into next
Pull crypto updates from Herbert Xu:
"Here is the crypto update for 3.16:
- Added test vectors for SHA/AES-CCM/DES-CBC/3DES-CBC.
- Fixed a number of error-path memory leaks in tcrypt.
- Fixed error-path memory leak in caam.
- Removed unnecessary global mutex from mxs-dcp.
- Added ahash walk interface that can actually be asynchronous.
- Cleaned up caam error reporting.
- Allow crypto_user get operation to be used by non-root users.
- Add support for SSS module on Exynos.
- Misc fixes"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/cryptodev-2.6: (60 commits)
crypto: testmgr - add aead cbc des, des3_ede tests
crypto: testmgr - Fix DMA-API warning
crypto: cesa - tfm->__crt_alg->cra_type directly
crypto: sahara - tfm->__crt_alg->cra_name directly
crypto: padlock - tfm->__crt_alg->cra_name directly
crypto: n2 - tfm->__crt_alg->cra_name directly
crypto: dcp - tfm->__crt_alg->cra_name directly
crypto: cesa - tfm->__crt_alg->cra_name directly
crypto: ccp - tfm->__crt_alg->cra_name directly
crypto: geode - Don't use tfm->__crt_alg->cra_name directly
crypto: geode - Weed out printk() from probe()
crypto: geode - Consistently use AES_KEYSIZE_128
crypto: geode - Kill AES_IV_LENGTH
crypto: geode - Kill AES_MIN_BLOCK_SIZE
crypto: mxs-dcp - Remove global mutex
crypto: hash - Add real ahash walk interface
hwrng: n2-drv - Introduce the use of the managed version of kzalloc
crypto: caam - reinitialize keys_fit_inline for decrypt and givencrypt
crypto: s5p-sss - fix multiplatform build
hwrng: timeriomem - remove unnecessary OOM messages
The driver for the "Picochip picoXcell true random number generator" was
added in v2.6.39. Its Kconfig symbol has always depended on
PICOXCELL_PC3X3. But that Kconfig symbol has never been part of the
tree. This means this driver has never been buildable. Let's remove it.
It can be re-added if its dependencies are actually part of the tree.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Acked-by: Jamie Iles <jamie@jamieiles.com>
HW_RANDOM_ATMEL should not only default to ARCH_AT91, it should depend
on it. This driver is useless on other architectures.
Likewise, HW_RANDOM_EXYNOS should depend on ARCH_EXYNOS, as it it
Also set the default to HW_RANDOM for the few architecture-specific
drivers which didn't have it yet, for consistency.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
This makes configuration more convenient IMHO, and avoids having to
repeat the dependency on HW_RANDOM for every single driver.
UML_RANDOM is the only hardware random number generator option which
does not depend on HW_RANDOM. Having it in the middle of the other
options breaks the alignment in "make menuconfig". Move it at the last
position to avoid that.
We've split Qualcomm MSM support into legacy and multiplatform. The RNG
driver is only relevant on the multiplatform supported SoCs so switch the
Kconfig depends to ARCH_QCOM.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
CC: Stanimir Varbanov <svarbanov@mm-sol.com>
Signed-off-by: Kumar Gala <galak@codeaurora.org>
Pull crypto update from Herbert Xu:
- Made x86 ablk_helper generic for ARM
- Phase out chainiv in favour of eseqiv (affects IPsec)
- Fixed aes-cbc IV corruption on s390
- Added constant-time crypto_memneq which replaces memcmp
- Fixed aes-ctr in omap-aes
- Added OMAP3 ROM RNG support
- Add PRNG support for MSM SoC's
- Add and use Job Ring API in caam
- Misc fixes
[ NOTE! This pull request was sent within the merge window, but Herbert
has some questionable email sending setup that makes him public enemy
#1 as far as gmail is concerned. So most of his emails seem to be
trapped by gmail as spam, resulting in me not seeing them. - Linus ]
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (49 commits)
crypto: s390 - Fix aes-cbc IV corruption
crypto: omap-aes - Fix CTR mode counter length
crypto: omap-sham - Add missing modalias
padata: make the sequence counter an atomic_t
crypto: caam - Modify the interface layers to use JR API's
crypto: caam - Add API's to allocate/free Job Rings
crypto: caam - Add Platform driver for Job Ring
hwrng: msm - Add PRNG support for MSM SoC's
ARM: DT: msm: Add Qualcomm's PRNG driver binding document
crypto: skcipher - Use eseqiv even on UP machines
crypto: talitos - Simplify key parsing
crypto: picoxcell - Simplify and harden key parsing
crypto: ixp4xx - Simplify and harden key parsing
crypto: authencesn - Simplify key parsing
crypto: authenc - Export key parsing helper function
crypto: mv_cesa: remove deprecated IRQF_DISABLED
hwrng: OMAP3 ROM Random Number Generator support
crypto: sha256_ssse3 - also test for BMI2
crypto: mv_cesa - Remove redundant of_match_ptr
crypto: sahara - Remove redundant of_match_ptr
This adds a driver for hardware random number generator present
on Qualcomm MSM SoC's.
Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
This driver provides kernel-side support for the Random Number
Generator hardware found on OMAP34xx processors.
This driver comes from Maemo 2.6.28 kernel and was tested on Nokia RX-51.
It is platform device because it needs board specific function for smc calls.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com>
Add a driver for the hwrng found in power7+ systems, based on the
existing code for the arch_get_random_long() hook.
We only register a single instance of the driver, not one per device,
because we use the existing per_cpu array of devices in the arch code.
This means we always read from the "closest" device, avoiding inter-chip
memory traffic.
Signed-off-by: Guo Chao <yan@linux.vnet.ibm.com>
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Merge upstream tree in order to reinstate crct10dif.
Add support for OMAP4 version of TRNG module
that is present on OMAP4, AM33xx and OMAP5 SoCs.
The modules have several differences including register
offsets, output size, triggering rng and how configuring
FROs. To handle these differences, a platform_data structure
is defined and contains routine pointers, register offsets. OMAP2
specific routines are prefixed with 'omap2_' and OMAP4
specific routines are prefixed with 'omap4_'.
Note: Few Hard coded values are from the TI AM33xx SDK.
CAVIUM_OCTEON_SOC most place we used to use CPU_CAVIUM_OCTEON. This
allows us to CPU_CAVIUM_OCTEON in places where we have no OCTEON SOC.
Remove CAVIUM_OCTEON_SIMULATOR as it doesn't really do anything, we can
get the same configuration with CAVIUM_OCTEON_SOC.
Signed-off-by: David Daney <david.daney@cavium.com>
Cc: linux-mips@linux-mips.org
Cc: linux-ide@vger.kernel.org
Cc: linux-edac@vger.kernel.org
Cc: linux-i2c@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: spi-devel-general@lists.sourceforge.net
Cc: devel@driverdev.osuosl.org
Cc: linux-usb@vger.kernel.org
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Patchwork: https://patchwork.linux-mips.org/patch/5295/
This adds a driver for random number generator present on Broadcom BCM2835 SoC,
used in Raspberry Pi and Roku 2 devices.
Signed-off-by: Dom Cobley <popcornmix@gmail.com>
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
Tested-by: Stephen Warren <swarren@wwwdotorg.org>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: linux-rpi-kernel@lists.infradead.org
Pull ARM SoC multiplatform conversion patches from Olof Johansson:
"Here are more patches in the progression towards multiplatform, sparse
irq conversions in particular.
Tegra has a handful of cleanups and general groundwork, but is not
quite there yet on full enablement.
Platforms that are enabled through this branch are VT8500 and Zynq.
Note that i.MX was converted in one of the earlier cleanup branches as
well (before we started a separate topic for multiplatform). And both
new platforms for this merge window, sunxi and bcm, were merged with
multiplatform support enabled."
Fix up conflicts mostly as per Olof.
* tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits)
ARM: zynq: Remove all unused mach headers
ARM: zynq: add support for ARCH_MULTIPLATFORM
ARM: zynq: make use of debug_ll_io_init()
ARM: zynq: remove TTC early mapping
ARM: tegra: move debug-macro.S to include/debug
ARM: tegra: don't include iomap.h from debug-macro.S
ARM: tegra: decouple uncompress.h and debug-macro.S
ARM: tegra: simplify DEBUG_LL UART selection options
ARM: tegra: select SPARSE_IRQ
ARM: tegra: enhance timer.c to get IO address from device tree
ARM: tegra: enhance timer.c to get IRQ info from device tree
ARM: timer: fix checkpatch warnings
ARM: tegra: add TWD to device tree
ARM: tegra: define DT bindings for and instantiate RTC
ARM: tegra: define DT bindings for and instantiate timer
clocksource/mtu-nomadik: use apb_pclk
clk: ux500: Register mtu apb_pclocks
ARM: plat-nomadik: convert platforms to SPARSE_IRQ
mfd/db8500-prcmu: use the irq_domain_add_simple()
mfd/ab8500-core: use irq_domain_add_simple()
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
This moves the MTU timer driver from arch/arm/plat-nomadik
to drivers/clocksource and moves the header file to the
platform_data directory.
As this moves the last file being compiled to an object out
of arch/arm/plat-nomadik, we have to "turn off the light"
and delete the plat-nomadik directory, because it is not
allowed to have an empty Makefile in a plat-* directory.
This is probably also a desired side effect of depopulating
the arch/arm directory of drivers. Luckily we have just
deleted all the <plat/*> include files prior to this so
by moving the last one we may delete the directory.
After this all the Ux500 and Nomadik device drivers live
outside of the arch/arm hierarchy.
Cc: Alessandro Rubini <rubini@unipv.it>
This driver will make use of any available TPM chip on the system as a
hwrng source.
Acked-by: David Safford <safford@linux.vnet.ibm.com>
Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
Pull MIPS updates from Ralf Baechle:
"More hardware support across the field including a bunch of device
drivers. The highlight however really are further steps towards
device tree.
This has been sitting in -next for ages. All MIPS _defconfigs have
been tested to boot or where I don't have hardware available, to at
least build fine."
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (77 commits)
MIPS: Loongson 1B: Add defconfig
MIPS: Loongson 1B: Add board support
MIPS: Netlogic: early console fix
MIPS: Netlogic: Fix indentation of smpboot.S
MIPS: Netlogic: remove cpu_has_dc_aliases define for XLP
MIPS: Netlogic: Remove unused pcibios_fixups
MIPS: Netlogic: Add XLP SoC devices in FDT
MIPS: Netlogic: Add IRQ mappings for more devices
MIPS: Netlogic: USB support for XLP
MIPS: Netlogic: XLP PCIe controller support.
MIPS: Netlogic: Platform changes for XLR/XLS I2C
MIPS: Netlogic: Platform NAND/NOR flash support
MIPS: Netlogic: Platform changes for XLS USB
MIPS: Netlogic: Remove NETLOGIC_ prefix
MIPS: Netlogic: SMP wakeup code update
MIPS: Netlogic: Update comments in smpboot.S
MIPS: BCM63XX: Add 96328avng reference board
MIPS: Expose PCIe drivers for MIPS
MIPS: BCM63XX: Add PCIe Support for BCM6328
MIPS: BCM63XX: Move the PCI initialization into its own function
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Cc: mpm@selenic.com
Cc: herbert@gondor.apana.org.au
Patchwork: https://patchwork.linux-mips.org/patch/3327/
Patchwork: https://patchwork.linux-mips.org/patch/4072/
This patch supports Exynos SOC's PRNG driver. Exynos's PRNG has 5 seeds and
5 random number outputs. Module is excuted under runtime power management control,
so it activates only while it's in use. Otherwise it will be suspended generally.
It was tested on PQ board by rngtest program.
Signed-off-by: Jonghwa Lee <jonghwa3.lee@samsung.com>
- New cipher/hash driver for ARM ux500.
- Code clean-up for aesni-intel.
- Misc fixes.
Fixed up conflicts in arch/arm/mach-ux500/devices-common.h, where quite
frankly some of it made no sense at all (the pull brought in a
declaration for the dbx500_add_platform_device_noirq() function, which
neither exists nor is used anywhere).
Also some trivial add-add context conflicts in the Kconfig file in
drivers/{char/hw_random,crypto}/
crypto: aesni-intel - move more common code to ablk_init_common
crypto: aesni-intel - use crypto_[un]register_algs
crypto: ux500 - Cleanup hardware identification
crypto: ux500 - Update DMA handling for 3.4
mach-ux500: crypto - core support for CRYP/HASH module.
crypto: ux500 - Add driver for HASH hardware
crypto: ux500 - Add driver for CRYP hardware
hwrng: Kconfig - modify default state for atmel-rng driver
hwrng: omap - use devm_request_and_ioremap
crypto: crypto4xx - move up err_request_irq label
crypto, xor: Sanitize checksumming function selection output
crypto: caam - add backward compatible string sec4.0
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Benjamin Herrenschmidt:
"Here are the powerpc goodies for 3.5. Main highlights are:
- Support for the NX crypto engine in Power7+
- A bunch of Anton goodness, including some micro optimization of our
syscall entry on Power7
- I converted a pile of our thermal control drivers to the new i2c
APIs (essentially turning the old therm_pm72 into a proper set of
windfarm drivers). That's one more step toward removing the
deprecated i2c APIs, there's still a few drivers to fix, but we are
getting close
- kexec/kdump support for 47x embedded cores
The big missing thing here is no updates from Freescale. Not sure
what's up here, but with Kumar not working for them anymore things are
a bit in a state of flux in that area."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (71 commits)
powerpc: Fix irq distribution
Revert "powerpc/hw-breakpoint: Use generic hw-breakpoint interfaces for new PPC ptrace flags"
powerpc: Fixing a cputhread code documentation
powerpc/crypto: Enable the PFO-based encryption device
powerpc/crypto: Build files for the nx device driver
powerpc/crypto: debugfs routines and docs for the nx device driver
powerpc/crypto: SHA512 hash routines for nx encryption
powerpc/crypto: SHA256 hash routines for nx encryption
powerpc/crypto: AES-XCBC mode routines for nx encryption
powerpc/crypto: AES-GCM mode routines for nx encryption
powerpc/crypto: AES-ECB mode routines for nx encryption
powerpc/crypto: AES-CTR mode routines for nx encryption
powerpc/crypto: AES-CCM mode routines for nx encryption
powerpc/crypto: AES-CBC mode routines for nx encryption
powerpc/crypto: nx driver code supporting nx encryption
powerpc/pseries: Enable the PFO-based RNG accelerator
powerpc/pseries/hwrng: PFO-based hwrng driver
powerpc/pseries: Add PFO support to the VIO bus
powerpc/pseries: Add pseries update notifier for OFDT prop changes
powerpc/pseries: Add new hvcall constants to support PFO
Adds support for the Platform Facilities Option (PFO)-based hardware
random number generator for POWER hardware.
Signed-off-by: Michael Neuling <mikey@neuling.org>
Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com>
In order to prevent building the Atmel hw_random driver for each and every
configuration, add a "default" Kconfig state in relation with
CONFIG_ARCH_AT91.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
This will allow to select this driver for newer SoCs. Make sure to
keep dependency on HAVE_CLK to avoid breaking other machines.
* 'for-linus' of git://github.com/richardweinberger/linux: (90 commits)
um: fix ubd cow size
um: Fix kmalloc argument order in um/vdso/vma.c
um: switch to use of drivers/Kconfig
UserModeLinux-HOWTO.txt: fix a typo
UserModeLinux-HOWTO.txt: remove ^H characters
um: we need sys/user.h only on i386
um: merge delay_{32,64}.c
um: distribute exports to where exported stuff is defined
um: kill system-um.h
um: generic ftrace.h will do...
um: segment.h is x86-only and needed only there
um: asm/pda.h is not needed anymore
um: hw_irq.h can go generic as well
um: switch to generic-y
um: clean Kconfig up a bit
um: a couple of missing dependencies...
um: kill useless argument of free_chan() and free_one_chan()
um: unify ptrace_user.h
um: unify KSTK_...
um: fix gcov build breakage
* kill duplicates with drivers/char/Kconfig
* take watchdog one into drivers/watchdog/Kconfig
* take mmapper to arch/um/Kconfig.um
* rename Kconfig.char menu to "UML Character Devices"
Signed-off-by: Richard Weinberger <richard@nod.at>
For the IP block on 9g45/9g46/9m10/9m11.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Reviewed-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Various PowerPC 4xx SoCs contain a TRNG embedded in the Security function.
This adds a device driver for that TRNG.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Acked-by: Matt Mackall <mpm@selenic.com>
PPC 970FX Evaluation kit (Maple) boards bear AMD8111 southbridge.
Allow this driver to be compiled in if PPC_MAPLE is selected.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
This driver adds support for the True Random Number Generator in
the Picochip PC3X3 and later devices.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
arch/arm/plat-omap/Kconfig
Convert ARCH_OMAP24XX to ARCH_OMAP2
The hardware random number generator by ST is used in both the Nomadik
8815 SoC and the U8500. It returns 16 bits every 400ns with automatic
delay if a read is issued too early. It depends on PLAT_NOMADIK.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
This patch adds support for the integrated RNG of the TX4939 SoC.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (417 commits)
MAINTAINERS: EB110ATX is not ebsa110
MAINTAINERS: update Eric Miao's email address and status
fb: add support of LCD display controller on pxa168/910 (base layer)
[ARM] 5552/1: ep93xx get_uart_rate(): use EP93XX_SYSCON_PWRCNT and EP93XX_SYSCON_PWRCN
[ARM] pxa/sharpsl_pm: zaurus needs generic pxa suspend/resume routines
[ARM] 5544/1: Trust PrimeCell resource sizes
[ARM] pxa/sharpsl_pm: cleanup of gpio-related code.
[ARM] pxa/sharpsl_pm: drop set_irq_type calls
[ARM] pxa/sharpsl_pm: merge pxa-specific code into generic one
[ARM] pxa/sharpsl_pm: merge the two sharpsl_pm.c since it's now pxa specific
[ARM] sa1100: remove unused collie_pm.c
[ARM] pxa: fix the conflicting non-static declarations of global_gpios[]
[ARM] 5550/1: Add default configure file for w90p910 platform
[ARM] 5549/1: Add clock api for w90p910 platform.
[ARM] 5548/1: Add gpio api for w90p910 platform
[ARM] 5551/1: Add multi-function pin api for w90p910 platform.
[ARM] Make ARM_VIC_NR depend on ARM_VIC
[ARM] 5546/1: ARM PL022 SSP/SPI driver v3
ARM: OMAP4: SMP: Update defconfig for OMAP4430
ARM: OMAP4: SMP: Enable SMP support for OMAP4430
Fix Kconfig to build via-rng.ko on X86_64 builds, as the VIA Nano
CPU supports x86_64, too.
Signed-off-by: Harald Welte <HaraldWelte@viatech.com>
This hw-random driver add support to RNGA hardware found
on some i.MX processors.
Signed-off-by: Alan Carvalho de Assis <acassis@gmail.com>
CC drivers/char/hw_random/timeriomem-rng.o
drivers/char/hw_random/timeriomem-rng.c: In function 'timeriomem_rng_data_read':
drivers/char/hw_random/timeriomem-rng.c:60: error: implicit declaration of function 'readl'
Some hardware platforms, the TS-7800[1] is one for example, can
supply the kernel with an entropy source, albeit a slow one for
TS-7800 users, by just reading a particular IO address. This
source must not be read above a certain rate otherwise the quality
suffers.
The driver is then hooked into by calling
platform_device_(register|add|del) passing a structure similar to:
static struct timeriomem_rng_data ts78xx_ts_rng_data = {
.address = (u32 *__iomem) TS_RNG,
.period = 1000000, /* one second */
static struct platform_device ts78xx_ts_rng_device = {
.name = "timeriomem_rng",
.id = -1,
.dev = {
.platform_data = &ts78xx_ts_rng_data,
.num_resources = 0,
[1] http://www.embeddedarm.com/products/board-detail.php?product=TS-7800
Signed-off-by: Alexander Clouter <alex@digriz.org.uk>
With feedback and suggestions from Sam Ravnborg.
Note that by itself, having a "hardware" random generator does very
little: you should probably run "rngd" in your guest to feed this into
the kernel entropy pool.
Included:
virtio_rng: dont use vmalloced addresses for virtio
If virtio_rng is build as a module, random_data is an address
in vmalloc space. As virtio expects guest real addresses, this
can cause any kind of funny behaviour, so lets allocate
random_data dynamically with kmalloc.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Update documentation for the hw_random support to be current:
- Documentation/hw_random.txt has been updated to reflect the
current code: it's a framework now, a "core" with a small
sysfs interface, that hardware-specific drivers plug in to.
Text specific to Intel hardware is now at the end.
- Kconfig now references the Documentation/hw_random.txt file
and better explains what this really does.
Both chunks of documentation now higlight the fact that the kernel entropy
pool is maintained by "rngd", and this driver has nothing directly to do with
that important task.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
There will be more product numbers in the future than just PA6T-1682M,
but they will share much of the features. Remove some of the explicit
references and compatibility checks with 1682M, and replace most of them
with the more generic term "PWRficient".
Acked-by: Michael Buesch <mb@bu3sch.de>
Acked-by: Doug Thompson <dougthompson@xmission.com>
Signed-off-by: Yinghai Lu <yinghai.lu@sun.com>
Acked-by: Alan Cox <alan@redhat.com>
Signed-off-by: Andi Kleen <ak@suse.de>
Driver for the on-chip hardware random number generator on PA Semi
PA6T-1682M.
Signed-off-by: Egor Martovetsky <egor@pasemi.com>
Signed-off-by: Michael Buesch <mb@bu3sch.de>
Cc: Kumar Gala <galak@gate.crashing.org>
Despite it being small, there should be the option of making it a
module...
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: Michael Buesch <mb@bu3sch.de>
Cc: Jeff Garzik <jeff@garzik.org>
