path: root/drivers/char/agp/i460-agp.c
2013-01-03Drivers: char: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: David Airlie <airlied@linux.ie> Cc: Matt Mackall <mpm@selenic.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21char: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: David Airlie <airlied@linux.ie> Cc: Olof Johansson <olof@lixom.net> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: Rajiv Andrade <mail@srajiv.net> Cc: Marcel Selhorst <tpmdd@selhorst.net> Cc: Sirrix AG <tpmdd@sirrix.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-arm-kernel@lists.infradead.org Cc: openipmi-developer@lists.sourceforge.net Cc: platform-driver-x86@vger.kernel.org Cc: tpmdd-devel@lists.sourceforge.net Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-08-03agp: kill phys_to_gart() and gart_to_phys()David Woodhouse
There seems to be no reason for these -- they're a 1:1 mapping on all platforms. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-08-03agp: Switch mask_memory() method to take address argument again, not pageDavid Woodhouse
In commit 07613ba2 ("agp: switch AGP to use page array instead of unsigned long array") we switched the mask_memory() method to take a 'struct page *' instead of an address. This is painful, because in some cases it has to be an IOMMU-mapped virtual bus address (in fact, shouldn't it _always_ be a dma_addr_t returned from pci_map_xxx(), and we just happen to get lucky most of the time?) Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-19agp: switch AGP to use page array instead of unsigned long arrayDave Airlie
This switches AGP to use an array of pages for tracking the pages allocated to the GART. This should enable GEM on PAE to work a lot better as we can pass highmem pages to the PAT code and it will do the right thing with them. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-08-22agp: enable optimized agp_alloc_pages methodsRene Herman
The pageattr-array patch that you currently have in tip/master only enables it for intel-agp, not the others. The attached enables it for all drivers currently directly using agp_generic_alloc_page() and agp_generic_destroy_page() (ocal driver is amd-k7-agp). The new agp_generic_alloc_pages() interface uses the also new pageattr array interface API. This makes all AGP drivers that up to now used generic_{alloc,destroy}_page() use it. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-19drivers/char/agp - use boolJoe Perches
Use boolean in AGP instead of having own TRUE/FALSE -- Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-01-30x86: cpa: move flush to cpaThomas Gleixner
The set_memory_* and set_pages_* family of API's currently requires the callers to do a global tlb flush after the function call; forgetting this is a very nasty deathtrap. This patch moves the global tlb flush into each of the callers Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-17convert ill defined log2() to ilog2()Fengguang Wu
It's *wrong* to have #define log2(n) ffz(~(n)) It should be *reversed*: #define log2(n) flz(~(n)) or #define log2(n) fls(n) or just use ilog2(n) defined in linux/log2.h. This patch follows the last solution, recommended by Andrew Morton. Cc: <linux-ext4@vger.kernel.org> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Chris Ahna <christopher.j.ahna@intel.com> Cc: David Mosberger-Tang <davidm@hpl.hp.com> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Dave Airlie <airlied@linux.ie> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15AGP fix race condition between unmapping and freeing pagesDave Airlie
With Andi's clflush fixup, we were getting hangs on server exit, flushing the mappings after freeing each page helped. This showed up a race condition where the pages after being freed could be reused before the agp mappings had been flushed. Flushing after each single page is a bad thing for future drm work, so make the page destroy a two pass unmapping all the pages, flushing the mappings, and then destroying the pages. Signed-off-by: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-08-25agp: balance ioremap checksScott Thompson
patchset against 2.6.23-rc3. corrects missing ioremap return checks and balancing on iounmap calls, integrated changes per list recommendations on the original set of patches.. Signed-off-by: Scott Thompson <postfail <at> hushmail.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-02-27[AGPGART] fix compile errorsRyusuke Konishi
This fixes the following compile failures of agpgart drivers. These errors were inserted by the recent AGPGART constification patch. drivers/char/agp/uninorth-agp.c:492: error: expected '{' before 'const' drivers/char/agp/uninorth-agp.c:517: error: expected '{' before 'const' drivers/char/agp/uninorth-agp.c: In function 'agp_uninorth_probe': drivers/char/agp/uninorth-agp.c:634: error: 'u3_agp_driver' undeclared (first use in this function) drivers/char/agp/uninorth-agp.c:634: error: (Each undeclared identifier is reported only once drivers/char/agp/uninorth-agp.c:634: error: for each function it appears in.) drivers/char/agp/uninorth-agp.c:636: error: 'uninorth_agp_driver' undeclared (first use in this function) Signed-off-by: Ryusuke Konishi <ryusuke@osrg.net> Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-22[AGPGART] Further constification.Dave Jones
Make agp_bridge_driver->aperture_sizes and ->masks const. Also agp_bridge_data->driver Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-03[AGPGART] Allow drm-populated agp memory typesThomas Hellstrom
This patch allows drm to populate an agpgart structure with pages of its own. It's needed for the new drm memory manager which dynamically flips pages in and out of AGP. The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is currently the only one supporting the new memory manager. Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver. AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected to do that, as well as taking care of cache- and tlb flushing when needed. It's not possible to request these types from user space using agpgart ioctls. The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT. Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-02-28[AGPGART] Lots of CodingStyle/whitespace cleanups.Dave Jones
Eliminate trailing whitespace. s/if(/if (/ s/for(/for (/ Signed-off-by: Dave Jones <davej@redhat.com>
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-11-08[PATCH] i460-agp warning fixesAndrew Morton
drivers/char/agp/i460-agp.c: In function `i460_fetch_size': drivers/char/agp/i460-agp.c:115: warning: size_t format, long unsigned int arg (arg 2) drivers/char/agp/i460-agp.c:115: warning: size_t format, long unsigned int arg (arg 3) drivers/char/agp/i460-agp.c: In function `i460_mask_memory': drivers/char/agp/i460-agp.c:542: warning: integer constant is too large for "long" type Note that the i460_mask_memory() change is a guess. But a good one, I suspect. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-11-08[PATCH] AGP performance fixesAlan Hourihane
AGP allocation/deallocation is suffering major performance issues due to the nature of global_flush_tlb() being called on every change_page_attr() call. For small allocations this isn't really seen, but when you start allocating 50000 pages of AGP space, for say, texture memory, then things can take seconds to complete. In some cases the situation is doubled or even quadrupled in the time due to SMP, or a deallocation, then a new reallocation. I've had a case of upto 20 seconds wait time to deallocate and reallocate AGP space. This patch fixes the problem by making it the caller's responsibility to call global_flush_tlb(), and so removes it from every instance of mapping a page into AGP space until the time that all change_page_attr() changes are done. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-11-07Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgartLinus Torvalds
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-24[AGPGART] Set .owner field of struct pci_driver.Dave Jones
From: Laurent Riffard <laurent.riffard@free.fr> This updates .owner field of struct pci_driver. This allows SYSFS to create the symlink from the driver to the module which provides it. $ tree /sys/bus/pci/drivers/agpgart-via/ /sys/bus/pci/drivers/agpgart-via/ |-- 0000:00:00.0 -> ../../../../devices/pci0000:00/0000:00:00.0 |-- bind |-- module -> ../../../../module/via_agp |-- new_id `-- unbind Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-10-20[AGPGART] Replace kmalloc+memset's with kzalloc'sDave Jones
2005-06-07[PATCH] AGP fix for Xen VMMKeir Fraser
When Linux is running on the Xen virtual machine monitor, physical addresses are virtualised and cannot be directly referenced by the AGP GART. This patch fixes the GART driver for Xen by adding a layer of abstraction between physical addresses and 'GART addresses'. Architecture-specific functions are also defined for allocating and freeing the GATT. Xen requires this to ensure that table really is contiguous from the point of view of the GART. These extra interface functions are defined as 'no-ops' for all existing architectures that use the GART driver. Signed-off-by: Keir Fraser <keir@xensource.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
