path: root/drivers/char/pcmcia/ipwireless/hardware.c
2009-11-28pcmcia: rework the irq_req_t typedefDominik Brodowski
Most of the irq_req_t typedef'd struct can be re-worked quite easily: (1) IRQInfo2 was unused in any case, so drop it. (2) IRQInfo1 was used write-only, so drop it. (3) Instance (private data to be passed to the IRQ handler): Most PCMCIA drivers using pcmcia_request_irq() to actually register an IRQ handler set the "dev_id" to the same pointer as the "priv" pointer in struct pcmcia_device. Modify the two exceptions (ipwireless, ibmtr_cs) to also work this waym and set the IRQ handler's "dev_id" to p_dev->priv unconditionally. (4) Handler is to be of type irq_handler_t. (5) Handler != NULL already tells whether an IRQ handler is present. Therefore, we do not need the IRQ_HANDLER_PRESENT flag in irq_req_t.Attributes. CC: netdev@vger.kernel.org CC: linux-bluetooth@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-scsi@vger.kernel.org CC: alsa-devel@alsa-project.org CC: Jaroslav Kysela <perex@perex.cz> CC: Jiri Kosina <jkosina@suse.cz> CC: Karsten Keil <isdn@linux-pingi.de> for the Bluetooth parts: Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-07-28ipwireless: fix compile failureJames Bottomley
There's a brown paper bag compile failure introduced by this patch commit a01386924874c4d6d67f8a34e66f04452c2abb69 Author: David Sterba <dsterba@suse.cz> Date: Mon Jul 28 16:53:32 2008 +0200 ipwireless: Preallocate received packet buffers with MRU size Really, it can't ever have been even compile tested. It looks like the closing bracket is in the wrong place, so this is the fix. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28ipwireless: Preallocate received packet buffers with MRU sizeDavid Sterba
ipwireless: Preallocate received packet buffers with MRU size Packets are assembled from link size (~300 bytes) up to PPP MRU (1500 by default). Try to preallocate full size rather than repeatedly advance buffer size by 256 bytes. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28ipwireless: Put packets to pool startDavid Sterba
ipwireless: Put packets to pool start Put packets to pool start, try to reuse cached memory. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28ipwireless: Constify buffer variablesDavid Sterba
ipwireless: Constify buffer variables Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28ipwireless: Do not return value from sending funcsDavid Sterba
ipwireless: Do not return value from sending funcs Do not return value from do_send_fragment and do_send_packet, it's not used. The packet size checks are not useful too: * zero length packet will never be sent, caller always passes packet_header size which is either 1 or 3 * MTU check is done in caller, no need to repeat Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28ipwireless: Remove endian-dependent bitfieldsDavid Sterba
ipwireless: Remove endian-dependent bitfields Remove endian-dependent bitfields and use bitmasks to transform packet header bitfields from/to machine order. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28ipwireless: Glue splitted printk strings backDavid Sterba
ipwireless: Glue splitted printk strings back Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28ipwireless: Remove pt_regs from interrupt handlerDavid Sterba
ipwireless: Remove pt_regs from interrupt handler Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28ipwireless: Rename spinlock variables to lockDavid Sterba
ipwireless: Rename spinlock variables to lock Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28ipwireless: Remove unused definesDavid Sterba
ipwireless: Remove unused defines Remove unused defines, defines hiding variables, defines hiding 0. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28ipwireless: Misc cleanupsDavid Sterba
ipwireless: Misc cleanups - remove likely() and some extra () in ifs - use unsigned in for loops - remove useless typecasts - remove obvious comments - add () around ?: Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-12drivers/char/pcmcia/ipwireless/hardware.c fix resource leakDarren Jenkins
Coverity CID: 2172 RESOURCE_LEAK When pool_allocate() tries to enlarge a packet, if it can not allocate enough memory, it returns NULL without first freeing the old packet. This patch just frees the packet first. Signed-off-by: Darren Jenkins <darrenrjenkins@gmail.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06ipwireless: Fix blocked sendingDavid Sterba
Packet sending is driven by two flags, tx_ready and tx_queued. It was possible, that there were queued data for sending and hardware was flagged as blocked but in fact it was not. The tx_queued was indicator but should be really a counter else first fragmented packet resets tx_queued flag, but there may be pending packets which do not get sent. New semantics: tx_ready - set, if hw is ready to send packet, no packet is being transferred right now set the flag right at the place where data are copied into hw memory and not earlier without checking if it was succesful tx_queued - count of enqueued packets, including fragments Tested-by: Michal Rokos <michal.rokos@gmail.com> Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipwireless: remove dead codeJiri Kosina
Remove unused leftovers of debugging functions. 2.6.25 material. Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07ipwireless: driver for PC Card 3G/UMTS modemDavid Sterba
The device is manufactured by IPWireless. In some countries (for example Czech Republic, T-Mobile ISP) this card is shipped for service called UMTS 4G. It's a piece of PCMCIA "4G" UMTS PPP networking hardware that presents itself as a serial character device (i.e. looks like usual modem to userspace, accepts AT commands, etc). Rewieved-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Ben Martel <benm@symmetric.co.nz> Signed-off-by: Stephen Blackheath <stephen@symmetric.co.nz> Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
