path: root/drivers/char/ds1620.c
2006-07-03[PATCH] make more file_operation structs staticArjan van de Ven
Mark the static struct file_operations in drivers/char as const. Making them const prevents accidental bugs, and moves them to the .rodata section so that they no longer do any false sharing; in addition with the proper debug option they are then protected against corruption.. [akpm@osdl.org: build fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] char/ds1620: use msleep() instead of schedule_timeout()Domen Puncer
Not sure why any driver needs to sleep for *two* ticks, so let's fix it. Use msleep() instead of schedule_timeout() to guarantee the task delays as expected. Signals are never checked for by the callers or in the function itself, so use TASK_UNINTERRUPTIBLE instead of TASK_INTERRUPTIBLE. The delay is presumed to have been written when HZ==100, and thus has been multiplied by 10 to pass to msleep(). Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Domen Puncer <domen@coderock.org> Acked-by: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
