path: root/drivers/char/drm/r128_drm.h
2007-10-15drm: remove XFREE86_VERSION macros.Dave Airlie
These are no longer needed or being used. Signed-off-by: Dave Airlie <airlied@redhat.com>
2007-07-11drm: fixup other drivers for typedef removalsDave Airlie
Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-12-19drm: r128: comment aligment with drm gitDave Airlie
Align some r128 license comments Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-01-02drm: update PCIGART support from CVSDave Airlie
In order to work on FreeBSD the gart needed to use a local mapping This patch moves the mainline to the new code and aligns some comment changes From: Eric Anholt <anholt@freebsd.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-09-25drm: lindent the drm directory.Dave Airlie
I've been threatening this for a while, so no point hanging around. This lindents the DRM code which was always really bad in tabbing department. I've also fixed some misnamed files in comments and removed some trailing whitespace. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-08-05drm: fix ioctl direction in r128 getparamDave Airlie
Set the IOWR correctly for r128 getparam. From: Egbert Eich <eich@suse.de> Signed-off-by: Dave Airlie <airlied@linux.ie>
