the caller to know that rq->bio has to be reset to the original bio, and it will silently do nothing if that is not done. Instead make it explicit that we need to pass in the first bio, by expecting a bio argument. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
