path: root/drivers/char/drm/drm_sman.h
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-07-12drm: detypedef the hashtab and more of smanDave Airlie
Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-07-12drm: de-typedef smanDave Airlie
2006-09-22drm: remove FALSE/TRUE that snuck in with simple memory manager changes.Andrew Morton
Thanks to Andrew Morton for pointing these out, I've fixed a few his patch missed. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-09-22drm: add simple DRM memory manager, and hash tableThomas Hellstrom
This adds the DRM hashtable and simple memory manager implementations from Tungsten Graphics, this is NOT the new memory manager, this is a replacement for the SIS and VIA memory managers. Signed-off-by: Dave Airlie <airlied@linux.ie>
