path: root/drivers/char/ip2main.c
2006-02-03[PATCH] ip2main.c warning fixesAndrew Morton
With Eric's "i386: Add a temporary to make put_user more type safe" patch we get a pile of warnings out of ip2m1in.c: drivers/char/ip2main.c: In function `ip2_ipl_ioctl': drivers/char/ip2main.c:2910: warning: assignment makes integer from pointer without a cast drivers/char/ip2main.c:2911: warning: assignment makes integer from pointer without a cast drivers/char/ip2main.c:2912: warning: assignment makes integer from pointer without a cast etc. This ioctl is copying the kernel virtual address of a large number of functions out to userspace. Heaven knows why. Rather than fixing the warnings, I think we'll just nuke that code. The patch also fixes a couple of `defined but not used' warnings. Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] clean up computone remaining cli useAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] Driver Core: fix up all callers of class_device_create()Greg Kroah-Hartman
The previous patch adding the ability to nest struct class_device changed the paramaters to the call class_device_create(). This patch fixes up all in-kernel users of the function. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-09[PATCH] timer initialization cleanup: DEFINE_TIMERIngo Molnar
Clean up timer initialization by introducing DEFINE_TIMER a'la DEFINE_SPINLOCK. Build and boot-tested on x86. A similar patch has been been in the -RT tree for some time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] gratuitous includes of asm/serial.hviro@ZenIV.linux.org.uk
Removed gratuitous includes of asm/serial.h in synklinkmp and ip2main. Allows to remove the rest of "broken on sparc32" in drivers/char - this stuff doesn't break the build anymore. Since it got zero testing, it almost certainly won't work there, though... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] drivers/char/ip2*: cleanupsAdrian Bunk
This patch contains the following cleanups: - i2cmd.c: #if 0 the unused function i2cmdUnixFlags - i2cmd.c: make the needlessly global funciton i2cmdBaudDef static - ip2main.c: remove dead code that wasn't reachable due to an #ifdef Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] class: convert drivers/char/* to use the new class api instead of ↵gregkh@suse.de
class_simple Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
