path: root/drivers/char/drm/r128_irq.c
2008-05-07Revert "drm/vbl rework: rework how the drm deals with vblank."Dave Airlie
This reverts commit ac741ab71bb39e6977694ac0cc26678d8673cda4. Okay this looks like wasn't as fully baked as I'd led myself to believe. Revert for now for further baking. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-04-26drm/vbl rework: rework how the drm deals with vblank.Jesse Barnes
Other Authors: Michel Dänzer <michel@tungstengraphics.com> mga: Ian Romanick <idr@us.ibm.com> via: Thomas Hellstrom <thomas-at-tungstengraphics-dot-com> This re-works the DRM internals to provide a better interface for drivers to expose vblank on multiple crtcs. It also includes work done by Michel on making i915 triple buffering and pageflipping work properly. Signed-off-by: Dave Airlie <airlied@redhat.com>
2007-07-11drm: fixup other drivers for typedef removalsDave Airlie
Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-01-02drm: update PCIGART support from CVSDave Airlie
In order to work on FreeBSD the gart needed to use a local mapping This patch moves the mainline to the new code and aligns some comment changes From: Eric Anholt <anholt@freebsd.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-09-25drm: lindent the drm directory.Dave Airlie
I've been threatening this for a while, so no point hanging around. This lindents the DRM code which was always really bad in tabbing department. I've also fixed some misnamed files in comments and removed some trailing whitespace. Signed-off-by: Dave Airlie <airlied@linux.ie>
