commit d2478521afc2022 ("char/ipmi: fix OOPS caused by
pnp_unregister_driver on unregistered driver") introduced a section
mismatch by calling __exit cleanup_ipmi_si from __devinit init_ipmi_si.
Remove __exit annotation from cleanup_ipmi_si.
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Acked-by: Corey Minyard <cminyard@mvista.com>
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits)
tty: serial: altera_jtaguart: Add device tree support
tty: serial: altera_uart: Add devicetree support
dt: eliminate of_platform_driver shim code
dt: Eliminate of_platform_{,un}register_driver
dt/serial: Eliminate users of of_platform_{,un}register_driver
dt/usb: Eliminate users of of_platform_{,un}register_driver
dt/video: Eliminate users of of_platform_{,un}register_driver
dt/net: Eliminate users of of_platform_{,un}register_driver
dt/sound: Eliminate users of of_platform_{,un}register_driver
dt/spi: Eliminate users of of_platform_{,un}register_driver
dt: uartlite: merge platform and of_platform driver bindings
dt: xilinx_hwicap: merge platform and of_platform driver bindings
ipmi: convert OF driver to platform driver
leds/leds-gpio: merge platform_driver with of_platform_driver
dt/sparc: Eliminate users of of_platform_{,un}register_driver
dt/powerpc: Eliminate users of of_platform_{,un}register_driver
dt/powerpc: move of_bus_type infrastructure to ibmebus
drivercore/dt: add a match table pointer to struct device
dt: Typo fix.
altera_ps2: Add devicetree support
This patch fixes an issue in OpenIPMI module where sometimes an ABORT command
is sent after sending an IPMI request to BMC causing the IPMI request to fail.
Signed-off-by: YiCheng Doe <yicheng.doe@hp.com>
Signed-off-by: Corey Minyard <cminyard@mvista.com>
Acked-by: Tom Mingarelli <thomas.mingarelli@hp.com>
Tested-by: Andy Cress <andy.cress@us.kontron.com>
Tested-by: Mika Lansirine <Mika.Lansirinne@stonesoft.com>
Tested-by: Brian De Wolf <bldewolf@csupomona.edu>
Cc: Jean Michel Audet <Jean-Michel.Audet@ca.Kontron.com>
Cc: Jozef Sudelsky <jozef.sudolsky@elbiahosting.sk>
Acked-by: Matthew Garrett <mjg@redhat.com>
of_bus is deprecated in favor of the plain platform bus. This patch
merges the ipmi OF driver with the existing platform driver.
CONFIG_PPC_OF occurrances are removed or replaced with CONFIG_OF.
Compile tested with and without CONFIG_OF. Tested OF probe and
default probe cases.
This patch fixes an OOPS triggered when calling modprobe ipmi_si a
second time after the first modprobe returned without finding any ipmi
devices. This can happen if you reload the module after having the
first module load fail. The driver was not deregistering from PNP in
that case.
Peter Huewe originally reported this patch and supplied a fix, I have a
different patch based on Linus' suggestion that cleans things up a bit
more.
Cc: stable@kernel.org
Cc: openipmi-developer@lists.sourceforge.net
Reviewed-by: Peter Huewe <peterhuewe@gmx.de>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (59 commits)
ACPI / PM: Fix build problems for !CONFIG_ACPI related to NVS rework
ACPI: fix resource check message
ACPI / Battery: Update information on info notification and resume
ACPI: Drop device flag wake_capable
ACPI: Always check if _PRW is present before trying to evaluate it
ACPI / PM: Check status of power resources under mutexes
ACPI / PM: Rename acpi_power_off_device()
ACPI / PM: Drop acpi_power_nocheck
ACPI / PM: Drop acpi_bus_get_power()
Platform / x86: Make fujitsu_laptop use acpi_bus_update_power()
ACPI / Fan: Rework the handling of power resources
ACPI / PM: Register power resource devices as soon as they are needed
ACPI / PM: Register acpi_power_driver early
ACPI / PM: Add function for updating device power state consistently
ACPI / PM: Add function for device power state initialization
ACPI / PM: Introduce __acpi_bus_get_power()
ACPI / PM: Introduce function for refcounting device power resources
ACPI / PM: Add functions for manipulating lists of power resources
ACPI / PM: Prevent acpi_power_get_inferred_state() from making changes
ACPICA: Update version to 20101209
The new GPE handler callback has 2 additional parameters, gpe_device and
gpe_number.
typedef
u32 (*acpi_gpe_handler) (acpi_handle gpe_device, u32 gpe_number, void *context);
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits)
perf session: Fix infinite loop in __perf_session__process_events
perf evsel: Support perf_evsel__open(cpus > 1 && threads > 1)
perf sched: Use PTHREAD_STACK_MIN to avoid pthread_attr_setstacksize() fail
perf tools: Emit clearer message for sys_perf_event_open ENOENT return
perf stat: better error message for unsupported events
perf sched: Fix allocation result check
perf, x86: P4 PMU - Fix unflagged overflows handling
dynamic debug: Fix build issue with older gcc
tracing: Fix TRACE_EVENT power tracepoint creation
tracing: Fix preempt count leak
tracepoint: Add __rcu annotation
tracing: remove duplicate null-pointer check in skb tracepoint
tracing/trivial: Add missing comma in TRACE_EVENT comment
tracing: Include module.h in define_trace.h
x86: Save rbp in pt_regs on irq entry
x86, dumpstack: Fix unused variable warning
x86, NMI: Clean-up default_do_nmi()
x86, NMI: Allow NMI reason io port (0x61) to be processed on any CPU
x86, NMI: Remove DIE_NMI_IPI
x86, NMI: Add priorities to handlers
They are a handful of places in the code that register a die_notifier
as a catch all in case no claims the NMI. Unfortunately, they trigger
on events like DIE_NMI and DIE_NMI_IPI, which depending on when they
registered may collide with other handlers that have the ability to
determine if the NMI is theirs or not.
The function unknown_nmi_error() makes one last effort to walk the
die_chain when no one else has claimed the NMI before spitting out
messages that the NMI is unknown.
This is a better spot for these devices to execute any code without
colliding with the other handlers.
The two drivers modified are only compiled on x86 arches I believe, so
they shouldn't be affected by other arches that may not have
DIE_NMIUNKNOWN defined.
Signed-off-by: Don Zickus <dzickus@redhat.com>
Cc: Russ Anderson <rja@sgi.com>
Cc: Corey Minyard <minyard@acm.org>
Cc: dann frazier <dannf@hp.com>
LKML-Reference: <1294348732-15030-3-git-send-email-dzickus@redhat.com>
of_address.h and of_irq.h are implicitly included on powerpc. Adding
them fixes builds on non-powerpc platforms.
Fixes for sdhci-of and ipmi drivers.
Auditing all drivers using of_get_property did not find other
occurrences likely to be used on LE platforms.
The IPMI smi_watcher will be used to catch the IPMI interface as they
come or go. In order to communicate with the correct IPMI device, it
should be confirmed whether it is what we wanted especially on the
system with multiple IPMI devices. But the new_smi callback function
of smi_watcher provides very limited info(only the interface number
and dev pointer) and there is no detailed info about the low level
interface. For example: which mechansim registers the IPMI
interface(ACPI, PCI, DMI and so on).
This is to add one interface that can get more info of low-level IPMI
device. For example: the ACPI device handle will be returned for the
pnp_acpi IPMI device.
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Changed <module>-objs to <module>-y in Makefile.
Signed-off-by: Tracey Dent <tdent48227@gmail.com>
Cc: Jiri Slaby <jirislaby@gmail.com>
Cc: Michal Marek <mmarek@suse.cz>
__init and __exit belong after the return type on functions, not
before.
Unloading ipmi module can trigger following error. (if
CONFIG_DEBUG_SPINLOCK=y)
[ 9633.779590] BUG: spinlock bad magic on CPU#1, rmmod/7170
[ 9633.779606] lock: f41f5414, .magic: 00000000, .owner:
<none>/-1, .owner_cpu: 0
[ 9633.779626] Pid: 7170, comm: rmmod Not tainted
2.6.36-rc7-11474-gb71eb1e-dirty #328
[ 9633.779644] Call Trace:
[ 9633.779657] [<c13921cc>] ? printk+0x18/0x1c
[ 9633.779672] [<c11a1f33>] spin_bug+0xa3/0xf0
[ 9633.779685] [<c11a1ffd>] do_raw_spin_lock+0x7d/0x160
[ 9633.779702] [<c1131537>] ? release_sysfs_dirent+0x47/0xb0
[ 9633.779718] [<c1131b78>] ? sysfs_addrm_finish+0xa8/0xd0
[ 9633.779734] [<c1394bac>] _raw_spin_lock_irqsave+0xc/0x20
[ 9633.779752] [<f99d93da>] cleanup_one_si+0x6a/0x200 [ipmi_si]
[ 9633.779768] [<c11305b2>] ? sysfs_hash_and_remove+0x72/0x80
[ 9633.779786] [<f99dcf26>] ipmi_pnp_remove+0xd/0xf [ipmi_si]
[ 9633.779802] [<c11f622b>] pnp_device_remove+0x1b/0x40
Fix this by initializing spinlocks in a smi_info_alloc() helper function,
right after memory allocation and clearing.
Acked-by: David Miller <davem@davemloft.net>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: <stable@kernel.org>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
* 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
block: autoconvert trivial BKL users to private mutex
drivers: autoconvert trivial BKL users to private mutex
ipmi: autoconvert trivial BKL users to private mutex
mac: autoconvert trivial BKL users to private mutex
mtd: autoconvert trivial BKL users to private mutex
scsi: autoconvert trivial BKL users to private mutex
Fix up trivial conflicts (due to addition of private mutex right next to
deletion of a version string) in drivers/char/pcmcia/cm40[04]0_cs.c
The patch below updates broken web addresses in the kernel
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Ben Pfaff <blp@cs.stanford.edu>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
When modprobe.conf has
options ipmi_si type="kcs" ports=0xCA2 regspacings="4"
ipmi_si can be loaded properly, but when try to unload it get:
Sep 20 15:00:27 xx abrt: Kerneloops: Reported 1 kernel oopses to Abrt
Sep 20 15:00:27 xx abrtd: Directory 'kerneloops-1285020027-1' creation detected
Sep 20 15:00:27 xx abrtd: New crash /var/spool/abrt/kerneloops-1285020027-1, processing
Sep 20 15:01:09 xx kernel: ------------[ cut here ]------------
Sep 20 15:01:09 xx kernel: WARNING: at drivers/base/driver.c:262 driver_unregister+0x8a/0xa0()
Sep 20 15:01:09 xx kernel: Hardware name: Sun Fire x4800
Sep 20 15:01:09 xx kernel: Unexpected driver unregister!
Sep 20 15:01:09 xx kernel: Modules linked in: ipmi_si(-) ipmi_msghandler ip6table_filter ip6_tables ebtable_nat ebtables ipt_MASQUERADE iptable_nat nf_nat bridge stp llc autofs4 sunrpc cpufreq_ondemand acpi_cpufreq freq_table mperf xt_physdev be2iscsi iscsi_boot_sysfs bnx2i cnic uio cxgb3i iw_cxgb3 cxgb3 mdio ib_iser rdma_cm ib_cm iw_cm ib_sa ib_mad ib_core ib_addr ipv6 iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi dm_mirror dm_region_hash dm_log dm_mod vhost_net macvtap macvlan tun kvm_intel kvm uinput sg ses enclosure ahci libahci pcspkr i2c_i801 i2c_core iTCO_wdt iTCO_vendor_support igb dca i7core_edac edac_core ext3 jbd mbcache sd_mod crc_t10dif megaraid_sas [last unloaded: ipmi_devintf]
Sep 20 15:01:09 xx kernel: Pid: 10625, comm: modprobe Tainted: G W 2.6.36-rc5-tip+ #6
Sep 20 15:01:09 xx kernel: Call Trace:
Sep 20 15:01:09 xx kernel: [<ffffffff810600df>] warn_slowpath_common+0x7f/0xc0
Sep 20 15:01:09 xx kernel: [<ffffffff810601d6>] warn_slowpath_fmt+0x46/0x50
Sep 20 15:01:09 xx kernel: [<ffffffff812ff60a>] driver_unregister+0x8a/0xa0
Sep 20 15:01:09 xx kernel: [<ffffffff812ae112>] pnp_unregister_driver+0x12/0x20
Sep 20 15:01:09 xx kernel: [<ffffffffa01d0327>] cleanup_ipmi_si+0x3c/0xa7 [ipmi_si]
Sep 20 15:01:09 xx kernel: [<ffffffff81099a60>] sys_delete_module+0x1a0/0x270
Sep 20 15:01:09 xx kernel: [<ffffffff814b7070>] ? do_page_fault+0x150/0x320
Sep 20 15:01:09 xx kernel: [<ffffffff8100b072>] system_call_fastpath+0x16/0x1b
Sep 20 15:01:09 xx kernel: ---[ end trace 0d1967161adcee0d ]---
We need to check if ipmi_pnp_driver is loaded before we try to unload it.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
After d9e1b6c45059ccf ("ipmi: fix ACPI detection with regspacing") we get
[ 11.026326] ipmi_si: probing via ACPI
[ 11.030019] ipmi_si 00:09: (null) regsize 1 spacing 1 irq 0
[ 11.035594] ipmi_si: Adding ACPI-specified kcs state machine
on an old system with only one range for ipmi kcs range.
Try to fix it by adding another res pointer.
All these files use the big kernel lock in a trivial
way to serialize their private file operations,
typically resulting from an earlier semi-automatic
pushdown from VFS.
None of these drivers appears to want to lock against
other code, and they all use the BKL as the top-level
lock in their file operations, meaning that there
is no lock-order inversion problem.
Consequently, we can remove the BKL completely,
replacing it with a per-file mutex in every case.
Using a scripted approach means we can avoid
typos.
file=$1
name=$2
if grep -q lock_kernel ${file} ; then
if grep -q 'include.*linux.mutex.h' ${file} ; then
sed -i '/include.*<linux\/smp_lock.h>/d' ${file}
else
sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file}
fi
sed -i ${file} \
-e "/^#include.*linux.mutex.h/,$ {
1,/^\(static\|int\|long\)/ {
/^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex);
-e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \
-e '/[ ]*cycle_kernel_lock();/d'
else
sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \
-e '/cycle_kernel_lock()/d'
fi
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus
* 'params' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (22 commits)
param: don't deref arg in __same_type() checks
param: update drivers/acpi/debug.c to new scheme
param: use module_param in drivers/message/fusion/mptbase.c
ide: use module_param_named rather than module_param_call
param: update drivers/char/ipmi/ipmi_watchdog.c to new scheme
param: lock if_sdio's lbs_helper_name and lbs_fw_name against sysfs changes.
param: lock myri10ge_fw_name against sysfs changes.
param: simple locking for sysfs-writable charp parameters
param: remove unnecessary writable charp
param: add kerneldoc to moduleparam.h
param: locking for kernel parameters
param: make param sections const.
param: use free hook for charp (fix leak of charp parameters)
param: add a free hook to kernel_param_ops.
param: silence .init.text references from param ops
Add param ops struct for hvc_iucv driver.
nfs: update for module_param_named API change
AppArmor: update for module_param_named API change
param: use ops in struct kernel_param, rather than get and set fns directly
param: move the EXPORT_SYMBOL to after the definitions.
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6:
mmc_spi: Fix unterminated of_match_table
of/sparc: fix build regression from of_device changes
of/device: Replace struct of_device with struct platform_device
Print out the reg spacing and size for spmi and smbios so BIOS developers
can make them consistent.
Also remove extra PFX on the duplicating path.
Cc: Matthew Garrett <mjg@redhat.com>
Cc: Len Brown <len.brown@intel.com>
Cc: Myron Stowe <myron.stowe@hp.com>
Free the temporary info struct when we have duplicated ones.
not used
Fix a warning message generated by GCC, and also updates a web address
pointing to a pdf containing information.
CC [M] drivers/char/ipmi/ipmi_si_intf.o
drivers/char/ipmi/ipmi_si_intf.c: In function 'try_init_spmi':
drivers/char/ipmi/ipmi_si_intf.c:2016:8: warning: variable 'addr_space' set but not used
Signed-off-by: Sergey V. <sftp.mtuci@gmail.com>
Acked-by: Corey Minyard <minyard@acm.org>
This is one of the most interesting users of module parameters in the
tree, so weaning it off the old-style non-const module_param_call
scheme is a useful exercise.
I was confused by set_param_int/get_param_int (vs. the normal
param_set_int and param_get_int), so I renamed set_param_int to
set_param_timeout, and re-used param_get_int directly instead of
get_param_int. I also implemented param_check_wdog_ifnum and
param_check_timeout, so now the ifnum_to_use and timeout/pretimeout
parameters can just use plain module_param().
After the commit that changed ipmi_si detecting sequence from SMBIOS/ACPI
to ACPI/SMBIOS,
| commit 754d453185275951d39792865927ec494fa1ebd8
| Author: Matthew Garrett <mjg@redhat.com>
| Date: Wed May 26 14:43:47 2010 -0700
| ipmi: change device discovery order
| The ipmi spec provides an ordering for si discovery. Change the driver to
| match, with the exception of preferring smbios to SPMI as HPs (at least)
| contain accurate information in the former but not the latter.
ipmi_si can not be initialized.
[ 138.799739] calling init_ipmi_devintf+0x0/0x109 @ 1
[ 138.805050] ipmi device interface
[ 138.818131] initcall init_ipmi_devintf+0x0/0x109 returned 0 after 12797 usecs
[ 138.822998] calling init_ipmi_si+0x0/0xa90 @ 1
[ 138.840276] IPMI System Interface driver.
[ 138.846137] ipmi_si: probing via ACPI
[ 138.849225] ipmi_si 00:09: [io 0x0ca2] regsize 1 spacing 1 irq 0
[ 138.864438] ipmi_si: Adding ACPI-specified kcs state machine
[ 138.870893] ipmi_si: probing via SMBIOS
[ 138.880945] ipmi_si: Adding SMBIOS-specified kcs state machineipmi_si: duplicate interface
[ 138.896511] ipmi_si: probing via SPMI
[ 138.899861] ipmi_si: Adding SPMI-specified kcs state machineipmi_si: duplicate interface
[ 138.917095] ipmi_si: Trying ACPI-specified kcs state machine at i/o address 0xca2, slave address 0x0, irq 0
[ 138.928658] ipmi_si: Interface detection failed
[ 138.953411] initcall init_ipmi_si+0x0/0xa90 returned 0 after 110847 usecs
in smbios has
DMI/SMBIOS
Handle 0x00C5, DMI type 38, 18 bytes
IPMI Device Information
Interface Type: KCS (Keyboard Control Style)
Specification Version: 2.0
I2C Slave Address: 0x00
NV Storage Device: Not Present
Base Address: 0x0000000000000CA2 (I/O)
Register Spacing: 32-bit Boundaries
in DSDT has
Device (BMC)
Name (_HID, EisaId ("IPI0001"))
Method (_STA, 0, NotSerialized)
If (LEqual (OSN, Zero))
Return (Zero)
Return (0x0F)
Name (_STR, Unicode ("IPMI_KCS"))
Name (_UID, Zero)
Name (_CRS, ResourceTemplate ()
IO (Decode16,
0x0CA2, // Range Minimum
0x0CA2, // Range Maximum
0x00, // Alignment
0x01, // Length
IO (Decode16,
0x0CA6, // Range Minimum
0x0CA6, // Range Maximum
0x00, // Alignment
0x01, // Length
Method (_IFT, 0, NotSerialized)
Return (One)
Method (_SRV, 0, NotSerialized)
Return (0x0200)
so the reg spacing should be 4 instead of 1.
Try to calculate regspacing for this kind of system.
Observed on a Sun Fire X4800. Other OSes work and pass certification.
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
of_device is just an alias for platform_device, so remove it entirely. Also
replace to_of_device() with to_platform_device() and update comment blocks.
This patch was initially generated from the following semantic patch, and then
edited by hand to pick up the bits that coccinelle didn't catch.
-struct of_device
+struct platform_device
Reviewed-by: David S. Miller <davem@davemloft.net>
Fix a regression introduced by ae74e823cb7d ("ipmi: add parameter to limit
CPU usage in kipmid").
Some systems were seeing CPU usage go up dramatically with the recent
changes to try to reduce timer usage in the IPMI driver. This was traced
down to schedule_timeout_interruptible(1) being changed to
schedule_timeout_interruptbile(0). Revert that part of the change.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16147
Reported-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
Tested-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
Cc: <stable@kernel.org> [2.6.34.x]
The ipmi code will never register a PCI or Open Firmware driver if a
hardcoded device is provided by the user by providing device addresses via
the module parameters. This can cause us to attempt to unregister a
driver that was never registered, resulting in an oops. Keep track of
registration in order to avoid this.
Fixes a post-2.6.34 regression.
If run_to_completion flag is set, it means that we are running in a
single-threaded mode, and thus no locks are held.
This fixes a deadlock when IPMI notifier is being called during panic.
Update core IPMI driver printk()'s with dev_printk(), and its constructs,
to provide additional device topology information.
An example of the additional device topology for a PNP device -
ipmi_si 00:02: probing via ACPI
ipmi_si 00:02: [io 0x0ca2-0x0ca3] regsize 1 spacing 1 irq 0
ipmi_si 00:02: Found new BMC (man_id: 0x00000b, prod_id: 0x0000, ...
ipmi_si 00:02: IPMI kcs interface initialized
and for a PCI device -
ipmi_si 0000:01:04.6: probing via PCI
ipmi_si 0000:01:04.6: PCI INT A -> GSI 21 (level, low) -> IRQ 21
ipmi_si 0000:01:04.6: [mem 0xf1ef0000-0xf1ef00ff] regsize 1 spaci...
ipmi_si 0000:01:04.6: IPMI kcs interface initialized
[minyard@acm.org: rework to fix rejects, extended it a bit]
Signed-off-by: Myron Stowe <myron.stowe@hp.com>
Signed-off-by: Corey Minyard <minyard@acm.org>
Cc: Zhao Yakui <yakui.zhao@intel.com>
Cc: Len Brown <lenb@kernel.org>
Convert PNP patch (git 9e368fa011d4e0aa050db348d69514900520e40b) to
maintain a pointer to a PNP device, 'pnp_dev', instead of the ACPI device,
'acpi_dev', that is currently being tracked with PNP based IPMI device
discovery.
Acked-by: Zhao Yakui <yakui.zhao@intel.com>
The timeouts in IPMI are in the 1-5 second range in message handling, so a
1 second timeout is a reasonable thing to do. This should help with
reducing power consumption on idle systems.
Some odd systems may have multiple BMCs, and we want to be able to support
them. Let's make the assumption that if a system legitimately has
multiple BMCs then each BMC's SI will be of the same type, and also that
we won't see multiple SIs of the same type unless we have multiple BMCs.
If these hold true then we should register all SIs of the same type.
We can reasonably alter the poll rate depending on whether we're
performing a transaction or merely waiting for an event.
If we're not currently in the middle of a transaction, and if we have
interrupts, there's no real reason to poll the controller more frequently
than the core IPMI code does. Set the interrupt_disabled flag
appropriately as the interrupt state changes, and make the timeout code
reset itself only if the transaction is incomplete or we have no
interrupts.
Only register one si per bmc. Use any user-provided devices first,
followed by the first device with an irq, followed by the first device
discovered.
The ipmi spec indicates that we should only make use of one si per bmc, so
separate device discovery and registration to make that possible.
[thenzl@redhat.com: fix mutex use]
Signed-off-by: Tomas Henzl <thenzl@redhat.com>
Switch from a char* to an enum to identify the address source of SIs,
making it easier to handle them appropriately during registration.
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing
* 'bkl/ioctl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing:
uml: Pushdown the bkl from harddog_kern ioctl
sunrpc: Pushdown the bkl from sunrpc cache ioctl
sunrpc: Pushdown the bkl from ioctl
autofs4: Pushdown the bkl from ioctl
uml: Convert to unlocked_ioctls to remove implicit BKL
ncpfs: BKL ioctl pushdown
coda: Clean-up whitespace problems in pioctl.c
coda: BKL ioctl pushdown
drivers: Push down BKL into various drivers
isdn: Push down BKL into ioctl functions
scsi: Push down BKL into ioctl functions
dvb: Push down BKL into ioctl functions
smbfs: Push down BKL into ioctl function
coda/psdev: Remove BKL from ioctl function
um/mmapper: Remove BKL usage
sn_hwperf: Kill BKL usage
hfsplus: Push down BKL into ioctl function
.name, .match_table and .owner are duplicated in both of_platform_driver
and device_driver. This patch is a removes the extra copies from struct
of_platform_driver and converts all users to the device_driver members.
This patch is a pretty mechanical change. The usage model doesn't change
and if any drivers have been missed, or if anything has been fixed up
incorrectly, then it will fail with a compile time error, and the fixup
will be trivial. This patch looks big and scary because it touches so
many files, but it should be pretty safe.
Acked-by: Sean MacLennan <smaclennan@pikatech.com>
The following structure elements duplicate the information in
'struct device.of_node' and so are being eliminated. This patch
makes all readers of these elements use device.of_node instead.
(struct of_device *)->node
(struct dev_archdata *)->prom_node (sparc)
(struct dev_archdata *)->of_node (powerpc & microblaze)
These are the last remaining device drivers using
the ->ioctl file operation in the drivers directory
(except from v4l drivers).
[fweisbec: drop i8k pushdown as it has been done from
procfs pushdown branch already]
This fixes a sysfs lockdep warning in the ipmi code.
Thanks to Eric Biederman and Yinghai Lu for the original versions of the
patch, unfortunatly they did not submit them in a form they could be
applied in.
Cc: Eric Biederman <ebiederm@xmission.com>
