path: root/drivers/char/agp/sworks-agp.c
2009-08-03agp: kill phys_to_gart() and gart_to_phys()David Woodhouse
There seems to be no reason for these -- they're a 1:1 mapping on all platforms. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-08-03agp: Switch mask_memory() method to take address argument again, not pageDavid Woodhouse
In commit 07613ba2 ("agp: switch AGP to use page array instead of unsigned long array") we switched the mask_memory() method to take a 'struct page *' instead of an address. This is painful, because in some cases it has to be an IOMMU-mapped virtual bus address (in fact, shouldn't it _always_ be a dma_addr_t returned from pci_map_xxx(), and we just happen to get lucky most of the time?) Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-19agp: switch AGP to use page array instead of unsigned long arrayDave Airlie
This switches AGP to use an array of pages for tracking the pages allocated to the GART. This should enable GEM on PAE to work a lot better as we can pass highmem pages to the PAT code and it will do the right thing with them. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-08-22agp: enable optimized agp_alloc_pages methodsRene Herman
The pageattr-array patch that you currently have in tip/master only enables it for intel-agp, not the others. The attached enables it for all drivers currently directly using agp_generic_alloc_page() and agp_generic_destroy_page() (ocal driver is amd-k7-agp). The new agp_generic_alloc_pages() interface uses the also new pageattr array interface API. This makes all AGP drivers that up to now used generic_{alloc,destroy}_page() use it. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-12agp: use dev_printk when possibleBjorn Helgaas
Convert printks to use dev_printk(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-06-19drivers/char/agp - use boolJoe Perches
Use boolean in AGP instead of having own TRUE/FALSE -- Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-02-20agp: fix missing casts that produced a warning.Dave Airlie
2008-02-19fix historic ioremap() abuse in AGPArjan van dev Ven
Several AGP drivers right now use ioremap_nocache() on kernel ram in order to turn a page of regular memory uncached. There are two problems with this: 1) This is a total nightmare for the ioremap() implementation to keep various mappings of the same page coherent. 2) It's a total nightmare for the AGP code since it adds a ton of complexity in terms of keeping track of 2 different pointers to the same thing, in terms of error handling etc etc. This patch fixes this by making the AGP drivers use the new set_memory_XX APIs instead. Note: amd-k7-agp.c is built on Alpha too, and generic.c is built on ia64 as well, which do not yet have the set_memory_*() APIs, so for them some we have a few ugly #ifdefs - hopefully they'll be fixed soon. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-04-26[AGPGART] sworks-agp: Switch to PCI ref counting APIsAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-22[AGPGART] Further constification.Dave Jones
Make agp_bridge_driver->aperture_sizes and ->masks const. Also agp_bridge_data->driver Signed-off-by: Dave Jones <davej@redhat.com>
2007-02-03[AGPGART] Allow drm-populated agp memory typesThomas Hellstrom
This patch allows drm to populate an agpgart structure with pages of its own. It's needed for the new drm memory manager which dynamically flips pages in and out of AGP. The patch modifies the generic functions as well as the intel agp driver. The intel drm driver is currently the only one supporting the new memory manager. Other agp drivers may need some minor fixing up once they have a corresponding memory manager enabled drm driver. AGP memory types >= AGP_USER_TYPES are not populated by the agpgart driver, but the drm is expected to do that, as well as taking care of cache- and tlb flushing when needed. It's not possible to request these types from user space using agpgart ioctls. The Intel driver also gets a new memory type for pages that can be bound cached to the intel GTT. Signed-off-by: Thomas Hellstrom <thomas@tungstengraphics.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-02-28[AGPGART] Lots of CodingStyle/whitespace cleanups.Dave Jones
Eliminate trailing whitespace. s/if(/if (/ s/for(/for (/ Signed-off-by: Dave Jones <davej@redhat.com>
2006-02-12[AGPGART] Improve the error message shown when we detect a ServerWorks CNB20HEDave Jones
This chipset is unsupported, and likely to remain that way. Signed-off-by: Dave Jones <davej@redhat.com>
2006-01-08[PATCH] fix more missing includesTim Schmielau
Include fixes for 2.6.14-git11. Should allow to remove sched.h from module.h on i386, x86_64, arm, ia64, ppc, ppc64, and s390. Probably more to come since I haven't yet checked the other archs. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-11-07Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgartLinus Torvalds
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-24[AGPGART] Set .owner field of struct pci_driver.Dave Jones
From: Laurent Riffard <laurent.riffard@free.fr> This updates .owner field of struct pci_driver. This allows SYSFS to create the symlink from the driver to the module which provides it. $ tree /sys/bus/pci/drivers/agpgart-via/ /sys/bus/pci/drivers/agpgart-via/ |-- 0000:00:00.0 -> ../../../../devices/pci0000:00/0000:00:00.0 |-- bind |-- module -> ../../../../module/via_agp |-- new_id `-- unbind Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-10-20[AGPGART] Replace kmalloc+memset's with kzalloc'sDave Jones
2005-09-23[AGPGART] Fix serverworks TLB flush.Dave Jones
Go back to what 2.4 kernels used to do here, as if this hits, the kernel just hangs indefinitly. Actually an improvement over 2.4 - we now break; out of the loop instead of just printing messages on timeouts. Signed-off-by: Dave Jones <davej@redhat.com>
2005-06-07[PATCH] AGP fix for Xen VMMKeir Fraser
When Linux is running on the Xen virtual machine monitor, physical addresses are virtualised and cannot be directly referenced by the AGP GART. This patch fixes the GART driver for Xen by adding a layer of abstraction between physical addresses and 'GART addresses'. Architecture-specific functions are also defined for allocating and freeing the GATT. Xen requires this to ensure that table really is contiguous from the point of view of the GART. These extra interface functions are defined as 'no-ops' for all existing architectures that use the GART driver. Signed-off-by: Keir Fraser <keir@xensource.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2005-05-01[PATCH] make lots of things staticAdrian Bunk
Another large rollup of various patches from Adrian which make things static where they were needlessly exported. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
