path: root/drivers/char/mxser.c
2009-04-06mxser: remove tty_port_tty_get from mxser_check_modem_statusJiri Slaby
mxser_check_modem_status is called with tty parameter, so the reference should be increased by callers already -- for ioctl syscall it is held whole time gap since open to close, for interrupt, the reference count is increased in the irq handler. There is no tty_kref_put in that function, so this also fixes a refcounting bug. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02tty: Introduce some close helpers for portsAlan Cox
Again this is a lot of common code we can unify Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02tty: Introduce a tty_port generic block_til_readyAlan Cox
Start sucking more commonality out of the drivers into a single piece of core code. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02tty: relock the mxser driverAlan Cox
2009-01-02tty: Pull the dtr raise into tty portAlan Cox
This moves another per device special out of what should be shared open wait paths into private methods Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02tty_port: Add a port level carrier detect operationAlan Cox
This is the first step to generalising the various pieces of waiting logic duplicated in all sorts of serial drivers. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-11tty: trivial - fix up email addresses in tty related stuffAlan Cox
2008-10-13tty: Remove lots of NULL checksAlan Cox
Many tty drivers contain 'can't happen' checks against NULL pointers passed in by the tty layer. These have never been possible to occur. Even more importantly if they ever do occur we want to know as it would be a serious bug. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13mxser: Switch to kref ttyAlan Cox
2008-07-30Char: mxser, ratelimit ioctl warningJiri Slaby
The GET_MAJOR ioctl prints out a warning, make it ratelimited. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25Char: mxser, various cleanupsJiri Slaby
- remove unused macro - some whitespace cleanup - useless debug prints removal Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25Char: mxser, remove predefined isa supportJiri Slaby
Remove a support of ISA addresses predefined at compile time. It is unused (filled by zeroes) and prolongs the code. Don't initialize global array and add `ioaddr' module param description. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25Char: mxser, prints cleanupJiri Slaby
- use dev_* for printing in pci probe function - move ISA p[rints directly into isa find function, do not postpone it. Remove macros bound to it then. - prepend some prints by "mxser: " to know what it belongs to Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25Char: mxser, globals cleanupJiri Slaby
- remove unused mxvar_diagflag - move mxser_msr into the only user/function - GMStatus, hmm, fix race-prone access to it. We need only one instance for real, not MXSER_PORTS. Move it to MOXA_GETMSTATUS ioctl. - mxser_mon_ext, almost the same, but alloc it on heap, since it has more than 2 kilos. - fix indexing, `i' is not the index value, `i * MXSER_PORTS_PER_BOARD + j' is Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25Char: mxser, ioctl cleanupJiri Slaby
- remove break ctl from ioctl handler, it's never reached, since tty_ops->break_ctl is defined (mxser break handling is done in software) - mark MOXA_GET_MAJOR as deprecated - fix TIOCGICOUNT (some retval non-checks of put_user). Use copy_to_user to whole structure instead. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22Char: mxser, add CP-102UF supportJiri Slaby
Add support for CP-102UF moxa card (update to 1.12 original driver) and increment this driver version. (Somewhat reworked by alan@redhat.com to merge in with other patches) Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22tty: rework break handlingAlan Cox
Some hardware needs to do break handling itself and may have partial support only. Make break_ctl return an error code. Add a tty driver flag so you can indicate driver hardware side break support. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22mxser: remove dead codeAlan Cox
Old style ioctl break code can go Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20tty: add more tty_port fieldsAlan Cox
Move more bits into the tty_port structure Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20mxser: use tty_portAlan Cox
Switch mxser to use the new tty_port structure Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mxser: convert large macros to functionsChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mxser: switch to put_char being intAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty/serial: lay the foundations for the next set of reworksAlan Cox
- Stop drivers calling their own flush method indirectly, it obfuscates code and it will change soon anyway - A few more lock_kernel paths temporarily needed in some driver internal waiting code - Remove private put_char method that does a write call for one char - we have that anyway - Most but not yet all of the termios copy under lock fixing (some has other dependencies to follow) - Note a few locking bugs in drivers found in the process - Kill remaining [ab]users of TIOCG/SSOFTCAR in the driver, these must go to fix the termios locking Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mxser: prepare for BKL pushdownAlan Cox
Push the BKL down into various internal routines in the driver ready to remove it from the break, ioctl and other call points. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Char: mxser, add support for CP-114ULJiri Slaby
Add new card (0x1393:0x1143) support added in 1.11 original driver, also allow rate change in set_serial_info ioctl (as per 1.11 too). Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Reviewed-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Char: mxser, remove itJiri Slaby
(Old) mxser is obsoleted by mxser_new and scheduled for removal on Dec 2007. Remove it by renaming mxser_new to mxser. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Reviewed-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07mxser/mxser_new: first pass over termios reporting for the mxser cardsAlan Cox
2008-02-07Char: char/serial, remove SERIAL_TYPE_NORMAL redefinesJiri Slaby
Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Remove inclusions of <linux/autoconf.h>Ralf Baechle
Nothing should ever include this file. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: "Mike Frysinger" <vapier.adi@gmail.com> Acked-by: "Bryan Wu" <cooloney.lkml@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18mxser: fix compiler warning when building without CONFIG_PCIJesper Juhl
drivers/char/mxser.c:386: warning: 'mxser_get_PCI_conf' declared 'static' but never defined when building without CONFIG_PCI. [jesper.juhl@gmail.com: Fix warning: 'CheckIsMoxaMust' defined but not used] Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18mxser: remove commented crapAlan Cox
This is years dead code and it keeps turning up in confusing ways when grepping for stuff. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16serial: remove termios checks from various old char serial driversAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-24Char: mxser, fix TIOCMIWAITJiri Slaby
There was schedule() missing in the TIOCMIWAIT ioctl. Solve it by moving the code to the wait_event_interruptible. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Jan Yenya Kasprzak <kas@fi.muni.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] mxser: remove useless fieldsCedric Le Goater
the session and pgrp fields in mxser_struct are unused. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Char: tty_wakeup cleanupJiri Slaby
tty_wakeup cleanup - remove wake_up_interruptible(&tty->write_wait) surrounding tty_wakup(tty); - substitute tty->ldisc.write_wakeup(tty) + wake_up() by tty_wakeup(tty); Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-30[PATCH] Char: mxser, fix oops when removing openedJiri Slaby
tty_driver->owner is not set, so if somebody remove mxser_module, it might oops (and doesn't tell the user: no way, it's in use). Set the .owner value. Cc: <osv@javad.com> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] mxser: PCI refcountsAlan Cox
Switch to pci ref counts for mxser when handling PCI devices. Use pci_get_device and drop the reference when we finish and unload. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Greg KH <greg@kroah.com> Cc: <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] mxser: correct tty driver nameJiri Slaby
Mxser tty driver name should be ttyMI, not ttyM. Correct this in mxser to avoid conflicts with isicom driver, which is ttyM. Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] add process_session() helper routineCedric Le Goater
Replace occurences of task->signal->session by a new process_session() helper routine. It will be useful for pid namespaces to abstract the session pid number. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-02[PATCH] const struct tty_operationsJeff Dike
As part of an SMP cleanliness pass over UML, I consted a bunch of structures in order to not have to document their locking. One of these structures was a struct tty_operations. In order to const it in UML without introducing compiler complaints, the declaration of tty_set_operations needs to be changed, and then all of its callers need to be fixed. This patch declares all struct tty_operations in the tree as const. In all cases, they are static and used only as input to tty_set_operations. As an extra check, I ran an i386 allyesconfig build which produced no extra warnings. 53 drivers are affected. I checked the history of a bunch of them, and in most cases, there have been only a handful of maintenance changes in the last six months. serial_core.c was the busiest one that I looked at. Signed-off-by: Jeff Dike <jdike@addtoit.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] serial: Fix up offenders peering at baud bits directlyAlan Cox
Stop some other people peering into the baud bits on their own and make them use the tty_get_baud_rate() helper as a preperation for the move to the new termios. Corrected dependancy previous one had on new termios structs Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: drivers/char: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] remove TTY_DONT_FLIPPaul Fulghum
Remove TTY_DONT_FLIP tty flag. This flag was introduced in 2.1.X kernels to prevent the N_TTY line discipline functions read_chan() and n_tty_receive_buf() from running at the same time. 2.2.15 introduced tty->read_lock to protect access to the N_TTY read buffer, which is the only state requiring protection between these two functions. The current TTY_DONT_FLIP implementation is broken for SMP, and is not universally honored by drivers that send data directly to the line discipline receive_buf function. Because TTY_DONT_FLIP is not necessary, is broken in implementation, and is not universally honored, it is removed. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] moxa: partial CodingStyle cleanup & spelling fixesJesper Juhl
Do a *partial* CodingStyle cleanup, correct some spelling in printk()'s && convert C++ comments to C comments - in moxa driver. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
