commit 6fd024893911dcb51b4a0aa71971db5ba38f7071 upstream.
The current initialisation code probes 'unsupported' AGP devices
simply by calling its own probe function. It does not lock these
devices or even check whether another driver is already bound to
them.
We must use the device core to manage this. So if the specific
device id table didn't match anything and agp_try_unsupported=1,
switch the device id table and call driver_attach() again.
There seems to be no reason for these -- they're a 1:1 mapping on all
platforms.
In commit 07613ba2 ("agp: switch AGP to use page array instead of
unsigned long array") we switched the mask_memory() method to take a
'struct page *' instead of an address. This is painful, because in some
cases it has to be an IOMMU-mapped virtual bus address (in fact,
shouldn't it _always_ be a dma_addr_t returned from pci_map_xxx(), and
we just happen to get lucky most of the time?)
This switches AGP to use an array of pages for tracking the
pages allocated to the GART. This should enable GEM on PAE to work
a lot better as we can pass highmem pages to the PAT code and it will
do the right thing with them.
Impact: fix bug to make agp work with dri
Jeffrey reported that dri does work with 64bit, but doesn't work with
32bit it turns out NB aperture is 32M, aperture on agp is 128M
64bit is using 64M for vaidation for 64 iommu/gart 32bit is only using
32M..., and will not update the nb aperture.
So try to compare nb apterture and agp apterture before leaving not
touch nb aperture.
Reported-by: Jeffrey Trull <jetrull@sbcglobal.net>
Tested-by: Jeffrey Trull <jetrull@sbcglobal.net>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: Dave Airlie <airlied@linux.ie>
Update assorted email addresses and related info to point
to a single current, valid address.
additionally
- trivial CREDITS entry updates. (Not that this file means much any more)
- remove arjans dead redhat.com address from powernow driver
Signed-off-by: Dave Jones <davej@redhat.com>
The pageattr-array patch that you currently have in tip/master only
enables it for intel-agp, not the others. The attached enables it for
all drivers currently directly using agp_generic_alloc_page() and
agp_generic_destroy_page() (ocal driver is amd-k7-agp).
The new agp_generic_alloc_pages() interface uses the also new
pageattr array interface API. This makes all AGP drivers that
up to now used generic_{alloc,destroy}_page() use it.
Signed-off-by: Rene Herman <rene.herman@gmail.com>
Convert printks to use dev_printk().
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
fails
I think the intent was that if no bridges matched agp_amd64_pci_table[],
we would fall back to checking for any bridge with the AGP capability.
But in the current code, we execute the fallback path only when
pci_register_driver() itself fails, which is unrelated to whether any
matching devices were found.
This patch counts the AGP bridges found in the probe() method and executes
the fallback path when none is found.
Use boolean in AGP instead of having own TRUE/FALSE
Factor-out common aperture_valid code.
Signed-off-by: Pavel Machek <pavel@suse.cz>
Cleanup gart handling on amd64 a bit: move common code into
enable_gart_translation , and use symbolic register names where
appropriate.
some systems are using 32M for gart and agp when memory is less than 4G.
Kernel will reject and try to allcate another 64M that is not needed,
and we will waste 64M of perfectly good RAM.
this patch adds a workaround by checking aper_base/order between NB and
agp bridge. If they are the same, and memory size is less than 4G, it
will allow it.
Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com>
while looking at Rafael J. Wysocki's system boot log,
I found a funny printout:
Node 0: aperture @ de000000 size 32 MB
Aperture too small (32 MB)
AGP bridge at 00:04:00
Aperture from AGP @ de000000 size 4096 MB (APSIZE 0)
Aperture too small (0 MB)
Your BIOS doesn't leave a aperture memory hole
Please enable the IOMMU option in the BIOS setup
This costs you 64 MB of RAM
Mapping aperture over 65536 KB of RAM @ 4000000
agpgart: Detected AGP bridge 20
agpgart: Aperture pointing to RAM
agpgart: Aperture from AGP @ de000000 size 4096 MB
agpgart: Aperture too small (0 MB)
agpgart: No usable aperture found.
agpgart: Consider rebooting with iommu=memaper=2 to get a good aperture.
it means BIOS allocated the correct gart on the NB and AGP bridge, but
because a bug in the silicon (the agp bridge reports the wrong order,
it wants 4G instead) the kernel will reject that allocation.
Also, because the size is only 32MB, and we try to get another 64M for gart,
late fix_northbridge can not revert that change because it still reads
the wrong size from agp bridge.
So try to double check the order value from the agp bridge, before calling
aperture_valid().
[ mingo@elte.hu: 32-bit fix. ]
Move symbolic constants into gart.h, and use them instead of hardcoded
constant.
This patch renames the IOMMU config option to GART_IOMMU because in fact it
means the GART and not general support for an IOMMU on x86.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Acked-by: Muli Ben-Yehuda <muli@il.ibm.com>
Instead of all drivers reading pci config space to get the revision
ID, they can now use the pci_device->revision member.
This exposes some issues where drivers where reading a word or a dword
for the revision number, and adding useless error-handling around the
read. Some drivers even just read it for no purpose of all.
In devices where the revision ID is being copied over and used in what
appears to be the equivalent of hotpath, I have left the copy code
and the cached copy as not to influence the driver's performance.
Compile tested with make all{yes,mod}config on x86_64 and i386.
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Acked-by: Dave Jones <davej@redhat.com>
I'm using a custom BIOS to configure the northbridge GART at address
0x80000000, size 2G. Linux complains:
"Aperture from northbridge cpu 0 beyond 4GB. Ignoring."
I think there's an off-by-two error in arch/x86_64/kernel/aperture.c:
AK: use correct types for i386
Signed-off-by: Andi Kleen <ak@suse.de>
Under CONFIG_DISCONTIGMEM, assuming that a !pfn_valid() implies all
subsequent pfn-s are also invalid is wrong. Thus replace this by
explicitly checking against the E820 map.
AK: make e820 on x86-64 not initdata
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Acked-by: Mark Langsdorf <mark.langsdorf@amd.com>
Make agp_bridge_driver->aperture_sizes and ->masks const.
Also agp_bridge_data->driver
This patch allows drm to populate an agpgart structure with pages of its own.
It's needed for the new drm memory manager which dynamically flips pages in and out of AGP.
The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is
currently the only one supporting the new memory manager.
Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver.
AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected
to do that, as well as taking care of cache- and tlb flushing when needed.
It's not possible to request these types from user space using agpgart ioctls.
The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT.
Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com>
Culled from the VIA codedrop.
Also fixes up one ID used in amd64-agp to use the
VIA part number instead of the board name in its ID.
When CONFIG_HOTPLUG=n, agp_amd64_resume() calls nforce3_agp_init(), which is
__devinit == __init, so has been discarded and is not usable for resume.
WARNING: drivers/char/agp/amd64-agp.o - Section mismatch: reference to .init.text: from .text between 'agp_amd64_resume' (at offset 0x249) and 'amd64_tlbflush'
Signed-off-by: Alan Cox <alan@redhat.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
drivers/char/agp/Kconfig
- Rename the GART_IOMMU option to IOMMU to make clear it's not
just for AMD
- Rewrite the help text to better emphatise this fact
- Make it an embedded option because too many people get it wrong.
To my astonishment I discovered the aacraid driver tests this
symbol directly. This looks quite broken to me - it's an internal
implementation detail of the PCI DMA API. Can the maintainer
please clarify what this test was intended to do?
Cc: linux-scsi@vger.kernel.org
Cc: alan@redhat.com
Cc: markh@osdl.org
- Factor out the duplicated access/cache code into a single file
* Shared between i386/x86-64.
- Share flush code between AGP and IOMMU
* Fix a bug: AGP didn't wait for end of flush before
- Drop 8 northbridges limit and allocate dynamically
- Add lock to serialize AGP and IOMMU GART flushes
- Add PCI ID for next AMD northbridge
- Random related cleanups
The old K8 NUMA discovery code is unchanged. New systems
should all use SRAT for this.
Cc: "Navin Boppuri" <navin.boppuri@newisys.com>
Cc: Dave Jones <davej@redhat.com>
pci_register_driver() never returns a positive number.
kernel.org bugzilla #6206
Based on patch from Serge Belyshev <belyshev@depni.sinp.msu.ru>
[description by AK]
Made a cut'n'paste error when adding the entry for the ALI M1695
AGP bridge and added a second entry for the 1689
Eliminate trailing whitespace.
s/if(/if (/
s/for(/for (/
This adds support for suspend/resume to the amd64-agp driver. Without
it, X displays garbage after resume from swsusp.
Signed-off-by: Michal Schmidt <xschmi00@stud.feec.vutbr.cz>
Cc: Andi Kleen <ak@muc.de>
Neither of them are ever written to.
Noted by Arjan van de Ven
Ugh!
Cc: davej@redhat.com
So far all new ones have worked and there isn't much variation because
the CPU does all the interesting bits.
So enable try unsupported by default.
Can be still disabled with try_unsupported=0 (module) or
amd64.try_unsupported=0 (boot option)
(no name because I'm not sure of the correct name)
Fix more include file problems that surfaced since I submitted the previous
fix-missing-includes.patch. This should now allow not to include sched.h
from module.h, which is done by a followup patch.
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
I recently picked up my older work to remove unnecessary #includes of
sched.h, starting from a patch by Dave Jones to not include sched.h
from module.h. This reduces the number of indirect includes of sched.h
by ~300. Another ~400 pointless direct includes can be removed after
this disentangling (patch to follow later).
However, quite a few indirect includes need to be fixed up for this.
In order to feed the patches through -mm with as little disturbance as
possible, I've split out the fixes I accumulated up to now (complete for
i386 and x86_64, more archs to follow later) and post them before the real
patch. This way this large part of the patch is kept simple with only
adding #includes, and all hunks are independent of each other. So if any
hunk rejects or gets in the way of other patches, just drop it. My scripts
will pick it up again in the next round.
This updates .owner field of struct pci_driver.
This allows SYSFS to create the symlink from the driver to the module which
provides it.
$ tree /sys/bus/pci/drivers/agpgart-via/
|-- 0000:00:00.0 -> ../../../../devices/pci0000:00/0000:00:00.0
|-- bind
|-- module -> ../../../../module/via_agp
|-- new_id
`-- unbind
Signed-off-by: Laurent Riffard <laurent.riffard@free.fr>
This patch adds the SiS 760 ID to the amd64-agp driver, so that agpgart can be
used on Athlon64 boards based on this chip.
Signed-off-by: Daniel Drake <dsd@gentoo.org>
When Linux is running on the Xen virtual machine monitor, physical
addresses are virtualised and cannot be directly referenced by the AGP
GART. This patch fixes the GART driver for Xen by adding a layer of
abstraction between physical addresses and 'GART addresses'.
Architecture-specific functions are also defined for allocating and freeing
the GATT. Xen requires this to ensure that table really is contiguous from
the point of view of the GART.
These extra interface functions are defined as 'no-ops' for all existing
architectures that use the GART driver.
Signed-off-by: Keir Fraser <keir@xensource.com>
Another large rollup of various patches from Adrian which make things static
where they were needlessly exported.
