Various PowerPC 4xx SoCs contain a TRNG embedded in the Security function.
This adds a device driver for that TRNG.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Acked-by: Matt Mackall <mpm@selenic.com>
PPC 970FX Evaluation kit (Maple) boards bear AMD8111 southbridge.
Allow this driver to be compiled in if PPC_MAPLE is selected.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
This driver adds support for the True Random Number Generator in
the Picochip PC3X3 and later devices.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
arch/arm/plat-omap/Kconfig
Convert ARCH_OMAP24XX to ARCH_OMAP2
The hardware random number generator by ST is used in both the Nomadik
8815 SoC and the U8500. It returns 16 bits every 400ns with automatic
delay if a read is issued too early. It depends on PLAT_NOMADIK.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
This patch adds support for the integrated RNG of the TX4939 SoC.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (417 commits)
MAINTAINERS: EB110ATX is not ebsa110
MAINTAINERS: update Eric Miao's email address and status
fb: add support of LCD display controller on pxa168/910 (base layer)
[ARM] 5552/1: ep93xx get_uart_rate(): use EP93XX_SYSCON_PWRCNT and EP93XX_SYSCON_PWRCN
[ARM] pxa/sharpsl_pm: zaurus needs generic pxa suspend/resume routines
[ARM] 5544/1: Trust PrimeCell resource sizes
[ARM] pxa/sharpsl_pm: cleanup of gpio-related code.
[ARM] pxa/sharpsl_pm: drop set_irq_type calls
[ARM] pxa/sharpsl_pm: merge pxa-specific code into generic one
[ARM] pxa/sharpsl_pm: merge the two sharpsl_pm.c since it's now pxa specific
[ARM] sa1100: remove unused collie_pm.c
[ARM] pxa: fix the conflicting non-static declarations of global_gpios[]
[ARM] 5550/1: Add default configure file for w90p910 platform
[ARM] 5549/1: Add clock api for w90p910 platform.
[ARM] 5548/1: Add gpio api for w90p910 platform
[ARM] 5551/1: Add multi-function pin api for w90p910 platform.
[ARM] Make ARM_VIC_NR depend on ARM_VIC
[ARM] 5546/1: ARM PL022 SSP/SPI driver v3
ARM: OMAP4: SMP: Update defconfig for OMAP4430
ARM: OMAP4: SMP: Enable SMP support for OMAP4430
Fix Kconfig to build via-rng.ko on X86_64 builds, as the VIA Nano
CPU supports x86_64, too.
Signed-off-by: Harald Welte <HaraldWelte@viatech.com>
This hw-random driver add support to RNGA hardware found
on some i.MX processors.
Signed-off-by: Alan Carvalho de Assis <acassis@gmail.com>
CC drivers/char/hw_random/timeriomem-rng.o
drivers/char/hw_random/timeriomem-rng.c: In function 'timeriomem_rng_data_read':
drivers/char/hw_random/timeriomem-rng.c:60: error: implicit declaration of function 'readl'
Some hardware platforms, the TS-7800[1] is one for example, can
supply the kernel with an entropy source, albeit a slow one for
TS-7800 users, by just reading a particular IO address. This
source must not be read above a certain rate otherwise the quality
suffers.
The driver is then hooked into by calling
platform_device_(register|add|del) passing a structure similar to:
static struct timeriomem_rng_data ts78xx_ts_rng_data = {
.address = (u32 *__iomem) TS_RNG,
.period = 1000000, /* one second */
static struct platform_device ts78xx_ts_rng_device = {
.name = "timeriomem_rng",
.id = -1,
.dev = {
.platform_data = &ts78xx_ts_rng_data,
.num_resources = 0,
[1] http://www.embeddedarm.com/products/board-detail.php?product=TS-7800
Signed-off-by: Alexander Clouter <alex@digriz.org.uk>
With feedback and suggestions from Sam Ravnborg.
Note that by itself, having a "hardware" random generator does very
little: you should probably run "rngd" in your guest to feed this into
the kernel entropy pool.
Included:
virtio_rng: dont use vmalloced addresses for virtio
If virtio_rng is build as a module, random_data is an address
in vmalloc space. As virtio expects guest real addresses, this
can cause any kind of funny behaviour, so lets allocate
random_data dynamically with kmalloc.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Update documentation for the hw_random support to be current:
- Documentation/hw_random.txt has been updated to reflect the
current code: it's a framework now, a "core" with a small
sysfs interface, that hardware-specific drivers plug in to.
Text specific to Intel hardware is now at the end.
- Kconfig now references the Documentation/hw_random.txt file
and better explains what this really does.
Both chunks of documentation now higlight the fact that the kernel entropy
pool is maintained by "rngd", and this driver has nothing directly to do with
that important task.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
There will be more product numbers in the future than just PA6T-1682M,
but they will share much of the features. Remove some of the explicit
references and compatibility checks with 1682M, and replace most of them
with the more generic term "PWRficient".
Acked-by: Michael Buesch <mb@bu3sch.de>
Acked-by: Doug Thompson <dougthompson@xmission.com>
Signed-off-by: Yinghai Lu <yinghai.lu@sun.com>
Acked-by: Alan Cox <alan@redhat.com>
Signed-off-by: Andi Kleen <ak@suse.de>
Driver for the on-chip hardware random number generator on PA Semi
PA6T-1682M.
Signed-off-by: Egor Martovetsky <egor@pasemi.com>
Signed-off-by: Michael Buesch <mb@bu3sch.de>
Cc: Kumar Gala <galak@gate.crashing.org>
Despite it being small, there should be the option of making it a
module...
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: Michael Buesch <mb@bu3sch.de>
Cc: Jeff Garzik <jeff@garzik.org>
