path: root/drivers/char/agp/amd-k7-agp.c
2008-10-16Merge branch 'agp-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6 * 'agp-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6: agp/nvidia: Support agp user-memory on nvidia agp. agp/amd-k7: Suspend support for AMD K7 GART driver agp/intel: Reduce extraneous PCI posting reads during init agp: Fix stolen memory counting on G4X.
2008-10-16agp/amd-k7: Suspend support for AMD K7 GART driverStuart Bennett
Reinitialize bridge registers after suspend, but avoid repeating the ioremap Tested and works on AMD761 Signed-off-by: Stuart Bennett <stuart@freedesktop.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-08-22agp: enable optimized agp_alloc_pages methodsRene Herman
The pageattr-array patch that you currently have in tip/master only enables it for intel-agp, not the others. The attached enables it for all drivers currently directly using agp_generic_alloc_page() and agp_generic_destroy_page() (ocal driver is amd-k7-agp). The new agp_generic_alloc_pages() interface uses the also new pageattr array interface API. This makes all AGP drivers that up to now used generic_{alloc,destroy}_page() use it. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-12agp: use dev_printk when possibleBjorn Helgaas
Convert printks to use dev_printk(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-06-19drivers/char/agp - use boolJoe Perches
Use boolean in AGP instead of having own TRUE/FALSE -- Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-04-26agp: fix shadowed variable warning in amd-k7-agp.cHarvey Harrison
Introduced between 2.6.25-rc2 and -rc3 drivers/char/agp/amd-k7-agp.c:439:6: warning: symbol 'cap_ptr' shadows an earlier one drivers/char/agp/amd-k7-agp.c:414:5: originally declared here cap_ptr is never used again in this function, don't bother redeclaring. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-02-20agp: fix missing casts that produced a warning.Dave Airlie
2008-02-19fix historic ioremap() abuse in AGPArjan van dev Ven
Several AGP drivers right now use ioremap_nocache() on kernel ram in order to turn a page of regular memory uncached. There are two problems with this: 1) This is a total nightmare for the ioremap() implementation to keep various mappings of the same page coherent. 2) It's a total nightmare for the AGP code since it adds a ton of complexity in terms of keeping track of 2 different pointers to the same thing, in terms of error handling etc etc. This patch fixes this by making the AGP drivers use the new set_memory_XX APIs instead. Note: amd-k7-agp.c is built on Alpha too, and generic.c is built on ia64 as well, which do not yet have the set_memory_*() APIs, so for them some we have a few ugly #ifdefs - hopefully they'll be fixed soon. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-02-05agp: remove unnecessary pci_dev_putJulia Lawall
pci_get_class implicitly does a pci_dev_put on its second argument, so pci_dev_put is only needed if there is a break out of the loop. The semantic match detecting this problem is as follows: // <smpl> @@ expression dev; expression E; @@ * pci_dev_put(dev) ... when != dev = E ( * pci_get_device(...,dev) | * pci_get_device_reverse(...,dev) | * pci_get_subsys(...,dev) | * pci_get_class(...,dev) ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-10-15fix use after free in amd create gatt pagesJesper Juhl
Coverity spotted a "use after free" bug in drivers/char/agp/amd-k7-agp.c::amd_create_gatt_pages(). The problem is this: If "entry = kzalloc(sizeof(struct amd_page_map), GFP_KERNEL);" fails, then there's a loop in the function to free all entries allocated so far and break out of the allocation loop. That in itself is pretty sane, but then the (now freed) 'tables' is assigned to amd_irongate_private.gatt_pages and 'retval' is set to -ENOMEM which causes amd_free_gatt_pages(); to be called at the end of the function. The problem with this is that amd_free_gatt_pages() will then loop 'amd_irongate_private.num_tables' times and try to free each entry in tables[] - this is bad since tables has already been freed and furthermore it will call kfree(tables) at the end - a double free. This patch removes the freeing loop in amd_create_gatt_pages() and instead relies entirely on the call to amd_free_gatt_pages() to free everything we allocated in case of an error. It also sets amd_irongate_private.num_tables to the actual number of entries allocated instead of just using the value passed in from the caller - this ensures that amd_free_gatt_pages() will only attempt to free stuff that was actually allocated. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2007-08-25agp: balance ioremap checksScott Thompson
patchset against 2.6.23-rc3. corrects missing ioremap return checks and balancing on iounmap calls, integrated changes per list recommendations on the original set of patches.. Signed-off-by: Scott Thompson <postfail <at> hushmail.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-22[AGPGART] Further constification.Dave Jones
Make agp_bridge_driver->aperture_sizes and ->masks const. Also agp_bridge_data->driver Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-03[AGPGART] Allow drm-populated agp memory typesThomas Hellstrom
This patch allows drm to populate an agpgart structure with pages of its own. It's needed for the new drm memory manager which dynamically flips pages in and out of AGP. The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is currently the only one supporting the new memory manager. Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver. AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected to do that, as well as taking care of cache- and tlb flushing when needed. It's not possible to request these types from user space using agpgart ioctls. The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT. Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com> Signed-off-by: Dave Jones <davej@redhat.com>
2007-01-28[AGPGART] Prevent (unlikely) memory leak in amd_create_gatt_pages()Dave Jones
If we fail an alloc, unwind the previous allocs that succeeded. Spotted-by: Alan Grimes <agrimes@speakeasy.net> Signed-off-by: Dave Jones <davej@redhat.com>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-10-24[AGPGART] Set .owner field of struct pci_driver.Dave Jones
From: Laurent Riffard <laurent.riffard@free.fr> This updates .owner field of struct pci_driver. This allows SYSFS to create the symlink from the driver to the module which provides it. $ tree /sys/bus/pci/drivers/agpgart-via/ /sys/bus/pci/drivers/agpgart-via/ |-- 0000:00:00.0 -> ../../../../devices/pci0000:00/0000:00:00.0 |-- bind |-- module -> ../../../../module/via_agp |-- new_id `-- unbind Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-10-20[AGPGART] Replace kmalloc+memset's with kzalloc'sDave Jones
2005-06-07[PATCH] AGP fix for Xen VMMKeir Fraser
When Linux is running on the Xen virtual machine monitor, physical addresses are virtualised and cannot be directly referenced by the AGP GART. This patch fixes the GART driver for Xen by adding a layer of abstraction between physical addresses and 'GART addresses'. Architecture-specific functions are also defined for allocating and freeing the GATT. Xen requires this to ensure that table really is contiguous from the point of view of the GART. These extra interface functions are defined as 'no-ops' for all existing architectures that use the GART driver. Signed-off-by: Keir Fraser <keir@xensource.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2005-05-01[PATCH] make lots of things staticAdrian Bunk
Another large rollup of various patches from Adrian which make things static where they were needlessly exported. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
