path: root/drivers/char/briq_panel.c
2008-06-20briq_panel: BKL pushdownArnd Bergmann
2007-07-10[POWERPC] Remove dead code for preventing pread() and pwrite() callsRobert P. J. Day
Remove the deactivated code for checking for pread() and pwrite() calls on the PPC-based BRIQ. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Rename get_property to of_get_property: driversStephen Rothwell
These are all the remaining instances of get_property. Simple rename of get_property to of_get_property. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-26Revert "[POWERPC] Rename get_property to of_get_property: drivers"Paul Mackerras
This reverts commit d05c7a80cf39ae7d0f8d0c3e47c93d51fcd393d3, which included changes which should go via other subsystem maintainers.
2007-04-24[POWERPC] Remove old interface find_path_deviceStephen Rothwell
Replaced by of_find_node_by_path. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] Rename get_property to of_get_property: driversStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-12[PATCH] mark struct file_operations const 3Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-23[PATCH] briq_panel: read() and write() get __user pointers, damnitAl Viro
annotated, fixed a roothole in ->write(). Dereferencing user-supplied pointer is a Bad Idea(tm)... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-23[PATCH] more fallout from get_property returning pointer to constAl Viro
2006-07-07[POWERPC] Add support for briq front panelBenjamin Herrenschmidt
This adds the driver for the Briq front panel. This is a cleaned up version of a driver that has been floating around for some time now, initially written by Karsten Jeppesen <karsten@jeppesens.com> and cleaned up by jk and myself. Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
