path: root/drivers/char/agp/amd-k7-agp.c
2014-01-07agp: Use pci_resource_start() to get CPU physical address for BARBjorn Helgaas
amd_irongate_configure(), ati_configure(), and nvidia_configure() call ioremap() on an address read directly from a BAR. But a BAR contains a bus address, and ioremap() expects a CPU physical address. Use pci_resource_start() to obtain the physical address. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-01-06agp: Support 64-bit APBASEBjorn Helgaas
Per the AGP 3.0 spec, APBASE is a standard PCI BAR and may be either 32 bits or 64 bits wide. Many drivers read APBASE directly, but they only handled 32-bit BARs. The PCI core reads APBASE at enumeration-time. Use pci_bus_address() instead of reading it again in the driver. This works correctly for both 32-bit and 64-bit BARs. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-01-03Drivers: char: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: David Airlie <airlied@linux.ie> Cc: Matt Mackall <mpm@selenic.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21char: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: David Airlie <airlied@linux.ie> Cc: Olof Johansson <olof@lixom.net> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: Rajiv Andrade <mail@srajiv.net> Cc: Marcel Selhorst <tpmdd@selhorst.net> Cc: Sirrix AG <tpmdd@sirrix.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-arm-kernel@lists.infradead.org Cc: openipmi-developer@lists.sourceforge.net Cc: platform-driver-x86@vger.kernel.org Cc: tpmdd-devel@lists.sourceforge.net Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21char: remove use of __devinitdataBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinitdata is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: David Airlie <airlied@linux.ie> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: Rajiv Andrade <mail@srajiv.net> Cc: Marcel Selhorst <tpmdd@selhorst.net> Cc: Sirrix AG <tpmdd@sirrix.com> Cc: openipmi-developer@lists.sourceforge.net Cc: tpmdd-devel@lists.sourceforge.net Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-02-04amd-k7-agp: remove non-x86 codeMatt Turner
amd-k7-agp can't be built on Alpha anymore, so remove now unnecessary code. Signed-off-by: Matt Turner <mattst88@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-19agp/amd-k7: Allow binding user memory to the AGP GART.Francisco Jerez
TTM-based DRM drivers need to be able to bind user memory to the AGP aperture. This patch fixes the "[TTM] AGP Bind memory failed." errors and the subsequent fallout seen with the nouveau driver. Signed-off-by: Francisco Jerez <currojerez@riseup.net> Tested-by: Grzesiek Sójka <pld@pfu.pl> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-04-23agp: use scratch page on memory remove and at GATT creation V4Jerome Glisse
Convert most AGP chipset to use scratch page as default entries. This help avoiding GPU querying 0 address and trigger computer fault. With KMS and memory manager we bind/unbind AGP memory constantly and it seems that some GPU are still doing AGP traffic even after GPU report being idle with the memory segment. Tested (radeon GPU KMS + Xorg + compiz + glxgears + quake3) on : - SIS 1039:0001 & 1039:0003 - Intel 865 8086:2571 Compile tested for other bridges V2 enable scratch page on uninorth V3 fix unbound check in uninorth insert memory (Michel Dänzer) V4 rebase on top of drm-next branch with the lastest intel AGP changeset (stable should use version V3 of the patch) Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Michel Dänzer <michel@daenzer.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-08-03agp: kill phys_to_gart() and gart_to_phys()David Woodhouse
There seems to be no reason for these -- they're a 1:1 mapping on all platforms. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-08-03agp: Switch mask_memory() method to take address argument again, not pageDavid Woodhouse
In commit 07613ba2 ("agp: switch AGP to use page array instead of unsigned long array") we switched the mask_memory() method to take a 'struct page *' instead of an address. This is painful, because in some cases it has to be an IOMMU-mapped virtual bus address (in fact, shouldn't it _always_ be a dma_addr_t returned from pci_map_xxx(), and we just happen to get lucky most of the time?) Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-19agp: switch AGP to use page array instead of unsigned long arrayDave Airlie
This switches AGP to use an array of pages for tracking the pages allocated to the GART. This should enable GEM on PAE to work a lot better as we can pass highmem pages to the PAT code and it will do the right thing with them. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-16Merge branch 'agp-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6 * 'agp-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6: agp/nvidia: Support agp user-memory on nvidia agp. agp/amd-k7: Suspend support for AMD K7 GART driver agp/intel: Reduce extraneous PCI posting reads during init agp: Fix stolen memory counting on G4X.
2008-10-16agp/amd-k7: Suspend support for AMD K7 GART driverStuart Bennett
Reinitialize bridge registers after suspend, but avoid repeating the ioremap Tested and works on AMD761 Signed-off-by: Stuart Bennett <stuart@freedesktop.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-08-22agp: enable optimized agp_alloc_pages methodsRene Herman
The pageattr-array patch that you currently have in tip/master only enables it for intel-agp, not the others. The attached enables it for all drivers currently directly using agp_generic_alloc_page() and agp_generic_destroy_page() (ocal driver is amd-k7-agp). The new agp_generic_alloc_pages() interface uses the also new pageattr array interface API. This makes all AGP drivers that up to now used generic_{alloc,destroy}_page() use it. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-12agp: use dev_printk when possibleBjorn Helgaas
Convert printks to use dev_printk(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-06-19drivers/char/agp - use boolJoe Perches
Use boolean in AGP instead of having own TRUE/FALSE -- Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-04-26agp: fix shadowed variable warning in amd-k7-agp.cHarvey Harrison
Introduced between 2.6.25-rc2 and -rc3 drivers/char/agp/amd-k7-agp.c:439:6: warning: symbol 'cap_ptr' shadows an earlier one drivers/char/agp/amd-k7-agp.c:414:5: originally declared here cap_ptr is never used again in this function, don't bother redeclaring. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-02-20agp: fix missing casts that produced a warning.Dave Airlie
2008-02-19fix historic ioremap() abuse in AGPArjan van dev Ven
Several AGP drivers right now use ioremap_nocache() on kernel ram in order to turn a page of regular memory uncached. There are two problems with this: 1) This is a total nightmare for the ioremap() implementation to keep various mappings of the same page coherent. 2) It's a total nightmare for the AGP code since it adds a ton of complexity in terms of keeping track of 2 different pointers to the same thing, in terms of error handling etc etc. This patch fixes this by making the AGP drivers use the new set_memory_XX APIs instead. Note: amd-k7-agp.c is built on Alpha too, and generic.c is built on ia64 as well, which do not yet have the set_memory_*() APIs, so for them some we have a few ugly #ifdefs - hopefully they'll be fixed soon. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-02-05agp: remove unnecessary pci_dev_putJulia Lawall
pci_get_class implicitly does a pci_dev_put on its second argument, so pci_dev_put is only needed if there is a break out of the loop. The semantic match detecting this problem is as follows: // <smpl> @@ expression dev; expression E; @@ * pci_dev_put(dev) ... when != dev = E ( * pci_get_device(...,dev) | * pci_get_device_reverse(...,dev) | * pci_get_subsys(...,dev) | * pci_get_class(...,dev) ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-10-15fix use after free in amd create gatt pagesJesper Juhl
Coverity spotted a "use after free" bug in drivers/char/agp/amd-k7-agp.c::amd_create_gatt_pages(). The problem is this: If "entry = kzalloc(sizeof(struct amd_page_map), GFP_KERNEL);" fails, then there's a loop in the function to free all entries allocated so far and break out of the allocation loop. That in itself is pretty sane, but then the (now freed) 'tables' is assigned to amd_irongate_private.gatt_pages and 'retval' is set to -ENOMEM which causes amd_free_gatt_pages(); to be called at the end of the function. The problem with this is that amd_free_gatt_pages() will then loop 'amd_irongate_private.num_tables' times and try to free each entry in tables[] - this is bad since tables has already been freed and furthermore it will call kfree(tables) at the end - a double free. This patch removes the freeing loop in amd_create_gatt_pages() and instead relies entirely on the call to amd_free_gatt_pages() to free everything we allocated in case of an error. It also sets amd_irongate_private.num_tables to the actual number of entries allocated instead of just using the value passed in from the caller - this ensures that amd_free_gatt_pages() will only attempt to free stuff that was actually allocated. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2007-08-25agp: balance ioremap checksScott Thompson
patchset against 2.6.23-rc3. corrects missing ioremap return checks and balancing on iounmap calls, integrated changes per list recommendations on the original set of patches.. Signed-off-by: Scott Thompson <postfail <at> hushmail.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-22[AGPGART] Further constification.Dave Jones
Make agp_bridge_driver->aperture_sizes and ->masks const. Also agp_bridge_data->driver Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-03[AGPGART] Allow drm-populated agp memory typesThomas Hellstrom
This patch allows drm to populate an agpgart structure with pages of its own. It's needed for the new drm memory manager which dynamically flips pages in and out of AGP. The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is currently the only one supporting the new memory manager. Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver. AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected to do that, as well as taking care of cache- and tlb flushing when needed. It's not possible to request these types from user space using agpgart ioctls. The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT. Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com> Signed-off-by: Dave Jones <davej@redhat.com>
2007-01-28[AGPGART] Prevent (unlikely) memory leak in amd_create_gatt_pages()Dave Jones
If we fail an alloc, unwind the previous allocs that succeeded. Spotted-by: Alan Grimes <agrimes@speakeasy.net> Signed-off-by: Dave Jones <davej@redhat.com>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-10-24[AGPGART] Set .owner field of struct pci_driver.Dave Jones
From: Laurent Riffard <laurent.riffard@free.fr> This updates .owner field of struct pci_driver. This allows SYSFS to create the symlink from the driver to the module which provides it. $ tree /sys/bus/pci/drivers/agpgart-via/ /sys/bus/pci/drivers/agpgart-via/ |-- 0000:00:00.0 -> ../../../../devices/pci0000:00/0000:00:00.0 |-- bind |-- module -> ../../../../module/via_agp |-- new_id `-- unbind Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-10-20[AGPGART] Replace kmalloc+memset's with kzalloc'sDave Jones
2005-06-07[PATCH] AGP fix for Xen VMMKeir Fraser
When Linux is running on the Xen virtual machine monitor, physical addresses are virtualised and cannot be directly referenced by the AGP GART. This patch fixes the GART driver for Xen by adding a layer of abstraction between physical addresses and 'GART addresses'. Architecture-specific functions are also defined for allocating and freeing the GATT. Xen requires this to ensure that table really is contiguous from the point of view of the GART. These extra interface functions are defined as 'no-ops' for all existing architectures that use the GART driver. Signed-off-by: Keir Fraser <keir@xensource.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2005-05-01[PATCH] make lots of things staticAdrian Bunk
Another large rollup of various patches from Adrian which make things static where they were needlessly exported. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
