Signed-off-by: Michael Buesch <m@bues.ch>
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
When the loop terminates with size == 0 in rng_dev_read we will
unlock the rng mutex twice.
Reported-by: Dan Carpenter <error27@gmail.com>
* 'bkl-drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
agp: Remove the BKL from agp_open
inifiband: Remove BKL from ipath_open()
mips: Remove BKL from tb0219
drivers: Remove BKL from scx200_gpio
drivers: Remove BKL from pc8736x_gpio
parisc: Remove BKL from eisa_eeprom
rtc: Remove BKL from efirtc
input: Remove BKL from hp_sdc_rtc
hw_random: Remove BKL from core
macintosh: Remove BKL from ans-lcd
nvram: Drop the bkl from non-generic nvram_llseek()
nvram: Drop the bkl from nvram_llseek()
mem_class: Drop the bkl from memory_open()
spi: Remove BKL from spidev_open
drivers: Remove BKL from cs5535_gpio
drivers: Remove BKL from misc_open
This patch prevents the hw_random core using too small of a buffer
on machines with small cacheline sizes.
Signed-off-by: Ian Molton <ian.molton@collabora.co.uk>
This patch implements a new method by which hw_random hardware drivers
can pass data to the core more efficiently, using a shared buffer.
The old methods have been retained as a compatability layer until all the
drivers have been updated.
Acked-by: Matt Mackall <mpm@selenic.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
hw_random core is completely serialized with rng_mutex. No need for
the cycle_kernel_lock() magic.
LKML-Reference: <20091010153349.844488872@linutronix.de>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
This allows subsytems to provide devtmpfs with non-default permissions
for the device node. Instead of the default mode of 0600, null, zero,
random, urandom, full, tty, ptmx now have a mode of 0666, which allows
non-privileged processes to access standard device nodes in case no
other userspace process applies the expected permissions.
This also fixes a wrong assignment in pktcdvd and a checkpatch.pl complain.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This adds support for misc devices to report their requested nodename to
userspace. It also updates a number of misc drivers to provide the
needed subdirectory and device name to be used for them.
Signed-off-by: Jan Blunck <jblunck@suse.de>
After 2.6.24 there was a plan to make the PM core acquire all device
semaphores during a suspend/hibernation to protect itself from
concurrent operations involving device objects. That proved to be
too heavy-handed and we found a better way to achieve the goal, but
before it happened, we had introduced the functions
device_pm_schedule_removal() and destroy_suspended_device() to allow
drivers to "safely" destroy a suspended device and we had adapted some
drivers to use them. Now that these functions are no longer necessary,
it seems reasonable to remove them and modify their users to use the
normal device unregistration instead.
Acked-by: Pavel Machek <pavel@ucw.cz>
The api for hardware random number generators is currently limited to
devices that never fail. If the hardware is registered as a source for
random numbers it has to work. This prevents the use of i/o based
random number devices where the i/o might fail.
Add a check for errors after the read from a hardware random number device.
This patch is required to support large random numbers retrieved
from the CEX2C cards on System z.
Signed-off-by: Ralph Wuerthner <rwuerthn@de.ibm.com>
Make it possible to unregister a Hardware Random Number Generator
device object in a safe way during a suspend/resume cycle.
Acked-by: Michael Buesch <mb@bu3sch.de>
Cc: Michael Buesch <mb@bu3sch.de>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Len Brown <lenb@kernel.org>
Cc: Greg KH <greg@kroah.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Richard Purdie <rpurdie@rpsys.net>
Handle waiting for new random within the drivers themselves, this allows to
use better suited timeouts for the individual rngs.
This also ment that some of the misc drivers had to also be fixed
up as they were assuming the device was a class_device.
Mark the static struct file_operations in drivers/char as const. Making
them const prevents accidental bugs, and moves them to the .rodata section
so that they no longer do any false sharing; in addition with the proper
debug option they are then protected against corruption..
[akpm@osdl.org: build fix]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: Michael Buesch <mb@bu3sch.de>
Cc: Jeff Garzik <jeff@garzik.org>
