path: root/drivers/char/drm/i915_dma.c
2006-01-25drm: i915 patches from Tungsten GraphicsDave Airlie
Fix CMDBUFFER path, add heap destroy and flesh out sarea for rotation (Tungsten Graphics) From: Alan Hourihane <alanh@tungstengraphics.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-01-02drm: update to i915 1.3.0Dave Airlie
Add support for vblank ioctls to i915 driver From: Dave Airlie <airlied@linux.ie> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-01-02drm: move ioctl flags to a bit field of flagsDave Airlie
From: Dave Airlie Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-11-10drm: rename driver hooks more understandablyDave Airlie
Rename the driver hooks in the DRM to something a little more understandable: preinit -> load postinit -> (removed) presetup -> firstopen postsetup -> (removed) open_helper -> open prerelease -> preclose free_filp_priv -> postclose pretakedown -> lastclose postcleanup -> unload release -> reclaim_buffers_locked version -> (removed) postinit and version were replaced with generic code in the Linux DRM (drivers now set their version numbers and description in the driver structure, like on BSD). postsetup wasn't used at all. Fixes the savage hooks for initializing and tearing down mappings at the right times. Testing involved at least starting X, running glxgears, killing glxgears, exiting X, and repeating. Tested on: FreeBSD (g200, g400, r200, r128) Linux (r200, savage4) From: Eric Anholt <anholt@freebsd.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-09-25drm: fix some lindent damageDave Airlie
2005-09-25drm: lindent the drm directory.Dave Airlie
I've been threatening this for a while, so no point hanging around. This lindents the DRM code which was always really bad in tabbing department. I've also fixed some misnamed files in comments and removed some trailing whitespace. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-07-10drm: add test for AGP devices and driver override for it.Dave Airlie
Added device_is_agp callback to drm_driver. This function is called by the platform-specific drm_device_is_agp function. Added implementation of this function the the Linux-specific portion of the MGA driver to detect PCI G450 cards. Added code to the Linux-specific portion of the generic DRM layer to not initialize AGP infrastructure if the card is not AGP (this matches what already existed in BSD). Fix up i810/i830 and i915 drivers to always return AGP as they don't always report the capability. Fix the MGA to not report AGP for a card that has an AGP chip behind a PCI bridge. From: Ian Romanick, Dave Airlie, Alan Hourihane Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-07-10drm: update support for drm pci buffersDave Airlie
The DRM needs to change the drm_pci interface for FreeBSD compatiblity, this patch introduces the drm_dma_handle_t and uses it in the Linux code. From: Tonnerre Lombard, Eric Anholt, and Sergey Vlasov Signed-off-by: David Airlie <airlied@linux.ie>
2005-07-07drm: misc cleanupDave Airlie
This patch contains the following cleanups: - make needlessly global functions static - remove the following unused global functions: - drm_fops.c: drm_read - i915_dma.c: i915_do_cleanup_pageflip Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-06-23Add missing license texts from Tungsten Graphics.Dave Airlie
From: Alan Hourihane Signed-off-by: David Airlie <airlied@linux.ie>
