path: root/drivers/char/hvc_vio.c
2007-05-07[POWERPC] Rename device_is_compatible to of_device_is_compatibleStephen Rothwell
for consistency with other Open Firmware interfaces (and Sparc). This is just a straight replacement. This leaves the compatibility define in place. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-27[POWERPC] Rename get_property to of_get_property: partial driversStephen Rothwell
This does drivers/machintosh and the hvc code. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-26Revert "[POWERPC] Rename get_property to of_get_property: drivers"Paul Mackerras
This reverts commit d05c7a80cf39ae7d0f8d0c3e47c93d51fcd393d3, which included changes which should go via other subsystem maintainers.
2007-04-13[POWERPC] Rename get_property to of_get_property: driversStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-25[POWERPC] The two vio HVC backends clashStephen Rothwell
Make sure only one of them actually registers as a driver. Also, remove cast from get_property(). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2006-07-31[POWERPC] pseries: Constify & voidify get_property()Jeremy Kerr
Now that get_property() returns a void *, there's no need to cast its return value. Also, treat the return value as const, so we can constify get_property later. pseries platform changes. Built for pseries_defconfig Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-13[POWERPC] Make the hvc_console output buffer size settableStephen Rothwell
So the iSeries console will be faster since it can send up to 200 bytes at a time to the Hypervisor. This only affects the tty part of the console, the console writes are still in 16 byte lots. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2006-03-28[PATCH] powerpc: hvc_console updatesRyan S. Arnold
These are some updates from both Ryan and Arnd for the hvc_console driver: The main point is to enable the inclusion of a console driver for rtas, which is currrently needed for the cell platform. Also shuffle around some data-type declarations and moves some functions out of include/asm-ppc64/hvconsole.h and into a new drivers/char/hvc_console.h file. Signed-off-by: "Ryan S. Arnold" <rsa@us.ibm.com> Signed-off-by: Arnd Bergmann <abergman@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-24powerpc: don't duplicate name between vio_driver and device_driverStephen Rothwell
Just set the name field directly in the device_driver structure contained in the vio_driver struct. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2005-08-30[PATCH] Make MODULE_DEVICE_TABLE work for vio devicesStephen Rothwell
Make MODULE_DEVICE_TABLE work for vio devices. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-07-07[PATCH] hvc_console: Separate the NUL character filtering from get_hvc_charsMilton Miller
Separate the NUL character filtering from get_hvc_chars. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] hvc_console: Register ops when setting up hvc_consoleMilton Miller
When registering the hvc console port, register a list of ops (read and write) to go with it, instead of calling fixed function names. This allows different ports to encode the data differently. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] hvc_console: Separate hvc_console and vio code 2Milton Miller
Remove all the vio device driver code from hvc_console.c This will allow us to separate hvsi, hvc, and allow hvc_console to be used without the ppc64 vio layer. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
