commit 48a719c238bcbb72d6da79de9c5b3b93ab472107 upstream.
Simplify if-statement while at it.
[ hpa: we need to #include <asm/smp.h> ]
Cc: Dave Jones <davej@redhat.com>
Cc: David Airlie <airlied@linux.ie>
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
LKML-Reference: <1264172467-25155-3-git-send-email-bp@amd64.org>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
commit fc61901373987ad61851ed001fe971f3ee8d96a3 upstream.
Some BIOSes fail to initialise the GTT, which will cause DMA faults when
the IOMMU is enabled. We need to clear the whole thing to point at the
scratch page, not just the part that Linux is going to use.
[anholt: Note that this may also help with stability in the presence of
driver bugs, by not drawing to memory we don't own]
Signed-off-by: Eric Anholt <eric@anholt.net>
Cc: Zhenyu Wang <zhenyuw@linux.intel.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel:
drm/i915: Select CONFIG_SHMEM
drm/i915: Fix CRT hotplug detect by checking really no channels attached
agp/intel: new host bridge support
drm/i915: Add more registers save/restore for Ironlake suspend
drm/i915: Fix IRQ stall issue on Ironlake
drm/i915: HDMI hardware workaround for Ironlake
drm/i915: Fix and cleanup DPLL calculation for Ironlake
drm/i915: Avoid potential sleep whilst holding spinlock
We should set this before calling agp_add_bridge() so that it's done
before we map the scratch page too.
This should probably fix the regression reported as k.o. bug #14627.
Add new CPU host bridge id, needed for support Ironlake graphics
device with it. No change for graphics device itself, so no need to
update drm/i915.
Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com>
* 'drm-intel-next' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel: (57 commits)
drm/i915: Handle ERESTARTSYS during page fault
drm/i915: Warn before mmaping a purgeable buffer.
drm/i915: Track purged state.
drm/i915: Remove eviction debug spam
drm/i915: Immediately discard any backing storage for uneeded objects
drm/i915: Do not mis-classify clean objects as purgeable
drm/i915: Whitespace correction for madv
drm/i915: BUG_ON page refleak during unbind
drm/i915: Search harder for a reusable object
drm/i915: Clean up evict from list.
drm/i915: Add tracepoints
drm/i915: framebuffer compression for GM45+
drm/i915: split display functions by chip type
drm/i915: Skip the sanity checks if the current relocation is valid
drm/i915: Check that the relocation points to within the target
drm/i915: correct FBC update when pipe base update occurs
drm/i915: blacklist Acer AspireOne lid status
ACPI: make ACPI button funcs no-ops if not built in
drm/i915: prevent FIFO calculation overflows on 32 bits with high dotclocks
drm/i915: intel_display.c handle latency variable efficiently
Fix up trivial conflicts in drivers/gpu/drm/i915/{i915_dma.c|i915_drv.h}
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6
* 'agp-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6:
agp/intel: remove restore in resume
agp: fix uninorth build
intel-agp: Set dma mask for i915
agp: kill phys_to_gart() and gart_to_phys()
intel-agp: fix sglist allocation to avoid vmalloc()
intel-agp: Move repeated sglist free into separate function
agp: Switch agp_{un,}map_page() to take struct page * argument
agp: tidy up handling of scratch pages w.r.t. DMA API
intel_agp: Use PCI DMA API correctly on chipsets new enough to have IOMMU
agp: Add generic support for graphics dma remapping
agp: Switch mask_memory() method to take address argument again, not page
As early pci resume has already restored config for host
bridge and graphics device, don't need to restore it again,
This removes an original order hack for graphics device restore.
This fixed the resume hang issue found by Alan Stern on 845G,
caused by extra config restore on graphics device.
Cc: Stable Team <stable@kernel.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Dave Airlie <airlied@linux.ie>
Ever since we enabled GEM, the pre-9xx chipsets (particularly 865) have had
serious stability issues. Back in May a wbinvd was added to the DRM to
work around much of the problem. Some failure remained -- easily visible
by dragging a window around on an X -retro desktop, or by looking at bugzilla.
The chipset flush was on the right track -- hitting the right amount of
memory, and it appears to be the only way to flush on these chipsets, but the
flush page was mapped uncached. As a result, the writes trying to clear the
writeback cache ended up bypassing the cache, and not flushing anything! The
wbinvd would flush out other writeback data and often cause the data we wanted
to get flushed, but not always. By removing the setting of the page to UC
and instead just clflushing the data we write to try to flush it, we get the
desired behavior with no wbinvd.
This exports clflush_cache_range(), which was laying around and happened to
basically match the code I was otherwise going to copy from the DRM.
Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org>
Cc: stable@kernel.org
Signed-off-by: Fabian Henze <hoacha@quantentunnel.de>
[Fix reversed HB & IG ids for B43]
New variant of IGDNG mobile chip has new host bridge id.
[anholt: Note that this new PCI ID doesn't impact the DRM, which doesn't
care about the PCI ID of the bridge]
If DMAR is configured in but absent, we really do want to make sure that
the dma mask is set appropriately. Otherwise we get mapping failures on
highmem. Spotted by Zhenyu Wang.
There seems to be no reason for these -- they're a 1:1 mapping on all
platforms.
When graphics dma remapping engine is active, we must fill
gart table with dma address from dmar engine, as now graphics
device access to graphics memory must go through dma remapping
table to get real physical address.
Add this support to all drivers which use intel_i915_insert_entries()
Signed-off-by: Zhenyu Wang <zhenyu.z.wang@intel.com>
In commit 07613ba2 ("agp: switch AGP to use page array instead of
unsigned long array") we switched the mask_memory() method to take a
'struct page *' instead of an address. This is painful, because in some
cases it has to be an IOMMU-mapped virtual bus address (in fact,
shouldn't it _always_ be a dma_addr_t returned from pci_map_xxx(), and
we just happen to get lucky most of the time?)
Otherwise, the high bits to be stuffed in the unused lower bits of the
page address are lost.
Signed-off-by: Pierre Willenbrock <pierre@pirsoft.de>
This switches AGP to use an array of pages for tracking the
pages allocated to the GART. This should enable GEM on PAE to work
a lot better as we can pass highmem pages to the PAT code and it will
do the right thing with them.
Both desktop and mobile versions are added.
Support the Intel 854 Chipset in fbdev.
We test and use the patch on a Thomson IP1101 IPTV-Box. On the VGA-Port
we get a normal signal.
Here is the link to the Mambux-Project: http://www.mambux.de
Cc: Keith Packard <keithp@keithp.com>
Cc: Dave Airlie <airlied@linux.ie>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
Signed-off-by: Stefan Husemann <shusemann@googlemail.com>
This is a G33-like desktop and mobile chipset.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
When GTT size is equal to amount of video memory, the amount of GTT
entries is computed lower than zero, which is invalid and leads to
off-by-one error in intel_i915_configure()
Originally posted here:
http://bugzilla.kernel.org/show_bug.cgi?id=12539
http://bugzilla.redhat.com/show_bug.cgi?id=445592
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
Cc: Lubomir Rintel <lkundrak@v3.sk>
Reviewed-by: Eric Anholt <eric@anholt.net>
Cc: <stable@kernel.org>
Update assorted email addresses and related info to point
to a single current, valid address.
additionally
- trivial CREDITS entry updates. (Not that this file means much any more)
- remove arjans dead redhat.com address from powernow driver
Signed-off-by: Dave Jones <davej@redhat.com>
agp/nvidia: Support agp user-memory on nvidia agp.
agp/amd-k7: Suspend support for AMD K7 GART driver
agp/intel: Reduce extraneous PCI posting reads during init
agp: Fix stolen memory counting on G4X.
Instead of doing a posting read after each GTT entry update, do a single one
at the end of the writes. This should reduce boot time a tiny amount by
avoiding a lot of extra uncached reads.
Signed-off-by: Keith Packard <keithp@keithp.com>
On the GM45, the amount of stolen memory mapped to the GTT was underestimated,
even though we had 508KB more available since the GTT doesn't take from
stolen memory. On the non-GM45 G4X, we overestimated how much stolen was
mapped to the GTT by 4KB, resulting in GPU page faults when that page was
accessed.
This update requires a corresponding update to xf86-video-intel to work
correctly.
arch/x86/mm/pageattr.c
Add agp_generic_destroy_pages(), it uses new pageattr array interface API.
Signed-off-by: Dave Airlie <airlied@gmail.com>
Add agp_generic_alloc_pages(), it uses new pageattr array interface API.
On my Intel chipset (965GM), the GTT is entirely erased across
suspend/resume. This patch simply re-plays the current mapping at resume
time to restore the table.=20
I noticed this once I started relying on persistent GTT mappings across VT
switch in our GEM work -- the old X server and DRM code carefully unbind
all memory from the GTT on VT switch, but GEM does not bother.
I placed the list management and rewrite code in the generic layer on the
assumption that it will be needed on other hardware, but I did not add the
rewrite call to anything other than the Intel resume function.
Keep a list of current GATT mappings. At resume time, rewrite them into
the GATT. This is needed on Intel (at least) as the entire GATT is
cleared across suspend/resume.
Cc: Dave Jones <davej@codemonkey.org.uk>
Convert printks to use dev_printk().
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
no more whitespace diffs for me.
This adds missing stolen memory size detect for IGD_GM, be sure to
detect right size as current X intel driver (2.3.2) which has already
worked out.
Use boolean in AGP instead of having own TRUE/FALSE
besides it apparently being useful only in 2.6.24 (the changes in 2.6.25
really mean that it could be converted back to a single-stage mechanism),
I'm seeing an issue in Xen Dom0 kernels, which is caused by the calling
of gart_to_virt() in the second stage invocations of the destroy function.
I think that besides this being a real issue with Xen (where
unmap_page_from_agp() is not just a page table attribute change), this
also is invalid from a theoretical perspective: One should not assume that
gart_to_virt() is still valid after unmapping a page. So minimally (keeping
the 2-stage mechanism) a patch like the one below would be needed.
Jan
Add a new IS_I915 and also do some checkpatch whitespace cleanups.
Change origin chipset name i965G_1 to market name G35.
The flush code resource handling was having problems where some BIOS
reserve the resource in a pnp block and some don't.
Also there was a bug in that configure was being called at resume
and resetting some of the structs.
This one adds new pci ids for Intel intergrated graphics chipset, with gtt
table access change on it and new gtt table size definition.
