path: root/drivers/char/agp/hp-agp.c
2007-10-17convert ill defined log2() to ilog2()Fengguang Wu
It's *wrong* to have #define log2(n) ffz(~(n)) It should be *reversed*: #define log2(n) flz(~(n)) or #define log2(n) fls(n) or just use ilog2(n) defined in linux/log2.h. This patch follows the last solution, recommended by Andrew Morton. Cc: <linux-ext4@vger.kernel.org> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Chris Ahna <christopher.j.ahna@intel.com> Cc: David Mosberger-Tang <davidm@hpl.hp.com> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Dave Airlie <airlied@linux.ie> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-25agp: balance ioremap checksScott Thompson
patchset against 2.6.23-rc3. corrects missing ioremap return checks and balancing on iounmap calls, integrated changes per list recommendations on the original set of patches.. Signed-off-by: Scott Thompson <postfail <at> hushmail.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-02-27[AGPGART] fix compile errorsRyusuke Konishi
This fixes the following compile failures of agpgart drivers. These errors were inserted by the recent AGPGART constification patch. drivers/char/agp/uninorth-agp.c:492: error: expected '{' before 'const' drivers/char/agp/uninorth-agp.c:517: error: expected '{' before 'const' drivers/char/agp/uninorth-agp.c: In function 'agp_uninorth_probe': drivers/char/agp/uninorth-agp.c:634: error: 'u3_agp_driver' undeclared (first use in this function) drivers/char/agp/uninorth-agp.c:634: error: (Each undeclared identifier is reported only once drivers/char/agp/uninorth-agp.c:634: error: for each function it appears in.) drivers/char/agp/uninorth-agp.c:636: error: 'uninorth_agp_driver' undeclared (first use in this function) Signed-off-by: Ryusuke Konishi <ryusuke@osrg.net> Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-22[AGPGART] Further constification.Dave Jones
Make agp_bridge_driver->aperture_sizes and ->masks const. Also agp_bridge_data->driver Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-03[AGPGART] Allow drm-populated agp memory typesThomas Hellstrom
This patch allows drm to populate an agpgart structure with pages of its own. It's needed for the new drm memory manager which dynamically flips pages in and out of AGP. The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is currently the only one supporting the new memory manager. Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver. AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected to do that, as well as taking care of cache- and tlb flushing when needed. It's not possible to request these types from user space using agpgart ioctls. The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT. Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-04-01ACPI: ia64 buildfixLen Brown
Signed-off-by: Len Brown <len.brown@intel.com>
2006-02-28[AGPGART] Lots of CodingStyle/whitespace cleanups.Dave Jones
Eliminate trailing whitespace. s/if(/if (/ s/for(/for (/ Signed-off-by: Dave Jones <davej@redhat.com>
2005-09-16[IA64] Remove warnings for gcc 4.0 IA64 compilation.Peter Chubb
This patch removes some compilation warnings, mostly trivially. acpi.c fix also noted by Kenji Kaneshige. Signed-off-by; Peter Chubb <peterc@gelato.unsw.edu.au> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-06-07[PATCH] AGP fix for Xen VMMKeir Fraser
When Linux is running on the Xen virtual machine monitor, physical addresses are virtualised and cannot be directly referenced by the AGP GART. This patch fixes the GART driver for Xen by adding a layer of abstraction between physical addresses and 'GART addresses'. Architecture-specific functions are also defined for allocating and freeing the GATT. Xen requires this to ensure that table really is contiguous from the point of view of the GART. These extra interface functions are defined as 'no-ops' for all existing architectures that use the GART driver. Signed-off-by: Keir Fraser <keir@xensource.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
