As of now, agp_compat_ioctl already runs without the BKL. Mutual exclusion
is enforced by agp_fe.agp_mutex in agp_ioctl() and agp_compat_ioctl().
Apply the same locking rationale to the two functions allowing BKL cleanup.
Signed-off-by: Mathieu Segaud <mathieu.segaud@regala.cx>
Signed-off-by: Dave Airlie <airlied@linux.ie>
In the face of containers and user namespaces, a uid==0 check for
security is not safe. Switch to a capability check.
I'm not sure I picked the right capability, but this being AGP
CAP_SYS_RAWIO seemed to make sense.
Signed-off-by: Serge Hallyn <serue@us.ibm.com>
This bumps the AGP interface to 0.103.
Certain Intel chipsets contains a global write buffer, and this can require
flushing from the drm or X.org to make sure all data has hit RAM before
initiating a GPU transfer, due to a lack of coherency with the integrated
graphics device and this buffer.
This just adds generic support to the AGP interfaces, a follow-on patch
will add support to the Intel driver to use this interface.
Remove fs.h from mm.h. For this,
1) Uninline vma_wants_writenotify(). It's pretty huge anyway.
2) Add back fs.h or less bloated headers (err.h) to files that need it.
As result, on x86_64 allyesconfig, fs.h dependencies cut down from 3929 files
rebuilt down to 3444 (-12.3%).
Cross-compile tested without regressions on my two usual configs and (sigh):
alpha arm-mx1ads mips-bigsur powerpc-ebony
alpha-allnoconfig arm-neponset mips-capcella powerpc-g5
alpha-defconfig arm-netwinder mips-cobalt powerpc-holly
alpha-up arm-netx mips-db1000 powerpc-iseries
arm arm-ns9xxx mips-db1100 powerpc-linkstation
arm-assabet arm-omap_h2_1610 mips-db1200 powerpc-lite5200
arm-at91rm9200dk arm-onearm mips-db1500 powerpc-maple
arm-at91rm9200ek arm-picotux200 mips-db1550 powerpc-mpc7448_hpc2
arm-at91sam9260ek arm-pleb mips-ddb5477 powerpc-mpc8272_ads
arm-at91sam9261ek arm-pnx4008 mips-decstation powerpc-mpc8313_rdb
arm-at91sam9263ek arm-pxa255-idp mips-e55 powerpc-mpc832x_mds
arm-at91sam9rlek arm-realview mips-emma2rh powerpc-mpc832x_rdb
arm-ateb9200 arm-realview-smp mips-excite powerpc-mpc834x_itx
arm-badge4 arm-rpc mips-fulong powerpc-mpc834x_itxgp
arm-carmeva arm-s3c2410 mips-ip22 powerpc-mpc834x_mds
arm-cerfcube arm-shannon mips-ip27 powerpc-mpc836x_mds
arm-clps7500 arm-shark mips-ip32 powerpc-mpc8540_ads
arm-collie arm-simpad mips-jazz powerpc-mpc8544_ds
arm-corgi arm-spitz mips-jmr3927 powerpc-mpc8560_ads
arm-csb337 arm-trizeps4 mips-malta powerpc-mpc8568mds
arm-csb637 arm-versatile mips-mipssim powerpc-mpc85xx_cds
arm-ebsa110 i386 mips-mpc30x powerpc-mpc8641_hpcn
arm-edb7211 i386-allnoconfig mips-msp71xx powerpc-mpc866_ads
arm-em_x270 i386-defconfig mips-ocelot powerpc-mpc885_ads
arm-ep93xx i386-up mips-pb1100 powerpc-pasemi
arm-footbridge ia64 mips-pb1500 powerpc-pmac32
arm-fortunet ia64-allnoconfig mips-pb1550 powerpc-ppc64
arm-h3600 ia64-bigsur mips-pnx8550-jbs powerpc-prpmc2800
arm-h7201 ia64-defconfig mips-pnx8550-stb810 powerpc-ps3
arm-h7202 ia64-gensparse mips-qemu powerpc-pseries
arm-hackkit ia64-sim mips-rbhma4200 powerpc-up
arm-integrator ia64-sn2 mips-rbhma4500 s390
arm-iop13xx ia64-tiger mips-rm200 s390-allnoconfig
arm-iop32x ia64-up mips-sb1250-swarm s390-defconfig
arm-iop33x ia64-zx1 mips-sead s390-up
arm-ixp2000 m68k mips-tb0219 sparc
arm-ixp23xx m68k-amiga mips-tb0226 sparc-allnoconfig
arm-ixp4xx m68k-apollo mips-tb0287 sparc-defconfig
arm-jornada720 m68k-atari mips-workpad sparc-up
arm-kafa m68k-bvme6000 mips-wrppmc sparc64
arm-kb9202 m68k-hp300 mips-yosemite sparc64-allnoconfig
arm-ks8695 m68k-mac parisc sparc64-defconfig
arm-lart m68k-mvme147 parisc-allnoconfig sparc64-up
arm-lpd270 m68k-mvme16x parisc-defconfig um-x86_64
arm-lpd7a400 m68k-q40 parisc-up x86_64
arm-lpd7a404 m68k-sun3 powerpc x86_64-allnoconfig
arm-lubbock m68k-sun3x powerpc-cell x86_64-defconfig
arm-lusl7200 mips powerpc-celleb x86_64-up
arm-mainstone mips-atlas powerpc-chrp32
First thing mm.h does is including sched.h solely for can_do_mlock() inline
function which has "current" dereference inside. By dealing with can_do_mlock()
mm.h can be detached from sched.h which is good. See below, why.
This patch
a) removes unconditional inclusion of sched.h from mm.h
b) makes can_do_mlock() normal function in mm/mlock.c
c) exports can_do_mlock() to not break compilation
d) adds sched.h inclusions back to files that were getting it indirectly.
e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were
getting them indirectly
Net result is:
a) mm.h users would get less code to open, read, preprocess, parse, ... if
they don't need sched.h
b) sched.h stops being dependency for significant number of files:
on x86_64 allmodconfig touching sched.h results in recompile of 4083 files,
after patch it's only 3744 (-8.3%).
Cross-compile tested on
all arm defconfigs, all mips defconfigs, all powerpc defconfigs,
alpha alpha-up
arm
i386 i386-up i386-defconfig i386-allnoconfig
ia64 ia64-up
m68k
mips
parisc parisc-up
powerpc powerpc-up
s390 s390-up
sparc sparc-up
sparc64 sparc64-up
um-x86_64
x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig
as well as my two usual configs.
This patch allows drm to populate an agpgart structure with pages of its own.
It's needed for the new drm memory manager which dynamically flips pages in and out of AGP.
The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is
currently the only one supporting the new memory manager.
Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver.
AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected
to do that, as well as taking care of cache- and tlb flushing when needed.
It's not possible to request these types from user space using agpgart ioctls.
The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT.
Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com>
Signed-off-by: Dave Jones <davej@redhat.com>
The following video card requires the agpgart driver ioctl
interface in order to detect video memory.
00:02.0 VGA compatible controller: Intel Corporation Mobile
945GM/GMS/940GML Express Integrated Graphics Controller (rev 03)
Tested on a Thinkpad Z61t, Xorg.0.log from a 32bit debian Xorg is at;
http://montezuma.homeunix.net/Xorg.0.log
Signed-off-by: Zwane Mwaikambo <zwane@infradead.org>
AGP keeps its own copy of the protection_map, upcoming DRM changes will
also require access to this map from modules.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Mark the static struct file_operations in drivers/char as const. Making
them const prevents accidental bugs, and moves them to the .rodata section
so that they no longer do any false sharing; in addition with the proper
debug option they are then protected against corruption..
[akpm@osdl.org: build fix]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Eliminate trailing whitespace.
s/if(/if (/
s/for(/for (/
Semaphore to mutex conversion.
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
Another large rollup of various patches from Adrian which make things static
where they were needlessly exported.
infrastructure for it.
Let it rip!
