path: root/drivers/char/agp/agp.h
2008-06-19drivers/char/agp - use boolJoe Perches
Use boolean in AGP instead of having own TRUE/FALSE -- Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-04-30drivers/char: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-02-05intel-agp: add new chipset IDZhenyu Wang
This one adds new pci ids for Intel intergrated graphics chipset, with gtt table access change on it and new gtt table size definition. Signed-off-by: Zhenyu Wang <zhenyu.z.wang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-02-05agp: add chipset flushing support to AGP interfaceDave Airlie
This bumps the AGP interface to 0.103. Certain Intel chipsets contains a global write buffer, and this can require flushing from the drm or X.org to make sure all data has hit RAM before initiating a GPU transfer, due to a lack of coherency with the integrated graphics device and this buffer. This just adds generic support to the AGP interfaces, a follow-on patch will add support to the Intel driver to use this interface. Signed-off-by: Dave Airlie <airlied@redhat.com>
2007-10-15AGP fix race condition between unmapping and freeing pagesDave Airlie
With Andi's clflush fixup, we were getting hangs on server exit, flushing the mappings after freeing each page helped. This showed up a race condition where the pages after being freed could be reused before the agp mappings had been flushed. Flushing after each single page is a bad thing for future drm work, so make the page destroy a two pass unmapping all the pages, flushing the mappings, and then destroying the pages. Signed-off-by: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-09-19intel-agp: Fix i830 mask variable that changed with G33 supportDave Airlie
The mask on i830 should be 0x70 always, later chips 0xF0 should be okay. Signed-off-by: Dave Airlie <airlied@linux.ie> Acked-by: Zhenyu Wang <zhenyu.z.wang@intel.com> Cc: Michael Haas <laga@laga.ath.cx> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-06[AGPGART] intel_agp: Add support for G33, Q33 and Q35 chipsetsWang Zhenyu
This patch adds pci ids for G33, Q33 and Q35 chips, and update with new GTT size and stolen mem size detect method on these chips. Signed-off-by: Wang Zhenyu <zhenyu.z.wang@intel.com> Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-22[AGPGART] Further constification.Dave Jones
Make agp_bridge_driver->aperture_sizes and ->masks const. Also agp_bridge_data->driver Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-03[AGPGART] Allow drm-populated agp memory typesThomas Hellstrom
This patch allows drm to populate an agpgart structure with pages of its own. It's needed for the new drm memory manager which dynamically flips pages in and out of AGP. The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is currently the only one supporting the new memory manager. Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver. AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected to do that, as well as taking care of cache- and tlb flushing when needed. It's not possible to request these types from user space using agpgart ioctls. The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT. Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com> Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-03[AGPGART] compat ioctlZwane Mwaikambo
The following video card requires the agpgart driver ioctl interface in order to detect video memory. 00:02.0 VGA compatible controller: Intel Corporation Mobile 945GM/GMS/940GML Express Integrated Graphics Controller (rev 03) Tested on a Thinkpad Z61t, Xorg.0.log from a 32bit debian Xorg is at; http://montezuma.homeunix.net/Xorg.0.log Signed-off-by: Zwane Mwaikambo <zwane@infradead.org> Signed-off-by: Dave Jones <davej@redhat.com>
2006-12-22[AGPGART] fix detection of aperture size versus GTT size on G965Eric Anholt
On the G965, the GTT size may be larger than is required to cover the aperture. (In fact, on all hardware we've seen, the GTT is 512KB to the aperture's 256MB). A previous commit forced the aperture size to 512MB on G965 to match GTT, which would likely result in hangs at best if users tried to rely on agpgart's aperture size information. Instead, we use the resource length for the aperture size and the system's reported GTT size when available for the GTT size. Because the MSAC registers which had been read for aperture size detection on i9xx chips just cause a change in the resource size, we can use generic code for aperture detection on all i9xx. Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-05[AGPGART] agp.h: constify struct agp_bridge_data::versionAlexey Dobriyan
drivers/char/agp/backend.c: In function `agp_backend_initialize': drivers/char/agp/backend.c:141: warning: assignment discards qualifiers from pointer target type Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-02-28[AGPGART] Lots of CodingStyle/whitespace cleanups.Dave Jones
Eliminate trailing whitespace. s/if(/if (/ s/for(/for (/ Signed-off-by: Dave Jones <davej@redhat.com>
2005-07-29[PATCH] agp: restore APBASE after setting APSIZEMatthew Garrett
When leaving S3 state, the AGP bridge may not have all PCI configuration registers set in the same way as they were at boot. This should be fixed by pci_restore_state - however, the APBASE register cannot be set to conflict with the APSIZE register. If APSIZE is larger than it was before suspend, pci_restore_state will not restore APBASE correctly. The attached patch adds an extra item to the agp_bridge_data structure and uses it to store the value of APBASE. On resume, this is then written after APSIZE has been set. This patch only touches the path used for Intel chipsets without integrated graphics, and may need to be extended to work with the others. Without this patch, I get the symptoms described in bug 4921 - APBASE ends up overlapping various PCI devices, and as a result they fail to work after resume. Signed-off-by: Matthew Garrett <mjg59@srcf.ucam.org> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-07[PATCH] AGP fix for Xen VMMKeir Fraser
When Linux is running on the Xen virtual machine monitor, physical addresses are virtualised and cannot be directly referenced by the AGP GART. This patch fixes the GART driver for Xen by adding a layer of abstraction between physical addresses and 'GART addresses'. Architecture-specific functions are also defined for allocating and freeing the GATT. Xen requires this to ensure that table really is contiguous from the point of view of the GART. These extra interface functions are defined as 'no-ops' for all existing architectures that use the GART driver. Signed-off-by: Keir Fraser <keir@xensource.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
