path: root/drivers/char/drm/drm_scatter.c
2008-03-30drm: fix for non-coherent DMA PowerPCBenjamin Herrenschmidt
This patch fixes bits of the DRM so to make the radeon DRI work on non-cache coherent PCI DMA variants of the PowerPC processors. It moves the few places that needs change to wrappers to that other architectures with similar issues can easily add their own changes to those wrappers, at least until we have more useful generic kernel API. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-02-07drm: cleanup DRM_DEBUG() parametersMárton Németh
As DRM_DEBUG macro already prints out the __FUNCTION__ string (see drivers/char/drm/drmP.h), it is not worth doing this again. At some other places the ending "\n" was added. airlied:- I cleaned up a few that this patch missed also Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-10-15drm: Replace DRM_IOCTL_ARGS with (dev, data, file_priv) and remove DRM_DEVICE.Eric Anholt
The data is now in kernel space, copied in/out as appropriate according to t This results in DRM_COPY_{TO,FROM}_USER going away, and error paths to deal with those failures. This also means that XFree86 4.2.0 support for i810 DR is lost. Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-10-15drm: Replace filp in ioctl arguments with drm_file *file_priv.Eric Anholt
As a fallout, replace filp storage with file_priv storage for "unique identifier of a client" all over the DRM. There is a 1:1 mapping, so this should be a noop. This could be a minor performance improvement, as everyth on Linux dereferenced filp to get file_priv anyway, while only the mmap ioct went the other direction. Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-07-11drm: detypedeffing continues...Dave Airlie
2007-07-11drm: remove drm_file_t, drm_device_t and drm_head_t typedefsDave Airlie
some drivers still todo. Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-07-11drm: remove a bunch of typedefs on the userspace interfaceDave Airlie
This moves a bunch of typedefs into a !defined __KERNEL__ to keep userspace API compatiblity, it changes all internal usages to structs/enum/unions. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-09-25drm: lindent the drm directory.Dave Airlie
I've been threatening this for a while, so no point hanging around. This lindents the DRM code which was always really bad in tabbing department. I've also fixed some misnamed files in comments and removed some trailing whitespace. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-08-05drm: updated DRM map patch for 32/64 bit systemsDave Airlie
I basically combined Paul's patches with additions that I had made for PCI scatter gather. I also tried more carefully to avoid problems with the same token assigned multiple times while trying to use the base address in the token if possible to gain as much backward compatibility as possible for broken DRI clients. From: Paul Mackerras <paulus@samba.org> and Egbert Eich <eich@suse.de> Signed-off-by: Dave Airlie <airlied@linux.ie>
