With the coming of kernel based modesetting and the memory manager stuff,
the everything in one directory approach was getting very ugly and
starting to be unmanageable.
This restructures the drm along the lines of other kernel components.
It creates a drivers/gpu/drm directory and moves the hw drivers into
subdirectores. It moves the includes into an include/drm, and
sets up the unifdef for the userspace headers we should be exporting.
This reverts commit ac741ab71bb39e6977694ac0cc26678d8673cda4.
Okay this looks like wasn't as fully baked as I'd led myself to believe.
Revert for now for further baking.
Other Authors: Michel Dänzer <michel@tungstengraphics.com>
mga: Ian Romanick <idr@us.ibm.com>
via: Thomas Hellstrom <thomas-at-tungstengraphics-dot-com>
This re-works the DRM internals to provide a better interface for drivers
to expose vblank on multiple crtcs.
It also includes work done by Michel on making i915 triple buffering and pageflipping work properly.
Signed-off-by: Dave Airlie <airlied@linux.ie>
I've been threatening this for a while, so no point hanging around.
This lindents the DRM code which was always really bad in tabbing department.
I've also fixed some misnamed files in comments and removed some trailing
whitespace.
This patch adds serveral new ioctls and a new query to get_param query to
support PCI MGA cards.
Two ioctls were added to implement interrupt based waiting. With this change,
the client-side driver no longer needs to map the primary DMA region or the
MMIO region. Previously, end-of-frame waiting was done by busy waiting in the
client-side driver until one of the MMIO registers (the current DMA pointer)
matched a pointer to the end of primary DMA space. By using interrupts, the
busy waiting and the extra mappings are removed.
A third ioctl was added to bootstrap DMA. This ioctl, which is used by the
X-server, moves a *LOT* of code from the X-server into the kernel. This allows
the kernel to do whatever needs to be done to setup DMA buffers. The entire
process and the locations of the buffers are hidden from user-mode.
Additionally, a get_param query was added to differentiate between G4x0 cards
and G550 cards. A gap was left in the numbering sequence so that, if needed,
G450 cards could be distinguished from G400 cards. According to Ville
Syrjälä, the G4x0 cards and the G550 cards handle anisotropic filtering
differently. This seems the most compatible way to let the client-side driver
know which card it's own. Doing this very small change now eliminates the
need to bump the DRM minor version twice.
http://marc.theaimsgroup.com/?l=dri-devel&m=106625815319773&w=2
(airlied - this may not work at this point, I think the follow on buffer
cleanup patches will be needed)
infrastructure for it.
Let it rip!
