* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
* 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
block: autoconvert trivial BKL users to private mutex
drivers: autoconvert trivial BKL users to private mutex
ipmi: autoconvert trivial BKL users to private mutex
mac: autoconvert trivial BKL users to private mutex
mtd: autoconvert trivial BKL users to private mutex
scsi: autoconvert trivial BKL users to private mutex
Fix up trivial conflicts (due to addition of private mutex right next to
deletion of a version string) in drivers/char/pcmcia/cm40[04]0_cs.c
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
All these files use the big kernel lock in a trivial
way to serialize their private file operations,
typically resulting from an earlier semi-automatic
pushdown from VFS.
None of these drivers appears to want to lock against
other code, and they all use the BKL as the top-level
lock in their file operations, meaning that there
is no lock-order inversion problem.
Consequently, we can remove the BKL completely,
replacing it with a per-file mutex in every case.
Using a scripted approach means we can avoid
typos.
These drivers do not seem to be under active
maintainance from my brief investigation. Apologies
to those maintainers that I have missed.
file=$1
name=$2
if grep -q lock_kernel ${file} ; then
if grep -q 'include.*linux.mutex.h' ${file} ; then
sed -i '/include.*<linux\/smp_lock.h>/d' ${file}
else
sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file}
fi
sed -i ${file} \
-e "/^#include.*linux.mutex.h/,$ {
1,/^\(static\|int\|long\)/ {
/^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex);
-e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \
-e '/[ ]*cycle_kernel_lock();/d'
else
sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \
-e '/cycle_kernel_lock()/d'
fi
printk() statements on module load or unload are frowned upon. Also,
add a few __init or __exit declarations.
Tested-by: Wolfram Sang <w.sang@pengutronix.de>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
When CONF_AUTO_SET_IO or CONF_AUTO_SET_IOMEM are set, the corresponding
fields in struct pcmcia_device *p_dev->resource[0,1,2] are set
accordinly. Drivers wishing to override certain settings may do so in
the callback function, but they no longer need to parse the CIS entries
stored in cistpl_cftable_entry_t themselves.
CC: netdev@vger.kernel.org
CC: linux-wireless@vger.kernel.org
CC: linux-ide@vger.kernel.org
CC: linux-usb@vger.kernel.org
CC: laforge@gnumonks.org
CC: linux-mtd@lists.infradead.org
CC: linux-bluetooth@vger.kernel.org
CC: alsa-devel@alsa-project.org
CC: linux-serial@vger.kernel.org
CC: Jiri Kosina <jkosina@suse.cz>
CC: linux-scsi@vger.kernel.org
Introduce an autoconfiguration feature to set certain values in
pcmcia_loop_config(), instead of copying the same code over and over
in each PCMCIA driver. At first, introduce the following options:
CONF_AUTO_CHECK_VCC check or matching Vcc entry
CONF_AUTO_SET_VPP set Vpp
CONF_AUTO_AUDIO enable the speaker line
Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth)
pcmcia_enable_device() now replaces pcmcia_request_configuration().
Instead of config_req_t, all necessary flags are either passed as
a parameter to pcmcia_enable_device(), or (in rare circumstances)
set in struct pcmcia_device -> flags.
With the last remaining user of include/pcmcia/cs.h gone, remove
all references.
IntType was only set to INT_MEMORY (driver pcmciamtd) or INT_MEMORY_AND_IO
(all other drivers). As this flags seems to relate to ioport access, make
it conditional to the driver having requested IO port access. There are two
drivers which do not request IO ports, but did set INT_MEMORY_AND_IO:
ray_cs and b43. For those, we consistently only set INT_MEMORY in future.
Instead of io_req_t, drivers are now requested to fill out
struct pcmcia_device *p_dev->resource[0,1] for up to two ioport
ranges. After a call to pcmcia_request_io(), the ports found there
are reserved, after calling pcmcia_request_configuration(), they may
be used.
CC: Michael Buesch <mb@bu3sch.de>
Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/)
After pcmcia_request_io(), do not make use of the values stored in
io_req_t, but instead use those found in struct pcmcia_device->resource[].
Remove cs_types.h which is no longer needed: Most definitions aren't
used at all, a few can be made away with, and two remaining definitions
(typedefs, unfortunatley) may be moved to more specific places.
dev_node_t was only used to transport some minor/major numbers
from the PCMCIA device drivers to deprecated userspace helpers.
However, only a few drivers made use of it, and the userspace
helpers are deprecated anyways. Therefore, get rid of dev_node_t .
As a first step, remove any usage of dev_node_t from drivers which
only wrote to this typedef/struct, but did not make use of it.
CC: Harald Welte <laforge@gnumonks.org>
Update remaining users and remove deprecated handle_to_dev() macro
Fix printk format warnings on sizeof() [size_t] arguments.
drivers/char/pcmcia/cm4040_cs.c:267: warning: format '%lu' expects type 'long unsigned int', but argument 5 has type 'size_t'
drivers/char/pcmcia/cm4040_cs.c:272: warning: format '%lu' expects type 'long unsigned int', but argument 5 has type 'size_t'
Convert PCMCIA drivers to use the dynamic debug infrastructure, instead of
requiring manual settings of PCMCIA_DEBUG. Only some rare extra debug checks
in cm4000_cs.c cm4040_cs.c are now hidden behind a "#ifdef CM4000_DEBUG"
or "#ifdef CM4040_DEBUG".
Also, remove all usages of the CS_CHECK macro and replace them with proper
Linux style calling and return value checking. The extra error reporting may
be dropped, as the PCMCIA core already complains about any (non-driver-author)
errors.
CC: David Sterba <dsterba@suse.cz>
Now that device_create() has been audited, rename things back to the
original call to be sane.
Instead of using own error or success codes, the PCMCIA code should rely on
the generic return values. Therefore, replace all occurrences of CS_SUCCESS
with 0.
By passing the current Vcc setting to the pcmcia_config_loop callback
function, we can remove pcmcia_get_configuration_info() calls from many
drivers.
Many drivers use the default CIS entry within their pcmcia_config_loop()
callback function. Therefore, factor the default CIS entry handling out.
Almost all drivers set p_dev->conf.ConfigIndex to cfg->index in
the pcmcia_config_loop() callback function. Therefore, factor it out.
Use the config loop helper in misc pcmcia drivers.
CC: <linux-parport@lists.infradead.org>
CC: Russell King <rmk+kernel@arm.linux.org.uk>
CC: Ed Okerson <eokerson@quicknet.net>
CC: boti@rocketmail.com
device_create() is race-prone, so use the race-free
device_create_drvdata() instead as device_create() is going away.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
When PCMCIA_DEBUG is set, cm40x0_cs.c and cm4000_cs.c don't build because the
definition of reader_to_dev uses a non-existent handle field of the struct
pcmcia_device in the call to handle_to_dev. As handle_to_dev works on struct
pcmcia_device, the fix is quite trivial.
Signed-off-by: Pascal Terjan <pterjan@mandriva.com>
Cc: Harald Welte <laforge@gnumonks.org>
Convert from class_device to device in drivers/char.
Signed-off-by: Tony Jones <tonyj@suse.de>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
cm4000_cs.c and cm4040_cs.c call the internal release function with
an argument of wrong type. this fixes bug #8485
Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch>
Cc: Bill McConnaughey <mcconnau@biochem.wustl.edu>
Cc: Natalie Protasevich <protasnb@gmail.com>
This patch fixes error paths in module_init and probe functions in cm4000_cs
and cm4040_cs drivers.
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Based on a patch from Don Howard <dhoward@redhat.com>
When calling write() with a buffer larger than 512 bytes, the
driver's write buffer overflows, allowing to overwrite the EIP and
execute arbitrary code with kernel privileges.
In read(), there exists a similar problem, but coming from the device.
A malicous or buggy device sending more than 512 bytes can overflow
of the driver's read buffer, with the same effects as above.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Harald Welte <laforge@gnumonks.org>
- Use timer macros to set function and data members and to modify
expiration time.
- Use DEFINE_TIMER for global timers and do not init them at run-time in
these cases.
- del_timer_sync is common in most cases -- we want to wait for timer
function if it's still running.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Dave Airlie <airlied@linux.ie>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Paul Fulghum <paulkf@microgate.com>
Cc: Kylene Jo Hall <kjhall@us.ibm.com>
Cc: Wim Van Sebroeck <wim@iguana.be>
Acked-by: Dmitry Torokhov <dtor@mail.ru> (Input bits)
struct pcmcia_device *p_dev->conf.ConfigBase and .Present are set in almost
all PCMICA driver right at the beginning, using the same calls but slightly
different implementations. Unfiy this in the PCMCIA core.
Includes a small bugfix ("drivers/net/pcmcia/xirc2ps_cs.c: remove unused
label") from and Signed-off-by Adrian Bunk <bunk@stusta.de>
The return value of class_create() need to be checked with IS_ERR().
And register_chrdev() returns errno on failure.
This patch includes these fixes for cm4000_cs and cm4040_cs.
Signed-off-by: Akinbou Mita <akinobu.mita@gmail.com>
Mark the static struct file_operations in drivers/char as const. Making
them const prevents accidental bugs, and moves them to the .rodata section
so that they no longer do any false sharing; in addition with the proper
debug option they are then protected against corruption..
[akpm@osdl.org: build fix]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
This patch corrects the order of the calls to register_chrdev() and
pcmcia_register_driver(). Now udev correctly creates userspace device
files /dev/cmmN and /dev/cmxN respectively.
Based on an earlier patch by Jan Niehusmann <jan@gondor.com>.
Signed-off-by: Harald Welte <laforge@netfilter.org>
Instead of the DEV_OK macro, drivers should use pcmcia_dev_present().
Instead of the two status values struct pcmcia_device->p_state and state,
use descriptive bitfields. Most value-checking in drivers was invalid, as
the core now only calls the ->remove() (a.k.a. detach) function in case the
attachement _and_ configuration was successful.
Most of the driver initialization isn't done in the .probe function, but in
the internal _config() functions. Make them return a value, so that .probe
can properly report whether the probing of the device succeeded or not.
dev_link_t * and client_handle_t both mean struct pcmcai_device * by now.
Therefore, remove all such indirections.
Embed dev_link_t into struct pcmcia_device(), as they basically address the
same entity. The actual contents of dev_link_t will be cleaned up step by step.
This patch includes a bugfix from and signed-off-by Andrew Morton.
As we do not allow setting Vcc in the pcmcia core, and Vpp1 and
Vpp2 can only be set to the same value, a lot of code can be
streamlined.
In all but one case, the suspend and resume functions of PCMCIA drivers
contain mostly of calls to pcmcia_release_configuration() and
pcmcia_request_configuration(). Therefore, move this code out of the
drivers and into the core.
pcmcia_disable_device(struct pcmcia_device *p_dev) performs the necessary
cleanups upon device or driver removal: it calls the appropriate
pcmcia_release_* functions, and can replace (most) of the current drivers'
_release() functions.
Using this patch, Omnikey CardMan 4000 and 4040 devices automatically
get their device nodes created by udev.
Also, we now check for (and handle) failure of pcmcia_register_driver()
callback
Unify the EVENT_CARD_INSERTION and "attach" callbacks to one unified
probe() callback. As all in-kernel drivers are changed to this new
callback, there will be no temporary backwards-compatibility. Inside a
probe() function, each driver _must_ set struct pcmcia_device
*p_dev->instance and instance->handle correctly.
With these patches, the basic driver interface for 16-bit PCMCIA drivers
now has the classic four callbacks known also from other buses:
int (*probe) (struct pcmcia_device *dev);
void (*remove) (struct pcmcia_device *dev);
int (*suspend) (struct pcmcia_device *dev);
int (*resume) (struct pcmcia_device *dev);
Unify the "detach" and REMOVAL_EVENT handlers to one "remove" function.
Old functionality is preserved, for the moment.
Move the suspend and resume methods out of the event handler, and into
special functions. Also use these functions for pre- and post-reset, as
almost all drivers already do, and the remaining ones can easily be
converted.
Bugfix to include/pcmcia/ds.c
Add new Omnikey Cardman 4040 smartcard reader driver
