__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This fixes a problem on 64-bit with 4GB with ATI RS690 chipsets. It
makes sure the pcigart table is allocated in coherent memory for DMA operations.
This adds support for configuring the RS690 GART.
This adds CP support for the r500 series of chips, and allows
accel 2D support on these chips with a new radeon driver.
Signed-off-by: Dave Airlie <airlied@linux.ie>
As DRM_DEBUG macro already prints out the __FUNCTION__ string (see
drivers/char/drm/drmP.h), it is not worth doing this again. At some
other places the ending "\n" was added.
airlied:- I cleaned up a few that this patch missed also
This code relied on the CPU and GPU address for the aperture being the same,
On some r5xx hardware I was playing with I noticed that this isn't always true.
This fixes issues seen on some r400 cards. (bugs.freedesktop.org 9957)
The data is now in kernel space, copied in/out as appropriate according to t
This results in DRM_COPY_{TO,FROM}_USER going away, and error paths to deal
with those failures. This also means that XFree86 4.2.0 support for i810 DR
is lost.
As a fallout, replace filp storage with file_priv storage for "unique
identifier of a client" all over the DRM. There is a 1:1 mapping, so this
should be a noop. This could be a minor performance improvement, as everyth
on Linux dereferenced filp to get file_priv anyway, while only the mmap ioct
went the other direction.
This was used to make all ioctl handlers return -errno on linux and errno on
*BSD. Instead, just return -errno in shared code, and flip sign on return f
shared code to *BSD code.
some drivers still todo.
This moves a bunch of typedefs into a !defined __KERNEL__ to keep userspace
API compatiblity, it changes all internal usages to structs/enum/unions.
This adds support for CRTC2 vblank on radeon similiar to the i915.
radeon: make PCI GART aperture size variable, but making table size variable
This is precursor to getting a TTM backend for this stuff, and also
allows the PCI table to be allocated at fb 0
radeon: add support for reverse engineered xpress200m
The IGPGART setup code was traced using mmio-trace on fglrx by myself
and Phillip Ezolt <phillipezolt@gmail.com> on dri-devel.
This code doesn't let the 3D driver work properly as the card has no
vertex shader support.
Thanks to Matthew Garrett + Ubuntu for providing me some hardware to do this
work on.
The overflows could lead to the AGP aperture overlapping the framebuffer are in the card's address space when the latter is located at the very end of th 32 bit address space, which would result in a freeze on X server startup,
probably because the card read commands from the framebuffer instead of from AGP.
See http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=392915 .
this applies some minor cleanups for the radeon driver, to use the
3D flush and reset the AGP flags on X recycle
RADEON_RB2D_DSTCACHE_CTLSTAT.
The latter seems to be a read-only mirror of the former.
When writeback isn't used, actually disable it in the hardware.
Not doing this might waste bus bandwidth or even cause memory corruption or
system crashes on systems that check bus transfers. No such incident has been
reported though.
This adds all the r300 and r400 PCI ids from DRM CVS, it also
makes these cards only initialise when the new xorg driver is
used, as otherwise the DRM can cause lockups.
This code reworks the radeon memory map so it works better
for newer r300 chips and for a lot of older PCI chips.
It really requires a new X driver in order to take advantage of this code.
From: Luiz Fernando Capitulino <lcapitulino@mandriva.com.br>
drivers/char/drm/radeon_cp.c:1643:31: warning: Using plain integer as NULL
pointer
Signed-off-by: Luiz Capitulino <lcapitulino@mandriva.com.br>
This patch pull in a lot of changes from CVS to the main core DRM,
and updates the radeon driver to 1.21.0 that supports r300 texrect
and radeon card type ioctl.
In order to work on FreeBSD the gart needed to use a local mapping
This patch moves the mainline to the new code and aligns some comment
changes
Rename the driver hooks in the DRM to something a little more understandable:
preinit -> load
postinit -> (removed)
presetup -> firstopen
postsetup -> (removed)
open_helper -> open
prerelease -> preclose
free_filp_priv -> postclose
pretakedown -> lastclose
postcleanup -> unload
release -> reclaim_buffers_locked
version -> (removed)
postinit and version were replaced with generic code in the Linux DRM (drivers
now set their version numbers and description in the driver structure, like on
BSD). postsetup wasn't used at all. Fixes the savage hooks for
initializing and tearing down mappings at the right times. Testing involved at
least starting X, running glxgears, killing glxgears, exiting X, and repeating.
Tested on: FreeBSD (g200, g400, r200, r128)
Linux (r200, savage4)
Manual fixups for some clashes due to re-indenting.
I've seen similar failure on alpha.
Obviously, someone forgot to convert sg->handle stuff for
PCI gart case.
In order to get some better debugging from people about certain hangs/crashes
we need to be able to turn AGP writeback off permanently...
I've been threatening this for a while, so no point hanging around.
This lindents the DRM code which was always really bad in tabbing department.
I've also fixed some misnamed files in comments and removed some trailing
whitespace.
Add support for Radeon PCI Express cards (needs a new X.org DDX)
Also allows PCI GART table to be stored in VRAM for non PCIE cards
This adds initial r300 3D support to the radeon DRM.
From: Nicolai Haehnle, Vladimir Dergachev, and others.
Signed-off-by: David Airlie <airlied@linux.ie>
I basically combined Paul's patches with additions that I had made
for PCI scatter gather.
I also tried more carefully to avoid problems with the same token
assigned multiple times while trying to use the base address in the
token if possible to gain as much backward compatibility as possible
for broken DRI clients.
From: Paul Mackerras <paulus@samba.org> and Egbert Eich <eich@suse.de>
This is a patch from DRM CVS that cleans up some code that was in CVS
that I never moved to the kernel, this patch produces the result of the
cleanups and puts it into the kernel drm.
From: Eric Anholt <anholt@freebsd.org>, Jon Smirl, Dave Airlie
infrastructure for it.
Let it rip!
