path: root/drivers/char/drm/drm_stub.c
2008-04-26drm: reorganise minor number handling using backported modesetting code.Dave Airlie
rips out the head crap and replaces it with an idr and drm_minor structure Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-02-07drm: the drm really should call pci_set_master..Dave Airlie
perhaps bonghits could turn on my bus-mastering because the drm certainly never bothered doing it before. Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-02-07drm: call driver load function after initialising AGPDave Airlie
needed to intel chipset flushing Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-02-07drm: update DRM sysfs supportJesse Barnes
Make DRM devices use real Linux devices instead of class devices, which are going away. While we're at it, clean up some of the interfaces to take struct drm_device * or struct device * and use the global drm_class where needed instead of passing it around. Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-02-07drm: run cleanfile across drm treeDave Airlie
2007-07-17drm: add idr_init to drm_stub.cDave Airlie
Brown paper bag for me this patch chunk didn't make it in the first application Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-07-11drm: remove drm_file_t, drm_device_t and drm_head_t typedefsDave Airlie
some drivers still todo. Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-07-11drm: cleanup list initialisationDave Airlie
2007-07-11drm: cleanup use of Linux list handling macrosDave Airlie
This makes the drms use of the list handling macros a lot cleaner and more along the lines of how they should be used and uses them in some more places. Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-03-23drm: fix driver deadlock with AIGLX and reclaim_buffers_lockedThomas Hellstrom
Bugzilla Bug #9457 Add refcounting of user waiters to the DRM hardware lock, so that we can use DRM_LOCK_CONT flag more conservatively. Also add a kernel waiter refcount that if nonzero transfers the lock for the kernel context when it is released. This is useful when waiting for idle and can be used for very simple fence object driver implementations for the new memory manager Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-12-11DRM: handle pci_enable_device failureJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-12-07drm: Make locked tasklet handling more robust.=?utf-8?q?Michel_D=C3=A4nzer?=
Initialize the spinlock unconditionally when struct drm_device is filled in, and return early in drm_locked_tasklet() if the driver doesn't support IRQs. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-12-07drm: Add support for tracking drawable information to core=?utf-8?q?Michel_D=C3=A4nzer?=
Actually make the existing ioctls for adding and removing drawables do something useful, and add another ioctl for the X server to update drawable information. The only kind of drawable information tracked so far is cliprects. Only reallocate cliprect memory if the number of cliprects changes. Also improve diagnostic output. hook up drm ioctl update draw export drm_get_drawable_info symbol Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-09-22drm: add device/vendor id to drm_device_t for compat with FreeBSD driversEric Anholt
2006-09-22drm: update user token hashing and map handlesThomas Hellstrom
Keep hashed user tokens, with the following changes: 32-bit physical device addresses are mapped directly to user-tokens. No duplicate maps are allowed, and the addresses are assumed to be outside of the range 0x10000000 through 0x30000000. The user-token is identical to the 32-bit physical start-address of the map. 64-bit physical device addressed are mapped to user-tokens in the range 0x10000000 to 0x30000000 with page-size increments. The user_token should not be interpreted as an address. Other map types, like upcoming TTM maps are mapped to user-tokens in the range 0x10000000 to 0x30000000 with page-size increments. The user_token should not be interpreted as an address. Implement hashed map lookups. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-09-22drm: remove the DRM pci domainDave Airlie
This patch removes the pci_domain from the DRM device structure, and gets it via a macro that either asks the platform or does the alpha special case. jgarzik asked for this to just use the platform magic, but I've no alpha experience and I'd rather not just break it and wait for someone to give out. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-09-22drm: remove local copies of pci bus/slot/funcDave
The drm keeps a local copy of these for little use. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-04-23drm: possible cleanupsDave Airlie
This patch contains the following possible cleanups: - make the following needlessly global function static: - drm_bufs.c: drm_addbufs_fb() - remove the following unused EXPORT_SYMBOL's: - drm_agpsupport.c: drm_agp_bind_memory - drm_bufs.c: drm_rmmap_locked - drm_bufs.c: drm_rmmap - drm_stub.c: drm_get_dev Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-02-06[PATCH] DRM: fix up classdev interface for drm coreGreg Kroah-Hartman
Current drm code doesn't work with userspace programs that listen only to the kernel event netlink socket as it is trying to create its own dev interface. Turns out lots of code can just be deleted as the driver core can do all of this work automatically for you. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-02sem2mutex: drivers/char/drm/Dave Airlie
From: Arjan van de Ven <arjan@infradead.org> Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-01-02drm: major update from CVS for radeon and coreDave Airlie
This patch pull in a lot of changes from CVS to the main core DRM, and updates the radeon driver to 1.21.0 that supports r300 texrect and radeon card type ioctl. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-11-11drm: simplify sysfs code for drmDave Airlie
This simplifies the sysfs code for the drm and add a dri_library_name attribute which can be used by a userspace app to figure out which library to load. From: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-11-10drm: rename driver hooks more understandablyDave Airlie
Rename the driver hooks in the DRM to something a little more understandable: preinit -> load postinit -> (removed) presetup -> firstopen postsetup -> (removed) open_helper -> open prerelease -> preclose free_filp_priv -> postclose pretakedown -> lastclose postcleanup -> unload release -> reclaim_buffers_locked version -> (removed) postinit and version were replaced with generic code in the Linux DRM (drivers now set their version numbers and description in the driver structure, like on BSD). postsetup wasn't used at all. Fixes the savage hooks for initializing and tearing down mappings at the right times. Testing involved at least starting X, running glxgears, killing glxgears, exiting X, and repeating. Tested on: FreeBSD (g200, g400, r200, r128) Linux (r200, savage4) From: Eric Anholt <anholt@freebsd.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-10-20merge Linus head tree into my drm tree and fix up conflictsDave Airlie
2005-10-05[PATCH] Fix drm 'debug' sysfs permissionsDave Jones
Just enables some extra printk's, but still.. Only the sysadmin should be able to do that. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-25drm: lindent the drm directory.Dave Airlie
I've been threatening this for a while, so no point hanging around. This lindents the DRM code which was always really bad in tabbing department. I've also fixed some misnamed files in comments and removed some trailing whitespace. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-07-10drm: cleanup buffer/map codeDave Airlie
This is a patch from DRM CVS that cleans up some code that was in CVS that I never moved to the kernel, this patch produces the result of the cleanups and puts it into the kernel drm. From: Eric Anholt <anholt@freebsd.org>, Jon Smirl, Dave Airlie Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-07-10drm: add test for AGP devices and driver override for it.Dave Airlie
Added device_is_agp callback to drm_driver. This function is called by the platform-specific drm_device_is_agp function. Added implementation of this function the the Linux-specific portion of the MGA driver to detect PCI G450 cards. Added code to the Linux-specific portion of the generic DRM layer to not initialize AGP infrastructure if the card is not AGP (this matches what already existed in BSD). Fix up i810/i830 and i915 drivers to always return AGP as they don't always report the capability. Fix the MGA to not report AGP for a card that has an AGP chip behind a PCI bridge. From: Ian Romanick, Dave Airlie, Alan Hourihane Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-07-07drm: misc cleanupDave Airlie
This patch contains the following cleanups: - make needlessly global functions static - remove the following unused global functions: - drm_fops.c: drm_read - i915_dma.c: i915_do_cleanup_pageflip Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave Airlie <airlied@linux.ie>
