path: root/drivers/char/agp/backend.c
2012-01-26agp: fix scratch page cleanupMichal Kubecek
In error cleanup of agp_backend_initialize() and in agp_backend_cleanup(), agp_destroy_page() is passed virtual address of the scratch page. This leads to a kernel warning if the initialization fails (or upon regular cleanup) as pointer to struct page should be passed instead. Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-09-15char: Convert vmalloc/memset to vzallocJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-21agp: kill agp_(map|unmap)_pageDaniel Vetter
Only used to remap the scratch page. Now that intel-gtt does this itself, kill the support code. Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-11agp: correct missing cleanup on error in agp_add_bridgeKevin Winchester
While investigating a kmemleak detected leak, I encountered the agp_add_bridge function. It appears to be responsible for freeing the agp_bridge_data in the case of a failure, but it is only doing so for some errors. Fix it to always free the bridge data if a failure condition is encountered. Signed-off-by: Kevin Winchester <kjwinchester@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-22mm: replace various uses of num_physpages by totalram_pagesJan Beulich
Sizing of memory allocations shouldn't depend on the number of physical pages found in a system, as that generally includes (perhaps a huge amount of) non-RAM pages. The amount of what actually is usable as storage should instead be used as a basis here. Some of the calculations (i.e. those not intending to use high memory) should likely even use (totalram_pages - totalhigh_pages). Signed-off-by: Jan Beulich <jbeulich@novell.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Dave Airlie <airlied@linux.ie> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-03agp: kill phys_to_gart() and gart_to_phys()David Woodhouse
There seems to be no reason for these -- they're a 1:1 mapping on all platforms. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-08-03agp: Switch agp_{un,}map_page() to take struct page * argumentDavid Woodhouse
2009-08-03agp: tidy up handling of scratch pages w.r.t. DMA APIDavid Woodhouse
2009-08-03agp: Add generic support for graphics dma remappingZhenyu Wang
New driver hooks for support graphics memory dma remapping are introduced in this patch. It makes generic code can tell if current device needs dma remapping, then call driver provided interfaces for mapping and unmapping. Change has also been made to handle scratch_page in remapping case. Signed-off-by: Zhenyu Wang <zhenyu.z.wang@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-08-03agp: Switch mask_memory() method to take address argument again, not pageDavid Woodhouse
In commit 07613ba2 ("agp: switch AGP to use page array instead of unsigned long array") we switched the mask_memory() method to take a 'struct page *' instead of an address. This is painful, because in some cases it has to be an IOMMU-mapped virtual bus address (in fact, shouldn't it _always_ be a dma_addr_t returned from pci_map_xxx(), and we just happen to get lucky most of the time?) Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-19agp: switch AGP to use page array instead of unsigned long arrayDave Airlie
This switches AGP to use an array of pages for tracking the pages allocated to the GART. This should enable GEM on PAE to work a lot better as we can pass highmem pages to the PAT code and it will do the right thing with them. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-10-20Update email addresses.Dave Jones
Update assorted email addresses and related info to point to a single current, valid address. additionally - trivial CREDITS entry updates. (Not that this file means much any more) - remove arjans dead redhat.com address from powernow driver Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12intel/agp: rewrite GTT on resumeKeith Packard
On my Intel chipset (965GM), the GTT is entirely erased across suspend/resume. This patch simply re-plays the current mapping at resume time to restore the table.=20 I noticed this once I started relying on persistent GTT mappings across VT switch in our GEM work -- the old X server and DRM code carefully unbind all memory from the GTT on VT switch, but GEM does not bother. I placed the list management and rewrite code in the generic layer on the assumption that it will be needed on other hardware, but I did not add the rewrite call to anything other than the Intel resume function. Keep a list of current GATT mappings. At resume time, rewrite them into the GATT. This is needed on Intel (at least) as the entire GATT is cleared across suspend/resume. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Keith Packard <keithp@keithp.com> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-08-12agp: use dev_printk when possibleBjorn Helgaas
Convert printks to use dev_printk(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-06-19agp: two-stage page destruction issueJan Beulich
besides it apparently being useful only in 2.6.24 (the changes in 2.6.25 really mean that it could be converted back to a single-stage mechanism), I'm seeing an issue in Xen Dom0 kernels, which is caused by the calling of gart_to_virt() in the second stage invocations of the destroy function. I think that besides this being a real issue with Xen (where unmap_page_from_agp() is not just a page table attribute change), this also is invalid from a theoretical perspective: One should not assume that gart_to_virt() is still valid after unmapping a page. So minimally (keeping the 2-stage mechanism) a patch like the one below would be needed. Jan Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-02-05agp: add chipset flushing support to AGP interfaceDave Airlie
This bumps the AGP interface to 0.103. Certain Intel chipsets contains a global write buffer, and this can require flushing from the drm or X.org to make sure all data has hit RAM before initiating a GPU transfer, due to a lack of coherency with the integrated graphics device and this buffer. This just adds generic support to the AGP interfaces, a follow-on patch will add support to the Intel driver to use this interface. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-01-30x86: remove flush_agp_mappings()Ingo Molnar
Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-15AGP fix race condition between unmapping and freeing pagesDave Airlie
With Andi's clflush fixup, we were getting hangs on server exit, flushing the mappings after freeing each page helped. This showed up a race condition where the pages after being freed could be reused before the agp mappings had been flushed. Flushing after each single page is a bad thing for future drm work, so make the page destroy a two pass unmapping all the pages, flushing the mappings, and then destroying the pages. Signed-off-by: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-07-09[AGPGART] Hand off AGP maintainence.Dave Jones
Most of the AGP changes recently have been done in lock-step with DRM updates, so it's probably easier to have airlied pushing AGP changes at the same time he does DRM updates. [Also remove my name from the boot messages. Cautionary tale to others: Never do this, when computers don't boot, people assume you're responsible even if 15 other subsystems initialised after yours. :-) ] Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-02-03[AGPGART] Allow drm-populated agp memory typesThomas Hellstrom
This patch allows drm to populate an agpgart structure with pages of its own. It's needed for the new drm memory manager which dynamically flips pages in and out of AGP. The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is currently the only one supporting the new memory manager. Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver. AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected to do that, as well as taking care of cache- and tlb flushing when needed. It's not possible to request these types from user space using agpgart ioctls. The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT. Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-08-11[AGPGART] Const'ify the agpgart driver version.Dave Jones
2006-02-28[AGPGART] Lots of CodingStyle/whitespace cleanups.Dave Jones
Eliminate trailing whitespace. s/if(/if (/ s/for(/for (/ Signed-off-by: Dave Jones <davej@redhat.com>
2005-11-16[AGPGART] Mark maxes_table as constDave Jones
It's never written to. Noted by Arjan van de Ven Signed-off-by: Dave Jones <davej@redhat.com>
2005-11-09Fix AGP compile on non-x86 architecturesLinus Torvalds
AGP shouldn't use "global_flush_tlb()" to flush the AGP mappings, that i spurely an x86'ism. The proper AGP mapping flusher that should be used is "flush_agp_mappings()", which on x86 obviously happens to do a global TLB flush. This makes AGP (or at least the config _I_ happen to use) compile again on ppc64. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-08[PATCH] AGP performance fixesAlan Hourihane
AGP allocation/deallocation is suffering major performance issues due to the nature of global_flush_tlb() being called on every change_page_attr() call. For small allocations this isn't really seen, but when you start allocating 50000 pages of AGP space, for say, texture memory, then things can take seconds to complete. In some cases the situation is doubled or even quadrupled in the time due to SMP, or a deallocation, then a new reallocation. I've had a case of upto 20 seconds wait time to deallocate and reallocate AGP space. This patch fixes the problem by making it the caller's responsibility to call global_flush_tlb(), and so removes it from every instance of mapping a page into AGP space until the time that all change_page_attr() changes are done. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-10-20[AGPGART] Replace kmalloc+memset's with kzalloc'sDave Jones
2005-09-10[PATCH] vfree and kfree cleanup in drivers/Jesper Juhl
This patch does a full cleanup of 'NULL checks before vfree', and a partial cleanup of calls to kfree for all of drivers/ - the kfree bit is partial in that I only did the files that also had vfree calls in them. The patch also gets rid of some redundant (void *) casts of pointers being passed to [vk]free, and a some tiny whitespace corrections also crept in. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-07[PATCH] AGP fix for Xen VMMKeir Fraser
When Linux is running on the Xen virtual machine monitor, physical addresses are virtualised and cannot be directly referenced by the AGP GART. This patch fixes the GART driver for Xen by adding a layer of abstraction between physical addresses and 'GART addresses'. Architecture-specific functions are also defined for allocating and freeing the GATT. Xen requires this to ensure that table really is contiguous from the point of view of the GART. These extra interface functions are defined as 'no-ops' for all existing architectures that use the GART driver. Signed-off-by: Keir Fraser <keir@xensource.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2005-05-01[PATCH] make lots of things staticAdrian Bunk
Another large rollup of various patches from Adrian which make things static where they were needlessly exported. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
