path: root/drivers/char/agp/generic.c
2012-04-12agp: Use u32 __iomem annotation to silence sparse warning.Santosh Nayak
Replace "void *" by "u32 __iomem *" to silence sparse warning. Signed-off-by: Santosh Nayak <santoshprasadnayak@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-04-12agp: Remove 'break' after 'return' statement.Santosh Nayak
'break' is unnecessary after 'return' statement. Remove all such 'break' as clean up. Signed-off-by: Santosh Nayak <santoshprasadnayak@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-01-06agp: Fix multi-line warning message whitespaceTormod Volden
Signed-off-by: Tormod Volden <debian.tormod@gmail.com> Reviewed-by: Corbin Simpson <MostAwesomeDude@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-21agp: fix arbitrary kernel memory writesVasiliy Kulikov
pg_start is copied from userspace on AGPIOC_BIND and AGPIOC_UNBIND ioctl cmds of agp_ioctl() and passed to agpioc_bind_wrap(). As said in the comment, (pg_start + mem->page_count) may wrap in case of AGPIOC_BIND, and it is not checked at all in case of AGPIOC_UNBIND. As a result, user with sufficient privileges (usually "video" group) may generate either local DoS or privilege escalation. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-21agp: fix OOM and buffer overflowVasiliy Kulikov
page_count is copied from userspace. agp_allocate_memory() tries to check whether this number is too big, but doesn't take into account the wrap case. Also agp_create_user_memory() doesn't check whether alloc_size is calculated from num_agp_pages variable without overflow. This may lead to allocation of too small buffer with following buffer overflow. Another problem in agp code is not addressed in the patch - kernel memory exhaustion (AGPIOC_RESERVE and AGPIOC_ALLOCATE ioctls). It is not checked whether requested pid is a pid of the caller (no check in agpioc_reserve_wrap()). Each allocation is limited to 16KB, though, there is no per-process limit. This might lead to OOM situation, which is not even solved in case of the caller death by OOM killer - the memory is allocated for another (faked) process. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-11-23agp: kill agp_rebind_memoryDaniel Vetter
Its only user, intel-gtt.c is now gone. Cc: Dave Airlie <airlied@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-11-23agp: kill agp_flush_chipset and corresponding ioctlDaniel Vetter
The intel drm calls the chipset functions now directly. Userspace never called the corresponding ioctl, hence it can be killed, too. Cc: Dave Airlie <airlied@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-10-26Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (476 commits) vmwgfx: Implement a proper GMR eviction mechanism drm/radeon/kms: fix r6xx/7xx 1D tiling CS checker v2 drm/radeon/kms: properly compute group_size on 6xx/7xx drm/radeon/kms: fix 2D tile height alignment in the r600 CS checker drm/radeon/kms/evergreen: set the clear state to the blit state drm/radeon/kms: don't poll dac load detect. gpu: Add Intel GMA500(Poulsbo) Stub Driver drm/radeon/kms: MC vram map needs to be >= pci aperture size drm/radeon/kms: implement display watermark support for evergreen drm/radeon/kms/evergreen: add some additional safe regs v2 drm/radeon/r600: fix tiling issues in CS checker. drm/i915: Move gpu_write_list to per-ring drm/i915: Invalidate the to-ring, flush the old-ring when updating domains drm/i915/ringbuffer: Write the value passed in to the tail register agp/intel: Restore valid PTE bit for Sandybridge after bdd3072 drm/i915: Fix flushing regression from 9af90d19f drm/i915/sdvo: Remove unused encoding member i915: enable AVI infoframe for intel_hdmi.c [v4] drm/i915: Fix current fb blocking for page flip drm/i915: IS_IRONLAKE is synonymous with gen == 5 ... Fix up conflicts in - drivers/gpu/drm/i915/{i915_gem.c, i915/intel_overlay.c}: due to the new simplified stack-based kmap_atomic() interface - drivers/gpu/drm/vmwgfx/vmwgfx_drv.c: added .llseek entry due to BKL removal cleanups.
2010-09-21agp: kill agp_(unmap|map)_memoryDaniel Vetter
DMA remapping was only used by the intel-gtt driver. With that code now folded into the driver, kill the agp generic support for it. Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-09-05AGP: Warn when GATT memory cannot be set to UCBorislav Petkov
This is one of those paranoid checks which should at least tell us that something is about to go haywire after we've disabled GART table walk probes which is done by default now on AMD. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Dave Airlie <airlied@redhat.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> LKML-Reference: <1283531981-7495-4-git-send-email-bp@amd64.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-15agp: add no warn since we have a fallback to vmalloc pathsDave Airlie
also drop the NORETRY we can probably nearly always satisfy order 1 allocs now, and again the vmalloc path is there. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-06-15agp: drop vmalloc flag.Dave Airlie
Since the code that was too ugly to live is upstream, we can use it now, instead of rolling our own. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-05-11agp: use NULL instead of 0 when pointer is neededBill Pemberton
Fixes sparse warning: drivers/char/agp/generic.c:1217:33: warning: Using plain integer as NULL pointer Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> CC: linux-kernel@vger.kernel.org Signed-off-by: Jiri Kosina <jkosina@suse.cz>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-08-03agp: kill phys_to_gart() and gart_to_phys()David Woodhouse
There seems to be no reason for these -- they're a 1:1 mapping on all platforms. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-08-03agp: Add generic support for graphics dma remappingZhenyu Wang
New driver hooks for support graphics memory dma remapping are introduced in this patch. It makes generic code can tell if current device needs dma remapping, then call driver provided interfaces for mapping and unmapping. Change has also been made to handle scratch_page in remapping case. Signed-off-by: Zhenyu Wang <zhenyu.z.wang@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-08-03agp: Switch mask_memory() method to take address argument again, not pageDavid Woodhouse
In commit 07613ba2 ("agp: switch AGP to use page array instead of unsigned long array") we switched the mask_memory() method to take a 'struct page *' instead of an address. This is painful, because in some cases it has to be an IOMMU-mapped virtual bus address (in fact, shouldn't it _always_ be a dma_addr_t returned from pci_map_xxx(), and we just happen to get lucky most of the time?) Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-19agp: switch AGP to use page array instead of unsigned long arrayDave Airlie
This switches AGP to use an array of pages for tracking the pages allocated to the GART. This should enable GEM on PAE to work a lot better as we can pass highmem pages to the PAT code and it will do the right thing with them. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-04-20agp: zero pages before sending to userspaceShaohua Li
AGP pages might be mapped into userspace finally, so the pages should be set to zero before userspace can use it. Otherwise there is potential information leakage. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-08-22Merge branch 'x86/urgent' into x86/patIngo Molnar
Conflicts: arch/x86/mm/pageattr.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-21agp: add agp_generic_destroy_pages()Shaohua Li
Add agp_generic_destroy_pages(), it uses new pageattr array interface API. Signed-off-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-21agp: generic_alloc_pages()Shaohua Li
Add agp_generic_alloc_pages(), it uses new pageattr array interface API. Signed-off-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-21Revert "reduce tlb/cache flush times of agpgart memory allocation"Ingo Molnar
This reverts commit 466ae837424dcc538b1af2a0eaf53be32edcdbe7.
2008-08-15reduce tlb/cache flush times of agpgart memory allocationShaohua Li
To reduce tlb/cache flush, makes agp memory allocation do one flush after all pages in a region are changed to uc. All agp drivers except agp-sgi uses agp_generic_alloc_page() for .agp_alloc_page, so the patch should work for them. agp-sgi is only for ia64, so not a problem too. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Cc: airlied@linux.ie Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-12intel/agp: rewrite GTT on resumeKeith Packard
On my Intel chipset (965GM), the GTT is entirely erased across suspend/resume. This patch simply re-plays the current mapping at resume time to restore the table.=20 I noticed this once I started relying on persistent GTT mappings across VT switch in our GEM work -- the old X server and DRM code carefully unbind all memory from the GTT on VT switch, but GEM does not bother. I placed the list management and rewrite code in the generic layer on the assumption that it will be needed on other hardware, but I did not add the rewrite call to anything other than the Intel resume function. Keep a list of current GATT mappings. At resume time, rewrite them into the GATT. This is needed on Intel (at least) as the entire GATT is cleared across suspend/resume. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Keith Packard <keithp@keithp.com> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-08-12agp: use dev_printk when possibleBjorn Helgaas
Convert printks to use dev_printk(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-06-26on_each_cpu(): kill unused 'retry' parameterJens Axboe
It's not even passed on to smp_call_function() anymore, since that was removed. So kill it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-19agp: more boolean conversions.Dave Airlie
2008-06-19drivers/char/agp - use boolJoe Perches
Use boolean in AGP instead of having own TRUE/FALSE -- Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-06-19agp: two-stage page destruction issueJan Beulich
besides it apparently being useful only in 2.6.24 (the changes in 2.6.25 really mean that it could be converted back to a single-stage mechanism), I'm seeing an issue in Xen Dom0 kernels, which is caused by the calling of gart_to_virt() in the second stage invocations of the destroy function. I think that besides this being a real issue with Xen (where unmap_page_from_agp() is not just a page table attribute change), this also is invalid from a theoretical perspective: One should not assume that gart_to_virt() is still valid after unmapping a page. So minimally (keeping the 2-stage mechanism) a patch like the one below would be needed. Jan Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-02-19fix historic ioremap() abuse in AGPArjan van dev Ven
Several AGP drivers right now use ioremap_nocache() on kernel ram in order to turn a page of regular memory uncached. There are two problems with this: 1) This is a total nightmare for the ioremap() implementation to keep various mappings of the same page coherent. 2) It's a total nightmare for the AGP code since it adds a ton of complexity in terms of keeping track of 2 different pointers to the same thing, in terms of error handling etc etc. This patch fixes this by making the AGP drivers use the new set_memory_XX APIs instead. Note: amd-k7-agp.c is built on Alpha too, and generic.c is built on ia64 as well, which do not yet have the set_memory_*() APIs, so for them some we have a few ugly #ifdefs - hopefully they'll be fixed soon. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-02-05agp: add chipset flushing support to AGP interfaceDave Airlie
This bumps the AGP interface to 0.103. Certain Intel chipsets contains a global write buffer, and this can require flushing from the drm or X.org to make sure all data has hit RAM before initiating a GPU transfer, due to a lack of coherency with the integrated graphics device and this buffer. This just adds generic support to the AGP interfaces, a follow-on patch will add support to the Intel driver to use this interface. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-01-30x86: remove flush_agp_mappings()Ingo Molnar
Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-15AGP fix race condition between unmapping and freeing pagesDave Airlie
With Andi's clflush fixup, we were getting hangs on server exit, flushing the mappings after freeing each page helped. This showed up a race condition where the pages after being freed could be reused before the agp mappings had been flushed. Flushing after each single page is a bad thing for future drm work, so make the page destroy a two pass unmapping all the pages, flushing the mappings, and then destroying the pages. Signed-off-by: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-07-27agp: don't lock pagesNick Piggin
AGP should not need to lock pages. They are not protecting any race because there is no lock_page calls, only SetPageLocked. This is causing hangs with d00806b183152af6d24f46f0c33f14162ca1262a. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-26[AGPGART] Move [un]map_page_into_agp into asm/agp.hJan Beulich
Remove an arch-dependent hunk in favor of #define-ing the respective bits in asm-<arch>/agp.h (allowing easier overriding in para-virtualized environments). Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-22[AGPGART] Further constification.Dave Jones
Make agp_bridge_driver->aperture_sizes and ->masks const. Also agp_bridge_data->driver Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-10[AGPGART] allow drm populated agp memory types cleanupsAndrew Morton
Fix whitespace, braces, use kzalloc(). Cc: Dave Airlie <airlied@linux.ie> Cc: Thomas Hellstrom <thomas@tungstengraphics.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-03[AGPGART] Allow drm-populated agp memory typesThomas Hellstrom
This patch allows drm to populate an agpgart structure with pages of its own. It's needed for the new drm memory manager which dynamically flips pages in and out of AGP. The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is currently the only one supporting the new memory manager. Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver. AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected to do that, as well as taking care of cache- and tlb flushing when needed. It's not possible to request these types from user space using agpgart ioctls. The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT. Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-12-22[AGPGART] Remove unnecessary flushes when inserting and removing pages.Thomas Hellstrom
This patch is to speed up flipping of pages in and out of the AGP aperture as needed by the new drm memory manager. A number of global cache flushes are removed as well as some PCI posting flushes. The following guidelines have been used: 1) Memory that is only mapped uncached and that has been subject to a global cache flush after the mapping was changed to uncached does not need any more cache flushes. Neither before binding to the aperture nor after unbinding. 2) Only do one PCI posting flush after a sequence of writes modifying page entries in the GATT. Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-12-12Merge ../linusDave Jones
2006-11-22[AGP] Allocate AGP pages with GFP_DMA32 by defaultLinus Torvalds
Not all graphic page remappers support physical addresses over the 4GB mark for remapping, so while some do (the AMD64 GART always did, and I just fixed the i965 to do so properly), we're safest off just forcing GFP_DMA32 allocations to make sure graphics pages get allocated in the low 32-bit address space by default. AGP sub-drivers that really care, and can do better, could just choose to implement their own allocator (or we could add another "64-bit safe" default allocator for their use), but quite frankly, you're not likely to care in practice. So for now, this trivial change means that we won't be allocating pages that we can't map correctly by mistake on x86-64. [ On traditional 32-bit x86, this could never happen, because GFP_KERNEL would never allocate any highmem memory anyway ] Acked-by: Andi Kleen <ak@suse.de> Acked-by: Dave Jones <davej@redhat.com> Cc: Eric Anholt <eric@anholt.net> Cc: Keith Packard <keithp@keithp.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[AGPGART] Fix up misprogrammed bridges with incorrect AGPv2 rates.Dave Jones
Some dumb bridges are programmed to disobey the AGP2 spec. This is likely a BIOS misprogramming rather than poweron default, or it would be a lot more common. AGPv2 spec 6.1.9 states: "The RATE field indicates the data transfer rates supported by this device. A.G.P. devices must report all that apply." Fix them up as best we can. This will prevent errors like.. agpgart: Found an AGP 3.5 compliant device at 0000:00:00.0. agpgart: req mode 1f000201 bridge_agpstat 1f000a14 vga_agpstat 2f000217. agpgart: Device is in legacy mode, falling back to 2.x agpgart: Putting AGP V2 device at 0000:00:00.0 into 0x mode agpgart: Putting AGP V2 device at 0000:01:00.0 into 0x mode agpgart: Putting AGP V2 device at 0000:01:00.1 into 0x mode https://bugs.freedesktop.org/show_bug.cgi?id=8816 Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-28[AGPGART] printk fixups.Dave Jones
2006-09-10[AGPGART] Rework AGPv3 modesetting fallback.Dave Jones
Sometimes the logic to handle AGPx8->AGPx4 fallback failed, as can be seen in https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=197346 The failures occured if the bridge was in AGPx8 mode, but the user hadn't specified a mode in their X config. We weren't setting the mode to the highest mode capable by the video card+bridge (as we do in the AGPv2 case), which was leading to all kinds of mayhem including us believing that after falling back from AGPx8, that we couldn't do x4 mode (which is disastrous in AGPv3, as those are the only two modes possible). Signed-off-by: Dave Jones <davej@redhat.com>
2006-05-30[AGPGART] Remove pointless code from agp_generic_create_gatt_table()Dave Jones
2006-02-28[AGPGART] Lots of CodingStyle/whitespace cleanups.Dave Jones
Eliminate trailing whitespace. s/if(/if (/ s/for(/for (/ Signed-off-by: Dave Jones <davej@redhat.com>
2005-11-09Fix AGP compile on non-x86 architecturesLinus Torvalds
AGP shouldn't use "global_flush_tlb()" to flush the AGP mappings, that i spurely an x86'ism. The proper AGP mapping flusher that should be used is "flush_agp_mappings()", which on x86 obviously happens to do a global TLB flush. This makes AGP (or at least the config _I_ happen to use) compile again on ppc64. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
