path: root/drivers/char/drm/r128_drv.h
2008-07-14drm: reorganise drm tree to be more future proof.Dave Airlie
With the coming of kernel based modesetting and the memory manager stuff, the everything in one directory approach was getting very ugly and starting to be unmanageable. This restructures the drm along the lines of other kernel components. It creates a drivers/gpu/drm directory and moves the hw drivers into subdirectores. It moves the includes into an include/drm, and sets up the unifdef for the userspace headers we should be exporting. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-05-07Revert "drm/vbl rework: rework how the drm deals with vblank."Dave Airlie
This reverts commit ac741ab71bb39e6977694ac0cc26678d8673cda4. Okay this looks like wasn't as fully baked as I'd led myself to believe. Revert for now for further baking. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-04-26drm/vbl rework: rework how the drm deals with vblank.Jesse Barnes
Other Authors: Michel Dänzer <michel@tungstengraphics.com> mga: Ian Romanick <idr@us.ibm.com> via: Thomas Hellstrom <thomas-at-tungstengraphics-dot-com> This re-works the DRM internals to provide a better interface for drivers to expose vblank on multiple crtcs. It also includes work done by Michel on making i915 triple buffering and pageflipping work properly. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-02-07drm: cleanup DRM_DEBUG() parametersMárton Németh
As DRM_DEBUG macro already prints out the __FUNCTION__ string (see drivers/char/drm/drmP.h), it is not worth doing this again. At some other places the ending "\n" was added. airlied:- I cleaned up a few that this patch missed also Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-02-07drm: run cleanfile across drm treeDave Airlie
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-15drm: Replace DRM_IOCTL_ARGS with (dev, data, file_priv) and remove DRM_DEVICE.Eric Anholt
The data is now in kernel space, copied in/out as appropriate according to t This results in DRM_COPY_{TO,FROM}_USER going away, and error paths to deal with those failures. This also means that XFree86 4.2.0 support for i810 DR is lost. Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-10-15drm: Replace filp in ioctl arguments with drm_file *file_priv.Eric Anholt
As a fallout, replace filp storage with file_priv storage for "unique identifier of a client" all over the DRM. There is a 1:1 mapping, so this should be a noop. This could be a minor performance improvement, as everyth on Linux dereferenced filp to get file_priv anyway, while only the mmap ioct went the other direction. Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-10-15drm: Remove DRM_ERR OS macro.Eric Anholt
This was used to make all ioctl handlers return -errno on linux and errno on *BSD. Instead, just return -errno in shared code, and flip sign on return f shared code to *BSD code. Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-07-11drm: detypedeffing continues...Dave Airlie
2007-07-11drm: drop drm_buf_t typedefDave Airlie
2007-07-11drm: fixup other drivers for typedef removalsDave Airlie
2007-05-08drm/radeon: upgrade to 1.27 - make PCI GART more flexibleDave Airlie
radeon: make PCI GART aperture size variable, but making table size variable This is precursor to getting a TTM backend for this stuff, and also allows the PCI table to be allocated at fb 0 radeon: add support for reverse engineered xpress200m The IGPGART setup code was traced using mmio-trace on fglrx by myself and Phillip Ezolt <phillipezolt@gmail.com> on dri-devel. This code doesn't let the 3D driver work properly as the card has no vertex shader support. Thanks to Matthew Garrett + Ubuntu for providing me some hardware to do this work on. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-12-19drm: r128: comment aligment with drm gitDave Airlie
Align some r128 license comments Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-01-02drm: update PCIGART support from CVSDave Airlie
In order to work on FreeBSD the gart needed to use a local mapping This patch moves the mainline to the new code and aligns some comment changes From: Eric Anholt <anholt@freebsd.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-11-10drm: rename driver hooks more understandablyDave Airlie
Rename the driver hooks in the DRM to something a little more understandable: preinit -> load postinit -> (removed) presetup -> firstopen postsetup -> (removed) open_helper -> open prerelease -> preclose free_filp_priv -> postclose pretakedown -> lastclose postcleanup -> unload release -> reclaim_buffers_locked version -> (removed) postinit and version were replaced with generic code in the Linux DRM (drivers now set their version numbers and description in the driver structure, like on BSD). postsetup wasn't used at all. Fixes the savage hooks for initializing and tearing down mappings at the right times. Testing involved at least starting X, running glxgears, killing glxgears, exiting X, and repeating. Tested on: FreeBSD (g200, g400, r200, r128) Linux (r200, savage4) From: Eric Anholt <anholt@freebsd.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-09-30drm: fix all sparse warning on 32-bit x86Dave Airlie
Finally cleaned up the sparse warnings for the drm. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-09-25drm: lindent the drm directory.Dave Airlie
I've been threatening this for a while, so no point hanging around. This lindents the DRM code which was always really bad in tabbing department. I've also fixed some misnamed files in comments and removed some trailing whitespace. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-09-11drm: add radeon PCI express supportDave Airlie
Add support for Radeon PCI Express cards (needs a new X.org DDX) Also allows PCI GART table to be stored in VRAM for non PCIE cards Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-07-07drm: add 32/64 support for MGA/R128/i915Dave Airlie
This adds compatiblity ioctls for mga/r128 and i915 DRM drivers. From: Paul Mackerras, David Airlie, Alan Hourihane, Egbert Eich. Signed-off-by: David Airlie <airlied@linux.ie>
