[ Upstream commit eb3255ee8f6f4691471a28fbf22db5e8901116cd ]
Fix this makecheck warning:
drivers/parisc/sba_iommu.c:98:19: warning: symbol 'sba_list'
was not declared. Should it be static?
Signed-off-by: Helge Deller <deller@gmx.de>
[ Upstream commit d703797380c540bbeac03f104ebcfc364eaf47cc ]
Flush caches after changing gatt entries and calculate entry according
to SBA requirements.
[ Upstream commit 8d88382b7436551a9ebb78475c546b670790cbf6 ]
Reported-by: kernel test robot <lkp@intel.com>
Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
Allow binding of user memory to the AGP GART on systems with HP
Quicksilver AGP bus. This resolves 'bind memory failed' error seen in
dmesg:
[29.365973] [TTM] AGP Bind memory failed.
[29.367030] [drm] Forcing AGP to PCI mode
The system doesn't more fail to bind the memory, and hence not falling
back to the PCI mode (if other failures aren't detected).
This is just a simple write down from the following patches:
agp/amd-k7: Allow binding user memory to the AGP GART
agp/hp-agp: Allow binding user memory to the AGP GART
Signed-off-by: Alex Ivanov <gnidorah@p0n4ik.tk>
Cc: <stable@vger.kernel.org> # 3.10
Use the new pci_alloc_dev(bus) to replace the existing using of
alloc_pci_dev(void).
[bhelgaas: drop pci_bus ref later in pci_release_dev()]
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Neela Syam Kolli <megaraidlinux@lsi.com>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Commit 338e4fab added a missing kfree if the alloc_pci_dev failed
but forgot to include <linux/slab.h> for the definition of
kfree.
Signed-off-by: Kyle McMartin <kyle@redhat.com>
alloc_pci_dev allocates some memory, so that memory should be freed before
leaving the function in an error case.
A simplified version of the semantic match that finds this problem is:
(http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
local idexpression x;
expression E;
identifier f1;
iterator I;
x = alloc_pci_dev(...);
<... when != x
when != true (x == NULL || ...)
when != if (...) { <+...x...+> }
when != I (...) { <+...x...+> }
x == NULL
x == E
x->f1
* return ...;
// </smpl>
Dan Carpenter <error27@gmail.com>
Dave Airlie <airlied@linux.ie>
Cc: Helge Deller <deller@gmx.de>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
This commit:
Commit 2a4ceb6d3e6a566cb4a9dc8f974177f031d27cd7
Author: David Woodhouse <David.Woodhouse@intel.com>
Date: Mon Jul 27 10:27:29 2009 +0100
agp: Switch mask_memory() method to take address argument again, not page
broke the parisc AGP driver (again). This patch fixes it.
Acked-by: Dave Airlie <airlied@redhat.com>
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
In commit 07613ba2 ("agp: switch AGP to use page array instead of
unsigned long array") we switched the mask_memory() method to take a
'struct page *' instead of an address. This is painful, because in some
cases it has to be an IOMMU-mapped virtual bus address (in fact,
shouldn't it _always_ be a dma_addr_t returned from pci_map_xxx(), and
we just happen to get lucky most of the time?)
Fix those compiler warnings, which indeed point to a bug:
drivers/char/agp/parisc-agp.c:228: warning: initialization from incompatible pointer type
drivers/char/agp/parisc-agp.c:201: warning: 'parisc_agp_page_mask_memory' defined but not used
This switches AGP to use an array of pages for tracking the
pages allocated to the GART. This should enable GEM on PAE to work
a lot better as we can pass highmem pages to the PAT code and it will
do the right thing with them.
commit 11c3b5c3e08f4d855cbef52883c266b9ab9df879
Author: Greg Kroah-Hartman <gregkh@suse.de>
Date: Tue Dec 16 12:24:56 2008 -0800
driver core: move klist_children into private structure
Broke our parisc build pretty badly because we touch the klists directly
in three cases (AGP, SBA and GSC). Although GregKH will revert this
patch, there's no reason we should be using the iterators directly, we
can just move to the standard device_for_each_child() API.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Tested-by: Helge Deller <deller@gmx.de>
Tested-by: Kyle McMartin <kyle@mcmartin.ca>
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6:
parisc: convert to generic compat_sys_ptrace
parisc: add rtc platform driver
parisc: initialize unwinder much earlier
parisc: add new syscalls
parisc: hijack jump to start_kernel
parisc: add pdc_coproc_cfg_unlocked and set_firmware_width_unlocked
parisc: move include/asm-parisc to arch/parisc/include/asm
parisc: move pdc_result to real2.S
parisc: unify CCIO_COLLECT_STATS implementation
parisc: add arch/parisc/kernel/.gitignore
parisc: ropes.h - fix <asm-parisc/*> -> <asm/*>
parisc: parisc-agp - fix <asm-parisc/*> -> <asm/*>
Resolve remove/rename conflict: include/asm-parisc/a.out.h is no longer
relevant.
The pageattr-array patch that you currently have in tip/master only
enables it for intel-agp, not the others. The attached enables it for
all drivers currently directly using agp_generic_alloc_page() and
agp_generic_destroy_page() (ocal driver is amd-k7-agp).
The new agp_generic_alloc_pages() interface uses the also new
pageattr array interface API. This makes all AGP drivers that
up to now used generic_{alloc,destroy}_page() use it.
Signed-off-by: Rene Herman <rene.herman@gmail.com>
Use boolean in AGP instead of having own TRUE/FALSE
It's *wrong* to have
#define log2(n) ffz(~(n))
It should be *reversed*:
#define log2(n) flz(~(n))
or
#define log2(n) fls(n)
or just use
ilog2(n) defined in linux/log2.h.
This patch follows the last solution, recommended by Andrew Morton.
Cc: <linux-ext4@vger.kernel.org>
Cc: Mingming Cao <cmm@us.ibm.com>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Chris Ahna <christopher.j.ahna@intel.com>
Cc: David Mosberger-Tang <davidm@hpl.hp.com>
Cc: Kyle McMartin <kyle@parisc-linux.org>
Cc: Dave Airlie <airlied@linux.ie>
Cc: Dave Jones <davej@codemonkey.org.uk>
Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn>
Convert code that allocs a struct pci_dev to use alloc_pci_dev().
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Can't really blame davej for mucking this up... static-ify
it while we're at it, which would have prevented this...
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
* master.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6: (78 commits)
[PARISC] Use symbolic last syscall in __NR_Linux_syscalls
[PARISC] Add missing statfs64 and fstatfs64 syscalls
Revert "[PARISC] Optimize TLB flush on SMP systems"
[PARISC] Compat signal fixes for 64-bit parisc
[PARISC] Reorder syscalls to match unistd.h
Revert "[PATCH] make kernel/signal.c:kill_proc_info() static"
[PARISC] fix sys_rt_sigqueueinfo
[PARISC] fix section mismatch warnings in harmony sound driver
[PARISC] do not export get_register/set_register
[PARISC] add ENTRY()/ENDPROC() and simplify assembly of HP/UX emulation code
[PARISC] convert to use CONFIG_64BIT instead of __LP64__
[PARISC] use CONFIG_64BIT instead of __LP64__
[PARISC] add ASM_EXCEPTIONTABLE_ENTRY() macro
[PARISC] more ENTRY(), ENDPROC(), END() conversions
[PARISC] fix ENTRY() and ENDPROC() for 64bit-parisc
[PARISC] Fixes /proc/cpuinfo cache output on B160L
[PARISC] implement standard ENTRY(), END() and ENDPROC()
[PARISC] kill ENTRY_SYS_CPUS
[PARISC] clean up debugging printks in smp.c
[PARISC] factor syscall_restart code out of do_signal
Fix conflict in include/linux/sched.h due to kill_proc_info() being made
publicly available to PARISC again.
Make agp_bridge_driver->aperture_sizes and ->masks const.
Also agp_bridge_data->driver
Signed-off-by: Dave Jones <davej@redhat.com>
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
