path: root/drivers/char/mwave
2009-09-24mwave: fix read buffer overflowRoel Kluin
Check whether index is within bounds before grabbing the element. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mwave: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-25mwave: ioctl BKL pushdownAlan Cox
Push the BKL down to the point it wraps the actual mwave method handlers Signed-off-by: Alan Cox <alan@redhat.com> Cc: Eric Sesterhenn <snakebyte@gmx.de> Cc: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25proper extern for mwave_s_mddAdrian Bunk
This patch adds a proper extern for mwave_s_mdd in drivers/char/mwave/mwavedd.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-02mwave-mwavedd: BKL pushdownArnd Bergmann
2008-04-24arm/mach-integrator/time.c, mwave: revert portions of recent irq cleanupsJeff Garzik
The recent irq cleanups for arch/arm/mach-integrator/time.c and drivers/char/mwave/tp3780i.c changed the request_irq() dev_id parameter, but neglected to change the matching free_irq() parameter, thus creating a bug upon irq de-registration. Given that the impetus for the changes is not yet accepted upstream, it is best to revert the irq cleanups. Mostly. A comment is added to time.c to reduce future confusion, of type that led to my time.c cleanup in the first place. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-20drivers/char: minor irq handler cleanupsJeff Garzik
- remove always-false tests - don't overload 'irq' argument, pass data properly via dev_id - remove pointless casts from void* Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-02-20[PATCH] mwave: interesting flags savingsAlexey Dobriyan
Flags from spin_lock_irqsave() are saved into global variable and restored from it. My gut feeling this is very racy. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-03remove mentionings of devfs in documentationAdrian Bunk
Now that devfs is removed, there's no longer any need to document how to do this or that with devfs. This patch includes some improvements by Joe Perches. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-01[PATCH] Off-by-one in drivers/char/mwave/mwavedd.cEric Sesterhenn
This fixes two off by ones in the mwave driver, found via find -iname \*.[ch] | xargs grep "> ARRAY_SIZE(" Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] make more file_operation structs staticArjan van de Ven
Mark the static struct file_operations in drivers/char as const. Making them const prevents accidental bugs, and moves them to the .rodata section so that they no longer do any false sharing; in addition with the proper debug option they are then protected against corruption.. [akpm@osdl.org: build fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-28[PATCH] fix array overrun in drivers/char/mwave/mwavedd.cEric Sesterhenn
this fixes coverity id #489. Since the last element in the array is always ARRAY_SIZE-1 we have to check for ipcnum >= ARRAY_SIZE() Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-15[PATCH] mwave: missing __user in ioctl struct declarationAl Viro
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-31[SERIAL] Convert mwave to use serial8250_(un)?register_portAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-25[PATCH] drivers/char/mwave/tp3780i.c: remove dead codeAdrian Bunk
This patch removes some dead code found by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] drivers/char/mwave/3780i.c: cleanupsAdrian Bunk
This patch contains the following cleanups: - make a needlessly global function static - #if 0 the unused global function dsp3780I_ReadGenCfg Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] drivers/char/mwave/tp3780i.c: remove kernel 2.2 #if'sAdrian Bunk
This patch removes #if's for kernel 2.2 . Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Driver Core: drivers/base - drivers/i2c/chips/adm1026.c: update ↵Yani Ioannou
device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
