The kzalloc() function has a 2-factor argument form, kcalloc(). This
patch replaces cases of:
kzalloc(a * b, gfp)
with:
kcalloc(a * b, gfp)
as well as handling cases of:
kzalloc(a * b * c, gfp)
with:
kzalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kzalloc_array(array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
kzalloc(4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
kzalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
kzalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
kzalloc(
- sizeof(u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(u8) * COUNT
+ COUNT
kzalloc(
- sizeof(__u8) * COUNT
+ COUNT
kzalloc(
- sizeof(char) * COUNT
+ COUNT
kzalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_CONST
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
- kzalloc
+ kcalloc
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
kzalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
kzalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
kzalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
kzalloc(
- sizeof(TYPE) * COUNT * STRIDE
kzalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
kzalloc(
- sizeof(THING) * (COUNT) * STRIDE
kzalloc(
- sizeof(THING) * COUNT * (STRIDE)
kzalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
kzalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
kzalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
kzalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
kzalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
kzalloc(
- COUNT * (STRIDE) * SIZE
kzalloc(
- COUNT * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * SIZE
kzalloc(
- COUNT * (STRIDE) * (SIZE)
kzalloc(
- (COUNT) * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * (SIZE)
kzalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
kzalloc(C1 * C2 * C3, ...)
kzalloc(
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
kzalloc(
- (E1) * (E2) * E3
kzalloc(
- (E1) * (E2) * (E3)
kzalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kzalloc(sizeof(THING) * C2, ...)
kzalloc(sizeof(TYPE) * C2, ...)
kzalloc(C1 * C2, ...)
- kzalloc
+ kcalloc
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- (E1) * E2
+ E1, E2
- kzalloc
+ kcalloc
- (E1) * (E2)
+ E1, E2
- kzalloc
+ kcalloc
- E1 * E2
+ E1, E2
pci_device_id are not supposed to change at runtime. All functions
working with pci_device_id provided by <linux/pci.h> work with
const pci_device_id. So mark the non-const structs as const.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
set_memory_* functions have moved to set_memory.h. Switch to this
explicitly.
Link: http://lkml.kernel.org/r/1488920133-27229-7-git-send-email-labbott@redhat.com
Signed-off-by: Laura Abbott <labbott@redhat.com>
- Remove soon-to-be-dead @redhat address.
- Jeff Hartmann wrote the bulk of the original backend code, and should
at least get a mention in the MODULE_AUTHOR for backend.o
- Various people at Intel have done a lot more work than myself on the
intel-* drivers, so again, mention that.
Signed-off-by: Dave Jones <davej@redhat.com>
We're accessing the PCI_COMMAND register here, so use the appropriate
#define. The bit we're writing (1 << 14) isn't defined by the PCI or PCIe
spec, so we don't have a name for it.
No functional change.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
amd_irongate_configure(), ati_configure(), and nvidia_configure() call
ioremap() on an address read directly from a BAR. But a BAR contains a
bus address, and ioremap() expects a CPU physical address. Use
pci_resource_start() to obtain the physical address.
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Per the AGP 3.0 spec, APBASE is a standard PCI BAR and may be either 32
bits or 64 bits wide. Many drivers read APBASE directly, but they only
handled 32-bit BARs.
The PCI core reads APBASE at enumeration-time. Use pci_bus_address()
instead of reading it again in the driver. This works correctly for both
32-bit and 64-bit BARs.
Use standard PM state macros PCI_Dx instead of numeric 0/1/2..
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: David Airlie <airlied@linux.ie>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Olof Johansson <olof@lixom.net>
Cc: Mattia Dongili <malattia@linux.it>
Cc: Kent Yoder <key@linux.vnet.ibm.com>
Cc: Rajiv Andrade <mail@srajiv.net>
Cc: Marcel Selhorst <tpmdd@selhorst.net>
Cc: Sirrix AG <tpmdd@sirrix.com>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: openipmi-developer@lists.sourceforge.net
Cc: platform-driver-x86@vger.kernel.org
Cc: tpmdd-devel@lists.sourceforge.net
CONFIG_HOTPLUG is going away as an option so __devinitdata is no
longer needed.
Convert most AGP chipset to use scratch page as default entries.
This help avoiding GPU querying 0 address and trigger computer
fault. With KMS and memory manager we bind/unbind AGP memory
constantly and it seems that some GPU are still doing AGP
traffic even after GPU report being idle with the memory segment.
Tested (radeon GPU KMS + Xorg + compiz + glxgears + quake3) on :
- SIS 1039:0001 & 1039:0003
- Intel 865 8086:2571
Compile tested for other bridges
V2 enable scratch page on uninorth
V3 fix unbound check in uninorth insert memory (Michel Dänzer)
V4 rebase on top of drm-next branch with the lastest intel AGP
changeset (stable should use version V3 of the patch)
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
Signed-off-by: Michel Dänzer <michel@daenzer.net>
There seems to be no reason for these -- they're a 1:1 mapping on all
platforms.
In commit 07613ba2 ("agp: switch AGP to use page array instead of
unsigned long array") we switched the mask_memory() method to take a
'struct page *' instead of an address. This is painful, because in some
cases it has to be an IOMMU-mapped virtual bus address (in fact,
shouldn't it _always_ be a dma_addr_t returned from pci_map_xxx(), and
we just happen to get lucky most of the time?)
This should fix TTM/KMS on some of the original ATI IGP chipsets.
(rs100/rs200)
This switches AGP to use an array of pages for tracking the
pages allocated to the GART. This should enable GEM on PAE to work
a lot better as we can pass highmem pages to the PAT code and it will
do the right thing with them.
Update assorted email addresses and related info to point
to a single current, valid address.
additionally
- trivial CREDITS entry updates. (Not that this file means much any more)
- remove arjans dead redhat.com address from powernow driver
The pageattr-array patch that you currently have in tip/master only
enables it for intel-agp, not the others. The attached enables it for
all drivers currently directly using agp_generic_alloc_page() and
agp_generic_destroy_page() (ocal driver is amd-k7-agp).
The new agp_generic_alloc_pages() interface uses the also new
pageattr array interface API. This makes all AGP drivers that
up to now used generic_{alloc,destroy}_page() use it.
Signed-off-by: Rene Herman <rene.herman@gmail.com>
Convert printks to use dev_printk().
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Use boolean in AGP instead of having own TRUE/FALSE
Addresses https://bugs.edge.launchpad.net/ubuntu/+source/linux-source-2.6.22/+bug/178634
Signed-off-by: Amit Kucheria <amit.kucheria@ubuntu.com>
Signed-off-by: maximilian attems <max@stro.at>
Acked-by: Dave Airlie <airlied@linux.ie>
Several AGP drivers right now use ioremap_nocache() on kernel ram in order
to turn a page of regular memory uncached.
There are two problems with this:
1) This is a total nightmare for the ioremap() implementation to keep
various mappings of the same page coherent.
2) It's a total nightmare for the AGP code since it adds a ton of
complexity in terms of keeping track of 2 different pointers to
the same thing, in terms of error handling etc etc.
This patch fixes this by making the AGP drivers use the new
set_memory_XX APIs instead.
Note: amd-k7-agp.c is built on Alpha too, and generic.c is built
on ia64 as well, which do not yet have the set_memory_*() APIs,
so for them some we have a few ugly #ifdefs - hopefully they'll
be fixed soon.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: Dave Airlie <airlied@linux.ie>
patchset against 2.6.23-rc3.
corrects missing ioremap return checks and balancing on iounmap calls, integrated changes per list
recommendations on the original set of patches..
Signed-off-by: Scott Thompson <postfail <at> hushmail.com>
ati_free_gatt_pages
Coverity spotted a "use after free" bug in
drivers/char/agp/ati-agp.c::ati_create_gatt_pages().
The same one that was in
drivers/char/agp/amd-k7-agp.c::amd_create_gatt_pages()
The problem is this:
If "entry = kzalloc(sizeof(struct ati_page_map), GFP_KERNEL);"
fails, then there's a loop in the function to free all entries
allocated so far and break out of the allocation loop. That in itself
is pretty sane, but then the (now freed) 'tables' is assigned to
ati_generic_private.gatt_pages and 'retval' is set to -ENOMEM which
causes ati_free_gatt_pages(); to be called at the end of the function.
The problem with this is that ati_free_gatt_pages() will then loop
'ati_generic_private.num_tables' times and try to free each entry in
tables[] - this is bad since tables has already been freed and
furthermore it will call kfree(tables) at the end - a double free.
This patch removes the freeing loop in ati_create_gatt_pages() and
instead relies entirely on the call to ati_free_gatt_pages() to free
everything we allocated in case of an error. It also sets
ati_generic_private.num_tables to the actual number of entries
allocated instead of just using the value passed in from the caller -
this ensures that ati_free_gatt_pages() will only attempt to free
stuff that was actually allocated.
Note: I'm in no way intimate with this code and I have no way to
actually test this patch (besides compile test it), so while I've
tried to be careful in reading the code and make sure the patch
does the right thing an ACK from someone who actually knows the
code in-depth would be very much appreciated.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Make agp_bridge_driver->aperture_sizes and ->masks const.
Also agp_bridge_data->driver
This patch allows drm to populate an agpgart structure with pages of its own.
It's needed for the new drm memory manager which dynamically flips pages in and out of AGP.
The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is
currently the only one supporting the new memory manager.
Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver.
AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected
to do that, as well as taking care of cache- and tlb flushing when needed.
It's not possible to request these types from user space using agpgart ioctls.
The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT.
Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com>
No point in clearing local pointers then returning.
Also fix up some CodingStyle nits.
This seems to exist just to save people typing 'struct' a few times,
and doesn't provide any additional value.
drivers/char/agp/Kconfig
acquired (aquired)
contiguous (contigious)
successful (succesful, succesfull)
surprise (suprise)
whether (weather)
some other misspellings
Signed-off-by: Andreas Mohr <andi@lisas.de>
Based on patches in the Ubuntu kernel.
Signed-off-by: Ben Collins <bcollins@ubuntu.com>
Eliminate trailing whitespace.
s/if(/if (/
s/for(/for (/
Add suspend/resume support for the ati-agp module
Signed-off-by: Jaco Kroon <jaco@kroon.co.za>
Acked-by: Pavel Machek <pavel@suse.cz>
I recently picked up my older work to remove unnecessary #includes of
sched.h, starting from a patch by Dave Jones to not include sched.h
from module.h. This reduces the number of indirect includes of sched.h
by ~300. Another ~400 pointless direct includes can be removed after
this disentangling (patch to follow later).
However, quite a few indirect includes need to be fixed up for this.
In order to feed the patches through -mm with as little disturbance as
possible, I've split out the fixes I accumulated up to now (complete for
i386 and x86_64, more archs to follow later) and post them before the real
patch. This way this large part of the patch is kept simple with only
adding #includes, and all hunks are independent of each other. So if any
hunk rejects or gets in the way of other patches, just drop it. My scripts
will pick it up again in the next round.
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
This updates .owner field of struct pci_driver.
This allows SYSFS to create the symlink from the driver to the module which
provides it.
$ tree /sys/bus/pci/drivers/agpgart-via/
|-- 0000:00:00.0 -> ../../../../devices/pci0000:00/0000:00:00.0
|-- bind
|-- module -> ../../../../module/via_agp
|-- new_id
`-- unbind
Signed-off-by: Laurent Riffard <laurent.riffard@free.fr>
When Linux is running on the Xen virtual machine monitor, physical
addresses are virtualised and cannot be directly referenced by the AGP
GART. This patch fixes the GART driver for Xen by adding a layer of
abstraction between physical addresses and 'GART addresses'.
Architecture-specific functions are also defined for allocating and freeing
the GATT. Xen requires this to ensure that table really is contiguous from
the point of view of the GART.
These extra interface functions are defined as 'no-ops' for all existing
architectures that use the GART driver.
Signed-off-by: Keir Fraser <keir@xensource.com>
Another large rollup of various patches from Adrian which make things static
where they were needlessly exported.
infrastructure for it.
Let it rip!
