path: root/drivers/char/agp/frontend.c
2014-05-06agp: info leak in agpioc_info_wrap()Dan Carpenter
On 64 bit systems the agp_info struct has a 4 byte hole between ->agp_mode and ->aper_base. We need to clear it to avoid disclosing stack information to userspace. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: David Airlie <airlied@linux.ie> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-07drivers/char: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Cc: David Airlie <airlied@linux.ie> Cc: Matt Mackall <mpm@selenic.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Corey Minyard <minyard@acm.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Peter Huewe <peterhuewe@gmx.de> Cc: Ashley Lai <ashley@ashleylai.com> Cc: Marcel Selhorst <tpmdd@selhorst.net> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-31drm, agpgart: Use pgprot_writecombine for AGP maps and make the MTRR optionalAndy Lutomirski
I'm not sure I understand the intent of the previous behavior. mmap on /dev/agpgart and DRM_AGP maps had no cache flags set, so they would be fully cacheable. But the DRM code (most of the time) would add a write-combining MTRR that would change the effective memory type to WC. The new behavior just requests WC explicitly for all AGP maps. If there is any code out there that expects cacheable access to the AGP aperture (because the drm driver doesn't request an MTRR or because it's using /dev/agpgart directly), then it will now end up with a UC or WC mapping, depending on the architecture and PAT availability. But cacheable access to the aperture seems like it's asking for trouble, because, AIUI, the aperture is an alias of RAM. Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-11-23agp: kill agp_flush_chipset and corresponding ioctlDaniel Vetter
The intel drm calls the chipset functions now directly. Userspace never called the corresponding ioctl, hence it can be killed, too. Cc: Dave Airlie <airlied@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-14agp: Remove the BKL from agp_openJohn Kacur
- Remove the BKL from agp_open - Perform a few clean-ups. Analysis: --------- int minor is local to the function. The following are protected by agp_fe.agp_mutex struct agp_file_private *priv; struct agp_client *client; Call-outs: kzalloc should be safe to call under the mutex_lock agp_find_client_by_pid: - agp_mmap calls that under agp_fe.agp_mutex which we hold in agp_open - agpioc_reserve_wrap calls it without any locking what-so-ever. - Is that an error? Or is that okay because it has pid that is a unique handle? agp_insert_file_private: - This function only manipulates struct agp_file_private, once again while agp_fe.agp_mutex is held Signed-off-by: John Kacur <jkacur@redhat.com> Acked-by: David Airlie <airlied@linux.ie> LKML-Reference: <alpine.LFD.2.00.0910112216060.12574@localhost.localdomain> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-06-20agp-frontend: BKL pushdownArnd Bergmann
2008-06-19agp: more boolean conversions.Dave Airlie
2008-04-26agp: convert drivers/char/agp/frontend.c to use unlocked_ioctlMathieu Segaud
As of now, agp_compat_ioctl already runs without the BKL. Mutual exclusion is enforced by agp_fe.agp_mutex in agp_ioctl() and agp_compat_ioctl(). Apply the same locking rationale to the two functions allowing BKL cleanup. Signed-off-by: Mathieu Segaud <mathieu.segaud@regala.cx> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-02-05agp: remove uid comparison as security checkserue@us.ibm.com
In the face of containers and user namespaces, a uid==0 check for security is not safe. Switch to a capability check. I'm not sure I picked the right capability, but this being AGP CAP_SYS_RAWIO seemed to make sense. Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-02-05agp: add chipset flushing support to AGP interfaceDave Airlie
This bumps the AGP interface to 0.103. Certain Intel chipsets contains a global write buffer, and this can require flushing from the drm or X.org to make sure all data has hit RAM before initiating a GPU transfer, due to a lack of coherency with the integrated graphics device and this buffer. This just adds generic support to the AGP interfaces, a follow-on patch will add support to the Intel driver to use this interface. Signed-off-by: Dave Airlie <airlied@redhat.com>
2007-07-29Remove fs.h from mm.hAlexey Dobriyan
Remove fs.h from mm.h. For this, 1) Uninline vma_wants_writenotify(). It's pretty huge anyway. 2) Add back fs.h or less bloated headers (err.h) to files that need it. As result, on x86_64 allyesconfig, fs.h dependencies cut down from 3929 files rebuilt down to 3444 (-12.3%). Cross-compile tested without regressions on my two usual configs and (sigh): alpha arm-mx1ads mips-bigsur powerpc-ebony alpha-allnoconfig arm-neponset mips-capcella powerpc-g5 alpha-defconfig arm-netwinder mips-cobalt powerpc-holly alpha-up arm-netx mips-db1000 powerpc-iseries arm arm-ns9xxx mips-db1100 powerpc-linkstation arm-assabet arm-omap_h2_1610 mips-db1200 powerpc-lite5200 arm-at91rm9200dk arm-onearm mips-db1500 powerpc-maple arm-at91rm9200ek arm-picotux200 mips-db1550 powerpc-mpc7448_hpc2 arm-at91sam9260ek arm-pleb mips-ddb5477 powerpc-mpc8272_ads arm-at91sam9261ek arm-pnx4008 mips-decstation powerpc-mpc8313_rdb arm-at91sam9263ek arm-pxa255-idp mips-e55 powerpc-mpc832x_mds arm-at91sam9rlek arm-realview mips-emma2rh powerpc-mpc832x_rdb arm-ateb9200 arm-realview-smp mips-excite powerpc-mpc834x_itx arm-badge4 arm-rpc mips-fulong powerpc-mpc834x_itxgp arm-carmeva arm-s3c2410 mips-ip22 powerpc-mpc834x_mds arm-cerfcube arm-shannon mips-ip27 powerpc-mpc836x_mds arm-clps7500 arm-shark mips-ip32 powerpc-mpc8540_ads arm-collie arm-simpad mips-jazz powerpc-mpc8544_ds arm-corgi arm-spitz mips-jmr3927 powerpc-mpc8560_ads arm-csb337 arm-trizeps4 mips-malta powerpc-mpc8568mds arm-csb637 arm-versatile mips-mipssim powerpc-mpc85xx_cds arm-ebsa110 i386 mips-mpc30x powerpc-mpc8641_hpcn arm-edb7211 i386-allnoconfig mips-msp71xx powerpc-mpc866_ads arm-em_x270 i386-defconfig mips-ocelot powerpc-mpc885_ads arm-ep93xx i386-up mips-pb1100 powerpc-pasemi arm-footbridge ia64 mips-pb1500 powerpc-pmac32 arm-fortunet ia64-allnoconfig mips-pb1550 powerpc-ppc64 arm-h3600 ia64-bigsur mips-pnx8550-jbs powerpc-prpmc2800 arm-h7201 ia64-defconfig mips-pnx8550-stb810 powerpc-ps3 arm-h7202 ia64-gensparse mips-qemu powerpc-pseries arm-hackkit ia64-sim mips-rbhma4200 powerpc-up arm-integrator ia64-sn2 mips-rbhma4500 s390 arm-iop13xx ia64-tiger mips-rm200 s390-allnoconfig arm-iop32x ia64-up mips-sb1250-swarm s390-defconfig arm-iop33x ia64-zx1 mips-sead s390-up arm-ixp2000 m68k mips-tb0219 sparc arm-ixp23xx m68k-amiga mips-tb0226 sparc-allnoconfig arm-ixp4xx m68k-apollo mips-tb0287 sparc-defconfig arm-jornada720 m68k-atari mips-workpad sparc-up arm-kafa m68k-bvme6000 mips-wrppmc sparc64 arm-kb9202 m68k-hp300 mips-yosemite sparc64-allnoconfig arm-ks8695 m68k-mac parisc sparc64-defconfig arm-lart m68k-mvme147 parisc-allnoconfig sparc64-up arm-lpd270 m68k-mvme16x parisc-defconfig um-x86_64 arm-lpd7a400 m68k-q40 parisc-up x86_64 arm-lpd7a404 m68k-sun3 powerpc x86_64-allnoconfig arm-lubbock m68k-sun3x powerpc-cell x86_64-defconfig arm-lusl7200 mips powerpc-celleb x86_64-up arm-mainstone mips-atlas powerpc-chrp32 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-03[AGPGART] Allow drm-populated agp memory typesThomas Hellstrom
This patch allows drm to populate an agpgart structure with pages of its own. It's needed for the new drm memory manager which dynamically flips pages in and out of AGP. The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is currently the only one supporting the new memory manager. Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver. AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected to do that, as well as taking care of cache- and tlb flushing when needed. It's not possible to request these types from user space using agpgart ioctls. The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT. Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com> Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-03[AGPGART] compat ioctlZwane Mwaikambo
The following video card requires the agpgart driver ioctl interface in order to detect video memory. 00:02.0 VGA compatible controller: Intel Corporation Mobile 945GM/GMS/940GML Express Integrated Graphics Controller (rev 03) Tested on a Thinkpad Z61t, Xorg.0.log from a 32bit debian Xorg is at; http://montezuma.homeunix.net/Xorg.0.log Signed-off-by: Zwane Mwaikambo <zwane@infradead.org> Signed-off-by: Dave Jones <davej@redhat.com>
2006-07-26[AGPGART] remove private page protection mapHugh Dickins
AGP keeps its own copy of the protection_map, upcoming DRM changes will also require access to this map from modules. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Dave Airlie <airlied@linux.ie> Signed-off-by: Dave Jones <davej@redhat.com>
2006-07-03[PATCH] make more file_operation structs staticArjan van de Ven
Mark the static struct file_operations in drivers/char as const. Making them const prevents accidental bugs, and moves them to the .rodata section so that they no longer do any false sharing; in addition with the proper debug option they are then protected against corruption.. [akpm@osdl.org: build fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-28[AGPGART] Lots of CodingStyle/whitespace cleanups.Dave Jones
Eliminate trailing whitespace. s/if(/if (/ s/for(/for (/ Signed-off-by: Dave Jones <davej@redhat.com>
2006-01-16[AGPGART] Semaphore to Mutex conversion.akpm@osdl.org
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2005-10-20[AGPGART] Replace kmalloc+memset's with kzalloc'sDave Jones
2005-05-01[PATCH] make lots of things staticAdrian Bunk
Another large rollup of various patches from Adrian which make things static where they were needlessly exported. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
