path: root/drivers/char/agp/efficeon-agp.c
2010-08-05agp: efficeon-agp: do not use PCI resources before pci_enable_device()Kulikov Vasiliy
IRQ and resource[] may not have correct values until after PCI hotplug setup occurs at pci_enable_device() time. The semantic match that finds this problem is as follows: // <smpl> @@ identifier x; identifier request ~= "pci_request.*|pci_resource.*"; @@ ( * x->irq | * x->resource | * request(x, ...) ) ... *pci_enable_device(x) // </smpl> Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-04-18agp/intel: introduce intel-agp.h header fileDaniel Vetter
Intel definitions have spilled into agp.h. Create a header file for them and also include it in efficion-agp.c 'cause it needs a few of them. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Eric Anholt <eric@anholt.net>
2009-08-03agp: kill phys_to_gart() and gart_to_phys()David Woodhouse
There seems to be no reason for these -- they're a 1:1 mapping on all platforms. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-19agp: switch AGP to use page array instead of unsigned long arrayDave Airlie
This switches AGP to use an array of pages for tracking the pages allocated to the GART. This should enable GEM on PAE to work a lot better as we can pass highmem pages to the PAT code and it will do the right thing with them. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-08-22agp: enable optimized agp_alloc_pages methodsRene Herman
The pageattr-array patch that you currently have in tip/master only enables it for intel-agp, not the others. The attached enables it for all drivers currently directly using agp_generic_alloc_page() and agp_generic_destroy_page() (ocal driver is amd-k7-agp). The new agp_generic_alloc_pages() interface uses the also new pageattr array interface API. This makes all AGP drivers that up to now used generic_{alloc,destroy}_page() use it. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-19drivers/char/agp - use boolJoe Perches
Use boolean in AGP instead of having own TRUE/FALSE -- Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2007-10-17x86: Create clflush() inline, remove hardcoded wbinvdH. Peter Anvin
Create an inline function for clflush(), with the proper arguments, and use it instead of hard-coding the instruction. This also removes one instance of hard-coded wbinvd, based on a patch by Bauder de Oliveira Costa. [ tglx: arch/x86 adaptation ] Cc: Andi Kleen <andi@firstfloor.org> Cc: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-08-06efficeon-agp leaks 'struct agp_bridge_data' in error paths of ↵Jesper Juhl
agp_efficeon_probe() (This is a resend of a patch originally submitted on 24-Jul-2007 00:14) Ok, this is something the coverity checker found (CID: 1813). I'm not at all intimate with this code, so I'm not sure if this attempt at a fix is correct (but at least it compiles). Please look it over and NACK if bad or merge if good ;-) Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-02-22[AGPGART] Further constification.Dave Jones
Make agp_bridge_driver->aperture_sizes and ->masks const. Also agp_bridge_data->driver Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-03[AGPGART] Allow drm-populated agp memory typesThomas Hellstrom
This patch allows drm to populate an agpgart structure with pages of its own. It's needed for the new drm memory manager which dynamically flips pages in and out of AGP. The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is currently the only one supporting the new memory manager. Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver. AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected to do that, as well as taking care of cache- and tlb flushing when needed. It's not possible to request these types from user space using agpgart ioctls. The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT. Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-08-11[AGPGART] CONFIG_PM=n slim: drivers/char/agp/efficeon-agp.cAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-04-14[efficeon-agp] Add missing memory maskH. Peter Anvin
Original patch by Benjamin Herrenschmidt after debugging by Brian Hinz. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Brian Hinz <bphinz@hotmail.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-28[AGPGART] Lots of CodingStyle/whitespace cleanups.Dave Jones
Eliminate trailing whitespace. s/if(/if (/ s/for(/for (/ Signed-off-by: Dave Jones <davej@redhat.com>
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-11-05[AGPGART] Fix up warning in efficeon driver.Dave Jones
efficeon-agp.c:222: warning: passing arg 1 of `virt_to_phys' makes pointer from integer without a cast Signed-off-by: Dave Jones <davej@redhat.com>
2005-10-24[AGPGART] Set .owner field of struct pci_driver.Dave Jones
From: Laurent Riffard <laurent.riffard@free.fr> This updates .owner field of struct pci_driver. This allows SYSFS to create the symlink from the driver to the module which provides it. $ tree /sys/bus/pci/drivers/agpgart-via/ /sys/bus/pci/drivers/agpgart-via/ |-- 0000:00:00.0 -> ../../../../devices/pci0000:00/0000:00:00.0 |-- bind |-- module -> ../../../../module/via_agp |-- new_id `-- unbind Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-06-07[PATCH] AGP fix for Xen VMMKeir Fraser
When Linux is running on the Xen virtual machine monitor, physical addresses are virtualised and cannot be directly referenced by the AGP GART. This patch fixes the GART driver for Xen by adding a layer of abstraction between physical addresses and 'GART addresses'. Architecture-specific functions are also defined for allocating and freeing the GATT. Xen requires this to ensure that table really is contiguous from the point of view of the GART. These extra interface functions are defined as 'no-ops' for all existing architectures that use the GART driver. Signed-off-by: Keir Fraser <keir@xensource.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2005-05-01[PATCH] make lots of things staticAdrian Bunk
Another large rollup of various patches from Adrian which make things static where they were needlessly exported. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] Fix u32 vs. pm_message_t in drivers/charPavel Machek
Here are fixes for drivers/char. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
