path: root/drivers/char/drm/drm_pciids.h
2008-07-14drm: reorganise drm tree to be more future proof.Dave Airlie
With the coming of kernel based modesetting and the memory manager stuff, the everything in one directory approach was getting very ugly and starting to be unmanageable. This restructures the drm along the lines of other kernel components. It creates a drivers/gpu/drm directory and moves the hw drivers into subdirectores. It moves the includes into an include/drm, and sets up the unifdef for the userspace headers we should be exporting. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-06-20drm/i915: add support for Intel series 4 chipsets.Zhenyu Wang
Signed-off-by: Zhenyu Wang <zhenyu.z.wang@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-06-19drm/radeon: merge IGP chip setup and fixup RS400 vs RS480 supportAlex Deucher
We only support RS480 (AMD based IGP) at the moment not RS400 (Intel based IGP) ones. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-03-17drm/radeon: fixup RV550 chip familyAlex Deucher
This fixes up the RV550 chips which are based on RV515, not RV530. It also adds another RS690 PCI ID. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-02-20drm/sis: add pciid for SiS 662/671 chipsetChaoyu Chen
2008-02-20drm: add new rv380 pciidMirko
2008-02-20drm/radeon: add initial rs690 support to drm.Maciej Cencora
This adds support for configuring the RS690 GART. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-02-07drm: add initial r500 drm supportDave Airlie
This adds CP support for the r500 series of chips, and allows accel 2D support on these chips with a new radeon driver. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-02-07i915: Add chipset id for Intel Integrated Graphics DeviceZhenyu Wang
This adds new chipset id in drm. Signed-off-by: Zhenyu Wang <zhenyu.z.wang@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-02-07drm: run cleanfile across drm treeDave Airlie
Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-01-23drm/i915: add support for E7221 chipsetCarlos Martín
E7221 chipset is a server version of the i915. Signed-off-by: Dave Airlie <airlied@linux.ie> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15via invalid device ids removalXavier Bachelot
0x1106, 0x7204 is unknown and thus is not an IGP/GPU. 0x1106, 0x3304 is K8M800 hostbridge, not an IGP/GPU. None of them are in drm git tree. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2007-06-27Add support SiS based XGI chips to SiS DRM.Ian Romanick
This adds support for some of the XGI Volari family that are based on the SiS. Signed-off-by: Dave Airlie <airlied@linux.ie> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-10drm/i915: Add support for the G33, Q33, and Q35 chipsets.Wang Zhenyu
These require that the status page be referenced by a pointer in GTT, rather than phsyical memory. So, we have the X Server allocate that memory and tell us the address, instead. Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-06-10i915: add new pciids for 945GME, 965GME/GLEWang Zhenyu
2007-05-26drm/radeon: add more IGP chipset pci idsDave Airlie
Add more IGP chipset PCI IDs Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-05-08drm/radeon: upgrade to 1.27 - make PCI GART more flexibleDave Airlie
radeon: make PCI GART aperture size variable, but making table size variable This is precursor to getting a TTM backend for this stuff, and also allows the PCI table to be allocated at fb 0 radeon: add support for reverse engineered xpress200m The IGPGART setup code was traced using mmio-trace on fglrx by myself and Phillip Ezolt <phillipezolt@gmail.com> on dri-devel. This code doesn't let the 3D driver work properly as the card has no vertex shader support. Thanks to Matthew Garrett + Ubuntu for providing me some hardware to do this work on. Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-04-26drm/i915: Add 965GM pci id updateWang Zhenyu
2007-03-11via: fix CX700 pci idThomas Hellstrom
2007-02-08via: add some new chipsetsThomas Hellstrom
Disable 3D functionality and AGP DMA for chipsets with the DX9 3D engine. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-09-22drm: use radeon specific names for radeon flagsDave Airlie
2006-09-22drm: allow detection of new VIA chipsetsChuck Short
Update pci ids. patch location: http://www.kernel.org/git/?p=linux/kernel/git/bcollins/ubuntu-dapper.git;a=c ommitdiff;h=5195a64a27550a279b2ecaf400066a3823f2d053 Signed-off-by: Chuck Short <zulcss@gmail.com> Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-09-22drm: Add support for Intel i965G chipsets.Alan Hourihane
This is a patch prepared by Guangdeng Liao based off of Tungsten Graphics's final code drop. From: Alan Hourihane <alanh@tungstengraphics.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-09-22drm: SiS 315 Awareness.Thomas Hellstrom
Add support for the SiS 315 to the DRM. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-09-22drm: Add the P4VM800PRO (?) PCI ID.Dave Airlie
2006-03-25drm: add new radeon PCI ids..Dave Airlie
This adds all the r300 and r400 PCI ids from DRM CVS, it also makes these cards only initialise when the new xorg driver is used, as otherwise the DRM can cause lockups. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-03-19drm: rationalise some pci idsDave Airlie
This is the start of some work from Roland Scheidegger to align the X DDX pci ids and the drm ones, however we don't want to put r300 ids in the kernel just yet, they destabilise a few machines. From: Roland Scheidegger (via DRM CVS) Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-02-13[PATCH] Remove "RV370 5B60 [Radeon X300 (PCIE)]" from DRI listDave Jones
I get a machine check exception, triple fault, or NMI watchdog lockup when DRI gets enabled on this card. (And Mauro Tassinari <mtassinari@cmanet.it> reports hung kernels too in http://lkml.org/lkml/2006/1/26/97) [ Adrian Bunk also states that this is the only RV350 entry for an RV370 in our lists, which implies that it's just buggy ] Cc: Adrian Bunk <bunk@stusta.de> Cc: Dave Jones <davej@redhat.com> Cc: Mauro Tassinari <mtassinari@cmanet.it> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-25drm: add X600 PCI IDsDave Airlie
From: Brice Goglin <Brice.Goglin@ens-lyon.org> Now that Xorg 6.9/7.0 has been released, DRI is supported on more Radeon cards without ATI proprietary drivers. I got my X300 to work without problem. But, another Radeon X600 required to add its PCI ids to the Radeon driver. Patch is attached. I can't be sure about the "CHIP_RV350", I copied it from the X300 entry (from http://dri.freedesktop.org/wiki/ATIRadeon, X600 is a rv380 chip while X300 is a rv370). But, at least it works now. Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-01-25drm: add i945GM PCI IDDave Airlie
From: Charles F. Johnson <charles.f.johnson@intel.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-01-02drm: update drm pci ids listDave Airlie
2005-09-25drm: lindent the drm directory.Dave Airlie
I've been threatening this for a while, so no point hanging around. This lindents the DRM code which was always really bad in tabbing department. I've also fixed some misnamed files in comments and removed some trailing whitespace. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-08-16drm: update pci ids for savage and viaDave Airlie
Fixup savage and via pci ids From: Dave Airlie <airlied@linux.ie>
2005-08-16drm: add initial r300 3D support.Dave Airlie
This adds initial r300 3D support to the radeon DRM. From: Nicolai Haehnle, Vladimir Dergachev, and others. Signed-off-by: David Airlie <airlied@linux.ie>
2005-08-05drm: remove the gamma driverDave Airlie
The gamma driver has been broken for quite a while, it doesn't build, we don't have a userspace, mine is in Ireland etc... Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-07-10drm: add new mga ids and typesDave Airlie
From: Ian Romanick <idr@us.ibm.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-06-28drm: Add via unichrome supportDave Airlie
Add DRM device driver for VIA Unichrome chipsets From: Unichrome Project http://unichrome.sf.net, Erdi Chen, Thomas Hellstrom Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-06-10[PATCH] drm add i945G pci idDave Airlie
Add pci identifier for i945G chipset Signed-off-by: Dave Airlie <airlied@linux.ie>
