path: root/drivers/char/hpet.c
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/char/hpet.c: fix information leak to userlandVasiliy Kulikov
Structure info is copied to userland with some padding fields unitialized. It leads to leaking of stack memory. [akpm@linux-foundation.org: remove now-unneeded zeroing of info->hi_ireqfreq] Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26hpet: fix style problemsJaswinder Singh Rajput
Fix the following style problems: WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h> WARNING: Use #include <linux/io.h> instead of <asm/io.h> ERROR: code indent should use tabs where possible ERROR: do not initialise statics to 0 or NULL Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26hpet: fix unwanted interrupt due to stale irq status bitClemens Ladisch
Jaswinder Singh Rajput wrote: > By executing Documentation/timers/hpet_example.c > > for polling, I requested for 3 iterations but it seems iteration work > for only 2 as first expired time is always very small. > > # ./hpet_example poll /dev/hpet 10 3 > -hpet: executing poll > hpet_poll: info.hi_flags 0x0 > hpet_poll: expired time = 0x13 > hpet_poll: revents = 0x1 > hpet_poll: data 0x1 > hpet_poll: expired time = 0x1868c > hpet_poll: revents = 0x1 > hpet_poll: data 0x1 > hpet_poll: expired time = 0x18645 > hpet_poll: revents = 0x1 > hpet_poll: data 0x1 Clearing the HPET interrupt enable bit disables interrupt generation but does not disable the timer, so the interrupt status bit will still be set when the timer elapses. If another interrupt arrives before the timer has been correctly programmed (due to some other device on the same interrupt line, or CONFIG_DEBUG_SHIRQ), this results in an extra unwanted interrupt event because the status bit is likely to be set from comparator matches that happened before the device was opened. Therefore, we have to ensure that the interrupt status bit is and stays cleared until we actually program the timer. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Reported-by: Jaswinder Singh Rajput <jaswinderlinux@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Bob Picco <bpicco@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26hpet: unmap unused I/O spaceJiri Slaby
When the initialization code in hpet finds a memory resource and does not find an IRQ, it does not unmap the memory resource previously mapped. There are buggy BIOSes which report resources exactly like this and what is worse the memory region bases point to normal RAM. This normally would not matter since the space is not touched. But when PAT is turned on, ioremap causes the page to be uncached and sets this bit in page->flags. Then when the page is about to be used by the allocator, it is reported as: BUG: Bad page state in process md5sum pfn:3ed00 page:ffffea0000dbd800 count:0 mapcount:0 mapping:(null) index:0x0 page flags: 0x20000001000000(uncached) Pid: 7956, comm: md5sum Not tainted 2.6.34-12-desktop #1 Call Trace: [<ffffffff810df851>] bad_page+0xb1/0x100 [<ffffffff810dfa45>] prep_new_page+0x1a5/0x1c0 [<ffffffff810dfe01>] get_page_from_freelist+0x3a1/0x640 [<ffffffff810e01af>] __alloc_pages_nodemask+0x10f/0x6b0 ... In this particular case: 1) HPET returns 3ed00000 as memory region base, but it is not in reserved ranges reported by the BIOS (excerpt): BIOS-e820: 0000000000100000 - 00000000af6cf000 (usable) BIOS-e820: 00000000af6cf000 - 00000000afdcf000 (reserved) 2) there is no IRQ resource reported by HPET method. On the other hand, the Intel HPET specs (1.0a) says (3.2.5.1): _CRS ( // Report 1K of memory consumed by this Timer Block memory range consumed // Optional: only used if BIOS allocates Interrupts [1] IRQs consumed ) [1] For case where Timer Block is configured to consume IRQ0/IRQ8 AND Legacy 8254/Legacy RTC hardware still exists, the device objects associated with 8254 & RTC devices should not report IRQ0/IRQ8 as "consumed resources". So in theory we should check whether if it is the case and use those interrupts instead. Anyway the address reported by the BIOS here is bogus, so non-presence of IRQ doesn't mean the "optional" part in point 2). Since I got no reply previously, fix this by simply unmapping the space when IRQ is not found and memory region was mapped previously. It would be probably more safe to walk the resources again and unmap appropriately depending on type. But as we now use only ioremap for both 2 memory resource types, it is not necessarily needed right now. Addresses https://bugzilla.novell.com/show_bug.cgi?id=629908 Reported-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Clemens Ladisch <clemens@ladisch.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-15hpet: kill BKL, add compat_ioctlArnd Bergmann
hpet uses the big kernel lock in its ioctl and open functions. Replace this with a private mutex to be sure. Since we're already touching the ioctl function, add the compat_ioctl version as well -- all commands except HPET_INFO are compatible and that one is easy to add. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Clemens Ladisch <clemens@ladisch.de> Cc: Bob Picco <bob.picco@hp.com>
2010-05-17drivers: Push down BKL into various driversArnd Bergmann
These are the last remaining device drivers using the ->ioctl file operation in the drivers directory (except from v4l drivers). [fweisbec: drop i8k pushdown as it has been done from procfs pushdown branch already] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-17hpet: use for_each_set_bit()Akinobu Mita
Replace open-coded loop with for_each_set_bit(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Clemens Ladisch <clemens@ladisch.de> Cc: Bob Picco <bob.picco@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-18sysctl: Drop & in front of every proc_handler.Eric W. Biederman
For consistency drop & in front of every proc_handler. Explicity taking the address is unnecessary and it prevents optimizations like stubbing the proc_handlers to NULL. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-12sysctl drivers: Remove dead binary sysctl supportEric W. Biederman
Now that sys_sysctl is a wrapper around /proc/sys all of the binary sysctl support elsewhere in the tree is dead code. Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Matt Mackall <mpm@selenic.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Neil Brown <neilb@suse.de> Cc: "James E.J. Bottomley" <James.Bottomley@suse.de> Acked-by: Clemens Ladisch <clemens@ladisch.de> for drivers/char/hpet.c Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-09-24hpet: hpet driver periodic timer setup bug fixesNils Carlson
The periodic interrupt from drivers/char/hpet.c does not work correctly, both when using the periodic capability of the hardware and while emulating the periodic interrupt (when hardware does not support periodic mode). With timers capable of periodic interrupts, the comparator field is first set with the period value followed by set of hidden accumulator, which has the side effect of overwriting the comparator value. This results in wrong periodicity for the interrupts. For, periodic interrupts to work, following steps are necessary, in that order. * Set config with Tn_VAL_SET_CNF bit * Write to hidden accumulator, the value written is the time when the first interrupt should be generated * Write compartor with period interval for subsequent interrupts (http://www.intel.com/hardwaredesign/hpetspec_1.pdf ) When emulating periodic timer with timers not capable of periodic interrupt, driver is adding the period to counter value instead of comparator value, which causes slow drift when using this emulation. Also, driver seems to add hpetp->hp_delta both while setting up periodic interrupt and while emulating periodic interrupts with timers not capable of doing periodic interrupts. This hp_delta will result in slower than expected interrupt rate and should not be used while setting the interval. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Nils Carlson <nils.carlson@ericsson.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-28irq: change ACPI GSI APIs to also take a device argumentYinghai Lu
We want to use dev_to_node() later on, to be aware of the 'home node' of the GSI in question. [ Impact: cleanup, prepare the IRQ code to be more NUMA aware ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Len Brown <lenb@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Len Brown <lenb@kernel.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Tony Luck <tony.luck@intel.com> Cc: linux-acpi@vger.kernel.org Cc: linux-ia64@vger.kernel.org LKML-Reference: <49F65560.20904@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-21clocksource: pass clocksource to read() callbackMagnus Damm
Pass clocksource pointer to the read() callback for clocksources. This allows us to share the callback between multiple instances. [hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods] [akpm@linux-foundation.org: cleanup] Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02hpet: fix the possibility of insane return value of hpet_calibrate() against SMIYasunori Goto
hpet_calibrate() has a possibility of miss-calibration due to SMI. If SMI interrupts in the while loop of calibration, then return value will be big. This change calibrates until stabilizing by the return value with a small value. [akpm@linux-foundation.org: trivial style tweaks] Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Acked-by: Clemens Ladisch <clemens@ladisch.de> Acked-by: Vojtech Pavlik <vojtech@suse.cz> Cc: Robert Picco <Robert.Picco@hp.com> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-24x86: correct link to HPET timer specificationDenis V. Lunev
Impact: update documentation / help text Original link is dead. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-01saner FASYNC handling on file closeAl Viro
As it is, all instances of ->release() for files that have ->fasync() need to remember to evict file from fasync lists; forgetting that creates a hole and we actually have a bunch that *does* forget. So let's keep our lives simple - let __fput() check FASYNC in file->f_flags and call ->fasync() there if it's been set. And lose that crap in ->release() instances - leaving it there is still valid, but we don't have to bother anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16drivers/char: use nr_irqsYinghai Lu
convert them to nr_irqs. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-10HPET: Remove spurious HPET busy warning message.David John
On x86 systems with CONFIG_HPET_TIMER enabled, when the HPET driver (drivers/char/hpet.c) is loaded, an incorrect busy message is printed when the driver initializes since the HPET has already been allocated by the core timer code. Remove the warning message. Signed-off-by: David John <davidjon@xenontk.org> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-31hpet: /dev/hpet - fixes and cleanup, fixDavid Brownell
fix: On Thursday 31 July 2008, Ingo Molnar wrote: >   drivers/built-in.o: In function `hpet_alloc': >   : undefined reference to `__udivdi3' >   drivers/built-in.o: In function `hpet_alloc': >   : undefined reference to `__umoddi3' Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-31hpet: /dev/hpet - fixes and cleanupDavid Brownell
Minor /dev/hpet updates and bugfixes: * Remove dead code, mostly remnants of an incomplete/unusable kernel interface ... noted when addressing "sparse" warnings: + hpet_unregister() and a routine it calls + hpet_task and all references, including hpet_task_lock + hpet_data.hd_flags (and HPET_DATA_PLATFORM) * Correct and improve boot message: + displays *counter* (shared between comparators) bit width, not *timer* bit widths (which are often mixed) + relabel "timers" as "comparators"; this is less confusing, they are not independent like normal timers are (sigh) + display MHz not Hz; it's never less than 10 MHz. * Tighten and correct the userspace interface code + don't accidentally program comparators in 64-bit mode using 32-bit values ... always force comparators into 32-bit mode + provide the correct bit definition flagging comparators with periodic capability ... the ABI is unchanged * Update Documentation/hpet.txt + be more correct and current + expand description a bit + don't mention that now-gone kernel interface Plus, add a FIXME comment for something that could cause big trouble on systems with more capable HPETs than at least Intel seems to ship. It seems that few folk use this userspace interface; it's not very usable given the general lack of HPET IRQ routing. I'm told that the only real point of it any more is to mmap for fast timestamps; IMO that's handled better through the gettimeofday() vsyscall. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-31Merge branch 'linus' into timers/hpetIngo Molnar
2008-07-25#if 0 hpet_unregister()Adrian Bunk
This patch #if 0's the unused hpet_unregister(). Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-20hpet: BKL pushdownArnd Bergmann
2008-06-02x86: get irq for hpet timerKevin Hao
HPET timer's IRQ is 0 by default. So we have to select which irq will be used by these timers. We wait to set the timer's irq until we really open it in order to reduce the chance of conflicting with other device. Signed-off-by: Kevin Hao <kexin.hao@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-30drivers/char: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-04-04x86: revert assign IRQs to hpet timerThomas Gleixner
The commits: commit 37a47db8d7f0f38dac5acf5a13abbc8f401707fa Author: Balaji Rao <balajirrao@gmail.com> Date: Wed Jan 30 13:30:03 2008 +0100 x86: assign IRQs to HPET timers, fix and commit e3f37a54f690d3e64995ea7ecea08c5ab3070faf Author: Balaji Rao <balajirrao@gmail.com> Date: Wed Jan 30 13:30:03 2008 +0100 x86: assign IRQs to HPET timers have been identified to cause a regression on some platforms due to the assignement of legacy IRQs which makes the legacy devices connected to those IRQs disfunctional. Revert them. This fixes http://bugzilla.kernel.org/show_bug.cgi?id=10382 Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: nuke a ton of dead hpet codeThomas Gleixner
No users, just ballast Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: assign IRQs to HPET timers, fixBalaji Rao
Looks like IRQ 31 is assigned to timer 3, even without the patch! I wonder who wrote the number 31. But the manual says that it is zero by default. I think we should check whether the timer has been allocated an IRQ before proceeding to assign one to it. Here is a patch that does this. Signed-off-by: Balaji Rao <balajirrao@gmail.com> Tested-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: assign IRQs to HPET timersBalaji Rao
The userspace API for the HPET (see Documentation/hpet.txt) did not work. The HPET_IE_ON ioctl was failing as there was no IRQ assigned to the timer device. This patch fixes it by allocating IRQs to timer blocks in the HPET. arch/x86/kernel/hpet.c | 13 +++++-------- drivers/char/hpet.c | 45 ++++++++++++++++++++++++++++++++++++++------- include/linux/hpet.h | 2 +- 3 files changed, 44 insertions(+), 16 deletions(-) Signed-off-by: Balaji Rao <balajirrao@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-09-26Silent drivers/char/hpet.c build warnings on i386S.Çağlar Onur
Following patch silents; ... drivers/char/hpet.c:72: warning: 'clocksource_hpet' defined but not used drivers/char/hpet.c:81: warning: 'hpet_clocksource' defined but not used ... build warnings on i386, they appeared after commit 3b2b64fd311c92f2137eb7cee7025794cd854057 Signed-off-by: S.Çağlar Onur <caglar@pardus.org.tr> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> -- drivers/char/hpet.c | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
2007-09-25ACPI: hpet: ACPI Error (utglobal-0126): Unknown exception code: 0xFFFFFFF0Zhao Yakui
If hpet has been initialized before registering hpet driver, the callback function of hpet_resources will return the status code of -EBUSY, which is not defined in the ACPI exception table. So when ACPI checks the status code of callback function, it will report the unknown exception code. So the status code in ACPI is used instead of the generic error code in the ACPI callback function of hpet_resources. For example: -EBUSY is replaced by AE_ALREADY_EXISTS -EINVAL is replaced by AE_NO_MEMORY http://bugzilla.kernel.org/show_bug.cgi?id=8630 Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-08-31Do not use the ia64 clocksource on non-ia64 architecturesLinus Torvalds
The HPET clocksource in drivers/char/hpet.c was written as generic code for ia64, but it is not yet ready to replace the native HPET clocksource implementations that the i386/x86-64 architectures use. On x86[-64], trying to register this clocksource results in potentially multiple hpet-based clocksources being registered, and if the ia64 one is chosen on x86_64 some users have experienced hangs. Eventually all three architectures may end up using the same code, but that is not the case right now. Cc: John Stultz <johnstul@us.ibm.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Paolo Ornati <ornati@fastwebnet.it> Cc: Bob Picco <bob.picco@hp.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26use CLOCKSOURCE_MASK() instead of too large constantAl Viro
2007-07-23ACPI: autoload modules - Create __mod_acpi_device_table symbol for all ACPI ↵Thomas Renninger
drivers modpost is going to use these to create e.g. acpi:ACPI0001 in modules.alias. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-20[IA64] Convert to generic timekeeping/clocksourceTony Luck
This is a merge of Peter Keilty's initial patch (which was revived by Bob Picco) for this with Hidetoshi Seto's fixes and scaling improvements. Acked-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove sys_sysctl support from the hpet timer driverEric W. Biederman
In the binary sysctl interface the hpet driver was claiming to be the cdrom driver. This is a no-no so remove support for the binary interface. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-04[PATCH] severing poll.h -> mm.hAl Viro
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-26[PATCH] Don't print virtual address in HPET initializationAndi Kleen
virtual addresses don't belong into kernel logs for non debugging Cc: clemens@ladisch.de Signed-off-by: Andi Kleen <ak@suse.de>
2006-07-03[PATCH] make more file_operation structs staticArjan van de Ven
Mark the static struct file_operations in drivers/char as const. Making them const prevents accidental bugs, and moves them to the .rodata section so that they no longer do any false sharing; in addition with the proper debug option they are then protected against corruption.. [akpm@osdl.org: build fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: drivers/char: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-01HPET: fix ACPI memory range length handlingBjorn Helgaas
ACPI address space descriptors contain _MIN, _MAX, and _LEN. _MIN and _MAX are the bounds within which the region can be moved (this is clarified in Table 6-38 of the ACPI 3.0 spec). We should use _LEN to determine the size of the region, not _MAX - _MIN + 1. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-02-14[PATCH] HPET: handle multiple ACPI EXTENDED_IRQ resourcesBjorn Helgaas
When the _CRS for a single HPET contains multiple EXTENDED_IRQ resources, we overwrote hdp->hd_nirqs every time we found one. So the driver worked when all the IRQs were described in a single EXTENDED_IRQ resource, but failed when multiple resources were used. (Strictly speaking, I think the latter is actually more correct, but both styles have been used.) Someday we should remove all the ACPI stuff from hpet.c and use PNP driver registration instead. But currently PNP_MAX_IRQ is 2, and HPETs often have more IRQs. Hint, hint, Adam :-) Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Bob Picco <robert.picco@hp.com> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Len Brown <len.brown@intel.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-10[ACPI] ACPICA 20050930Bob Moore
Completed a major overhaul of the Resource Manager code - specifically, optimizations in the area of the AML/internal resource conversion code. The code has been optimized to simplify and eliminate duplicated code, CPU stack use has been decreased by optimizing function parameters and local variables, and naming conventions across the manager have been standardized for clarity and ease of maintenance (this includes function, parameter, variable, and struct/typedef names.) All Resource Manager dispatch and information tables have been moved to a single location for clarity and ease of maintenance. One new file was created, named "rsinfo.c". The ACPI return macros (return_ACPI_STATUS, etc.) have been modified to guarantee that the argument is not evaluated twice, making them less prone to macro side-effects. However, since there exists the possibility of additional stack use if a particular compiler cannot optimize them (such as in the debug generation case), the original macros are optionally available. Note that some invocations of the return_VALUE macro may now cause size mismatch warnings; the return_UINT8 and return_UINT32 macros are provided to eliminate these. (From Randy Dunlap) Implemented a new mechanism to enable debug tracing for individual control methods. A new external interface, acpi_debug_trace(), is provided to enable this mechanism. The intent is to allow the host OS to easily enable and disable tracing for problematic control methods. This interface can be easily exposed to a user or debugger interface if desired. See the file psxface.c for details. acpi_ut_callocate() will now return a valid pointer if a length of zero is specified - a length of one is used and a warning is issued. This matches the behavior of acpi_ut_allocate(). Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-06Pull release into acpica branchLen Brown
2005-10-30[PATCH] hpet: hpet driver cleanupsRandy Dunlap
- Use kzalloc() instead of kmalloc + memset. - Clean/fix some printk's. - Use NULL for pointers instead of 0. - Combine hpet busy searching locations into a function call. Signed-off-by: Randy Dunlap <randy_d_dunlap@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] hpet: use HPET physical addresses for dup. detectionRandy Dunlap
- Use HPET physical address to detect duplicates, not logical addresses. Using logical (mapped) addresses fails to detect duplicates because ioremap() returns a new mapped address each time. - iounmap() regions when duplicate/busy areas are found. Signed-off-by: Randy Dunlap <randy_d_dunlap@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
