path: root/drivers/char/drm/radeon_irq.c
2005-09-25drm: lindent the drm directory.Dave Airlie
I've been threatening this for a while, so no point hanging around. This lindents the DRM code which was always really bad in tabbing department. I've also fixed some misnamed files in comments and removed some trailing whitespace. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-06-26drm: fix radeon irq properlyDave Airlie
After the previous fix in 2.6.12, this patch should properly fix the radeon IRQ handling code. From: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-06-10[PATCH] remove bogus hack from radeon IRQ handlerDave Airlie
This removes a bogus hack from the radeon IRQ handler. There is a better fix from myself and benh in DRM CVS but I'll wait until 2.6.13-rc so it gets more testing. Signed-off-by: Dave Airlie <airlied@linux.ie>
